Нет запуска
densio
Нет запуска
Сообщение densio »
Прошу помочь
ситуация
[root@localhost ~]# service asterisk status
asterisk dead but subsys locked
asterisk (pid 15789) is running...
asterisk (pid 16342) is running...
asterisk (pid 16883) is running...
[root@localhost ~]# service asterisk stop
пере запускается через кажд 5 сек
ps aux | grep asterisk
root     17418  0.1  0.0   5132   960 pts/0    S    16:28   0:00 /bin/sh /usr/sbin/safe_asterisk
root     26940  0.0  0.0   4420   784 pts/0    S+   16:32   0:00 grep asterisk
# asterisk -vvvc
ВСЕ ЧТО ИЗ WARNING
Parsing '/etc/asterisk/res_config_mysql.conf': Found
[Apr  4 16:33:15] WARNING[28925]: res_config_mysql.c:1505 load_mysql_config: MySQL RealTime: No database user found, using 'asterisk' as default.
[Apr  4 16:33:15] WARNING[28925]: res_config_mysql.c:1511 load_mysql_config: MySQL RealTime: No database password found, using 'asterisk' as default.
[Apr  4 16:33:15] WARNING[28925]: res_config_mysql.c:1517 load_mysql_config: MySQL RealTime: No database host found, using localhost via socket.
[Apr  4 16:33:15] WARNING[28925]: res_config_mysql.c:1523 load_mysql_config: MySQL RealTime: No database name found, using 'asterisk' as default.
[Apr  4 16:33:15] WARNING[28925]: res_config_mysql.c:1529 load_mysql_config: MySQL RealTime: No database port found, using 3306 as default.
[Apr  4 16:33:15] WARNING[28925]: res_config_mysql.c:1541 load_mysql_config: MySQL RealTime: No database socket found, using '/var/lib/mysql/mysql.sock' as default.
[Apr  4 16:33:15] WARNING[28925]: res_config_mysql.c:1546 load_mysql_config: MySQL RealTime: No database socket found (and unable to detect a suitable path).
[Apr  4 16:33:15] NOTICE[28925]: config.c:2584 ast_config_engine_register: Registered Config Engine mysql
  == MySQL RealTime driver loaded.
LOG
[Apr  4 15:39:30] Asterisk 11.25.1 built by root @ localhost.localdomain on a i686 running Linux on 2017-01-24 00:43:36 UTC
[Apr  4 15:39:30] NOTICE[16300] cdr.c: CDR simple logging enabled.
[Apr  4 15:39:30] NOTICE[16300] loader.c: 199 modules will be loaded.
[Apr  4 15:39:30] NOTICE[16300] res_smdi.c: No SMDI interfaces are available to listen on, not starting SMDI listener.
[Apr  4 15:39:30] WARNING[16300] res_config_mysql.c: MySQL RealTime: No database user found, using 'asterisk' as default.
[Apr  4 15:39:30] WARNING[16300] res_config_mysql.c: MySQL RealTime: No database password found, using 'asterisk' as default.
[Apr  4 15:39:30] WARNING[16300] res_config_mysql.c: MySQL RealTime: No database host found, using localhost via socket.
[Apr  4 15:39:30] WARNING[16300] res_config_mysql.c: MySQL RealTime: No database name found, using 'asterisk' as default.
[Apr  4 15:39:30] WARNING[16300] res_config_mysql.c: MySQL RealTime: No database port found, using 3306 as default.
[Apr  4 15:39:30] WARNING[16300] res_config_mysql.c: MySQL RealTime: No database socket found, using '/var/lib/mysql/mysql.sock' as default.
[Apr  4 15:39:30] WARNING[16300] res_config_mysql.c: MySQL RealTime: No database socket found (and unable to detect a suitable path).
[Apr  4 15:39:30] NOTICE[16300] config.c: Registered Config Engine mysql
[Apr  4 15:39:30] NOTICE[16300] config.c: Registered Config Engine sqlite3
[Apr  4 15:39:30] NOTICE[16300] config.c: Registered Config Engine curl
[Apr  4 15:39:31] NOTICE[16300] chan_skinny.c: Configuring skinny from skinny.conf
[Apr  4 15:39:31] NOTICE[16300] cel_custom.c: No mappings found in cel_custom.conf. Not logging CEL to custom CSVs.
