Got SIP response 603 "Declined" back from х.х.х.х
alex_dergilev
Сообщение alex_dergilev »
Добрый день. Имеется проблема следующего характера:
Имеется Asterisk и fxo шлюз. При исходящем вызове в лог сыпется сообщение
Got SIP response 603 "Declined" back from "voip_шлюз":5060
    -- SIP/912-00000062 is busy
912 - транк на шлюз
дебаг дает следующий выхлоп:
== Using UDPTL TOS bits 184
  == Using UDPTL CoS mark 5
  == Using SIP RTP TOS bits 184
Audio is at 5060
Adding codec 0x2 (gsm) to SDP
Adding codec 0x100 (g729) to SDP
Adding codec 0x40 (slin) to SDP
Reliably Transmitting (no NAT) to "fxo_шлюз":
INVITE sip:89180494402@"fxo_шлюз" SIP/2.0
Via: SIP/2.0/UDP "ip_atc";branch=z9hG4bK321c06c3
From: "Kudarev NN" <sip:"username"@"ip_atc">;tag=as19530cb8
To: <sip:89180494402@"fxo_шлюз">
Contact: <sip:"username"@"ip_atc">
Call-ID: 7e7f873f494e657a2d4457df785752f2@"ip_atc"
CSeq: 102 INVITE
User-Agent: FPBX-2.11.0(1.8.7.1)
Date: Thu, 03 Sep 2015 11:31:16 GMT
Content-Length: 386
v=0
o=root 489176493 489176493 IN IP4 "ip_atc"
s=Asterisk PBX 1.8.7.1
c=IN IP4 "ip_atc"
t=0 0
m=audio 14150 RTP/AVP 0 8 3 18 10 101
a=rtpmap:0 PCMU/8000
a=rtpmap:8 PCMA/8000
a=rtpmap:3 GSM/8000
a=rtpmap:18 G729/8000
a=fmtp:18 annexb=no
a=rtpmap:10 L16/8000
a=fmtp:101 0-16
a=silenceSupp:off - - - -
a=ptime:20
a=sendrecv
    -- Called SIP/912/89180494402
<--- SIP read from UDP:"fxo_шлюз" --->
SIP/2.0 100 Trying
Via: SIP/2.0/UDP "ip_atc":5060;branch=z9hG4bK321c06c3;received="ip_atc"
CSeq: 102 INVITE
Server: TA810
Require: timer
Session-Expires: 1800;refresher=uas
Contact: <sip:89180494402@"fxo_шлюз">
--- (13 headers 0 lines) ---
<--- SIP read from UDP:"fxo_шлюз"--->
SIP/2.0 603 Declined
Via: SIP/2.0/UDP "ip_atc";branch=z9hG4bK321c06c3;received="ip_atc"
From: "Kudarev NN" <sip:223@"ip_atc">;tag=as19530cb8
To: <sip:89180494402@"fxo_шлюз">;tag=as6a72c19d
CSeq: 102 INVITE
Server: TA810
--- (10 headers 0 lines) ---
    -- Got SIP response 603 "Declined" back from "fxo_шлюз":5060
Transmitting (no NAT) to "fxo_шлюз":5060:
ACK sip:89180494402@"fxo_шлюз" SIP/2.0
To: <sip:XXXXXXXXXXX@"fxo_шлюз">;tag=as6a72c19d
CSeq: 102 ACK
    -- SIP/912-00000083 is busy
Шлюз отдает ответ
не могу понять в чем проблема, помогите пож-ста бестолковому
Wapo
Re: Got SIP response 603 "Declined" back from х.х.х.х
Сообщение Wapo »
603 - "отказ по иным причинам". Тут вам надо не дебаг гнать sip-а, а настройки шлюза как на самом астере так и что прописано в шлюзе (теже маршруты и т.д.)
alex_dergilev
Wapo, про "неопределенность" причины я уже нашел информацию, вот сижу ковыряю шлюз, но тут вроде бы всё нормально, шлюз Neogate TA810
А, ну тогда всё нормально.
