Проблема с исходящими звонками.
Alexey_761
Сообщение Alexey_761 »
Мозг успешно сломан :)
Без посторонней помощи не справиться...
Все остальное работает, сип зарегин у провайдера, входящие звонки работают.
В CLI пишет:
Connected to Asterisk 11.10.2 currently running on localhost (pid = 1614)
> Saved useragent "RSIP SP2.0 v2.0" for peer 101
== Using SIP RTP TOS bits 184
-- Executing [904542XXXX@from-sip-external:1] NoOp("SIP/101-00000000", "Received incoming SIP connection from unknown peer to 904542XXXX") in new stack
-- Executing [904542XXXX@from-sip-external:2] Set("SIP/101-00000000", "DID=904542XXXX") in new stack
-- Executing [904542XXXX@from-sip-external:3] Goto("SIP/101-00000000", "s,1") in new stack
-- Goto (from-sip-external,s,1)
-- Executing [s@from-sip-external:1] GotoIf("SIP/101-00000000", "0?checklang:noanonymous") in new stack
-- Goto (from-sip-external,s,5)
-- Executing [s@from-sip-external:5] Set("SIP/101-00000000", "TIMEOUT(absolute)=15") in new stack
-- Channel will hangup at 2014-08-11 11:32:40.658 EDT.
-- Executing [s@from-sip-external:6] Log("SIP/101-00000000", "WARNING,"Rejecting unknown SIP connection from 192.168.0.111"") in new stack
[2014-08-11 11:32:25] WARNING[2295][C-00000000]: Ext. s:6 @ from-sip-external: "Rejecting unknown SIP connection from 192.168.0.111"
-- Executing [s@from-sip-external:7] Answer("SIP/101-00000000", "") in new stack
> 0xb7324b00 -- Probation passed - setting RTP source address to 192.168.0.111:23546
-- Executing [s@from-sip-external:8] Wait("SIP/101-00000000", "2") in new stack
[2014-08-11 11:32:25] NOTICE[2295][C-00000000]: channel.c:4301 __ast_read: Dropping incompatible voice frame on SIP/101-00000000 of format gsm since our native format has changed to (ulaw)
-- Executing [s@from-sip-external:9] Playback("SIP/101-00000000", "ss-noservice") in new stack
-- <SIP/101-00000000> Playing 'ss-noservice.ulaw' (language 'en')
-- Executing [s@from-sip-external:10] PlayTones("SIP/101-00000000", "congestion") in new stack
-- Executing [s@from-sip-external:11] Congestion("SIP/101-00000000", "5") in new stack
== Spawn extension (from-sip-external, s, 11) exited non-zero on 'SIP/101-00000000'
-- Executing [h@from-sip-external:1] Hangup("SIP/101-00000000", "") in new stack
== Spawn extension (from-sip-external, h, 1) exited non-zero on 'SIP/101-00000000'
localhost*CLI>
Весьма смущает фраза:
В чем может быть причина?
Re: Проблема с исходящими звонками.
Alexey_761 писал(а):-- Executing [904542XXXX@from-sip-external:1] NoOp("SIP/101-00000000", "Received incoming SIP connection from unknown peer to 904542XXXX") in new stack
а это не смущает?
Alexey_761
Ну новенький я... по подробней плиз.
должно быть
[101]
Alexey_761
Проверил так и есть...
TVMaker
Сообщение TVMaker »
А вызов на 904542ХХХХ - это куда? В Турцию или что-то типа "7" или "8" пропущено впереди?
уберите все insecure
попробуйте нормальным софтфоном (X-lite, Linphone, MicroSip...)
Alexey_761
С 8 и +7 попробовал, результат тоже.
insecure нашел только в транке, но он там обязателен, провайдер только так работает.
Во внутренних номерах insecure не нашел.
с внутренних не должно быть попаданий в контекст from-sip-external
Alexey_761
На счет контекста согласен, исправил. Его поставил тоже в результате эксперементов.
