peer не даёт работать user`у
ubnt
Сообщение ubnt »
Есть номер телефонный 28ХХХХХ.
Выходит ошибка Out of capacity
Тип соединения sip account.
Если поставить user only, входящие звонки работают.
Если поставить peer, исходящие работают, входящие нет.
Если поставить friend, то исходящие работают, а входящие нет.
-- Called SIP/28XXXXX_peer/28XXXXX
<--- SIP read from UDP:195.64.217.115:5060 --->
SIP/2.0 100 Trying
Via: SIP/2.0/UDP 10.45.1.13:5060;branch=z9hG4bK64efd16c;rport=5060;received=92.242.6.110
To: <sip:28XXXXX@sip6.ural.net>
Call-ID: 53f7f2b4199f3c204b9e32c03874b13d@sip6.ural.net
CSeq: 102 INVITE
Contact: <sip:28XXXXX@195.64.217.115:5060>
Server: TS-v4.5.1-17W
--- (9 headers 0 lines) ---
SIP/2.0 603 Decline
To: <sip:28XXXXX@sip6.ural.net>;tag=547663675-3826336096-620815540-3932369040
CSeq: 102 INVITE
Reason: Centrex;cause=181;text="Out of capacity"
--- (10 headers 0 lines) ---
    -- Got SIP response 603 "Decline" back from 195.64.217.115:5060
Transmitting (NAT) to 195.64.217.115:5060:
ACK sip:28XXXXX@sip6.ural.net SIP/2.0
Contact: <sip:28XXXXX@10.45.1.13:5060>
CSeq: 102 ACK
User-Agent: FPBX-12.0.1rc34(11.7.0)
    -- SIP/28XXXXX_peer-0000005f is busy
  == Everyone is busy/congested at this time (1:1/0/0)
    -- Executing [s@macro-dialout-trunk:23] NoOp("SIP/28XXXXX_peer-0000005e", "Dial failed for some reason with DIALSTATUS = BUSY and HANGUPCAUSE = 21") in new stack
    -- Executing [s@macro-dialout-trunk:24] GotoIf("SIP/28XXXXX_peer-0000005e", "1?continue,1:s-BUSY,1") in new stack
    -- Executing [continue@macro-dialout-trunk:1] NoOp("SIP/28XXXXX_peer-0000005e", "TRUNK Dial failed due to BUSY HANGUPCAUSE: 21 - failing through to other trunks") in new stack
    -- Executing [continue@macro-dialout-trunk:2] Set("SIP/28XXXXX_peer-0000005e", "CALLERID(number)=") in new stack
    -- Executing [28XXXXX@from-internal:6] Macro("SIP/28XXXXX_peer-0000005e", "outisbusy,") in new stack
    -- Executing [s@macro-outisbusy:1] Progress("SIP/28XXXXX_peer-0000005e", "") in new stack
Audio is at 13230
<--- Transmitting (NAT) to 195.64.217.115:5060 --->
SIP/2.0 183 Session Progress
Via: SIP/2.0/UDP 195.64.217.115:5060;branch=z9hG4bK-1491512635-3826336096-620815540-39323690401;received=195.64.217.115;rport=5060
Via: SIP/2.0/UDP 195.64.217.115:5061;rport=5061;branch=z9hG4bK-1491512635-3826336096-620815540-3932369040;received=195.64.217.115
From: <sip:9625576738@195.64.217.115:5061;user=phone>;tag=2530913595-3826336096-620815540-3932369040
To: <sip:28XXXXX@195.64.217.115;user=phone>;tag=as13260d5d
Call-ID: 1BD7818D263914C6FE97462877D82ECC
CSeq: 1 INVITE
Server: FPBX-12.0.1rc34(11.7.0)
Content-Type: applica
Re: peer не даёт работать user`у
Поставить peer & insecure=invite
ubnt
Сообщение ubnt »
type=peer
secret=XXXXXXX
username=907661
host=sip6.ural.net
fromuser=2XXXXXX
fromdomain=sip6.ural.net
canreinvite=no
nat=force_rport,comedia
context=from-internal
insecure=invite,port
ubnt
Сообщение ubnt »
Вообщем провайдер неправильные настройки продиктовал. peer + user, а не friend.
Обращайтесь к провайдеру, пусть помогает своему клиенту.
ubnt
Сообщение ubnt »
Да спасибо он "помог" уже утверждая что должен быть friend, а не peer + user.
lk29
Сообщение lk29 »
мессага старая но
чем закончилось то ?
просто чел Коневекс счас недоступен
а трабла та-же
603 буть она не ладна
Видимо поставили
и всё поехало.
