Everyone is busy/congested at this time (1:0/1/0)"
terra2039
Сообщение terra2039 »
Система slackware 13.1 астериск 1.6. Астериск стоит за натом реальника нет. при наборе номера пишет следующее.
Connected to Asterisk 1.6.2.17.2 currently running on asterisk (pid = 10002)
Verbosity is at least 3
    -- Executing [94513260@default:1] NoOp("SIP/10.224.25.14-00000002", ""Starting A-number analysis"") in new stack
    -- Executing [94513260@default:2] MixMonitor("SIP/10.224.25.14-00000002", "/var/record/1.office/call-center/1000-94513260-2011.04.23-10`59`33.wav") in new stack
    -- Executing [94513260@default:3] NoOp("SIP/10.224.25.14-00000002", ""Finishing A-number analysis"") in new stack
    -- Executing [94513260@default:4] Set("SIP/10.224.25.14-00000002", "CALLERID(num)=0029162532") in new stack
    -- Executing [94513260@default:5] Set("SIP/10.224.25.14-00000002", "CALLERID(name)=ast-gotti-gw") in new stack
    -- Executing [94513260@default:6] Dial("SIP/10.224.25.14-00000002", "SIP/4513260@sipnet") in new stack
  == Begin MixMonitor Recording SIP/10.224.25.14-00000002
    -- Called 4513260@sipnet
[Apr 23 10:59:46] WARNING[14119]: chan_sip.c:3828 retrans_pkt: Maximum retries exceeded on transmission 477177d424d4d22d4acd9df0179eef00@sipnet.ru for seqno 102 (Critical Request) -- See doc/sip-retransmit.txt.
[Apr 23 10:59:46] WARNING[14119]: chan_sip.c:3855 retrans_pkt: Hanging up call 477177d424d4d22d4acd9df0179eef00@sipnet.ru - no reply to our critical packet (see doc/sip-retransmit.txt).
    -- Executing [94513260@default:7] Hangup("SIP/10.224.25.14-00000002", "") in new stack
  == Spawn extension (default, 94513260, 7) exited non-zero on 'SIP/10.224.25.14-00000002'
  == End MixMonitor Recording SIP/10.224.25.14-00000002
sip.conf
register = @sipnet.ru
bindport = 5060
bindaddr = 0.0.0.0
context   = default
allowguest = yes
allowoverlap = yes
;realm = fantasyworld
srvlookup = yes
language = ru
udpbindaddr = 0.0.0.0
[authentication]
[sipnet]
insecure=invite
username=
secret=
host=sipnet.ru
fromuser=
fromdomain=sipnet.ru
port=5060
dtmfmode=rfc2833
canreinvite=no
        [1000]
        context=localAndPSTAndMobileAndLD
        type-friend
        username=1000
        secret=148125
        nat=yes
        allow=all
        callerid="IT Crowd"
        callgroup=1
        pickgroup=1
        language=ru
        canreinvite=yes
        mailbox=1000@fantasyworld.ru,1000
extensions.conf
    priorityjumping=yes
    static=yes
    writeprotect=no
    autofallthrough=yes
    clearglobalvars=no
[globals]
    DYNAMIC_FEATURES=automon
[default]
    include => 0029162532
    include => city-in
    include => LocalAndFree
    include => LocalAndPSTN
    include => LocalAndPSTNAndMobile
    include => LocalOnly
[LocalOnly]
[city-in]
    exten => s,1,Answer