[Apr  4 15:39:35] Asterisk 11.25.1 built by root @ localhost.localdomain on a i686 running Linux on 2017-01-24 00:43:36 UTC
[Apr  4 15:39:35] NOTICE[16391] cdr.c: CDR simple logging enabled.
[Apr  4 15:39:35] NOTICE[16391] loader.c: 199 modules will be loaded.
[Apr  4 15:39:35] NOTICE[16391] res_smdi.c: No SMDI interfaces are available to listen on, not starting SMDI listener.
[Apr  4 15:39:35] WARNING[16391] res_config_mysql.c: MySQL RealTime: No database user found, using 'asterisk' as default.
[Apr  4 15:39:35] WARNING[16391] res_config_mysql.c: MySQL RealTime: No database password found, using 'asterisk' as default.
[Apr  4 15:39:35] WARNING[16391] res_config_mysql.c: MySQL RealTime: No database host found, using localhost via socket.
[Apr  4 15:39:35] WARNING[16391] res_config_mysql.c: MySQL RealTime: No database name found, using 'asterisk' as default.
[Apr  4 15:39:35] WARNING[16391] res_config_mysql.c: MySQL RealTime: No database port found, using 3306 as default.
[Apr  4 15:39:35] WARNING[16391] res_config_mysql.c: MySQL RealTime: No database socket found, using '/var/lib/mysql/mysql.sock' as default.
[Apr  4 15:39:35] WARNING[16391] res_config_mysql.c: MySQL RealTime: No database socket found (and unable to detect a suitable path).
[Apr  4 15:39:35] NOTICE[16391] config.c: Registered Config Engine mysql
[Apr  4 15:39:35] NOTICE[16391] config.c: Registered Config Engine sqlite3
[Apr  4 15:39:35] NOTICE[16391] config.c: Registered Config Engine curl
[Apr  4 15:39:35] NOTICE[16391] chan_skinny.c: Configuring skinny from skinny.conf
[Apr  4 15:39:35] NOTICE[16391] cel_custom.c: No mappings found in cel_custom.conf. Not logging CEL to custom CSVs.
[Apr  4 15:39:39] Asterisk 11.25.1 built by root @ localhost.localdomain on a i686 running Linux on 2017-01-24 00:43:36 UTC
[Apr  4 15:39:40] NOTICE[16477] cdr.c: CDR simple logging enabled.
[Apr  4 15:39:40] NOTICE[16477] loader.c: 199 modules will be loaded.
[Apr  4 15:39:40] NOTICE[16477] res_smdi.c: No SMDI interfaces are available to listen on, not starting SMDI listener.
[Apr  4 15:39:40] WARNING[16477] res_config_mysql.c: MySQL RealTime: No database user found, using 'asterisk' as default.
[Apr  4 15:39:40] WARNING[16477] res_config_mysql.c: MySQL RealTime: No database password found, using 'asterisk' as default.
[Apr  4 15:39:40] WARNING[16477] res_config_mysql.c: MySQL RealTime: No database host found, using localhost via socket.
[Apr  4 15:39:40] WARNING[16477] res_config_mysql.c: MySQL RealTime: No database name found, using 'asterisk' as default.
[Apr  4 15:39:40] WARNING[16477] res_config_mysql.c: MySQL RealTime: No database port found, using 3306 as default.
[Apr  4 15:39:40] WARNING[16477] res_config_mysql.c: MySQL RealTime: No database socket found, using '/var/lib/mysql/mysql.sock' as default.
[Apr  4 15:39:40] WARNING[16477] res_config_mysql.c: MySQL RealTime: No database socket found (and unable to detect a suitable path).
