[asterisk-announce] [BUG] Authentication Bypass
http://lists.digium.com/pipermail/aster ... 00662.html
Asterisk Project Security Advisory - ASTERISK-2016-009
Product Asterisk
Summary
Nature of Advisory Authentication Bypass
Susceptibility Remote unauthenticated sessions
Severity Minor
Exploits Known No
Reported On October 3, 2016
Reported By Walter Doekes
Posted On
Last Updated On December 8, 2016
    Description  The chan_sip channel driver has a liberal definition for
                 whitespace when attempting to strip the content between a
                 SIP header name and a colon character. Rather than
                 following RFC 3261 and stripping only spaces and horizontal
                 tabs, Asterisk treats any non-printable ASCII character as
                 if it were whitespace. This means that headers such as
                 Contact\x01:
                 will be seen as a valid Contact header.
                 This mostly does not pose a problem until Asterisk is
                 placed in tandem with an authenticating SIP proxy. In such
                 a case, a crafty combination of valid and invalid To
                 headers can cause a proxy to allow an INVITE request into
                 Asterisk without authentication since it believes the
                 request is an in-dialog request. However, because of the
                 bug described above, the request will look like an
                 out-of-dialog request to Asterisk. Asterisk will then
                 process the request as a new call. The result is that
                 Asterisk can process calls from unvetted sources without
                 any authentication.
                 If you do not use a proxy for authentication, then this
                 issue does not affect you.
                 If your proxy is dialog-aware (meaning that the proxy keeps
                 track of what dialogs are currently valid), then this issue
                 If you use chan_pjsip instead of chan_sip, then this issue
    Resolution  chan_sip has been patched to only treat spaces and
                horizontal tabs as whitespace following a header name. This
                allows for Asterisk and authenticating proxies to view
                requests the same way
                               Affected Versions
                         Product                       Release
                                                       Series
                  Asterisk Open Source                  11.x    All Releases
                  Asterisk Open Source                  13.x    All Releases
                  Asterisk Open Source                  14.x    All Releases
                   Certified Asterisk                   13.8    All Releases
                                  Corrected In
          Product                              Release
    Asterisk Open Source               11.25.1, 13.13.1, 14.2.1
     Certified Asterisk                11.6-cert16, 13.8-cert4
                                    Patches
                 SVN URL                              Revision
           Links
    Asterisk Project Security Advisories are posted at
    http://www.asterisk.org/security
    This document may be superseded by later versions; if so, the latest
    version will be posted at
    http://downloads.digium.com/pub/security/ASTERISK-2016-009.pdf and
    http://downloads.digium.com/pub/security/ASTERISK-2016-009.html
semenhasov
Re: [asterisk-announce] [BUG] Authentication Bypass
Сообщение semenhasov »
И что...
Да ничего хорошего...
