Не проходит входящий звонок (Elastix) с транка
koval
Сообщение koval »
Провайдер транк отдает по IP без регистрации. Исходящий настроил, всё работает. Проблема с входящим.
10.X.242.42 - IP адрес Asterisk
62.X.15.8 - IP адрес шлюза транка
[2016-02-10 21:55:50] VERBOSE[3255] chan_sip.c: Reliably Transmitting (no NAT) to 62.X.15.8:5060:
OPTIONS sip:62.X.15.8 SIP/2.0
Via: SIP/2.0/UDP 10.X.242.42:5060;branch=z9hG4bK2a4d99ff
From: "Unknown" <sip:Unknown@10.X.242.42>;tag=as1499ba48
To: <sip:62.X.15.8>
Contact: <sip:Unknown@10.X.242.42:5060>
Call-ID: 6da784e876517fe554b5eae642fcbbb8@10.X.242.42:5060
CSeq: 102 OPTIONS
User-Agent: FPBX-2.11.0(11.17.1)
Date: Wed, 10 Feb 2016 20:55:50 GMT
<--- SIP read from UDP:62.X.15.8:5060 --->
SIP/2.0 480 No Routes Found
To: <sip:62.X.15.8>;tag=aprqngfrt-ng5ugi20000c6
CSeq: 102 OPTIONS
[2016-02-10 21:55:50] VERBOSE[3255] chan_sip.c: --- (6 headers 0 lines) ---
[2016-02-10 21:55:50] VERBOSE[3255] chan_sip.c: Really destroying SIP dialog '6da784e876517fe554b5eae642fcbbb8@10.X.242.42:5060' Method: OPTIONS
[2016-02-10 21:55:51] VERBOSE[3255] chan_sip.c: Reliably Transmitting (no NAT) to 62.X.15.8:5060:
Via: SIP/2.0/UDP 10.X.242.42:5060;branch=z9hG4bK5a33b1ea
From: "Unknown" <sip:phone_number@10.X.242.42>;tag=as06822043
To: <sip:62.X.15.8>
Contact: <sip:phone_number@10.X.242.42:5060>
Call-ID: 2daaf3552bf337ab602f68043ace42e8@10.X.242.42:5060
CSeq: 102 OPTIONS
Date: Wed, 10 Feb 2016 20:55:51 GMT
SIP/2.0 200 OK
To: <sip:62.X.15.8>;tag=snl_0011502104
CSeq: 102 OPTIONS
Contact: <sip:E1157000@62.X.3.76:5060;transport=udp;maddr=62.X.3.76>
Supported: sip-stun
[2016-02-10 21:55:51] VERBOSE[3255] chan_sip.c: --- (9 headers 0 lines) ---
[2016-02-10 21:55:51] VERBOSE[3255] chan_sip.c: Really destroying SIP dialog '2daaf3552bf337ab602f68043ace42e8@10.X.242.42:5060' Method: OPTIONS
To: <sip:62.X.15.8>
CSeq: 102 OPTIONS
CSeq: 102 OPTIONS
To: <sip:62.X.15.8>
CSeq: 102 OPTIONS
SIP/2.0 200 OK
CSeq: 102 OPTIONS
Supported: sip-stun
По ходу лога несколько вопрос.
1. Почему нету INVITE от сервера? Разве входящий звонок не должен инициализироваться от шлюза, в нашем случае от 62.X.15.8 ?
2. Почему сначала определяется как
, а потом как
From: "Unknown" <sip:phone_number@10.X.242.42>;tag=as06822043.
Почему номер телефона не сразу определяется?
3. Правильно ли я понимаю что
To: <sip:62.X.15.8>
CSeq: 102 OPTIONS
означает что
посылает информацию для
<sip:62.X.15.8>
Re: Не проходит входящий звонок (Elastix) с транка
1) Вы не знаете что такое SIP пакеты OPTIONS, прочитайте теорию для продолжения диалога, это важно.
2) далее следуйте по схеме:
koval
Сообщение koval »
Ded, спасибо за ответ.
С того что я понял
OPTIONS, данный тип запроса используется для проверки совместимости сторон, он позволяет клиенту получить информацию о том, какие методы поддерживает удаленная сторона, и что самое главное, нет необходимости совершать вызов удаленной стороны(нет необходимости в отправке INVITE запроса) ... Ответ на такой запрос должен быть таким же, как если мы отправили запрос INVITE, например это может быть ответ 200(OK), означающий что удаленная сторона готова принять звонок.
https://habrahabr.ru/post/212401/
Вот еще
Запросом OPTIONS вызываемый пользователь запрашивает информацию о функциональных возможностях терминального оборудования вызываемого пользователя. В ответ на этот запрос оборудование вызываемого пользователя сообщает требуемые сведения. Применение запроса OPTIONS ограничено теми случаями, когда необходимо узнать о функциональных возможностях оборудования до установления соединения. Для установления соединения запрос этого типа не используется.
http://iptop.net/sip/06.php
То есть провайдер может высылать OPTIONS, а потом если OPTIONS положительный то шлет INVITE для установления соединения.
Тепер смотрим на мой случай.
OPTIONS высылает
(это мой Астерикс) до шлюза провайдера
sip:62.X.15.8
To: <sip:62.X.15.8>
Разве не должно быть наоборот? Разве не
sip:62.X.15.8
должен высылать OPTIONS до
Glukinho
Сообщение Glukinho »
Вы с провайдером не пробовали на эту тему говорить?
На пакеты OPTIONS вообще не смотрите, что там внутри - это ни на что не влияет. Главное, чтобы проходили сами пакеты и ответы на них.
Вообще, судя по предоставленным вами IP-адресам, между вашим сервером и сервером провайдера есть NAT. А в этом случае регистрация от вас к провайдеру обязательна, без этого провайдер не узнает, на какой IP-адрес и порт отправлять к вам звонки. Что вы и видите - входящие звонки (пакеты INVITE) до вас не доходят.
koval
Сообщение koval »
Поговорил с провайдером. Косяк был на их стороне. Поправили. Всё работает.
Всем спасибо за участие!