[Apr  4 15:39:40] NOTICE[16477] config.c: Registered Config Engine mysql
[Apr  4 15:39:40] NOTICE[16477] config.c: Registered Config Engine sqlite3
[Apr  4 15:39:40] NOTICE[16477] config.c: Registered Config Engine curl
[Apr  4 15:39:40] NOTICE[16477] chan_skinny.c: Configuring skinny from skinny.conf
[Apr  4 15:39:40] NOTICE[16477] cel_custom.c: No mappings found in cel_custom.conf. Not logging CEL to custom CSVs.
densio
Re: Нет запуска
Сообщение densio »
asterisk -r
Unable to connect to remote asterisk (does /var/run/asterisk/asterisk.ctl exist?)
nano /etc/asterisk/asterisk.conf
[files]
astctlpermissions = 0660
astctlowner = root
astctlgroup = apache
astctl = asterisk.ctl
[compat]
pbx_realtime=1.6
res_agi=1.6
app_set=1.6
densio
Re: Нет запуска
Сообщение densio »
# users
root root
uname -a
Linux localhost.localdomain 2.6.32-642.13.1.el6.i686 #1 SMP Wed Jan 11 20:21:04 UTC 2017 i686 i686 i386 GNU/Linux
safe_asterisk
/usr/sbin/safe_asterisk: line 170: 13066 Illegal instruction     (core dumped) nice -n $PRIORITY "${ASTSBINDIR}/asterisk" -f ${CLIARGS} ${ASTARGS} > /dev/${TTY} 2>&1 < /dev/${TTY}
/usr/sbin/safe_asterisk: line 170: 13362 Illegal instruction     (core dumped) nice -n $PRIORITY "${ASTSBINDIR}/asterisk" -f ${CLIARGS} ${ASTARGS} > /dev/${TTY} 2>&1 < /dev/${TTY}
/usr/sbin/safe_asterisk: line 170: 13652 Illegal instruction     (core dumped) nice -n $PRIORITY "${ASTSBINDIR}/asterisk" -f ${CLIARGS} ${ASTARGS} > /dev/${TTY} 2>&1 < /dev/${TTY}
/usr/sbin/safe_asterisk: line 170: 13943 Illegal instruction     (core dumped) nice -n $PRIORITY "${ASTSBINDIR}/asterisk" -f ${CLIARGS} ${ASTARGS} > /dev/${TTY} 2>&1 < /dev/${TTY}
mv: cannot stat `/tmp/core.13974': No such file or directory
/usr/sbin/safe_asterisk: line 170: 14122 Illegal instruction     (core dumped) nice -n $PRIORITY "${ASTSBINDIR}/asterisk" -f ${CLIARGS} ${ASTARGS} > /dev/${TTY} 2>&1 < /dev/${TTY}
/usr/sbin/safe_asterisk: line 170: 15758 Illegal instruction     (core dumped) nice -n $PRIORITY "${ASTSBINDIR}/asterisk" -f ${CLIARGS} ${ASTARGS} > /dev/${TTY} 2>&1 < /dev/${TTY}
bash -x /etc/init.d/asterisk start
# bash -x /etc/init.d/asterisk start
+ AST_SBIN=/usr/sbin
+ . /etc/rc.d/init.d/functions
++ TEXTDOMAIN=initscripts
++ umask 022
++ PATH=/sbin:/usr/sbin:/bin:/usr/bin
++ export PATH
++ '[' -z '' ']'
++ COLUMNS=80
++ '[' -z '' ']'
+++ /sbin/consoletype
++ CONSOLETYPE=pty
++ '[' -f /etc/sysconfig/i18n -a -z '' -a -z '' ']'
++ . /etc/profile.d/lang.sh
++ unset LANGSH_SOURCED
++ '[' -z '' ']'
++ '[' -f /etc/sysconfig/init ']'
++ . /etc/sysconfig/init
+++ BOOTUP=color
+++ RES_COL=60
+++ MOVE_TO_COL='echo -en \033[60G'
