Не работают внутренние звонки на FreePBX
ubnt
Сообщение ubnt »
<--- SIP read from UDP:10.45.1.244:5060 --->
INVITE sip:777@10.45.1.22 SIP/2.0
Via: SIP/2.0/UDP 10.45.1.244:5060;branch=z9hG4bK731807976;rport
From: "Иванов Р.Р." <sip:200@10.45.1.22>;tag=968444042
To: <sip:777@10.45.1.22>
Call-ID: 1182619293-5060-12@BA.CD.B.CEE
CSeq: 110 INVITE
Contact: "Иванов Р.Р." <sip:200@10.45.1.244:5060>
X-Grandstream-PBX: true
User-Agent: Grandstream GXP2160 1.0.1.6
Privacy: none
P-Preferred-Identity: "Иванов Р.Р." <sip:200@10.45.1.22>
Supported: replaces, path, timer
Allow: INVITE, ACK, OPTIONS, CANCEL, BYE, SUBSCRIBE, NOTIFY, INFO, REFER, UPDATE, MESSAGE
Accept: application/sdp, application/dtmf-relay
Content-Length: 330
v=0
o=200 8000 8000 IN IP4 10.45.1.244
s=SIP Call
c=IN IP4 10.45.1.244
t=0 0
m=audio 5004 RTP/AVP 0 8 18 9 2 101
a=sendrecv
a=rtpmap:0 PCMU/8000
a=ptime:20
a=rtpmap:8 PCMA/8000
a=rtpmap:18 G729/8000
a=fmtp:18 annexb=no
a=rtpmap:9 G722/8000
a=rtpmap:2 G726-32/8000
a=fmtp:101 0-15
--- (17 headers 16 lines) ---
Sending to 10.45.1.244:5060 (no NAT)
Using INVITE request as basis request - 1182619293-5060-12@BA.CD.B.CEE
Found peer '200' for '200' from 10.45.1.244:5060
<--- Reliably Transmitting (no NAT) to 10.45.1.244:5060 --->
SIP/2.0 401 Unauthorized
Via: SIP/2.0/UDP 10.45.1.244:5060;branch=z9hG4bK731807976;received=10.45.1.244;rport=5060
To: <sip:777@10.45.1.22>;tag=as39fc4c24
CSeq: 110 INVITE
Server: FPBX-12.0.1rc34(11.7.0)
WWW-Authenticate: Digest algorithm=MD5, realm="asterisk", nonce="776c60aa"
Scheduling destruction of SIP dialog '1182619293-5060-12@BA.CD.B.CEE' in 6400 ms (Method: INVITE)
ACK sip:777@10.45.1.22 SIP/2.0
CSeq: 110 ACK
--- (7 headers 0 lines) ---
Via: SIP/2.0/UDP 10.45.1.244:5060;branch=z9hG4bK807213145;rport
CSeq: 111 INVITE
Authorization: Digest username="200", realm="asterisk", nonce="776c60aa", uri="sip:777@10.45.1.22", response="90fa28eb34bf39b542e23297e46ef4fc", algorithm=MD5
Privacy: none
Content-Length: 330
v=0
s=SIP Call
t=0 0
a=sendrecv
a=ptime:20
a=fmtp:18 annexb=no
a=fmtp:101 0-15
--- (18 headers 16 lines) ---
  == Using SIP RTP TOS bits 184
Found RTP audio format 0
Found RTP audio format 8
Found RTP audio format 18
Found RTP audio format 9
Found RTP audio format 2
Found RTP audio format 101
Found audio description format G722 for ID 9
Found audio description format G726-32 for ID 2
Capabilities: us - (gsm|ulaw|alaw|g726|g729|g722), peer - audio=(ulaw|alaw|g726|g729|g722)/video=(nothing)/text=(nothing), combined - (ulaw|alaw|g726|g729|g722)
Peer audio RTP is at port 10.45.1.244:5004
Looking for 777 in from-internal (domain 10.45.1.22)
list_route: hop: <sip:200@10.45.1.244:5060>
<--- Transmitting (no NAT) to 10.45.1.244:5060 --->
SIP/2.0 100 Trying
Via: SIP/2.0/UDP 10.45.1.244:5060;branch=z9hG4bK807213145;received=10.45.1.244;rport=5060
CSeq: 111 INVITE
Session-Expires: 1800;refresher=uas
Contact: <sip:777@10.45.1.22:5060>