Сейчас немного другая ошибка.
Перевел, говорит типа "заняты все цепи"...
Это про что?
  -- Executing [904542XXXX@from-internal:1] Macro("SIP/101-0000001a", "user-ca        llerid,LIMIT,EXTERNAL,") in new stack
    -- Executing [s@macro-user-callerid:1] Set("SIP/101-0000001a", "TOUCH_MONITO        R=1407853672.26") in new stack
    -- Executing [s@macro-user-callerid:2] Set("SIP/101-0000001a", "AMPUSER=101"        ) in new stack
    -- Executing [s@macro-user-callerid:3] GotoIf("SIP/101-0000001a", "0?report"        ) in new stack
    -- Executing [s@macro-user-callerid:4] ExecIf("SIP/101-0000001a", "1?Set(REA        LCALLERIDNUM=101)") in new stack
    -- Executing [s@macro-user-callerid:5] Set("SIP/101-0000001a", "AMPUSER=101"        ) in new stack
    -- Executing [s@macro-user-callerid:6] GotoIf("SIP/101-0000001a", "0?limit")        in new stack
    -- Executing [s@macro-user-callerid:7] Set("SIP/101-0000001a", "AMPUSERCIDNA        ME=101") in new stack
    -- Executing [s@macro-user-callerid:8] GotoIf("SIP/101-0000001a", "0?report"        ) in new stack
    -- Executing [s@macro-user-callerid:9] Set("SIP/101-0000001a", "AMPUSERCID=1        01") in new stack
    -- Executing [s@macro-user-callerid:10] Set("SIP/101-0000001a", "__DIAL_OPTI        ONS=Ttr") in new stack
    -- Executing [s@macro-user-callerid:11] Set("SIP/101-0000001a", "CALLERID(al        l)="101" <101>") in new stack
    -- Executing [s@macro-user-callerid:12] GotoIf("SIP/101-0000001a", "0?limit"        ) in new stack
    -- Executing [s@macro-user-callerid:13] ExecIf("SIP/101-0000001a", "1?Set(GR        OUP(concurrency_limit)=101)") in new stack
    -- Executing [s@macro-user-callerid:14] GosubIf("SIP/101-0000001a", "7?sub-c        css,s,1(from-internal,904542XXXX)") in new stack
    -- Executing [s@sub-ccss:1] ExecIf("SIP/101-0000001a", "0?Return()") in new        stack
    -- Executing [s@sub-ccss:2] Set("SIP/101-0000001a", "CCSS_SETUP=TRUE") in ne        w stack
    -- Executing [s@sub-ccss:3] GosubIf("SIP/101-0000001a", "0?monitor_config,1(        from-internal,904542XXXX):monitor_default,1(from-internal,904542XXXX)") in new s        tack
    -- Executing [monitor_default@sub-ccss:1] GotoIf("SIP/101-0000001a", "0?is_e        xten") in new stack
    -- Executing [monitor_default@sub-ccss:2] StackPop("SIP/101-0000001a", "") i        n new stack
    -- Executing [monitor_default@sub-ccss:3] Return("SIP/101-0000001a", "FALSE"        ) in new stack
    -- Executing [s@macro-user-callerid:15] GotoIf("SIP/101-0000001a", "1?contin        ue") in new stack
    -- Goto (macro-user-callerid,s,28)
    -- Executing [s@macro-user-callerid:28] Set("SIP/101-0000001a", "CALLERID(nu        mber)=101") in new stack
    -- Executing [s@macro-user-callerid:29] Set("SIP/101-0000001a", "CALLERID(na        me)=101") in new stack
    -- Executing [s@macro-user-callerid:30] Set("SIP/101-0000001a", "CDR(cnum)=1        01") in new stack
    -- Executing [s@macro-user-callerid:31] Set("SIP/101-0000001a", "CDR(cnam)=1        01") in new stack