+++ SETCOLOR_SUCCESS='echo -en \033[0;32m'
+++ SETCOLOR_FAILURE='echo -en \033[0;31m'
+++ SETCOLOR_WARNING='echo -en \033[0;33m'
+++ SETCOLOR_NORMAL='echo -en \033[0;39m'
+++ PROMPT=yes
+++ AUTOSWAP=no
+++ ACTIVE_CONSOLES='/dev/tty[1-6]'
+++ SINGLE=/sbin/sushell
++ '[' pty = serial ']'
++ __sed_discard_ignored_files='/\(~\|\.bak\|\.orig\|\.rpmnew\|\.rpmorig\|\.rpmsave\)$/d'
+++ cat /proc/cmdline
++ strstr 'ro root=/dev/mapper/VolGroup-lv_root rd_NO_LUKS LANG=en_US.UTF-8 rd_NO_MD rd_LVM_LV=VolGroup/lv_swap SYSFONT=latarcyrheb-sun16 crashkernel=129M@0M rd_LVM_LV=VolGroup/lv_root  KEYBOARDTYPE=pc KEYTABLE=us rd_NO_DM rhgb quiet' rc.debug
++ '[' 'ro root=/dev/mapper/VolGroup-lv_root rd_NO_LUKS LANG=en_US.UTF-8 rd_NO_MD rd_LVM_LV=VolGroup/lv_swap SYSFONT=latarcyrheb-sun16 crashkernel=129M@0M rd_LVM_LV=VolGroup/lv_root  KEYBOARDTYPE=pc KEYTABLE=us rd_NO_DM rhgb quiet' = 'ro root=/dev/mapper/VolGroup-lv_root rd_NO_LUKS LANG=en_US.UTF-8 rd_NO_MD rd_LVM_LV=VolGroup/lv_swap SYSFONT=latarcyrheb-sun16 crashkernel=129M@0M rd_LVM_LV=VolGroup/lv_root  KEYBOARDTYPE=pc KEYTABLE=us rd_NO_DM rhgb quiet' ']'
++ return 1
+ '[' -x /usr/sbin/asterisk ']'
+ '[' -d ']'
+ DAEMON=/usr/sbin/asterisk
+ SAFE_ASTERISK=/usr/sbin/safe_asterisk
++ readlink /etc/init.d/asterisk
+ CONFIG0=
++ basename /etc/init.d/asterisk
+ CONFIGFILE=/etc/sysconfig/asterisk
+ '[' -r /etc/sysconfig/asterisk ']'
+ . /etc/sysconfig/asterisk
++ COLOR=yes
+ RETVAL=0
+ case "$1" in
+ start
++ /usr/sbin/asterisk -rx 'core show version'
+ VERSION=
++ cut -c 1-8
++ echo
+ '[' '' = Asterisk ']'
+ echo -n 'Starting asterisk: '
Starting asterisk: + '[' -f /usr/sbin/safe_asterisk ']'
+ DAEMON=/usr/sbin/safe_asterisk
+ '[' x = xyes ']'
+ '[' 0 -gt 0 ']'
+ '[' 0 -gt 0 ']'
+ '[' 0 -gt 0 ']'
+ '[' x = xyes ']'
+ '[' x = xyes -o x = xyes ']'
+ '[' xyes = xyes ']'
+ export TERM=linux
+ TERM=linux
+ RETVAL=0
+ '[' 0 -eq 0 ']'
+ touch /var/lock/subsys/asterisk
+ daemon sh -c '/usr/sbin/safe_asterisk  -c'
+ echo
+ return 0
+ exit 0
Re: Нет запуска
А права /var/run/asterisk/ кто проверять будет?
densio
Re: Нет запуска
Сообщение densio »
ls -l /var/run/asterisk/
total 4
srw-rw---- 1 root apache 0 Apr  4 17:08 asterisk.ctl
-rw-r--r-- 1 root root   6 Apr  4 17:08 asterisk.pid
на другом сервере (откуда сделал копию тоже самое)
Re: Нет запуска
Ну тогда у вас всё ОК.
densio
Re: Нет запуска
Сообщение densio »
densio писал(а):ls -l /var/run/asterisk/
total 4
ну типа права такие
и все запускается
всё сдаюсь не знаю чо дальше
Re: Нет запуска
densio писал(а):astctlgroup = apache
Зачет !
densio писал(а):и все запускается
Тогда см. выше:
ded писал(а):Ну тогда у вас всё ОК.
