Проблема с транзитом
busl
Сообщение busl »
Здравствуйте. Оборудование: IP-шлюз---астериск---провайдер телефонии. Не проходят звонки. Подозреваю, где-то выключен транзит, хотя от циски звонки проходят транзитом. Что посоветуете, "будущее телефонии" в прочтении.
Connected to Asterisk 1.8.21.0 currently running on tsns (pid = 5901)
Verbosity is at least 7
-- Executing [483292@tsn_incoming_exchange:1] Log("SIP/IK-1_IP-000017bb", "NOTICE, ---Start tsn_incoming_exchange context---") in new stack
[2014-06-03 10:04:16] NOTICE[31199]: Ext. 483292:1 @ tsn_incoming_exchange: ---Start tsn_incoming_exchange context---
-- Executing [483292@tsn_incoming_exchange:2] Set("SIP/IK-1_IP-000017bb", "__TSN_SOURCE=TSN_FROM_OUTGOING") in new stack
-- Executing [483292@tsn_incoming_exchange:3] Gosub("SIP/IK-1_IP-000017bb", "tsn_interceptor,483292,1(483292)") in new stack
-- Executing [483292@tsn_interceptor:1] Log("SIP/IK-1_IP-000017bb", "NOTICE, ---Start tsn_interceptor context---") in new stack
[2014-06-03 10:04:16] NOTICE[31199]: Ext. 483292:1 @ tsn_interceptor: ---Start tsn_interceptor context---
-- Executing [483292@tsn_interceptor:2] Set("SIP/IK-1_IP-000017bb", "__TSN_START_TIME=1401775456") in new stack
-- Executing [483292@tsn_interceptor:3] Set("SIP/IK-1_IP-000017bb", "__TSN_ORIGINAL_EXTEN=483292") in new stack
-- Executing [483292@tsn_interceptor:4] Set("SIP/IK-1_IP-000017bb", "__TSN_C_E=AOC:_AN:_EXT:483292") in new stack
-- Executing [483292@tsn_interceptor:5] Set("SIP/IK-1_IP-000017bb", "__TSN_MONITOR_FILE=") in new stack
-- Executing [483292@tsn_interceptor:6] Gosub("SIP/IK-1_IP-000017bb", "tsn_set_monitor_filename_by_calling_party,483292,1") in new stack
-- Executing [483292@tsn_set_monitor_filename_by_calling_party:1] Log("SIP/IK-1_IP-000017bb", "NOTICE, ---Start tsn_set_monitor_filename_by_calling_party context---") in new stack
[2014-06-03 10:04:16] NOTICE[31199]: Ext. 483292:1 @ tsn_set_monitor_filename_by_calling_party: ---Start tsn_set_monitor_filename_by_calling_party context---
-- Executing [483292@tsn_set_monitor_filename_by_calling_party:2] GotoIf("SIP/IK-1_IP-000017bb", "1?3:12") in new stack
-- Goto (tsn_set_monitor_filename_by_calling_party,483292,3)
-- Executing [483292@tsn_set_monitor_filename_by_calling_party:3] GotoIf("SIP/IK-1_IP-000017bb", "0?4:8") in new stack
-- Goto (tsn_set_monitor_filename_by_calling_party,483292,8)
-- Executing [483292@tsn_set_monitor_filename_by_calling_party:8] GotoIf("SIP/IK-1_IP-000017bb", "0?9:10") in new stack
-- Goto (tsn_set_monitor_filename_by_calling_party,483292,10)
-- Executing [483292@tsn_set_monitor_filename_by_calling_party:10] NoOp("SIP/IK-1_IP-000017bb", "Finish if_if_if_tsn_set_monitor_filename_by_calling_party_59_60_61") in new stack
-- Executing [483292@tsn_set_monitor_filename_by_calling_party:11] NoOp("SIP/IK-1_IP-000017bb", "Finish if_if_tsn_set_monitor_filename_by_calling_party_59_60") in new stack
