Sipnet исходящая номерация
imusg
Сообщение imusg »
Ребят, не могу настроить исходящую номерацию на транк sipnet!!! При наборе Ekiga пишет "Удалёный пользователь отказался от звонка". Что делать?
Re: Sipnet исходящая номерация
Напишите писмо удалённому пользователю. Спросите - в чём причина отказа?
imusg
Сообщение imusg »
Ха) Да, шутник!!!
Вот что в консоли пишет asterisk:
Asterisk 1.6.2.18, Copyright (C) 1999 - 2010 Digium, Inc. and others.
Created by Mark Spencer <markster@digium.com>
Asterisk comes with ABSOLUTELY NO WARRANTY; type 'core show warranty' for detail
s.
This is free software, with components licensed under the GNU General Public
License version 2 and other licenses; you are welcome to redistribute it under
certain conditions. Type 'core show license' for details.
  == Parsing '/etc/asterisk/asterisk.conf':   == Found
Connected to Asterisk 1.6.2.18 currently running on l (pid = 4956)
Verbosity is at least 3
  == Using SIP RTP TOS bits 184
    -- Executing [+78442266777@from-internal:1] Macro("SIP/104-00000000", "user-
callerid,SKIPTTL,") in new stack
    -- Executing [s@macro-user-callerid:1] Set("SIP/104-00000000", "AMPUSER=104"
) in new stack
    -- Executing [s@macro-user-callerid:2] GotoIf("SIP/104-00000000", "0?report"
) in new stack
    -- Executing [s@macro-user-callerid:3] ExecIf("SIP/104-00000000", "1?Set(REA
LCALLERIDNUM=104)") in new stack
    -- Executing [s@macro-user-callerid:4] Set("SIP/104-00000000", "AMPUSER=104"
) in new stack
    -- Executing [s@macro-user-callerid:5] Set("SIP/104-00000000", "AMPUSERCIDNA
ME=104") in new stack
    -- Executing [s@macro-user-callerid:6] GotoIf("SIP/104-00000000", "0?report"
) in new stack
    -- Executing [s@macro-user-callerid:7] Set("SIP/104-00000000", "AMPUSERCID=1
04") in new stack
    -- Executing [s@macro-user-callerid:8] Set("SIP/104-00000000", "CALLERID(all
)="104" <104>") in new stack
    -- Executing [s@macro-user-callerid:9] GotoIf("SIP/104-00000000", "1?continu
e") in new stack
    -- Goto (macro-user-callerid,s,18)
    -- Executing [s@macro-user-callerid:18] NoOp("SIP/104-00000000", "Using Call
erID "104" <104>") in new stack
    -- Executing [+78442266777@from-internal:2] Set("SIP/104-00000000", "_NODEST
=") in new stack
    -- Executing [+78442266777@from-internal:3] Macro("SIP/104-00000000", "recor
d-enable,104,OUT,") in new stack
    -- Executing [s@macro-record-enable:1] GotoIf("SIP/104-00000000", "1?check")
 in new stack
    -- Executing [s@macro-record-enable:4] ExecIf("SIP/104-00000000", "0?MacroEx
it()") in new stack
    -- Executing [s@macro-record-enable:5] GotoIf("SIP/104-00000000", "0?Group:O
UT") in new stack
    -- Goto (macro-record-enable,s,16)
    -- Executing [s@macro-record-enable:16] GotoIf("SIP/104-00000000", "0?IN") i
n new stack
    -- Executing [s@macro-record-enable:17] ExecIf("SIP/104-00000000", "1?MacroE
xit()") in new stack
    -- Executing [+78442266777@from-internal:4] Macro("SIP/104-00000000", "dialo
ut-trunk,2,+78442266777,,") in new stack
    -- Executing [s@macro-dialout-trunk:1] Set("SIP/104-00000000", "DIAL_TRUNK="
) in new stack
    -- Executing [s@macro-dialout-trunk:2] GosubIf("SIP/104-00000000", "0?sub-pi
ncheck,s,1") in new stack