    -- Executing [777@from-internal:1] Set("SIP/200-00000006", "__RINGTIMER=15") in new stack
    -- Executing [777@from-internal:2] Macro("SIP/200-00000006", "exten-vm,novm,777,0,0,0") in new stack
    -- Executing [s@macro-exten-vm:1] Macro("SIP/200-00000006", "user-callerid,") in new stack
    -- Executing [s@macro-user-callerid:1] Set("SIP/200-00000006", "TOUCH_MONITOR=1414584412.6") in new stack
    -- Executing [s@macro-user-callerid:2] Set("SIP/200-00000006", "AMPUSER=200") in new stack
    -- Executing [s@macro-user-callerid:3] GotoIf("SIP/200-00000006", "0?report") in new stack
    -- Executing [s@macro-user-callerid:4] ExecIf("SIP/200-00000006", "1?Set(REALCALLERIDNUM=200)") in new stack
    -- Executing [s@macro-user-callerid:5] Set("SIP/200-00000006", "AMPUSER=200") in new stack
    -- Executing [s@macro-user-callerid:6] GotoIf("SIP/200-00000006", "0?limit") in new stack
    -- Executing [s@macro-user-callerid:7] Set("SIP/200-00000006", "AMPUSERCIDNAME=Иванов РР") in new stack
    -- Executing [s@macro-user-callerid:8] GotoIf("SIP/200-00000006", "0?report") in new stack
    -- Executing [s@macro-user-callerid:9] Set("SIP/200-00000006", "AMPUSERCID=200") in new stack
    -- Executing [s@macro-user-callerid:10] Set("SIP/200-00000006", "__DIAL_OPTIONS=Ttr") in new stack
    -- Executing [s@macro-user-callerid:11] Set("SIP/200-00000006", "CALLERID(all)="Иванов РР" <200>") in new stack
    -- Executing [s@macro-user-callerid:12] GotoIf("SIP/200-00000006", "0?limit") in new stack
    -- Executing [s@macro-user-callerid:13] ExecIf("SIP/200-00000006", "0?Set(GROUP(concurrency_limit)=200)") in new stack
[2014-10-29 17:06:52] WARNING[4069][C-00000006]: pbx.c:4878 pbx_extension_helper: No application 'GosubIf' for extension (macro-user-callerid, s, 14)
  == Spawn extension (macro-user-callerid, s, 14) exited non-zero on 'SIP/200-00000006' in macro 'user-callerid'
  == Spawn extension (macro-exten-vm, s, 1) exited non-zero on 'SIP/200-00000006' in macro 'exten-vm'
  == Spawn extension (from-internal, 777, 2) exited non-zero on 'SIP/200-00000006'
    -- Executing [h@from-internal:1] Hangup("SIP/200-00000006", "") in new stack
  == Spawn extension (from-internal, h, 1) exited non-zero on 'SIP/200-00000006'
SIP/2.0 603 Declined
To: <sip:777@10.45.1.22>;tag=as0878f765
CSeq: 111 INVITE
Content-Length: 0ч
CSeq: 111 ACK
Really destroying SIP dialog '1182619293-5060-12@BA.CD.B.CEE' Method: ACK
Reliably Transmitting (no NAT) to 10.45.1.244:5060:
OPTIONS sip:200@10.45.1.244:5060 SIP/2.0
Via: SIP/2.0/UDP 10.45.1.22:5060;branch=z9hG4bK70a2ae9d
From: "Unknown" <sip:Unknown@10.45.1.22>;tag=as5944720f
To: <sip:200@10.45.1.244:5060>
Contact: <sip:Unknown@10.45.1.22:5060>
Call-ID: 322d7eed1638af6b129167de4cb59607@10.45.1.22:5060
CSeq: 102 OPTIONS
User-Agent: FPBX-12.0.1rc34(11.7.0)
Date: Wed, 29 Oct 2014 12:07:30 GMT
SIP/2.0 200 OK
To: <sip:200@10.45.1.244:5060>;tag=1614249780
CSeq: 102 OPTIONS
--- (10 headers 0 lines) ---
