Не работает logger
gofer_k
Не работает logger
Сообщение gofer_k »
Всем привет.
Не пишутся логи в астере 11.13.1
вот что он мне пи шет на команду "logger show channels"
CLI> logger show channels
Channel                             Type     Status    Configuration
                                    Console  Enabled    - NOTICE WARNING ERROR
вот конфиг
cat logger.conf
; Logging Configuration
; In this file, you configure logging to files or to
; the syslog system.
; "logger reload" at the CLI will reload configuration
; of the logging system.
; Customize the display of debug message time stamps
; this example is the ISO 8601 date format (yyyy-mm-dd HH:MM:SS)
; see strftime(3) Linux manual for format specifiers.  Note that there is also
; a fractional second parameter which may be used in this field.  Use %1q
; for tenths, %2q for hundredths, etc.
dateformat=%F %T       ; ISO 8601 date format
;dateformat=%F %T.%3q   ; with milliseconds
; This makes Asterisk write callids to log messages
; (defaults to yes)
;use_callids = no
; This appends the hostname to the name of the log files.
;appendhostname = yes
; This determines whether or not we log queue events to a file
; (defaults to yes).
;queue_log = no
; Determines whether the queue_log always goes to a file, even
; when a realtime backend is present (defaults to no).
;queue_log_to_file = yes
; Set the queue_log filename
; (defaults to queue_log)
;queue_log_name = queue_log
; When using realtime for the queue log, use GMT for the timestamp
; instead of localtime.  The default of this option is 'no'.
;queue_log_realtime_use_gmt = yes
; Log rotation strategy:
; none:  Do not perform any logrotation at all.  You should make
;        very sure to set up some external logrotate mechanism
;        as the asterisk logs can get very large, very quickly.
; sequential:  Rename archived logs in order, such that the newest
;              has the highest sequence number [default].  When
;              exec_after_rotate is set, ${filename} will specify
;              the new archived logfile.
; rotate:  Rotate all the old files, such that the oldest has the
;          highest sequence number [this is the expected behavior
;          for Unix administrators].  When exec_after_rotate is
;          set, ${filename} will specify the original root filename.
; timestamp:  Rename the logfiles using a timestamp instead of a
;             sequence number when "logger rotate" is executed.
;             When exec_after_rotate is set, ${filename} will
;             specify the new archived logfile.
;rotatestrategy = rotate
; Run a system command after rotating the files.  This is mainly
; useful for rotatestrategy=rotate. The example allows the last
; two archive files to remain uncompressed, but after that point,
; they are compressed on disk.
; exec_after_rotate=gzip -9 ${filename}.2
; For each file, specify what to log.
; For console logging, you set options at start of
; Asterisk with -v for verbose and -d for debug
; See 'asterisk -h' for more information.
; Directory for log files is configures in asterisk.conf
; option astlogdir
[logfiles]
; Format is "filename" and then "levels" of debugging to be included:
;    debug
;    notice
;    warning
;    error
;    verbose(<level>)
;    dtmf
;    fax
;    security
; Special filename "console" represents the root console
; Filenames can either be relative to the standard Asterisk log directory
; (see 'astlogdir' in asterisk.conf), or absolute paths that begin with
; Verbose takes an optional argument, in the form of an integer level.
; Verbose messages with higher levels will not be logged to the file.  If
; the verbose level is not specified, it will log verbose messages following
; the current level of the root console.
; Special level name "*" means all levels, even dynamic levels registered
; by modules after the logger has been initialized (this means that loading
; and unloading modules that create/remove dynamic logger levels will result
; in these levels being included on filenames that have a level name of "*",
; without any need to perform a 'logger reload' or similar operation).
; Note that there is no value in specifying both "*" and specific level names
; for a filename; the "*" level means all levels.  The only exception is if
; you need to specify a specific verbose level. e.g, "verbose(3),*".
; We highly recommend that you DO NOT turn on debug mode if you are simply
; running a production system.  Debug mode turns on a LOT of extra messages,
; most of which you are unlikely to understand without an understanding of
; the underlying code.  Do NOT report debug messages as code issues, unless
; you have a specific issue that you are attempting to debug.  They are
; messages for just that -- debugging -- and do not rise to the level of
; something that merit your attention as an Asterisk administrator.  Debug
; messages are also very verbose and can and do fill up logfiles quickly;
; this is another reason not to have debug mode on a production system unless
; you are in the process of debugging a specific issue.
;debug => debug
;security => security
console => notice,warning,error
;console => notice,warning,error,debug
messages => security, notice,warning,error
;full => notice,warning,error,debug,verbose,dtmf,fax
;syslog keyword : This special keyword logs to syslog facility
;syslog.local0 => notice,warning,error
Что за фигня логи в messages => security, notice,warning,error не пишется файл пустой
Glukinho
Re: Не работает logger
Сообщение Glukinho »
Для начала я бы пробел убрал между security и notice.
gofer_k
Сообщение gofer_k »
Пробел в конфиге роли не играет.
Все оказалось проще.
core stop now
asterisk start
А я делал
logger reload
Короче я так понял logger reload не перезапускает по нормальному логер нужно стопать астер и рестартить.
Wapo
Сообщение Wapo »
Вынужден разочаровать - ни разу по сталкивался с тем, что logger reload как-то криво отрабатывается. Все что угодно было - тот же say load new по два раза или же очереди релодить для корректного сброса - но не логгер. Может засада в версии астера?
Glukinho
У меня logger reload всегда нормально отрабатывал.