    -- Executing [s@macro-dialout-trunk:3] GotoIf("SIP/104-00000000", "0?disable
trunk,1") in new stack
    -- Executing [s@macro-dialout-trunk:4] Set("SIP/104-00000000", "DIAL_NUMBER=
+78442266777") in new stack
    -- Executing [s@macro-dialout-trunk:5] Set("SIP/104-00000000", "DIAL_TRUNK_O
PTIONS=tr") in new stack
    -- Executing [s@macro-dialout-trunk:6] Set("SIP/104-00000000", "OUTBOUND_GRO
UP=OUT_2") in new stack
    -- Executing [s@macro-dialout-trunk:7] GotoIf("SIP/104-00000000", "0?nomax")
 in new stack
    -- Executing [s@macro-dialout-trunk:8] GotoIf("SIP/104-00000000", "0?chanful
l") in new stack
    -- Executing [s@macro-dialout-trunk:9] GotoIf("SIP/104-00000000", "0?skipout
cid") in new stack
    -- Executing [s@macro-dialout-trunk:10] Set("SIP/104-00000000", "DIAL_TRUNK_
OPTIONS=") in new stack
    -- Executing [s@macro-dialout-trunk:11] Macro("SIP/104-00000000", "outbound-
callerid,2") in new stack
    -- Executing [s@macro-outbound-callerid:1] ExecIf("SIP/104-00000000", "0?Set
(CALLERPRES()=)") in new stack
    -- Executing [s@macro-outbound-callerid:2] ExecIf("SIP/104-00000000", "0?Set
(REALCALLERIDNUM=104)") in new stack
    -- Executing [s@macro-outbound-callerid:3] GotoIf("SIP/104-00000000", "1?nor
mcid") in new stack
    -- Executing [s@macro-outbound-callerid:6] Set("SIP/104-00000000", "USEROUTC
ID=104") in new stack
    -- Executing [s@macro-outbound-callerid:7] Set("SIP/104-00000000", "EMERGENC
YCID=") in new stack
    -- Executing [s@macro-outbound-callerid:8] Set("SIP/104-00000000", "TRUNKOUT
CID=imusg") in new stack
    -- Executing [s@macro-outbound-callerid:9] GotoIf("SIP/104-00000000", "1?tru
nkcid") in new stack
    -- Goto (macro-outbound-callerid,s,12)
    -- Executing [s@macro-outbound-callerid:12] ExecIf("SIP/104-00000000", "1?Se
t(CALLERID(all)=imusg)") in new stack
    -- Executing [s@macro-outbound-callerid:13] ExecIf("SIP/104-00000000", "1?Se
t(CALLERID(all)=104)") in new stack
    -- Executing [s@macro-outbound-callerid:14] ExecIf("SIP/104-00000000", "0?Se
t(CALLERID(all)=)") in new stack
    -- Executing [s@macro-outbound-callerid:15] ExecIf("SIP/104-00000000", "0?Se
t(CALLERPRES()=prohib_passed_screen)") in new stack
    -- Executing [s@macro-dialout-trunk:12] ExecIf("SIP/104-00000000", "0?AGI(fi
xlocalprefix)") in new stack
    -- Executing [s@macro-dialout-trunk:13] Set("SIP/104-00000000", "OUTNUM=+784
    -- Executing [s@macro-dialout-trunk:14] Set("SIP/104-00000000", "custom=SIP/
sipnet") in new stack
    -- Executing [s@macro-dialout-trunk:15] ExecIf("SIP/104-00000000", "0?Set(DI
AL_TRUNK_OPTIONS=M(setmusic^))") in new stack
    -- Executing [s@macro-dialout-trunk:16] Macro("SIP/104-00000000", "dialout-t
runk-predial-hook,") in new stack
    -- Executing [s@macro-dialout-trunk-predial-hook:1] MacroExit("SIP/104-00000
000", "") in new stack
    -- Executing [s@macro-dialout-trunk:17] GotoIf("SIP/104-00000000", "0?bypass
,1") in new stack
    -- Executing [s@macro-dialout-trunk:18] GotoIf("SIP/104-00000000", "0?custom
trunk") in new stack
    -- Executing [s@macro-dialout-trunk:19] Dial("SIP/104-00000000", "SIP/sipnet
/+78442266777,300,") in new stack
    -- Couldn't call sipnet/+78442266777
  == Everyone is busy/congested at this time (0:0/0/0)