    -- Executing [s@macro-user-callerid:32] Set("SIP/101-0000001a", "CHANNEL(lan        guage)=en") in new stack
    -- Executing [904542XXXX@from-internal:2] Set("SIP/101-0000001a", "MOHCLASS=        default") in new stack
    -- Executing [904542XXXX@from-internal:3] ExecIf("SIP/101-0000001a", "1?Set(        TRUNKCIDOVERRIDE=holkin01)") in new stack
    -- Executing [9045426488@from-internal:4] Set("SIP/101-0000001a", "_NODEST="        ) in new stack
    -- Executing [904542XXXX@from-internal:5] Gosub("SIP/101-0000001a", "sub-rec        ord-check,s,1(out,904542XXXX,)") in new stack
    -- Executing [s@sub-record-check:1] Set("SIP/101-0000001a", "REC_POLICY_MODE        _SAVE=") in new stack
    -- Executing [s@sub-record-check:2] GotoIf("SIP/101-0000001a", "1?check") in        new stack
    -- Goto (sub-record-check,s,7)
    -- Executing [s@sub-record-check:7] Set("SIP/101-0000001a", "__MON_FMT=wav")        in new stack
    -- Executing [s@sub-record-check:8] GotoIf("SIP/101-0000001a", "1?next") in        new stack
    -- Goto (sub-record-check,s,11)
    -- Executing [s@sub-record-check:11] ExecIf("SIP/101-0000001a", "0?Return()"        ) in new stack
    -- Executing [s@sub-record-check:12] ExecIf("SIP/101-0000001a", "0?Set(__REC        _POLICY_MODE=)") in new stack
    -- Executing [s@sub-record-check:13] GotoIf("SIP/101-0000001a", "0?out,1") i        n new stack
    -- Executing [s@sub-record-check:14] Set("SIP/101-0000001a", "__REC_STATUS=I        NITIALIZED") in new stack
    -- Executing [s@sub-record-check:15] Set("SIP/101-0000001a", "NOW=1407853672        ") in new stack
    -- Executing [s@sub-record-check:16] Set("SIP/101-0000001a", "__DAY=12") in        new stack
    -- Executing [s@sub-record-check:17] Set("SIP/101-0000001a", "__MONTH=08") i        n new stack
    -- Executing [s@sub-record-check:18] Set("SIP/101-0000001a", "__YEAR=2014")        in new stack
    -- Executing [s@sub-record-check:19] Set("SIP/101-0000001a", "__TIMESTR=2014        0812-102752") in new stack
    -- Executing [s@sub-record-check:20] Set("SIP/101-0000001a", "__FROMEXTEN=10        1") in new stack
    -- Executing [s@sub-record-check:21] Set("SIP/101-0000001a", "__CALLFILENAME        =out-9045426488-101-20140812-102752-1407853672.26") in new stack
    -- Executing [s@sub-record-check:22] Goto("SIP/101-0000001a", "out,1") in ne        w stack
    -- Executing [out@sub-record-check:1] ExecIf("SIP/101-0000001a", "1?Set(__RE        C_POLICY_MODE=dontcare)") in new stack
    -- Executing [out@sub-record-check:2] GosubIf("SIP/101-0000001a", "0?record,        1(exten,9045426488,101)") in new stack
    -- Executing [out@sub-record-check:3] Return("SIP/101-0000001a", "") in new        stack
    -- Executing [9045426488@from-internal:6] Macro("SIP/101-0000001a", "dialout        -trunk,2,9045426488,,off") in new stack
    -- Executing [s@macro-dialout-trunk:1] Set("SIP/101-0000001a", "DIAL_TRUNK=2        ") in new stack
    -- Executing [s@macro-dialout-trunk:2] GosubIf("SIP/101-0000001a", "0?sub-pi        ncheck,s,1()") in new stack
