Неправильно определяется extension при входящих
ubnt
Сообщение ubnt »
[2014-10-30 13:42:31] NOTICE[1649][C-00000065]: chan_sip.c:25450 handle_request_invite: Call from '907661' (195.64.217.115:5060) to extension 's' rejected because extension not found in context 'incoming'.
Scheduling destruction of SIP dialog '946C6723CC64FCB1C0864DD560077AC0' in 6400 ms (Method: INVITE)
<--- SIP read from UDP:195.64.217.115:5060 --->
ACK sip:s@10.45.1.13:5060 SIP/2.0
Via: SIP/2.0/UDP 195.64.217.115:5060;rport;branch=z9hG4bK-2617757359-3826323552-620784798-39323690401
Via: SIP/2.0/UDP 195.64.217.115:5061;rport=5061;branch=z9hG4bK-2617757359-3826323552-620784798-3932369040;received=195.64.217.115
From: <sip:917xxxxxxx@195.64.217.115:5061;user=phone>;tag=4277913519-3826323552-620784798-3932369040
To: <sip:28ххххх@195.64.217.115;user=phone>;tag=as22242dac
Call-ID: 946C6723CC64FCB1C0864DD560077AC0
CSeq: 1 ACK
Contact: <sip:9172237053@195.64.217.115:5060>
User-Agent: TS-v4.5.1-17W
--- (11 headers 0 lines) ---
Really destroying SIP dialog '946C6723CC64FCB1C0864DD560077AC0' Method: ACK
Really destroying SIP dialog '735401726d5011453f49d76b4815d6a4@127.0.1.1' Method: REGISTER
Really destroying SIP dialog '3032ea1778ffff5e49e2f3c42b8aaf43@127.0.1.1' Method: REGISTER
Really destroying SIP dialog '04447645764229d94c351e03728ec251@127.0.1.1' Method: REGISTER
Really destroying SIP dialog '04fc9d506e0613cc1eadc348427625a9@127.0.1.1' Method: REGISTER
Really destroying SIP dialog '3dad53410020627e168fb63240d01ddf@127.0.1.1' Method: REGISTER
Really destroying SIP dialog '568277ca2371493b0852a4810572dfb7@127.0.1.1' Method: REGISTER
[ext-did-0002]
include => ext-did-0002-custom
exten => fax,1,Goto(${CUT(FAX_DEST,^,1)},${CUT(FAX_DEST,^,2)},${CUT(FAX_DEST,^,3)})
exten => _791XXXXXXXX,1,Set(__FROM_DID=${EXTEN})
exten => _791XXXXXXXX,n,Gosub(app-blacklist-check,s,1())
exten => _791XXXXXXXX,n,Set(CDR(did)=${FROM_DID})
exten => _791XXXXXXXX,n,ExecIf($[ "${CALLERID(name)}" = "" ] ?Set(CALLERID(name)=${CALLERID(num)}))
exten => _791XXXXXXXX,n,Set(CHANNEL(musicclass)=default)
exten => _791XXXXXXXX,n,Set(__MOHCLASS=default)
exten => _791XXXXXXXX,n,GotoIf($["${__REVERSAL_REJECT}"="TRUE" & "${CHANNEL(reversecharge)}"="1" ]?macro-hangupcall)
exten => _791XXXXXXXX,n,Set(__CALLINGPRES_SV=${CALLERPRES()})
exten => _791XXXXXXXX,n,Set(CALLERPRES()=allowed_not_screened)
exten => _791XXXXXXXX,n(dest-ext),Goto(from-did-direct,200,1)
И естественно занято.
ubnt
Re: Неправильно определяется extension при входящих
Сообщение ubnt »
[200]
deny=0.0.0.0/0.0.0.0
secret=xxxxxxx
dtmfmode=rfc2833
canreinvite=yes
context=from-internal
trustrpid=no
sendrpid=no
nat=force_rport,comedia
port=5060
qualifyfreq=60
transport=udp,tcp,tls
avpf=no
force_avp=no
icesupport=no
encryption=no
callgroup=
pickupgroup=
dial=SIP/200
mailbox=200@device
permit=0.0.0.0/0.0.0.0
callerid=Director <200>
callcounter=yes
faxdetect=no
cc_monitor_policy=generic
[2860356trunk]
host=external.ru
secret=xxxxxxx
defaultuser=907661
fromuser=2800000
fromdomain=external.ru
canreinvite=no
context=incoming
insecure=invite,port
Ни на какие мысли не наводит?
ubnt
Сообщение ubnt »
Наводит, почему не видится номер на который идет звонок? 907661 это имя пользователя.
Или это внешний номер?
Последний раз редактировалось ubnt 30 окт 2014, 12:23, всего редактировалось 1 раз.
покажите строку регистрации
ubnt
Сообщение ubnt »
register=28xxxxx@external.ru:mypassword:907661@external.ru:5060
ubnt
Сообщение ubnt »
DID нет же :(
register=28xxxxx@external.ru:mypassword:907661@external.ru:5060/бат-тут-нут-гду-номер?
номера то нету
SolarW писал(а):Call from '907661' (195.64.217.115:5060) to extension 's' rejected because extension not found in context 'incoming'.
Блин, перевод с английского, дорого.
Вызов с 907661 на экстеншин 's' сброшен потому как этот екстеншин 's' нифига не найден в контексте 'incoming' куда вы сваливаете свои входящие.
Проверяйте свой контекст 'incoming' со всеми инклюдами.
... а ищет extension 's' тащемта когда
без 0/бат-тут-нут-гду-номер