    -- Executing [s@macro-dialout-trunk:20] NoOp("SIP/104-00000000", "Dial faile
d for some reason with DIALSTATUS = CHANUNAVAIL and HANGUPCAUSE = 0") in new sta
ck
    -- Executing [s@macro-dialout-trunk:21] Goto("SIP/104-00000000", "s-CHANUNAV
AIL,1") in new stack
    -- Goto (macro-dialout-trunk,s-CHANUNAVAIL,1)
    -- Executing [s-CHANUNAVAIL@macro-dialout-trunk:1] Set("SIP/104-00000000", R
C=0") in new stack
    -- Executing [s-CHANUNAVAIL@macro-dialout-trunk:2] Goto("SIP/104-00000000",
"0,1") in new stack
    -- Goto (macro-dialout-trunk,0,1)
    -- Executing [+78442266777@from-internal:5] Macro("SIP/104-00000000", "outis
busy,") in new stack
    -- Executing [s@macro-outisbusy:1] Progress("SIP/104-00000000", "") in new s
tack
    -- Executing [s@macro-outisbusy:2] Playback("SIP/104-00000000", "all-circuit
s-busy-now,noanswer") in new stack
    -- <SIP/104-00000000> Playing 'all-circuits-busy-now.gsm' (language 'en')
    -- Executing [s@macro-outisbusy:3] Playback("SIP/104-00000000", "pls-try-cal
l-later,noanswer") in new stack
    -- <SIP/104-00000000> Playing 'pls-try-call-later.gsm' (language 'en')
    -- Executing [s@macro-outisbusy:4] Macro("SIP/104-00000000", "hangupcall") i
n new stack
    -- Executing [s@macro-hangupcall:1] GotoIf("SIP/104-00000000", "1?skiprg") i
n new stack
    -- Goto (macro-hangupcall,s,4)
    -- Executing [s@macro-hangupcall:4] GotoIf("SIP/104-00000000", "1?skipblkvm"
) in new stack
    -- Executing [s@macro-hangupcall:7] GotoIf("SIP/104-00000000", "1?theend") i
n new stack
    -- Executing [s@macro-hangupcall:9] Hangup("SIP/104-00000000", "") in new st
ack
  == Spawn extension (macro-hangupcall, s, 9) exited non-zero on 'SIP/104-000000
00' in macro 'hangupcall'
  == Spawn extension (macro-outisbusy, s, 4) exited non-zero on 'SIP/104-0000000
0' in macro 'outisbusy'
  == Spawn extension (from-internal, +78442266777, 5) exited non-zero on 'SIP/10
4-00000000'
    -- Executing [h@from-internal:1] Macro("SIP/104-00000000", "hangupcall") in
new stack
n new stack
) in new stack
n new stack
ack
  == Spawn extension (from-internal, h, 1) exited non-zero on 'SIP/104-00000000'
l*CLI>
Пользовате5лям, которые не могут настроить входящие/исходящие на Sipnet, несмотря на множество примеров и инструкций, несмотря на форум на Sipnet.ru, заниматься VoIP строго противопоказано. Повреждённая хромосома - не попишешь!
imusg
Сообщение imusg »
Шуштишь да!!! Помоги лучше понять и разобраться, что не так!!!
Мы на ты? Славно!
Кыш!
imusg
Сообщение imusg »
Что значит кыш? Вы мне поможете или нет? у меня сервер стоит в локальной сети, в инет сеть выходит через отдельную машину, а она через модем Мегафона. Настраиваю через FreePBX.
Последний раз редактировалось imusg 24 июн 2011, 13:33, всего редактировалось 1 раз.
Samael28
Сообщение Samael28 »
Боюсь, уже нет. При этом вообще стоило хотя бы правильно указать, что пользуете FreePBX или что-то подобное. Потом - на форум СипНета для настроек под конкретную морду.
Мой профайл на Upwork
imusg
Сообщение imusg »
Asterisk к sipnet подключён, это видно как через sip show registery, так и на главной странице freepbx!
imusg
Сообщение imusg »
У меня сервер стоит в локальной сети, в инет сеть выходит через отдельную машину, а она через модем Мегафона. Настраиваю через FreePBX.