    -- Executing [s@macro-dialout-trunk:3] GotoIf("SIP/101-0000001a", "0?disable        trunk,1") in new stack
    -- Executing [s@macro-dialout-trunk:4] Set("SIP/101-0000001a", "DIAL_NUMBER=        9045426488") in new stack
    -- Executing [s@macro-dialout-trunk:5] Set("SIP/101-0000001a", "DIAL_TRUNK_O        PTIONS=Ttr") in new stack
    -- Executing [s@macro-dialout-trunk:6] Set("SIP/101-0000001a", "OUTBOUND_GRO        UP=OUT_2") in new stack
    -- Executing [s@macro-dialout-trunk:7] GotoIf("SIP/101-0000001a", "1?nomax")        in new stack
    -- Executing [s@macro-dialout-trunk:9] GotoIf("SIP/101-0000001a", "0?skipout        cid") in new stack
    -- Executing [s@macro-dialout-trunk:10] Set("SIP/101-0000001a", "DIAL_TRUNK_        OPTIONS=Tt") in new stack
    -- Executing [s@macro-dialout-trunk:11] Macro("SIP/101-0000001a", "outbound-        callerid,2") in new stack
    -- Executing [s@macro-outbound-callerid:1] ExecIf("SIP/101-0000001a", "0?Set        (CALLERPRES()=)") in new stack
    -- Executing [s@macro-outbound-callerid:2] ExecIf("SIP/101-0000001a", "0?Set        (REALCALLERIDNUM=101)") in new stack
    -- Executing [s@macro-outbound-callerid:3] GotoIf("SIP/101-0000001a", "1?nor        mcid") in new stack
    -- Executing [s@macro-outbound-callerid:6] Set("SIP/101-0000001a", "USEROUTC        ID=") in new stack
    -- Executing [s@macro-outbound-callerid:7] Set("SIP/101-0000001a", "EMERGENC        YCID=") in new stack
    -- Executing [s@macro-outbound-callerid:8] Set("SIP/101-0000001a", "TRUNKOUT        CID=holkin01") in new stack
    -- Executing [s@macro-outbound-callerid:9] GotoIf("SIP/101-0000001a", "1?tru        nkcid") in new stack
    -- Goto (macro-outbound-callerid,s,14)
    -- Executing [s@macro-outbound-callerid:14] ExecIf("SIP/101-0000001a", "1?Se        t(CALLERID(all)=holkin01)") in new stack
    -- Executing [s@macro-outbound-callerid:15] ExecIf("SIP/101-0000001a", "0?Se        t(CALLERID(all)=)") in new stack
    -- Executing [s@macro-outbound-callerid:16] ExecIf("SIP/101-0000001a", "1?Se        t(CALLERID(all)=holkin01)") in new stack
    -- Executing [s@macro-outbound-callerid:17] ExecIf("SIP/101-0000001a", "0?Se        t(CALLERPRES()=prohib_passed_screen)") in new stack
    -- Executing [s@macro-outbound-callerid:18] Set("SIP/101-0000001a", "CDR(out        bound_cnum)=") in new stack
    -- Executing [s@macro-outbound-callerid:19] Set("SIP/101-0000001a", "CDR(out        bound_cnam)=holkin01") in new stack
    -- Executing [s@macro-dialout-trunk:12] GosubIf("SIP/101-0000001a", "0?sub-f        lp-2,s,1()") in new stack
    -- Executing [s@macro-dialout-trunk:13] Set("SIP/101-0000001a", "OUTNUM=9045        426488") in new stack
    -- Executing [s@macro-dialout-trunk:14] Set("SIP/101-0000001a", "custom=SIP/        holkin01") in new stack
    -- Executing [s@macro-dialout-trunk:15] ExecIf("SIP/101-0000001a", "0?Set(DI        AL_TRUNK_OPTIONS=M(setmusic^default)Tt)") in new stack
    -- Executing [s@macro-dialout-trunk:16] ExecIf("SIP/101-0000001a", "0?Set(DI        AL_TRUNK_OPTIONS=TtM(confirm))") in new stack
