"Виснет" *
akam
"Виснет" *
Сообщение akam »
Здравствуйте, уже несколько дней бьюсь над проблемой - "виснет" Asterisk, то есть не отвечает на запросы регистрации телефонов и никуда уже не позвонить (вообще весь трафик с порта 5060 прекращается), хотя на него можно зайти в cli.
в cli показывает, что пользователи подключены, хотя это не так:
PRIME_BBCODE_SPOILER_SHOW PRIME_BBCODE_SPOILER: sip show peers
im*CLI>
Name/username Host Dyn Nat ACL Port Status
1000 (Unspecified) D N A 5060 UNKNOWN
2001/2001 192.168.115.10 D N A 55458 OK (127 ms)
2002/2002 192.168.113.19 D N A 55458 OK (200 ms)
2003/2003 192.168.115.10 D N A 55526 OK (152 ms)
2006/2006 192.168.115.10 D N A 55525 OK (181 ms)
и т.д.....
дебаг показывает кучу таких сообщений
[Aug 9 16:43:59] DEBUG[13322] channel.c: Avoiding initial deadlock for channel '0x15212d0'
[Aug 9 16:43:59] DEBUG[13322] channel.c: Failure, could not lock '0x15212d0' after 199 retries!
PRIME_BBCODE_SPOILER_SHOW PRIME_BBCODE_SPOILER: logs
[Aug 9 16:46:59] VERBOSE[14144] pbx.c: == Spawn extension (from-internal, STARTMEETME, 4) exited non-zero on 'SIP/3025-00000007'
[Aug 9 16:46:59] DEBUG[14144] channel.c: Soft-Hanging up channel 'SIP/3025-00000007'
[Aug 9 16:46:59] DEBUG[14144] pbx.c: Launching 'Hangup'
[Aug 9 16:46:59] VERBOSE[14144] pbx.c: -- Executing [h@from-internal:1] Hangup("SIP/3025-00000007", "") in new stack
[Aug 9 16:46:59] DEBUG[14144] pbx.c: Spawn extension (from-internal,h,1) exited non-zero on 'SIP/3025-00000007'
[Aug 9 16:46:59] VERBOSE[14144] pbx.c: == Spawn extension (from-internal, h, 1) exited non-zero on 'SIP/3025-00000007'
[Aug 9 16:46:59] DEBUG[14144] channel.c: Hanging up channel 'SIP/3025-00000007'
[Aug 9 16:46:59] DEBUG[14144] chan_sip.c: Hangup call SIP/3025-00000007, SIP callid 7031582328775-1905129297779@192.168.55.119
[Aug 9 16:46:59] DEBUG[14144] chan_sip.c: Updating call counter for incoming call
[Aug 9 16:46:59] DEBUG[13897] devicestate.c: No provider found, checking channel drivers for SIP - 3025
[Aug 9 16:46:59] DEBUG[13897] chan_sip.c: Checking device state for peer 3025
[Aug 9 16:46:59] DEBUG[13897] devicestate.c: Changing state for SIP/3025 - state 2 (In use)
[Aug 9 16:46:59] DEBUG[13897] devicestate.c: device 'SIP/3025' state '2'
[Aug 9 16:46:59] DEBUG[13916] app_queue.c: Device 'SIP/3025' changed to state '2' (In use) but we don't care because they're not a member of any queue.
[Aug 9 16:46:59] DEBUG[14144] cdr_addon_mysql.c: Inserting a CDR record.
[Aug 9 16:46:59] DEBUG[14144] cdr_addon_mysql.c: SQL command as follows: INSERT INTO cdr (calldate,clid,src,dst,dcontext,channel,lastapp,lastdata,duration,billsec,disposition,amaflags,uniqueid) VALUES ('2011-08-09 16:46:57','\"Aidar Kamalov\" <3025>','3025','STARTMEETME','from-internal','SIP/3025-00000007','MeetMe','2222,cM,','2','2','ANSWERED','3','1312894017.7')
[Aug 9 16:46:59] DEBUG[13915] chan_sip.c: Stopping retransmission on '43dcc6166d1f297809ca19aa35b8f884@172.22.32.99' of Request 102: Match Found
[Aug 9 16:46:59] DEBUG[13915] chan_sip.c: Destroying SIP dialog 43dcc6166d1f297809ca19aa35b8f884@172.22.32.99
[Aug 9 16:46:59] DEBUG[13915] chan_sip.c: Destroying SIP dialog 7031582328775-1905129297779@192.168.55.119
[Aug 9 16:47:00] DEBUG[13915] acl.c: Found IP address for this socket
[Aug 9 16:47:00] DEBUG[13915] chan_sip.c: Setting SIP_TRANSPORT_UDP with address 192.168.55.249:5060
[Aug 9 16:47:00] DEBUG[13915] chan_sip.c: Allocating new SIP dialog for 53702908217318-908085919212@192.168.115.10 - REGISTER (No RTP)
[Aug 9 16:47:00] DEBUG[13915] chan_sip.c: **** Received REGISTER (2) - Command in SIP REGISTER
[Aug 9 16:47:00] DEBUG[13915] chan_sip.c: Trying to put 'SIP/2.0 401' onto UDP socket destined for 192.168.115.10:55458
[Aug 9 16:47:00] DEBUG[13901] chan_iax2.c: ip callno count decremented to 0 for 95.78.123.17
[Aug 9 16:47:00] DEBUG[13906] chan_iax2.c: ip callno count incremented to 1 for 95.78.123.17
[Aug 9 16:47:00] DEBUG[13907] chan_iax2.c: schedule decrement of callno used for 95.78.123.17 in 60 seconds
[Aug 9 16:47:00] DEBUG[13907] chan_iax2.c: Peer dusl-to-office: got pong, lastms 116, historicms 116, maxms 2000
[Aug 9 16:47:03] DEBUG[14163] manager.c: Manager received command 'login'
[Aug 9 16:47:03] DEBUG[14163] manager.c: Manager received command 'Command'
[Aug 9 16:47:04] DEBUG[14163] manager.c: Manager received command 'Command'
[Aug 9 16:47:04] DEBUG[14163] channel.c: Avoiding initial deadlock for channel '0x7f315c3566f0'
[Aug 9 16:47:04] DEBUG[14163] channel.c: Failure, could not lock '0x7f315c3566f0' after 199 retries!
