huawei e1550 на centos
sorgchik
Сообщение sorgchik »
Установил:
1. usb-modeswitch-1.1.4
2. usb-modeswitch-data
Подключаю модем:
[root@mail etc]# lsusb
Bus 007 Device 001: ID 0000:0000
Bus 003 Device 001: ID 0000:0000
Bus 005 Device 001: ID 0000:0000
Bus 004 Device 006: ID 12d1:1446 Huawei Technologies Co., Ltd. E1552 (HSPA modem)
Bus 004 Device 001: ID 0000:0000
Bus 001 Device 001: ID 0000:0000
Bus 006 Device 001: ID 0000:0000
Bus 002 Device 001: ID 0000:0000
Bus 008 Device 001: ID 0000:0000
[root@mail etc]#
Переключаю:
[root@mail etc]# /usr/sbin/usb_modeswitch -I -W -D -v 12d1 -p 1446
Taking all parameters from the command line
 * usb-modeswitch: handle USB devices with multiple modes
 * Version 1.1.2alpha (C) Josua Dietze 2010
 * Based on libusb0 (0.1.12 and above)
 ! PLEASE REPORT NEW CONFIGURATIONS !
DefaultVendor=  0x12d1
DefaultProduct= 0x1446
TargetVendor=   not set
TargetProduct=  not set
TargetClass=    not set
DetachStorageOnly=0
HuaweiMode=0
SierraMode=0
SonyMode=0
GCTMode=0
MessageEndpoint= not set
MessageContent= not set
NeedResponse=0
ResponseEndpoint= not set
Interface=0x00
InquireDevice disabled
Success check disabled
System integration mode enabled
usb_set_debug: Setting debugging level to 15 (on)
usb_os_find_busses: Found 007
usb_os_find_busses: Found 003
usb_os_find_busses: Found 005
usb_os_find_busses: Found 004
usb_os_find_busses: Found 001
usb_os_find_busses: Found 006
usb_os_find_busses: Found 002
usb_os_find_busses: Found 008
usb_os_find_devices: Found 001 on 007
usb_os_find_devices: Found 001 on 003
usb_os_find_devices: Found 001 on 005
usb_os_find_devices: Found 006 on 004
usb_os_find_devices: Found 001 on 004
error obtaining child information: Inappropriate ioctl for device
usb_os_find_devices: Found 001 on 001
usb_os_find_devices: Found 001 on 006
usb_os_find_devices: Found 001 on 002
usb_os_find_devices: Found 001 on 008
Looking for default devices ...
  searching devices, found USB ID 0000:0000
  searching devices, found USB ID 12d1:1446
   found matching vendor ID
   found matching product ID
   adding device
 Found devices in default mode or class (1)
Accessing device 006 on bus 004 ...
USB description data (for identification)
Manufacturer: HUAWEI Technology
     Product: HUAWEI Mobile
  Serial No.: not provided
Warning: no switching method given.
-> Run lsusb to note any changes. Bye.
[root@mail etc]#
в чем может быть проблема?
Re: huawei e1550 на centos
А как насчет пойти от обратного?
Вставить модем в машину с виндами.
Поставить драйвера.
Дать модему команду переводящую его в режим "modem only" (AT^U2DIAG=0).
После этого переставить его в линукс и нормально им пользоваться не заморачиваясь с usb-modeswitch
sorgchik
спасибо за подсказку SolarW :)
два вопроса пока решить не могу...
первый
при подключении модема, на /dev/ttyUCB[0..9] выставляются права 660, добавил новое правило:
[root@localhost rules.d]# cat /etc/udev/rules.d/45-usb.rules
KERNEL=="ttyUSB[0-9]*", ID=="2-1:1.0", NAME="%k", SYMLINK+="hw00", GROUP="uucp", MODE="0777"
KERNEL=="ttyUSB[0-9]*", ID=="2-1:1.1", NAME="%k", SYMLINK+="hw01", GROUP="uucp", MODE="0777"
KERNEL=="ttyUSB[0-9]*", ID=="2-1:1.2", NAME="%k", SYMLINK+="hw02", GROUP="uucp", MODE="0777" [root@localhost rules.d]#
теперь на файлах вообще 600, а группа root :?
в принципе этот вопрос я думаю можно закрыть скриптиком в автозагрузку, почему просто не срабатывают правила, не понимаю.