    exten => s,2,Set(TIMEOUT(digit)=5)
    exten => s,3,Set(TIMEOUT(response)=10)
    exten => s,4,BackGround(gotti/gotti-welcome)
    exten => s,5,WaitExten(8)
    exten => s,6,GotoIfTime(8:00-20:00|*|*|*?0029162532,s,9)
    exten => s,7,Dial(SIP/1999,300,otmw)
    exten => s,8,Goto(14)
    exten => s,9,Dial(SIP/1001,10,otmw)
    exten => s,10,Dial(SIP/1002,10,otmw)
    exten => s,11,Dial(SIP/1003,10,otmw)
    exten => s,12,Dial(SIP/1004,10,otmw)
    exten => s,13,Dial(SIP/1005,10,otmw)
    exten => s,14,Hangup
    exten => i,1,GotoIfTime(8:00-20:00|*|*|*?0029162532,i,4)
    exten => i,2,Dial(SIP/1999,300,otmw)
    exten => i,3,Goto(9)
    exten => i,4,Dial(SIP/1001,10,otmw)
    exten => i,5,Dial(SIP/1002,10,otmw)
    exten => i,6,Dial(SIP/1003,10,otmw)
    exten => i,7,Dial(SIP/1004,10,otmw)
    exten => i,8,Dial(SIP/1005,10,otmw)
    exten => i,9,Hangup
    exten => _XXXX,1,Goto(LocalAndPSTNAndMobileAndLD,${EXTEN},1)
[0029162532]
    exten => s,1,Answer
    exten => i,9,Hangup
[LocalAndFree]
    exten => _98800XXXXXXX,1,Set(CALLERID(num)=0029162532)
    exten => _98800XXXXXXX,2,Set(CALLERID(name)=ast-gotti-gw)
    exten => _98800XXXXXXX,3,Dial(SIP/${EXTEN:1}@sipnet,300,Wj)
    exten => _98800XXXXXXX,4,Hangup
    exten => _98800XXXXXXX,104,Playback(gotti/out_line_busy)
    exten => _98800XXXXXXX,105,Hangup
    exten => _98810XXXXXXX,1,Set(CALLERID(num)=0029162532)
    exten => _98810XXXXXXX,2,Set(CALLERID(name)=ast-gotti-gw)
    exten => _98810XXXXXXX,3,Dial(SIP/${EXTEN:1}@sipnet,300,Wj)
    exten => _98810XXXXXXX,4,Hangup
    exten => _98810XXXXXXX,104,Playback(gotti/out_line_busy)
    exten => _98810XXXXXXX,105,Hangup
[LocalAndPSTN]
    exten => _9XXXXXXX,1,NoOP("Starting A-number analysis")
    exten => _9XXXXXXX/_100X,2,MixMonitor(/var/record/1.office/call-center/${CALLERID(num)}-${EXTEN}-${STRFTIME(${EPOCH},,%Y.%m.%d-%H`%M`%S)}.wav)
    exten => _9XXXXXXX/_101X,2,MixMonitor(/var/record/1.office/head/${CALLERID(num)}-${EXTEN}-${STRFTIME(${EPOCH},,%Y.%m.%d-%H`%M`%S)}.wav)
    exten => _9XXXXXXX/_102X,2,MixMonitor(/var/record/1.office/fin/${CALLERID(num)}-${EXTEN}-${STRFTIME(${EPOCH},,%Y.%m.%d-%H`%M`%S)}.wav)
    exten => _9XXXXXXX/_103X,2,MixMonitor(/var/record/1.office/buh/${CALLERID(num)}-${EXTEN}-${STRFTIME(${EPOCH},,%Y.%m.%d-%H`%M`%S)}.wav)
    exten => _9XXXXXXX/_110X,2,MixMonitor(/var/record/1.office/orp/${CALLERID(num)}-${EXTEN}-${STRFTIME(${EPOCH},,%Y.%m.%d-%H`%M`%S)}.wav)
    exten => _9XXXXXXX/_111X,2,MixMonitor(/var/record/1.office/okp/${CALLERID(num)}-${EXTEN}-${STRFTIME(${EPOCH},,%Y.%m.%d-%H`%M`%S)}.wav)
    exten => _9XXXXXXX/_112X,2,MixMonitor(/var/record/1.office/okp/${CALLERID(num)}-${EXTEN}-${STRFTIME(${EPOCH},,%Y.%m.%d-%H`%M`%S)}.wav)
    exten => _9XXXXXXX/_120X,2,MixMonitor(/var/record/1.office/postavki/${CALLERID(num)}-${EXTEN}-${STRFTIME(${EPOCH},,%Y.%m.%d-%H`%M`%S)}.wav)
