Debug SIP History
dad495
Debug SIP History
Сообщение dad495 »
Привет!
Наблюдаю разрывы звонков, включил запись дебага в лог + дамп SIP history.
Вот тестовый звонок, исходящий с 6000 (Asterisk) на 1342 (TDE600). Звонящий 6000 положил трубку.
---------- SIP HISTORY for '04dff1aa02c27debcd88c8d4e3a64a33@172.20.139.78'
[2015-09-18 12:14:23] DEBUG[6366] chan_sip.c:   * SIP Call
[2015-09-18 12:14:23] DEBUG[6366] chan_sip.c:   001. Rx              INVITE / 1345717135 INVITE / sip:1342@172.20.128.253
[2015-09-18 12:14:23] DEBUG[6366] chan_sip.c:   002. AuthChal        Auth challenge sent for  - nc 0
[2015-09-18 12:14:23] DEBUG[6366] chan_sip.c:   003. TxRespRel       SIP/2.0 / 1345717135 INVITE - 401 Unauthorized
[2015-09-18 12:14:23] DEBUG[6366] chan_sip.c:   004. SchedDestroy    6400 ms
[2015-09-18 12:14:23] DEBUG[6366] chan_sip.c:   005. Rx              ACK / 1345717135 ACK / sip:1342@172.20.128.253
[2015-09-18 12:14:23] DEBUG[6366] chan_sip.c:   006. Rx              INVITE / 1345717136 INVITE / sip:1342@172.20.128.253
[2015-09-18 12:14:23] DEBUG[6366] chan_sip.c:   007. CancelDestroy
[2015-09-18 12:14:23] DEBUG[6366] chan_sip.c:   008. Invite          New call: 04dff1aa02c27debcd88c8d4e3a64a33@172.20.139.78
[2015-09-18 12:14:23] DEBUG[6366] chan_sip.c:   009. AuthOK          Auth challenge successful for 6000
[2015-09-18 12:14:23] DEBUG[6366] chan_sip.c:   010. NewChan         Channel SIP/6000-00006413 - from 04dff1aa02c27debcd88c8d4e3a64a
[2015-09-18 12:14:23] DEBUG[6366] chan_sip.c:   011. TxResp          SIP/2.0 / 1345717136 INVITE - 100 Trying
[2015-09-18 12:14:23] DEBUG[6366] chan_sip.c:   012. TxResp          SIP/2.0 / 1345717136 INVITE - 180 Ringing
[2015-09-18 12:14:23] DEBUG[6366] chan_sip.c:   013. TxRespRel       SIP/2.0 / 1345717136 INVITE - 200 OK
[2015-09-18 12:14:23] DEBUG[6366] chan_sip.c:   014. Rx              ACK / 1345717136 ACK / sip:1342@172.20.128.253:5060
[2015-09-18 12:14:23] DEBUG[6366] chan_sip.c:   015. Rx              BYE / 1345717137 BYE / sip:1342@172.20.128.253:5060
[2015-09-18 12:14:23] DEBUG[6366] chan_sip.c:   016. RTCPaudio       Quality:ssrc=1510766844;themssrc=1897728338;lp=0;rxjitter=0.000
[2015-09-18 12:14:23] DEBUG[6366] chan_sip.c:   017. RTCPaudioJitter Quality:minrxjitter=0.000000;maxrxjitter=0.000000;avgrxjitter=0
[2015-09-18 12:14:23] DEBUG[6366] chan_sip.c:   018. RTCPaudioLoss   Quality:minrxlost=0.000000;maxrxlost=0.000000;avgrxlost=0.00000
[2015-09-18 12:14:23] DEBUG[6366] chan_sip.c:   019. RTCPaudioRTT    Quality:minrtt=0.000000;maxrtt=0.000000;avgrtt=0.000000;stdevrt
[2015-09-18 12:14:23] DEBUG[6366] chan_sip.c:   020. SchedDestroy    6400 ms
[2015-09-18 12:14:23] DEBUG[6366] chan_sip.c:   021. TxResp          SIP/2.0 / 1345717137 BYE - 200 OK
[2015-09-18 12:14:23] DEBUG[6366] chan_sip.c:   022. Hangup          Cause Normal Clearing
[2015-09-18 12:14:23] DEBUG[6366] chan_sip.c:   023. AutoDestroy     04dff1aa02c27debcd88c8d4e3a64a33@172.20.139.78
---------- END SIP HISTORY for '04dff1aa02c27debcd88c8d4e3a64a33@172.20.139.78'
RX TX в истории пишется относительно звонящего или астериска?
Вот строчка "Rx BYE / 1345717137 BYE / sip:1342@172.20.128.253:5060". Не могу понять почему тут Rx, ведь 6000 положил трубку.
Помогите разобраться.
Re: Debug SIP History
Судя по этому логу 1342 положил трубку.
Более подробно можно увидеть выполнив
CLI> sip set debug peer 1342
dad495
Сообщение dad495 »
sip debug хорошо, но на постоянку его не оставишь. Проблема плавающая. Мне как раз интересует Rx Tx относительно чего имеется ввиду, или если обобщить, как правильно читать sip history.
dad495 писал(а):sip debug хорошо, но на постоянку его не оставишь. Проблема плавающая..
Но поставьте! И всё будет писаться в /var/log/asterisk/full
где можно спокойно найти и разобрать причины.
dad495
Сообщение dad495 »
Хорошо, посмотрю поставить или нет. Но я интересовался конкретно sip history и все же хочу узнать ответ.