-- Executing [483292@tsn_set_monitor_filename_by_calling_party:12] NoOp("SIP/IK-1_IP-000017bb", "Finish if_tsn_set_monitor_filename_by_calling_party_59") in new stack
-- Executing [483292@tsn_set_monitor_filename_by_calling_party:13] Return("SIP/IK-1_IP-000017bb", "") in new stack
-- Executing [483292@tsn_interceptor:7] Gosub("SIP/IK-1_IP-000017bb", "tsn_router,483292,1") in new stack
-- Executing [483292@tsn_router:1] Gosub("SIP/IK-1_IP-000017bb", "tsn_router_point,s,1(SIP,483292,ipcomm,180,)") in new stack
-- Executing [s@tsn_router_point:1] Log("SIP/IK-1_IP-000017bb", "NOTICE, ---Start tsn_router_point context---") in new stack
[2014-06-03 10:04:16] NOTICE[31199]: Ext. s:1 @ tsn_router_point: ---Start tsn_router_point context---
-- Executing [s@tsn_router_point:2] Set("SIP/IK-1_IP-000017bb", "__TSN_FAR_CHAN_TYPE=SIP") in new stack
-- Executing [s@tsn_router_point:3] Set("SIP/IK-1_IP-000017bb", "__TSN_FAR_NAME=483292") in new stack
-- Executing [s@tsn_router_point:4] Set("SIP/IK-1_IP-000017bb", "__TSN_FAR_PEER=ipcomm") in new stack
-- Executing [s@tsn_router_point:5] Set("SIP/IK-1_IP-000017bb", "__TSN_FAR_TYPE=") in new stack
-- Executing [s@tsn_router_point:6] Set("SIP/IK-1_IP-000017bb", "__TSN_DIAL_TIMEOUT=180") in new stack
-- Executing [s@tsn_router_point:7] Set("SIP/IK-1_IP-000017bb", "__TSN_DIAL_OPTIONS=") in new stack
-- Executing [s@tsn_router_point:8] Return("SIP/IK-1_IP-000017bb", "") in new stack
-- Executing [483292@tsn_router:2] Return("SIP/IK-1_IP-000017bb", "") in new stack
-- Executing [483292@tsn_interceptor:8] Gosub("SIP/IK-1_IP-000017bb", "tsn_set_monitor_filename_by_far_party,483292,1") in new stack
-- Executing [483292@tsn_set_monitor_filename_by_far_party:1] Log("SIP/IK-1_IP-000017bb", "NOTICE, ---Start tsn_set_monitor_filename_by_far_party context---") in new stack
[2014-06-03 10:04:16] NOTICE[31199]: Ext. 483292:1 @ tsn_set_monitor_filename_by_far_party: ---Start tsn_set_monitor_filename_by_far_party context---
-- Executing [483292@tsn_set_monitor_filename_by_far_party:2] GotoIf("SIP/IK-1_IP-000017bb", "1?3:10") in new stack
-- Goto (tsn_set_monitor_filename_by_far_party,483292,3)
-- Executing [483292@tsn_set_monitor_filename_by_far_party:3] GotoIf("SIP/IK-1_IP-000017bb", "0?4:6") in new stack
-- Goto (tsn_set_monitor_filename_by_far_party,483292,6)
-- Executing [483292@tsn_set_monitor_filename_by_far_party:6] GotoIf("SIP/IK-1_IP-000017bb", "0?7:8") in new stack
-- Goto (tsn_set_monitor_filename_by_far_party,483292,8)
-- Executing [483292@tsn_set_monitor_filename_by_far_party:8] NoOp("SIP/IK-1_IP-000017bb", "Finish if_if_if_tsn_set_monitor_filename_by_far_party_62_63_64") in new stack
-- Executing [483292@tsn_set_monitor_filename_by_far_party:9] NoOp("SIP/IK-1_IP-000017bb", "Finish if_if_tsn_set_monitor_filename_by_far_party_62_63") in new stack
-- Executing [483292@tsn_set_monitor_filename_by_far_party:10] NoOp("SIP/IK-1_IP-000017bb", "Finish if_tsn_set_monitor_filename_by_far_party_62") in new stack