    exten => _9XXXXXXX/_130X,2,NoOP("No record for IT")
    exten => _9XXXXXXX/_131X,2,NoOP("No record for arenda")
    exten => _9XXXXXXX/_140X,2,MixMonitor(/var/record/1.office/marketing/${CALLERID(num)}-${EXTEN}-${STRFTIME(${EPOCH},,%Y.%m.%d-%H`%M`%S)}.wav)
    exten => _9XXXXXXX/_150X,2,MixMonitor(/var/record/1.office/e-shop/${CALLERID(num)}-${EXTEN}-${STRFTIME(${EPOCH},,%Y.%m.%d-%H`%M`%S)}.wav)
    exten => _9XXXXXXX/_160X,2,MixMonitor(/var/record/1.office/hr/${CALLERID(num)}-${EXTEN}-${STRFTIME(${EPOCH},,%Y.%m.%d-%H`%M`%S)}.wav)
    exten => _9XXXXXXX/_199X,2,MixMonitor(/var/record/1.office/secure/${CALLERID(num)}-${EXTEN}-${STRFTIME(${EPOCH},,%Y.%m.%d-%H`%M`%S)}.wav)
    exten => _9XXXXXXX/_2XXX,2,MixMonitor(/var/record/2.service/${CALLERID(num)}-${EXTEN}-${STRFTIME(${EPOCH},,%Y.%m.%d-%H`%M`%S)}.wav)
    exten => _9XXXXXXX/_3XXX,2,MixMonitor(/var/record/3.sclad/${CALLERID(num)}-${EXTEN}-${STRFTIME(${EPOCH},,%Y.%m.%d-%H`%M`%S)}.wav)
    exten => _9XXXXXXX/_4XXX,2,MixMonitor(/var/record/4.bonanza/${CALLERID(num)}-${EXTEN}-${STRFTIME(${EPOCH},,%Y.%m.%d-%H`%M`%S)}.wav)
    exten => _9XXXXXXX/_5XXX,2,MixMonitor(/var/record/5.podsolnuh/${CALLERID(num)}-${EXTEN}-${STRFTIME(${EPOCH},,%Y.%m.%d-%H`%M`%S)}.wav)
    exten => _9XXXXXXX,3,NoOP("Finishing A-number analysis")
    exten => _9XXXXXXX,4,Set(CALLERID(num)=0029162532)
    exten => _9XXXXXXX,5,Set(CALLERID(name)=ast-gotti-gw)
    exten => _9XXXXXXX,6,Dial(SIP/${EXTEN:1}@sipnet)
    exten => _9XXXXXXX,7,Hangup
    exten => _9XXXXXXX,107,Playback(gotti/out_line_busy)
    exten => _9XXXXXXX,108,Hangup
[LocalAndPSTNAndMobile]
    exten => _989XXXXXXXXX,1,NoOP("Starting A-number analysis")
    exten => _989XXXXXXXXX/_100X,2,MixMonitor(/var/record/1.office/call-center/${CALLERID(num)}-${EXTEN}-${STRFTIME(${EPOCH},,%Y.%m.%d-%H`%M`%S)}.wav)
    exten => _989XXXXXXXXX/_101X,2,MixMonitor(/var/record/1.office/head/${CALLERID(num)}-${EXTEN}-${STRFTIME(${EPOCH},,%Y.%m.%d-%H`%M`%S)}.wav)
    exten => _989XXXXXXXXX/_102X,2,MixMonitor(/var/record/1.office/fin/${CALLERID(num)}-${EXTEN}-${STRFTIME(${EPOCH},,%Y.%m.%d-%H`%M`%S)}.wav)
    exten => _989XXXXXXXXX/_103X,2,MixMonitor(/var/record/1.office/buh/${CALLERID(num)}-${EXTEN}-${STRFTIME(${EPOCH},,%Y.%m.%d-%H`%M`%S)}.wav)
    exten => _989XXXXXXXXX/_110X,2,MixMonitor(/var/record/1.office/orp/${CALLERID(num)}-${EXTEN}-${STRFTIME(${EPOCH},,%Y.%m.%d-%H`%M`%S)}.wav)
    exten => _989XXXXXXXXX/_111X,2,MixMonitor(/var/record/1.office/okp/${CALLERID(num)}-${EXTEN}-${STRFTIME(${EPOCH},,%Y.%m.%d-%H`%M`%S)}.wav)
    exten => _989XXXXXXXXX/_112X,2,MixMonitor(/var/record/1.office/okp/${CALLERID(num)}-${EXTEN}-${STRFTIME(${EPOCH},,%Y.%m.%d-%H`%M`%S)}.wav)