второй, вот лог входящего звонка:
localhost*CLI>
  == Starting Datacard/datacard0-14d7 at data-inc,s,1 failed so falling back to exten 's'
  == Starting Datacard/datacard0-14d7 at data-inc,s,1 still failed so falling back to context 'default'
    -- Executing [s@default:1] Playback("Datacard/datacard0-14d7", "vm-goodbye") in new stack
    -- <Datacard/datacard0-14d7> Playing 'vm-goodbye.gsm' (language 'en')
    -- Executing [s@default:2] Macro("Datacard/datacard0-14d7", "hangupcall") in new stack
    -- Executing [s@macro-hangupcall:1] GotoIf("Datacard/datacard0-14d7", "1?skiprg") in new stack
    -- Goto (macro-hangupcall,s,4)
    -- Executing [s@macro-hangupcall:4] GotoIf("Datacard/datacard0-14d7", "1?skipblkvm") in new stack
    -- Executing [s@macro-hangupcall:7] GotoIf("Datacard/datacard0-14d7", "1?theend") in new stack
    -- Executing [s@macro-hangupcall:9] Hangup("Datacard/datacard0-14d7", "") in new stack
  == Spawn extension (macro-hangupcall, s, 9) exited non-zero on 'Datacard/datacard0-14d7' in macro 'hangupcall'
  == Spawn extension (default, s, 2) exited non-zero on 'Datacard/datacard0-14d7'
    -- Datacard datacard0 has disconnected
localhost*CLI>
не понимаю, откуда берется контекст default, когда в datacard.conf прописан datdacard-incoming :roll:
Прописан то может и прописан, а есть ли - datdacard-incoming ?
Проверять
>dialplan show datdacard-incoming
sorgchik
спасибо ded, действительно контекст то я и не создавал!
но вот решил я все это дело направить в from-pstn, но тут вообще не ладится..
 Loaded chan_datacard.so => (Datacard Channel Driver)
    -- Datacard datacard0 trying to connect on /dev/ttyUSB2...
    -- Datacard datacard0 has connected, initializing...
    -- Datacard datacard0 initialized and ready
    -- Executing [s@from-pstn:1] NoOp("Datacard/datacard0-7abb", "No DID or CID Match") in new stack
    -- Executing [s@from-pstn:2] Answer("Datacard/datacard0-7abb", "") in new stack
    -- Executing [s@from-pstn:3] Wait("Datacard/datacard0-7abb", "2") in new stack
  == Spawn extension (from-pstn, s, 3) exited non-zero on 'Datacard/datacard0-7abb'
    -- Executing [h@from-pstn:1] Hangup("Datacard/datacard0-7abb", "") in new stack
  == Spawn extension (from-pstn, h, 1) exited non-zero on 'Datacard/datacard0-7abb'
localhost*CLI>
отваливается модем и соответственно Hangup, что опять то не так :(
sorgchik
прошил модем более новой прошивкой, перестал дисконектится при входящем звонке, но вот смущает строка
No DID or CID Match
получается я немогу направить звонок куда хочу..
trscod
Сообщение trscod »
sorgchik писал(а): отваливается модем и соответственно Hangup, что опять то не так :(
Там есть файлик Readme в комплекте с datacard. Если бы Вы его прочитали, то поняли, что на центосе щастья не будет :(
sorgchik
там нет ни слова о centos
sorgchik писал(а):при подключении модема, на /dev/ttyUCB[0..9] выставляются права 660, добавил новое правило:
Кладезь знаний по проблеме весь перечитан? :)
У меня вот так права на порт назначаются.
KERNEL=="ttyUSB[0-9]*", ID=="2-1.5:1.0", SYMLINK+="hv0", GROUP="root", MODE="0666"
KERNEL=="ttyUSB[0-9]*", ID=="2-1.5:1.1", SYMLINK+="hv1", GROUP="root", MODE="0666"
KERNEL=="ttyUSB[0-9]*", ID=="2-1.5:1.2", SYMLINK+="hv2", GROUP="root", MODE="0666"
У пользователя asterisk прав хватает с модемом работать...
sorgchik писал(а):там нет ни слова о centos
Зато там написано
Please use a recent Linux kernel, 2.6.33+ recommended.
А у вас что uname -a говорит?
