Перестали ходить звонки *->SIP->TDE200->E1
D9thc
Сообщение D9thc »
Дано:
в одной локалке Asterisk 11.6.0 - SIPGW16 - TDE200 - E1
Нумерация: * - 3XX; TDE200 - [12]XX
sip.conf
context=default
allowguest=no
allowoverlap=no
udpbindaddr=10.98.0.240
externip=***********
tcpenable=no
transport=udp
srvlookup=yes
language=ru
progressinband=yes
dtmfmode=auto
alwaysauthreject=yes
rtptimeout=600
rtpholdtimeout=600
t38pt_udptl=yes
callcounter=yes
notifyhold=yes
pedantic=no
directmedia=nonat
[sip-phone](!) ;template
context=dialplan
canreinvite=no
; define device
[309](sip-phone)
secret=************
nat=no
и т.д.
[panastde200]
t38pt_udptl=yes
username=panastde200
secret=**************
context=dialplan
callerid="Office" <Office>
insecure = port,invite
port=35060
dtmfmode=rfc2833
canreinvite=no
nat=no
call-limit=16
extensions.conf
static=yes
writeprotect=no
clearglobalvars=no
[globals]
[dialplan]
exten => _3XX,1,Dial(SIP/${EXTEN},90,tT)
exten => _3XX,2,Hangup()
exten => _[12]XX,1,Dial(SIP/panastde200/${EXTEN},90,tT)
exten => _[27]XXXXXX,1,Dial(SIP/panastde200/${EXTEN},90,tT)
какое-то время все работало.... и вот:
-- Executing [7330642@dialplan:1] Dial("SIP/309-0000002e", "SIP/panastde200/7330642,90,tT") in new stack
Audio is at 16544
Reliably Transmitting (no NAT) to 10.98.0.200:35060:
INVITE sip:7330642@10.98.0.200:35060 SIP/2.0
Via: SIP/2.0/UDP 10.98.0.240:5060;branch=z9hG4bK08d9153e
To: <sip:7330642@10.98.0.200:35060>
Contact: <sip:309@10.98.0.240:5060>
Call-ID: 06e0c21633ec597b2b08e5ad7b1644d1@10.98.0.240:5060
CSeq: 102 INVITE
User-Agent: Asterisk PBX 11.6.0
Date: Fri, 24 Oct 2014 03:34:45 GMT
Content-Length: 229
v=0
o=root 79616740 79616740 IN IP4 10.98.0.240
s=Asterisk PBX 11.6.0
c=IN IP4 10.98.0.240
t=0 0
m=audio 16544 RTP/AVP 8 101
a=rtpmap:8 PCMA/8000
a=fmtp:101 0-16
a=ptime:20
a=sendrecv
-- Called SIP/panastde200/7330642
<--- SIP read from UDP:10.98.0.200:35060 --->
SIP/2.0 100 Trying
To: sip:7330642@10.98.0.200
CSeq: 102 INVITE
--- (7 headers 0 lines) ---
INVITE sip:330642@10.98.0.240 SIP/2.0
Via: SIP/2.0/UDP 10.98.0.200:35060;branch=z9hG4bK000019fc;rport
To: sip:330642@10.98.0.240
Call-ID: 00005c16-c2f67bde3eed100084100080f0d50c68@10.98.0.200
CSeq: 1 INVITE
Contact: sip:panastde200@10.98.0.200:35060
Supported: timer,100rel
Session-Expires: 600
Allow: INVITE,ACK,CANCEL,BYE,PRACK,OPTIONS,REGISTER,INFO,UPDATE
User-Agent: Panasonic-MPR08-V4.2003/VSIPGW-V2.3001
Content-Length: 264
v=0
o=- 1 1 IN IP4 10.98.0.201
s=-
c=IN IP4 10.98.0.201
t=0 0
m=audio 12132 RTP/AVP 8 0 18 101
a=rtpmap:8 PCMA/8000/1
a=rtpmap:0 PCMU/8000/1
a=rtpmap:18 G729/8000/1
a=fmtp:101 0-15
a=sendrecv
a=ptime:20
a=rtcp:12133
--- (14 headers 14 lines) ---
Sending to 10.98.0.200:35060 (no NAT)
Using INVITE request as basis request - 00005c16-c2f67bde3eed100084100080f0d50c68@10.98.0.200
Found peer '309' for '309' from 10.98.0.200:35060
<--- Reliably Transmitting (no NAT) to 10.98.0.200:35060 --->
SIP/2.0 401 Unauthorized
Via: SIP/2.0/UDP 10.98.0.200:35060;branch=z9hG4bK000019fc;received=10.98.0.200;rport=35060
To: sip:330642@10.98.0.240;tag=as466ddda0
CSeq: 1 INVITE
Server: Asterisk PBX 11.6.0
WWW-Authenticate: Digest algorithm=MD5, realm="asterisk", nonce="4798db4a"
Scheduling destruction of SIP dialog '00005c16-c2f67bde3eed100084100080f0d50c68@10.98.0.200' in 6464 ms (Method: INVITE)
ACK sip:330642@10.98.0.240 SIP/2.0
CSeq: 1 ACK
--- (8 headers 0 lines) ---
Via: SIP/2.0/UDP 10.98.0.200:35060;branch=z9hG4bK00003d91;rport
CSeq: 2 INVITE
Authorization: Digest realm="asterisk", nonce="4798db4a", algorithm=MD5, uri="sip:330642@10.98.0.240", username="panastde200", response="5f5df7531c0b314f3febeff1bca5ccf2"
Content-Length: 264
v=0
s=-
t=0 0
a=fmtp:101 0-15
a=sendrecv
a=ptime:20
a=rtcp:12133
--- (15 headers 14 lines) ---
[2014-10-24 09:34:45] WARNING[2809][C-00000139]: chan_sip.c:16376 check_auth: username mismatch, have <309>, digest has <panastde200>
