как этот freepbx отлаживать?
ubnt
Сообщение ubnt »
Интересует сам дистрибутив, а не asterisk. Добавил ingoing в extensions_custom.conf, теперь при нажатии кнопки apply выходит пародия на ошибку:
exit: 20
Aborting reload because extension conflicts or bad destinations
Откат конфигов не помог :( Попытки найти отладку в гугле приводят в asterisk, но в астериске логов нет после нажатия, следовательно до перезагрузки дело не доходит.
ubnt
Re: как этот freepbx отлаживать?
Сообщение ubnt »
А вот еще что этот Император Отладки выдал:
DEST STATUS: EMPTY
Inbound Route: (/)
amportal a dbug
Please wait...
trying to run as user asterisk:
[FPBXDBUGDISABLE] already set to [0]
==> /var/log/asterisk/freepbx_debug <==
2014-Dec-04 13:32:12	/usr/share/php/DB/mysql.php:240
[DEPRECATION_WARNING]: mysql_connect(): The mysql extension is deprecated and will be removed in the future: use mysqli or PDO instead
2014-Dec-04 13:32:13	/usr/share/php/DB/mysql.php:240
==> /var/log/asterisk/freepbx.log <==
[2014-Dec-01 04:51:31] [INFO] (freepbx-12/install_amp:1705) - freepbx setting [SHOWLANGUAGE] set to [TRUE]
[2014-Dec-01 04:51:31] [INFO] (freepbx-12/install_amp:1705) - freepbx setting [MODULEADMINWGET] set to [TRUE]
[2014-Dec-01 04:51:31] [INFO] (freepbx-12/install_amp:1705) - freepbx setting [CDRDBHOST] set to []
[2014-Dec-01 04:51:31] [INFO] (freepbx-12/install_amp:1705) - freepbx setting [CDRDBNAME] set to []
[2014-Dec-01 04:51:31] [INFO] (freepbx-12/install_amp:1705) - freepbx setting [CDRDBPASS] set to []
[2014-Dec-01 04:51:31] [INFO] (freepbx-12/install_amp:1705) - freepbx setting [CDRDBPORT] set to []
[2014-Dec-01 04:51:31] [INFO] (freepbx-12/install_amp:1705) - freepbx setting [CDRDBTABLENAME] set to []
[2014-Dec-01 04:51:31] [INFO] (freepbx-12/install_amp:1705) - freepbx setting [CDRDBTYPE] set to []
[2014-Dec-01 04:51:31] [INFO] (freepbx-12/install_amp:1705) - freepbx setting [CDRDBUSER] set to []
[2014-Dec-01 04:51:31] [INFO] (freepbx-12/install_amp:1705) - freepbx setting [AMPSYSLOGLEVEL] set to [FILE]
2014-Dec-04 13:32:18	/usr/share/php/DB/mysql.php:240
2014-Dec-04 13:32:19	/usr/share/php/DB/mysql.php:240
Мне уже несмешно :(
ingoing? Вот так именно? И сразу его в extensions_custom.conf?
Вы тоже Император всея Астериска, как я погляжу.
ubnt писал(а):Добавил ingoing в extensions_custom.conf, теперь при нажатии кнопки apply выходит пародия на ошибку:
exit: 20
Вы просто пародия на настройщика дистрибутивов freePBX. На курсы настройщиков не хотите? Или хотя бы книжку почитать про freePBX?
Алекс Робар «FreePBX 2.5 Мощные телефонные решения» - в библиотеке asterisk.ru
ubnt
Сообщение ubnt »
Лучше подскажите как отладку включить. amportal a dbug ничего не выдаёт.
А тут всё понятно, без сарказма:
и тут:
DEST STATUS: EMPTY
Inbound Route: (/)
у вас просто нет входящего маршрута. И нет нужды его засовывать в extensions_custom.conf. Ибо есть для этого вэб интерфейс, а там Inbound routes. Синтаксис и логику которого распрашивать на форуме неприлично, это ламерство. Лучше читайте
ubnt
Сообщение ubnt »
Есть там входящие маршруты. На базе данных его заклинивало. В ней кастомный номер без прописанного маршрута, удалил запись, нажал apply и всё заработало. А во входящих роутах никаких намёков на этот номер не было. Ни в inbound routes, ни в full reports, ни в print extensions.
И как без кастомного маршрута туда прописать extension (t38modem), который находится в sip_custom.conf?
Платный суппорт поможет!
Не хочется Вас обижать, но сарказм Ваш мне непонятен, как и стремление всё засовывать в _custom.conf без знаний и умений.
Не понимая логики freePBX Вы просто вгоняете систему в ступор.
marsik
Сообщение marsik »
ded писал(а):Алекс Робар «FreePBX 2.5 Мощные телефонные решения» - в библиотеке asterisk.ru
кстати про библиотеку:
ссылка на «Configuring Cisco SPA5xx IP Telephones in an Asterisk Environments» приказала долго жить
ссылка на «Configuring Cisco SPA5xx IP Telephones in an Asterisk Environments» поправлена!
