Пытаюсь настроить Asterisk 1.6.2.9 (debian rep) + Grandstream FXS шлюзы. У этих самых Grandsteram есть функция Early Dial, т.е. они могут слать SIP INVITE после каждой цифры, а asterisk должен отвечать SIP 484 если данного номера нет в номерном плане. Так вот он после первой же цифры вместо 484 дает полный отлуп в виде 404:
[May 5 14:26:39] DEBUG[21191] acl.c: Found IP address for this socket
[May 5 14:26:39] DEBUG[21191] chan_sip.c: Setting SIP_TRANSPORT_UDP with address 192.168.1.1:5060
[May 5 14:26:39] VERBOSE[21191] netsock.c: == Using SIP RTP CoS mark 5
[May 5 14:26:39] DEBUG[21191] chan_sip.c: Setting NAT on RTP to Off
[May 5 14:26:39] DEBUG[21191] chan_sip.c: Allocating new SIP dialog for 587137444-5062-5@192.168.1.98 - INVITE (With RTP)
[May 5 14:26:39] DEBUG[21191] chan_sip.c: **** Received INVITE (5) - Command in SIP INVITE
[May 5 14:26:39] DEBUG[21191] chan_sip.c: Trying to put 'SIP/2.0 401' onto UDP socket destined for 192.168.1.98:5062
[May 5 14:26:39] DEBUG[21191] chan_sip.c: **** Received ACK (6) - Command in SIP ACK
[May 5 14:26:39] DEBUG[21191] chan_sip.c: Stopping retransmission on '587137444-5062-5@192.168.1.98' of Response 40: Match Found
[May 5 14:26:39] DEBUG[21191] chan_sip.c: Processing session-level SDP v=0... UNSUPPORTED.
[May 5 14:26:39] DEBUG[21191] chan_sip.c: Processing session-level SDP o=111 8002 8000 IN IP4 192.168.1.98... UNSUPPORTED.
[May 5 14:26:39] DEBUG[21191] chan_sip.c: Processing session-level SDP s=SIP Call... UNSUPPORTED.
[May 5 14:26:39] DEBUG[21191] chan_sip.c: Processing session-level SDP c=IN IP4 192.168.1.98... OK.
[May 5 14:26:39] DEBUG[21191] chan_sip.c: Processing session-level SDP t=0 0... UNSUPPORTED.
[May 5 14:26:39] DEBUG[21191] chan_sip.c: Processing media-level (audio) SDP a=sendrecv... OK.
[May 5 14:26:39] DEBUG[21191] chan_sip.c: Processing media-level (audio) SDP a=rtpmap:18 G729/8000... OK.
[May 5 14:26:39] DEBUG[21191] chan_sip.c: Processing media-level (audio) SDP a=fmtp:18 annexb=no... UNSUPPORTED.
[May 5 14:26:39] DEBUG[21191] chan_sip.c: Processing media-level (audio) SDP a=ptime:20... OK.
[May 5 14:26:39] DEBUG[21191] chan_sip.c: Processing media-level (audio) SDP a=rtpmap:8 PCMA/8000... OK.
[May 5 14:26:39] DEBUG[21191] chan_sip.c: Processing media-level (audio) SDP a=rtpmap:0 PCMU/8000... OK.
[May 5 14:26:39] DEBUG[21191] chan_sip.c: Processing media-level (audio) SDP a=rtpmap:2 G726-32/8000... OK.
[May 5 14:26:39] DEBUG[21191] chan_sip.c: Processing media-level (audio) SDP a=rtpmap:97 iLBC/8000... OK.
[May 5 14:26:39] DEBUG[21191] chan_sip.c: Processing media-level (audio) SDP a=fmtp:97 mode=20... UNSUPPORTED.
[May 5 14:26:39] DEBUG[21191] chan_sip.c: Processing media-level (audio) SDP a=rtpmap:102 G729E/8000... OK.
[May 5 14:26:39] DEBUG[21191] chan_sip.c: Processing media-level (audio) SDP a=rtpmap:100 AAL2-G726-16/8000... OK.