Really destroying SIP dialog '322d7eed1638af6b129167de4cb59607@10.45.1.22:5060' Method: OPTIONS
Reliably Transmitting (no NAT) to 10.45.1.243:5060:
OPTIONS sip:777@10.45.1.243:5060 SIP/2.0
Via: SIP/2.0/UDP 10.45.1.22:5060;branch=z9hG4bK3355f355
From: "Unknown" <sip:Unknown@10.45.1.22>;tag=as0232e4eb
To: <sip:777@10.45.1.243:5060>
Call-ID: 0abc6cf7205e3790571dfa9114314276@10.45.1.22:5060
CSeq: 102 OPTIONS
<--- SIP read from UDP:10.45.1.243:5060 --->
SIP/2.0 200 OK
To: <sip:777@10.45.1.243:5060>;tag=363064525
CSeq: 102 OPTIONS
Really destroying SIP dialog '0abc6cf7205e3790571dfa9114314276@10.45.1.22:5060' Method: OPTIONS
Via: SIP/2.0/UDP 10.45.1.22:5060;branch=z9hG4bK1fd0ba75
From: "Unknown" <sip:Unknown@10.45.1.22>;tag=as07c1e9cb
Call-ID: 7a36e34018a775c274dc9b82303897d9@10.45.1.22:5060
CSeq: 102 OPTIONS
Date: Wed, 29 Oct 2014 12:08:30 GMT
SIP/2.0 200 OK
To: <sip:200@10.45.1.244:5060>;tag=1251556395
CSeq: 102 OPTIONS
Really destroying SIP dialog '7a36e34018a775c274dc9b82303897d9@10.45.1.22:5060' Method: OPTIONS
Via: SIP/2.0/UDP 10.45.1.22:5060;branch=z9hG4bK75ec2817
From: "Unknown" <sip:Unknown@10.45.1.22>;tag=as5577697c
Call-ID: 22fb6db2453f0a960b1c1f17035434df@10.45.1.22:5060
CSeq: 102 OPTIONS
SIP/2.0 200 OK
To: <sip:777@10.45.1.243:5060>;tag=1884975987
CSeq: 102 OPTIONS
Re: Не работают внутренние звонки на FreePBX
Вызов прервался неожидаемо на обработке макроса user-callerid
что означает, что скорее всего Вы "Иванов Р.Р." <sip:200@10.45.1.22> покурочили диалплан вручную.
ubnt
Сообщение ubnt »
module load app_stack помогло. Буду искать в логах почему он упал.
ded писал(а):что означает, что скорее всего Вы "Иванов Р.Р." <sip:200@10.45.1.22> покурочили диалплан вручную.
Не, это тихо и без объявления войны в FreePBX 2.11 / 2.12 можно стало Display name на русском указывать (не прошло и ста лет).
Раньше для этого приходилось вручную выпиливать проверку чтобы вводимые в этом поле символы были AlphaNumeric
Дык, я не о том! Апликация GosubIf из macro-user-callerid сама не могла же удалиться?
ubnt
Сообщение ubnt »
exten => s,n,GosubIf($[${LEN(${DB(AMPUSER/${AMPUSER}/ccss/cc_agent_policy)})} & "${DB(AMPUSER/${AMPUSER}/ccss/cc_agent_policy)}" != "never"]?sub-ccss,s,1(${MACRO_CONTEXT},${CALLERID(dnid)}))
Так она на месте и почему module load app_stack помогает, а добавление "load app_stack.so" в modules.conf нет?
Хотя... Сейчас глянем зависимости.
ubnt
Сообщение ubnt »
https://bugs.launchpad.net/ubuntu/+sour ... ug/1314058
:lol: :x
Вот называется и не захотел делать слаку :(
ubnt
Сообщение ubnt »
Кстати, а почему он в дистрибутивах такой кривой? Вроде ничего особенного в сборке нет. А что в ubuntu, что в debian ругают их пакеты астериска. Ставить шлимазловскую сборку? Но я терпеть не могу такие зверьвдв линуксы. Неужели теперь руками или скриптом обновления делать?
ubnt писал(а): Ставить шлимазловскую сборку?
Что мешает сделать свою, гойскую сборку?
ubnt
Сообщение ubnt »
Это если только свой реп тащить, но никак не сборку.
