Странное поведение при регистрации у провайдера
hoodoo10
Сообщение hoodoo10 »
Здравствуйте. прошу помощи, потому что в тупике из-за непонятного поведения астериска.
Description: Linux Mint 17.2 Rafaela
Release: 17.2
Codename: rafaela
Asterisk 13.5.0
Суть проблемы:
При запуске системы сразу захожу в консоль астериска, и получаю такие ошибки:
[Aug 14 23:31:47] WARNING[2508]: chan_sip.c:3740 __sip_xmit: sip_xmit of 0x31ed2c0 (len 399) to (null) returned -1: Invalid argument
[Aug 14 23:31:51] WARNING[2508]: chan_sip.c:3740 __sip_xmit: sip_xmit of 0x31ed2c0 (len 399) to (null) returned -1: Invalid argument
[Aug 14 23:31:55] WARNING[2508]: chan_sip.c:3740 __sip_xmit: sip_xmit of 0x31ed2c0 (len 399) to (null) returned -1: Invalid argument
[Aug 14 23:31:59] WARNING[2508]: chan_sip.c:3740 __sip_xmit: sip_xmit of 0x31ed2c0 (len 399) to (null) returned -1: Invalid argument
[Aug 14 23:32:03] WARNING[2508]: chan_sip.c:3740 __sip_xmit: sip_xmit of 0x31ed2c0 (len 399) to (null) returned -1: Invalid argument
[Aug 14 23:32:05] NOTICE[2508]: chan_sip.c:15330 sip_reg_timeout:    -- Registration for '299251@sip.zadarma.com' timed out, trying again (Attempt #2)
P55H*CLI> sip show peers
Name/username             Host                                    Dyn Forcerport Comedia    ACL Port     Status      Description
1000/1000                 192.168.100.9                            D  Auto (No)  No             55229    Unmonitored
1001/1001                 192.168.100.3                            D  Auto (No)  No             36803    Unmonitored
1002/1002                 127.0.0.1                                D  Auto (No)  No             5061     Unmonitored
1003/1003                 192.168.100.2                            D  Auto (No)  No             5062     Unmonitored
zadarma/299251            (Unspecified)                               Auto (No)  No             0        Unmonitored
5 sip peers [Monitored: 0 online, 0 offline Unmonitored: 4 online, 1 offline]
P55H*CLI> sip show registry
Host                                    dnsmgr Username       Refresh State                Reg.Time
sip.zadarma.com:5060                    N      299251             105 Registered           Fri, 14 Aug 2015 23:32:06
1 SIP registrations.
sip.conf
register => 299251:secret@sip.zadarma.com
[zadarma]
type=peer
username=299251
secret=secret
fromuser=299251
fromdomain=sip.zadarma.com
host=sip.zadarma.com
context=incoming_zadarma
canreinvite=no
insecure=invite
Звонки вместо [incoming_zadarma] идут в [default]
Затем я открываю в vim sip.conf -> i -> Esc -> :wq (т.е. ничего в файле не меняю. Просто захожу в режим редактирования, выхожу из него, сохраняю), далее core reload и тут происходит вот это:
zadarma/299251            185.45.152.161                              Auto (No)  No             5060     Unmonitored
5 sip peers [Monitored: 0 online, 0 offline Unmonitored: 5 online, 0 offline]
Звонки ничинают идти как надо. Servise asterisk restart дает такой же результат.
Вполне возможно, что я зря убил 2 дня на поиски решения проблемы, но хотел сам разобраться. Не получилось.
Книгу "будущее телефонии" читаю. Конфиги у меня элементарные, практически из начала, так что скорее всего должно работать без проблем, но не хотит.
Заранее спасибо откликнувшимся.
Re: Странное поведение при регистрации у провайдера
Ну так напишите в баг трекер .
hoodoo10
В том-то и дело, что это не баг астериска. Только что ставил 13.4, 11.19 - поведение аналогичное.
Осмелюсь предположить - это вообще не баг. Это что-то у вас с ДНС. который не резолвит правильно хост sip.zadarma.com
Вот у вас после шаманства
а у меня
PING sip.zadarma.com (185.45.152.174) 56(84) bytes of data.
64 bytes from 174.152.45.185.fr.sipdc.net (185.45.152.174): icmp_req=1 ttl=59 time=41.3 ms