    exten => _989XXXXXXXXX/_120X,2,MixMonitor(/var/record/1.office/postavki/${CALLERID(num)}-${EXTEN}-${STRFTIME(${EPOCH},,%Y.%m.%d-%H`%M`%S)}.wav)
    exten => _989XXXXXXXXX/_130X,2,NoOP("no record for IT")
    exten => _989XXXXXXXXX/_131X,2,NoOP("no record for arenda")
    exten => _989XXXXXXXXX/_140X,2,MixMonitor(/var/record/1.office/marketing/${CALLERID(num)}-${EXTEN}-${STRFTIME(${EPOCH},,%Y.%m.%d-%H`%M`%S)}.wav)
    exten => _989XXXXXXXXX/_150X,2,MixMonitor(/var/record/1.office/e-shop/${CALLERID(num)}-${EXTEN}-${STRFTIME(${EPOCH},,%Y.%m.%d-%H`%M`%S)}.wav)
    exten => _989XXXXXXXXX/_160X,2,MixMonitor(/var/record/1.office/hr/${CALLERID(num)}-${EXTEN}-${STRFTIME(${EPOCH},,%Y.%m.%d-%H`%M`%S)}.wav)
    exten => _989XXXXXXXXX/_199X,2,MixMonitor(/var/record/1.office/secure/${CALLERID(num)}-${EXTEN}-${STRFTIME(${EPOCH},,%Y.%m.%d-%H`%M`%S)}.wav)
    exten => _989XXXXXXXXX/_2XXX,2,MixMonitor(/var/record/2.service/${CALLERID(num)}-${EXTEN}-${STRFTIME(${EPOCH},,%Y.%m.%d-%H`%M`%S)}.wav)
    exten => _989XXXXXXXXX/_3XXX,2,MixMonitor(/var/record/3.sclad/${CALLERID(num)}-${EXTEN}-${STRFTIME(${EPOCH},,%Y.%m.%d-%H`%M`%S)}.wav)
    exten => _989XXXXXXXXX/_4XXX,2,MixMonitor(/var/record/4.bonanza/${CALLERID(num)}-${EXTEN}-${STRFTIME(${EPOCH},,%Y.%m.%d-%H`%M`%S)}.wav)
    exten => _989XXXXXXXXX/_5XXX,2,MixMonitor(/var/record/5.podsolnuh/${CALLERID(num)}-${EXTEN}-${STRFTIME(${EPOCH},,%Y.%m.%d-%H`%M`%S)}.wav)
    exten => _989XXXXXXXXX,3,NoOP("Finishing A-number analysis")
    exten => _989XXXXXXXXX,4,Set(CALLERID(num)=0029162532)
    exten => _989XXXXXXXXX,5,Set(CALLERID(name)=ast-gotti-gw)
    exten => _989XXXXXXXXX,6,Dial(SIP/${EXTEN:1}@sipnet)
    exten => _989XXXXXXXXX,7,Hangup
    exten => _989XXXXXXXXX,107,Playback(gotti/out_line_busy)
    exten => _989XXXXXXXXX,108,Hangup
[LocalAndPSTNAndMobileAndLD]
    exten => _98XXXXXXXXXX,1,NoOP("Starting A-number analysis")
    exten => _98XXXXXXXXXX/_100X,2,MixMonitor(/var/record/1.office/call-center/${CALLERID(num)}-${EXTEN}-${STRFTIME(${EPOCH},,%Y.%m.%d-%H`%M`%S)}.wav)
    exten => _98XXXXXXXXXX/_101X,2,MixMonitor(/var/record/1.office/head/${CALLERID(num)}-${EXTEN}-${STRFTIME(${EPOCH},,%Y.%m.%d-%H`%M`%S)}.wav)
    exten => _98XXXXXXXXXX/_102X,2,MixMonitor(/var/record/1.office/fin/${CALLERID(num)}-${EXTEN}-${STRFTIME(${EPOCH},,%Y.%m.%d-%H`%M`%S)}.wav)
    exten => _98XXXXXXXXXX/_103X,2,MixMonitor(/var/record/1.office/buh/${CALLERID(num)}-${EXTEN}-${STRFTIME(${EPOCH},,%Y.%m.%d-%H`%M`%S)}.wav)
    exten => _98XXXXXXXXXX/_110X,2,MixMonitor(/var/record/1.office/orp/${CALLERID(num)}-${EXTEN}-${STRFTIME(${EPOCH},,%Y.%m.%d-%H`%M`%S)}.wav)
    exten => _98XXXXXXXXXX/_111X,2,MixMonitor(/var/record/1.office/okp/${CALLERID(num)}-${EXTEN}-${STRFTIME(${EPOCH},,%Y.%m.%d-%H`%M`%S)}.wav)
    exten => _98XXXXXXXXXX/_112X,2,MixMonitor(/var/record/1.office/okp/${CALLERID(num)}-${EXTEN}-${STRFTIME(${EPOCH},,%Y.%m.%d-%H`%M`%S)}.wav)