[2014-10-24 09:34:45] NOTICE[2809][C-00000139]: chan_sip.c:25300 handle_request_invite: Failed to authenticate device sip:309@10.98.0.240;tag=23504
SIP/2.0 403 Forbidden
Via: SIP/2.0/UDP 10.98.0.200:35060;branch=z9hG4bK00003d91;received=10.98.0.200;rport=35060
CSeq: 2 INVITE
CSeq: 2 ACK
Authorization: Digest realm="asterisk", nonce="4798db4a", algorithm=MD5, uri="sip:330642@10.98.0.240", username="panastde200", response="bf8ca0348e06103f1f728506db384215"
--- (9 headers 0 lines) ---
To: sip:7330642@10.98.0.200;tag=26085
CSeq: 102 INVITE
Server: Panasonic-MPR08-V4.2003/VSIPGW-V2.3001
ACK sip:7330642@10.98.0.200:35060 SIP/2.0
To: <sip:7330642@10.98.0.200:35060>;tag=26085
CSeq: 102 ACK
[2014-10-24 09:34:45] WARNING[2809][C-00000138]: chan_sip.c:22945 handle_response_invite: Received response: "Forbidden" from '"309" <sip:309@10.98.0.240>;tag=as51e4b644'
Scheduling destruction of SIP dialog '06e0c21633ec597b2b08e5ad7b1644d1@10.98.0.240:5060' in 6400 ms (Method: INVITE)
-- Auto fallthrough, channel 'SIP/309-0000002e' status is 'CHANUNAVAIL'
Really destroying SIP dialog '06e0c21633ec597b2b08e5ad7b1644d1@10.98.0.240:5060' Method: INVITE
Really destroying SIP dialog '00005c16-c2f67bde3eed100084100080f0d50c68@10.98.0.200' Method: ACK
OPTIONS sip:panastde200@10.98.0.200:35060 SIP/2.0
Via: SIP/2.0/UDP 10.98.0.240:5060;branch=z9hG4bK12e1d311
From: "asterisk" <sip:asterisk@10.98.0.240>;tag=as34ace2dd
To: <sip:panastde200@10.98.0.200:35060>
Contact: <sip:asterisk@10.98.0.240:5060>
Call-ID: 1308c74f138b5aca0f2bb8ac2c4705f7@10.98.0.240:5060
CSeq: 102 OPTIONS
Date: Fri, 24 Oct 2014 03:34:52 GMT
SIP/2.0 200 OK
To: sip:panastde200@10.98.0.200;tag=3976
CSeq: 102 OPTIONS
Contact: sip:10.98.0.200:35060
Accept-Encoding: *
Accept-Language: *
--- (12 headers 0 lines) ---
Really destroying SIP dialog '1308c74f138b5aca0f2bb8ac2c4705f7@10.98.0.240:5060' Method: OPTIONS
Смущает - куда делась первая семерка в номере????
Помогите разобраться.
Re: Перестали ходить звонки *->SIP->TDE200->E1
TDE200 пытается вызвать 330642 на астериске
Вот что точно смущает, так это полное отсутствие оформления вашего сообщения. Рулон логов без тега CODE и SPOILER.
"Спасибо" что уважаете читающих.
ТС - вообще это безобразие, можно же логи и полные конфиги под спойлер запихивать.. Уважайте всех, кто это вынужден читать..
Вам нужно добавить для пира параметр
fromuser=panastde200
Также малость неверно
Если пир с регистрацией - тогда нужно это убрать.
Вообще же сама схема немного ущербна, TDE не в состоянии делать полный транзит. Правильнее Астер подключать к ТфОП E1, а за ним уже и TDE.
D9thc
Сообщение D9thc »
Над оформлением - конечно извиняюсь...
Не понял куда нужно добавить ?
В sip.conf
[309](sip-phone)
secret=************
nat=no
D9thc, вот вы выложили SIP dump, вам указали на строчки, на которые стоит обратить внимание.
Разворачиваем (уже спойлер), тупо жмем CTRL+F и вбиваем в поиск panastde200 и смотрим что подсвечено. Там можно разглядеть:
CSeq: 2 INVITE
Если зайти в гугл и вбить туда username mismatch digest has можно получить инфу о том что это и как с этим жить.
virus_net, смотрим схему в заголовке темы
D9thc, вы кидаете вызов на TDE она пытается вам его обратно отправить на астериск, т.к. нет маршрута на E1
Vlad1983, честно, даже не смотрел. Ибо надоело.
Если ТС изначально не утруждается даже над оформлением своего поста, то ИМХО считаю это полным неуважением к тем кто потенциально должен помогать. Всем некогда, всем срочно и абы как.
Если они не вникают, то почему я должен ?
virus_net, не вникаете? не надо?
идите мимо!
от вас мусора больше чет от таких постов.
D9thc писал(а): Не понял куда нужно добавить ?
Конечно в пир [panastde200]
еще стоит наверное там использовать sendrpid=yes
и убрать insecure=port,invite, а также callerid
также username давно уже defaultuser, поправил ниже
итого:
[panastde200]
t38pt_udptl=yes
defaultuser=panastde200
context=dialplan
port=35060
dtmfmode=rfc2833
canreinvite=no
directmedia=no
sendrpid=yes
nat=no
call-limit=16