[May 5 14:26:39] DEBUG[21191] chan_sip.c: We're settling with these formats: 0x4 (ulaw)
[May 5 14:26:39] DEBUG[21191] chan_sip.c: Checking SIP call limits for device 111
[May 5 14:26:39] DEBUG[21191] chan_sip.c: Updating call counter for incoming call
[May 5 14:26:39] DEBUG[21179] devicestate.c: No provider found, checking channel drivers for SIP - 111
[May 5 14:26:39] DEBUG[21179] chan_sip.c: Checking device state for peer 111
[May 5 14:26:39] DEBUG[21191] chan_sip.c: Trying to put 'SIP/2.0 404' onto UDP socket destined for 192.168.1.98:5062
[May 5 14:26:39] DEBUG[21179] devicestate.c: Changing state for SIP/111 - state 2 (In use)
[May 5 14:26:39] DEBUG[21179] devicestate.c: device 'SIP/111' state '2'
[May 5 14:26:39] NOTICE[21191] chan_sip.c: Call from '111' to extension '1' rejected because extension not found in context 'DLPN_DialPlan1'.
PowerEdge*CLI> dialplan show
[ Context 'app_dial_gosub_virtual_context' created by 'app_dial' ]
's' => 1. NoOp() [app_dial]
[ Context 'app_queue_gosub_virtual_context' created by 'app_queue' ]
's' => 1. NoOp() [app_queue]
[ Context 'parkedcalls' created by 'features' ]
'700' => 1. Park() [features]
[ Context 'demo' created by 'pbx_lua' ]
Alt. Switch => 'Lua/' [pbx_lua]
[ Context 'ringroups-custom-3' created by 'pbx_config' ]
's' => 1. NoOp(Buh_all) [pbx_config]
2. Dial(SIP/101&SIP/108&SIP/109,60,${DIALOPTIONS}i) [pbx_config]
3. Hangup() [pbx_config]
[ Context 'ringroups-custom-2' created by 'pbx_config' ]
's' => 1. NoOp(Buh) [pbx_config]
2. Dial(SIP/109,10,${DIALOPTIONS}i) [pbx_config]
3. Dial(SIP/108,10,${DIALOPTIONS}i) [pbx_config]
4. Dial(SIP/101,10,${DIALOPTIONS}i) [pbx_config]
5. Goto(ringroups-custom-3,s,1) [pbx_config]
[ Context 'ringroups-custom-1' created by 'pbx_config' ]
's' => 1. NoOp(Managers) [pbx_config]
2. Dial(SIP/104,10,${DIALOPTIONS}i) [pbx_config]
3. Dial(SIP/107,10,${DIALOPTIONS}i) [pbx_config]
4. Dial(SIP/102,10,${DIALOPTIONS}i) [pbx_config]
5. Goto(ringroups-custom-4,s,1) [pbx_config]
[ Context 'ringroups-custom-4' created by 'pbx_config' ]
's' => 1. NoOp(Managers_all) [pbx_config]
2. Dial(SIP/102&SIP/104&SIP/107,60,${DIALOPTIONS}i) [pbx_config]
[ Context 'DID_trunk_1' created by 'pbx_config' ]
's' => 1. Goto(ringroups-custom-1,s,1) [pbx_config]
[ Context 'outgoing' created by 'pbx_config' ]
'_9X.' => 1. Dial(SIP/trunk_1/${EXTEN:1},,tT) [pbx_config]
2. Congestion() [pbx_config]
[ Context 'DLPN_DialPlan1' created by 'pbx_config' ]
Include => 'default' [pbx_config]
Include => 'outgoing' [pbx_config]
[ Context 'ringgroups' created by 'pbx_config' ]
'220' => 1. Goto(ringroups-custom-1,s,1) [pbx_config]
'221' => 1. Goto(ringroups-custom-2,s,1) [pbx_config]
'222' => 1. Goto(ringroups-custom-3,s,1) [pbx_config]
'223' => 1. Goto(ringroups-custom-4,s,1) [pbx_config]
[ Context 'default' created by 'pbx_config' ]
'101' => hint: SIP/101 [pbx_config]
1. Dial(${HINT}) [pbx_config]
'102' => hint: SIP/102 [pbx_config]
'103' => hint: SIP/103 [pbx_config]
'104' => hint: SIP/104 [pbx_config]
'105' => hint: SIP/105 [pbx_config]
'106' => hint: SIP/106 [pbx_config]
'107' => hint: SIP/107 [pbx_config]
'108' => hint: SIP/108 [pbx_config]
'109' => hint: SIP/109 [pbx_config]
'110' => hint: SIP/110 [pbx_config]
'111' => hint: SIP/111 [pbx_config]
'112' => hint: SIP/112 [pbx_config]
'113' => hint: SIP/113 [pbx_config]
'199' => hint: SIP/199 [pbx_config]
Include => 'DID_trunk_1' [pbx_config]
-= 27 extensions (55 priorities) in 13 contexts. =-