    exten => _98XXXXXXXXXX/_120X,2,MixMonitor(/var/record/1.office/postavki/${CALLERID(num)}-${EXTEN}-${STRFTIME(${EPOCH},,%Y.%m.%d-%H`%M`%S)}.wav)
    exten => _98XXXXXXXXXX/_130X,2,NoOP("No record for IT")
    exten => _98XXXXXXXXXX/_131X,2,NoOP("No record for arenda")
    exten => _98XXXXXXXXXX/_140X,2,MixMonitor(/var/record/1.office/marketing/${CALLERID(num)}-${EXTEN}-${STRFTIME(${EPOCH},,%Y.%m.%d-%H`%M`%S)}.wav)
    exten => _98XXXXXXXXXX/_150X,2,MixMonitor(/var/record/1.office/e-shop/${CALLERID(num)}-${EXTEN}-${STRFTIME(${EPOCH},,%Y.%m.%d-%H`%M`%S)}.wav)
    exten => _98XXXXXXXXXX/_160X,2,MixMonitor(/var/record/1.office/hr/${CALLERID(num)}-${EXTEN}-${STRFTIME(${EPOCH},,%Y.%m.%d-%H`%M`%S)}.wav)
    exten => _98XXXXXXXXXX/_199X,2,MixMonitor(/var/record/1.office/secure/${CALLERID(num)}-${EXTEN}-${STRFTIME(${EPOCH},,%Y.%m.%d-%H`%M`%S)}.wav)
    exten => _98XXXXXXXXXX/_2XXX,2,MixMonitor(/var/record/2.service/${CALLERID(num)}-${EXTEN}-${STRFTIME(${EPOCH},,%Y.%m.%d-%H`%M`%S)}.wav)
    exten => _98XXXXXXXXXX/_3XXX,2,MixMonitor(/var/record/3.sclad/${CALLERID(num)}-${EXTEN}-${STRFTIME(${EPOCH},,%Y.%m.%d-%H`%M`%S)}.wav)
    exten => _98XXXXXXXXXX/_4XXX,2,MixMonitor(/var/record/4.bonanza/${CALLERID(num)}-${EXTEN}-${STRFTIME(${EPOCH},,%Y.%m.%d-%H`%M`%S)}.wav)
    exten => _98XXXXXXXXXX/_5XXX,2,MixMonitor(/var/record/5.podsolnuh/${CALLERID(num)}-${EXTEN}-${STRFTIME(${EPOCH},,%Y.%m.%d-%H`%M`%S)}.wav)
    exten => _98XXXXXXXXXX,3,NoOP("Finishing A-number analysis")
    exten => _98XXXXXXXXXX,4,Set(CALLERID(num)=0029162532)
    exten => _98XXXXXXXXXX,5,Set(CALLERID(name)=ast-gotti-gw)
    exten => _98XXXXXXXXXX,6,Dial(SIP/${EXTEN:1}@sipnet)
    exten => _98XXXXXXXXXX,7,Hangup
    exten => _98XXXXXXXXXX,107,Playback(gotti/out_line_busy)
    exten => _98XXXXXXXXXX,108,Hangup
Re: Everyone is busy/congested at this time (1:0/1/0)"
Слишком много конфигов. Избыточно ненужная инфа.
Лучше использовать синтаксис
exten => _X.,1,Dial(SIP/sipnet/${EXTEN})
вместо SIP/${EXTEN}@sipnet
А куда мы звоним - Dial("SIP/10.224.25.14-00000002", "SIP/4513260@sipnet") ??
Для анализа лучше включать sip set debug peer sipnet чтобы видеть наши запросы INVITE и SIP ответы на них от sipnet.
А вообще то этот вопрос - разновидность маргинального тупого "Не могу подключиться к sipnetб помогите!"
На некоторых форумах по астериск эта тема приведена разъяснена примерами конфигов и заблокирована навечно.
Ибо если при готовых примерах не удаётся раскурить траблы - надо менять специальность.
terra2039
10.224.25.14 это адрес астера к нему коннектится клиент х-лайт.
ded писал(а):Лучше использовать синтаксис
ded писал(а):Для анализа лучше включать sip set debug peer sipnet чтобы видеть наши запросы INVITE и SIP ответы на них от sipnet.
