Неправильный ответ на OPTIONS
white_joker
Сообщение white_joker »
Доброго дня!
У нас сейчас подключили SIP транк от Мегафона и провайдер просит меня сделать так чтобы Asterisk отвечал на запросы OPTIONS.
И чтобы свои запросы не посылал. Соответвенно со вторым пунктом я справился отключив qualify. Подскажите как быть с первым.
на данный момент у меня вот такая инфа в sip debug
[Nov 1 10:30:09] Scheduling destruction of SIP dialog 'gmofdtkdn5dte99ojg99utknjmdtjjmt@SoftX3000' in 32000 ms (Method: OPTIONS)
[Nov 1 10:30:21] Really destroying SIP dialog 'tltude8n558efmu8fqef8dnoojgdkn8j@SoftX3000' Method: OPTIONS
[Nov 1 10:30:29]
[Nov 1 10:30:29] <--- SIP read from UDP:*.*.*.*:5060 --->
[Nov 1 10:30:29] OPTIONS sip:812.megafonnw.ru:5060 SIP/2.0
[Nov 1 10:30:29] Via: SIP/2.0/UDP *.*.*.*:5060;branch=z9hG4bKgq871e20dojh2k3q42u0.1
[Nov 1 10:30:29] Call-ID: ek5uujl9d8o88ueleu5odfuouq9g9uqt@SoftX3000
[Nov 1 10:30:29] From: <sip:812.megafonnw.ru:5060>;tag=k5t8t89j
[Nov 1 10:30:29] To: <sip:812.megafonnw.ru:5060>
[Nov 1 10:30:29] CSeq: 1 OPTIONS
[Nov 1 10:30:29] Max-Forwards: 69
[Nov 1 10:30:29] Content-Length: 0
[Nov 1 10:30:29]
[Nov 1 10:30:29] <------------->
[Nov 1 10:30:29] --- (8 headers 0 lines) ---
[Nov 1 10:30:29] Sending to *.*.*.*:5060 (no NAT)
[Nov 1 10:30:29] Looking for s in default (domain 812.megafonnw.ru)
[Nov 1 10:30:29]
[Nov 1 10:30:29] <--- Transmitting (no NAT) to *.*.*.*:5060 --->
[Nov 1 10:30:29] SIP/2.0 404 Not Found
[Nov 1 10:30:29] Via: SIP/2.0/UDP *.*.*.*:5060;branch=z9hG4bKgq871e20dojh2k3q42u0.1;received=*.*.*.*
[Nov 1 10:30:29] To: <sip:812.megafonnw.ru:5060>;tag=as683b37c6
[Nov 1 10:30:29] Server: Asterisk PBX 13.4.0
[Nov 1 10:30:29] Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REFER, SUBSCRIBE, NOTIFY, INFO, PUBLISH, MESSAGE
[Nov 1 10:30:29] Supported: replaces, timer
[Nov 1 10:30:29] Accept: application/sdp
[Nov 1 10:30:29]
[Nov 1 10:30:29]
[Nov 1 10:30:29] <------------>
Re: Неправильный ответ на OPTIONS
https://issues.asterisk.org/jira/browse/ASTERISK-16997
Какая версия Asterisk ? Что в дебаге ?
white_joker
Asterisk 13.4.0
дебаг я же под спойлер засунул.или еще какая то инфа нужна?
white_joker
Должен добавить что связь есть и звонки проходят! Но провайдер требует ответ на OPTIONS 200 OK. Мотивируя это тем что при подключении нескольких номеров это не будет работать.
Как бы нам инфа не нужна, как бы направление куда копать уже подказано.
Хорошо, ещё один линк: https://issues.asterisk.org/jira/browse/ASTERISK-20180
читаем комментарии:
Rusty Newton added a comment - 27/Jul/12 1:25 PM
Alexy, it's looking for s in default, which should be correct.
What happens when you satisfy that with an s extension in default?
Alexey added a comment - 27/Jul/12 3:27 PM - edited
Sorry. My fault.
I removed include => demo from extensions.conf.
and not added anything.
After i added
[default]
exten => s,1,Hangup
All started to be ok.
Sorry for your time.
whoim
Сообщение whoim »
white_joker писал(а):Должен добавить что связь есть и звонки проходят! Но провайдер требует ответ на OPTIONS 200 OK. Мотивируя это тем что при подключении нескольких номеров это не будет работать.
работать будет, просто звонки будут ходить через "первый" транк, который успел подняться.
Разницы особой нет, didы приходят правильно, маршрутизируются тоже.
white_joker
Господа спасибо за помощь все заработало как нужно. я почему то был уверен что не требуется перезагрузка всего астериска. после перзагрузки утром все заработало.
И что же вы такого правили что потребовалась перезагрузка ? :shock:
white_joker
virus_net писал(а):И что же вы такого правили что потребовалась перезагрузка ? :shock:
в том то и дело что только конфигурацию sip.я поэтому и не перезагружал и удивлялся отчего не работает.
а sip reload ?