[Aug 9 16:47:10] DEBUG[14186] manager.c: Manager received command 'login'
[Aug 9 16:47:10] DEBUG[14186] manager.c: Manager received command 'Command'
[Aug 9 16:47:11] DEBUG[14186] manager.c: Manager received command 'Command'
[Aug 9 16:47:11] DEBUG[14186] channel.c: Avoiding initial deadlock for channel '0x7f315c3566f0'
[Aug 9 16:47:11] DEBUG[14186] channel.c: Failure, could not lock '0x7f315c3566f0' after 199 retries!
[Aug 9 16:47:18] DEBUG[14241] manager.c: Manager received command 'login'
[Aug 9 16:47:18] DEBUG[14241] manager.c: Manager received command 'Command'
и
[Aug 9 16:38:52] WARNING[12147] app_meetme.c: Unable to write frame to channel SIP/3025-00000002
никак не мог понять после чего * отваливается, но подозреваю meetme, - в первый раз звоню на 2222 и после дозвона скидываю - появляются первые записи Unable to write frame to channel, во второй раз звоню - в телеконференции уже есть один участник, в третий раз звоню * виснет, причем на команду в cli core restart now - никак не реагирует.
система Linux im 2.6.37-gentoo-r4 #3 SMP Sat Jul 23 12:49:35 MSD 2011 x86_64 AMD Athlon(tm) 64 X2 Dual Core Processor 6000+ AuthenticAMD GNU/Linux
asterisk 1.6.2.18 (пробовал и 1.6.2.20 и 1.8)
Что только не делал, потом снес все, заново поставил, и все равно(
Подскажите пожалуйста в какую строну копать?
aizek
Re: "Виснет" *
Сообщение aizek »
Попробуйте отключить все модули таймингов, кроме res_timing_dahdi.so
modules.conf
noload => res_timing_timerfd.so
noload => res_timing_pthread.so
akam
Re: "Виснет" *
Сообщение akam »
спасибо огромное!, вроде помогло, звонил раз 49 на конференцию, не вылетело, завтра получше потестирую..
никогда бы не догадался сам так сделать, как я понял синхронизация средствами ядра у меня глючила, и щас я оставил только синхронизацию средставми dahdy_dummy? Чем мне это может грозить?
Re: "Виснет" *
Проблемностю применения на виртуалках.
aleokos
Re: "Виснет" *
Сообщение aleokos »
Здравствуйте, аналогичная проблема. Asterisk, сервер проработав около года стал виснуть , то есть не отвечает на запросы регистрации телефонов и никуда уже не позвонить.
рестарт сервиса Asterisk помогает на некоторое время.
Asterisk 1.6.2.9-2+squeeze4 built by buildd @ biber on a i686 running Linux
DAHDI Version: 2.3.0.1 Echo Canceller: OSLEC
*CLI> module show like timi
Module Description Use Count
res_timing_dahdi.so DAHDI Timing Interface 7
1 modules loaded
DNS работает исправно на этом сервере, как прямой так и обратный.
[Sep 12 16:58:25] DEBUG[2961] channel.c: Avoiding deadlock for channel '0x97dca08'
[Sep 12 16:58:25] DEBUG[2961] channel.c: Failure, could not lock '0x97dca08' after 199 retries!
поиски привели сюда. прошу помощи.
Re: "Виснет" *
счас придет ded и скажет волшебную фразу - обновляйтесь до актуальных версий 1.8.15.1 и 2.6.1
PS Вчера с компиляцией зависимостей обновил ubuntu 10.04 с оригинальной из репов с 1.8.11 до актуальных за 2 часа.
aleokos
Re: "Виснет" *
Сообщение aleokos »
я все понимаю, но сервер отработал в почти год, и вдруг - пук.
что-то изменилось в PRI? нагрузка не увеличилась.
Re: "Виснет" *
я обычно глучащий сервер начинаю лечить с замены блока питания
Re: "Виснет" *
корпус открывать пробовали?
пыль по выдувать... пощупать что греется... и т.д.
aleokos
Re: "Виснет" *
Сообщение aleokos »
действительно дельные советы.
пошёл корпус открывать.