    -- Executing [s@macro-dialout-trunk:17] Macro("SIP/101-0000001a", "dialout-t        runk-predial-hook,") in new stack
    -- Executing [s@macro-dialout-trunk-predial-hook:1] MacroExit("SIP/101-00000        01a", "") in new stack
    -- Executing [s@macro-dialout-trunk:18] GotoIf("SIP/101-0000001a", "0?bypass        ,1") in new stack
    -- Executing [s@macro-dialout-trunk:19] ExecIf("SIP/101-0000001a", "1?Set(CO        NNECTEDLINE(num,i)=9045426488)") in new stack
    -- Executing [s@macro-dialout-trunk:20] ExecIf("SIP/101-0000001a", "1?Set(CO        NNECTEDLINE(name,i)=CID:)") in new stack
    -- Executing [s@macro-dialout-trunk:21] GotoIf("SIP/101-0000001a", "0?custom        trunk") in new stack
    -- Executing [s@macro-dialout-trunk:22] Dial("SIP/101-0000001a", "SIP/holkin        01/904542XXXX,300,Tt") in new stack
    -- Called SIP/holkin01/9045426488
[2014-08-12 10:27:52] WARNING[1654][C-00000010]: chan_sip.c:23127 handle_respons        e_invite: Received response: "Forbidden" from '"holkin01" <sip:Unknown@192.168.0        .110>;tag=as22dd5c5c'
    -- Executing [s@macro-dialout-trunk:23] NoOp("SIP/101-0000001a", "Dial faile        d for some reason with DIALSTATUS = CHANUNAVAIL and HANGUPCAUSE = 21") in new st        ack
    -- Executing [s@macro-dialout-trunk:24] GotoIf("SIP/101-0000001a", "0?contin        ue,1:s-CHANUNAVAIL,1") in new stack
    -- Goto (macro-dialout-trunk,s-CHANUNAVAIL,1)
    -- Executing [s-CHANUNAVAIL@macro-dialout-trunk:1] Set("SIP/101-0000001a", "        RC=21") in new stack
    -- Executing [s-CHANUNAVAIL@macro-dialout-trunk:2] Goto("SIP/101-0000001a",        "21,1") in new stack
    -- Goto (macro-dialout-trunk,21,1)
    -- Executing [21@macro-dialout-trunk:1] Goto("SIP/101-0000001a", "continue,1        ") in new stack
    -- Executing [continue@macro-dialout-trunk:1] NoOp("SIP/101-0000001a", "TRUN        K Dial failed due to CHANUNAVAIL HANGUPCAUSE: 21 - failing through to other trun        ks") in new stack
    -- Executing [continue@macro-dialout-trunk:2] Set("SIP/101-0000001a", "CALLE        RID(number)=101") in new stack
    -- Executing [9045426488@from-internal:7] Macro("SIP/101-0000001a", "outisbu        sy,") in new stack
    -- Executing [s@macro-outisbusy:1] Progress("SIP/101-0000001a", "") in new s        tack
    -- Executing [s@macro-outisbusy:2] GotoIf("SIP/101-0000001a", "0?emergency,1        ") in new stack
    -- Executing [s@macro-outisbusy:3] GotoIf("SIP/101-0000001a", "0?intracompan        y,1") in new stack
    -- Executing [s@macro-outisbusy:4] Playback("SIP/101-0000001a", "all-circuit        s-busy-now&pls-try-call-later, noanswer") in new stack
    -- <SIP/101-0000001a> Playing 'all-circuits-busy-now.gsm' (language 'en')
  == Spawn extension (macro-outisbusy, s, 4) exited non-zero on 'SIP/101-0000001        a' in macro 'outisbusy'
  == Spawn extension (from-internal, 904542XXXX, 7) exited non-zero on 'SIP/101-        0000001a'
    -- Executing [h@from-internal:1] Hangup("SIP/101-0000001a", "") in new stack
  == Spawn extension (from-internal, h, 1) exited non-zero on 'SIP/101-0000001a'
localhost*CLI>
