ERROR[1474]: tcptls.c:984 __ssl_setup: TLS/SSL error loading cert file. </etc/asterisk/keys/asterisk.pem>Модераторы: Glukinho, Zavr2008, Glukinho, Zavr2008
ERROR[1474]: tcptls.c:984 __ssl_setup: TLS/SSL error loading cert file. </etc/asterisk/keys/asterisk.pem>http://forums.asterisk.org/viewtopic.php?f=1&t=87211Problem solved by creating the certificates manually using OpenSSL instead of using the asterisk provided helper script ast_tls_cert. Apparently the script didn't produce a certificate that could be read by asterisk.