-- Executing [483292@tsn_set_monitor_filename_by_far_party:11] GotoIf("SIP/IK-1_IP-000017bb", "0?12:13") in new stack
-- Goto (tsn_set_monitor_filename_by_far_party,483292,13)
-- Executing [483292@tsn_set_monitor_filename_by_far_party:13] NoOp("SIP/IK-1_IP-000017bb", "Finish if_tsn_set_monitor_filename_by_far_party_65") in new stack
-- Executing [483292@tsn_set_monitor_filename_by_far_party:14] Return("SIP/IK-1_IP-000017bb", "") in new stack
-- Executing [483292@tsn_interceptor:9] Gosub("SIP/IK-1_IP-000017bb", "tsn_set_dialoptions,483292,1") in new stack
-- Executing [483292@tsn_set_dialoptions:1] Log("SIP/IK-1_IP-000017bb", "NOTICE, ---Start tsn_set_dialoptions context---") in new stack
[2014-06-03 10:04:16] NOTICE[31199]: Ext. 483292:1 @ tsn_set_dialoptions: ---Start tsn_set_dialoptions context---
-- Executing [483292@tsn_set_dialoptions:2] GotoIf("SIP/IK-1_IP-000017bb", "0?3:7") in new stack
-- Goto (tsn_set_dialoptions,483292,7)
-- Executing [483292@tsn_set_dialoptions:7] NoOp("SIP/IK-1_IP-000017bb", "Finish if_tsn_set_dialoptions_66") in new stack
-- Executing [483292@tsn_set_dialoptions:8] Return("SIP/IK-1_IP-000017bb", "") in new stack
-- Executing [483292@tsn_interceptor:10] Return("SIP/IK-1_IP-000017bb", "483292") in new stack
-- Executing [483292@tsn_incoming_exchange:4] GotoIf("SIP/IK-1_IP-000017bb", "0?5:7") in new stack
-- Goto (tsn_incoming_exchange,483292,7)
-- Executing [483292@tsn_incoming_exchange:7] Log("SIP/IK-1_IP-000017bb", "ERRROR, ---Transit disabling---") in new stack
[2014-06-03 10:04:16] ERROR[31199]: app_verbose.c:154 log_exec: Unknown log level: 'ERRROR'
-- Executing [483292@tsn_incoming_exchange:8] Hangup("SIP/IK-1_IP-000017bb", "") in new stack
== Spawn extension (tsn_incoming_exchange, 483292, 8) exited non-zero on 'SIP/IK-1_IP-000017bb'
-- Executing [h@tsn_incoming_exchange:1] Gosub("SIP/IK-1_IP-000017bb", "tsn_hangup,s,1") in new stack
-- Executing [s@tsn_hangup:1] Log("SIP/IK-1_IP-000017bb", "NOTICE, ---Start tsn_hangup context---") in new stack
[2014-06-03 10:04:16] NOTICE[31199]: Ext. s:1 @ tsn_hangup: ---Start tsn_hangup context---
-- Executing [s@tsn_hangup:2] Gosub("SIP/IK-1_IP-000017bb", "tsn_exec_hangups,s,1") in new stack
-- Executing [s@tsn_exec_hangups:1] Log("SIP/IK-1_IP-000017bb", "NOTICE, ---Start tsn_exec_hangups context---") in new stack
[2014-06-03 10:04:16] NOTICE[31199]: Ext. s:1 @ tsn_exec_hangups: ---Start tsn_exec_hangups context---
-- Executing [s@tsn_exec_hangups:2] GotoIf("SIP/IK-1_IP-000017bb", "0?3:5") in new stack
-- Goto (tsn_exec_hangups,s,5)
-- Executing [s@tsn_exec_hangups:5] NoOp("SIP/IK-1_IP-000017bb", "Finish while_tsn_exec_hangups_57") in new stack
-- Executing [s@tsn_exec_hangups:6] Return("SIP/IK-1_IP-000017bb", "") in new stack
-- Executing [s@tsn_hangup:3] DumpChan("SIP/IK-1_IP-000017bb", "") in new stack
Dumping Info For Channel: SIP/IK-1_IP-000017bb:
Info:
Name= SIP/IK-1_IP-000017bb
Type= SIP
UniqueID= 1401775456.6075
LinkedID= 1401775456.6075
CallerIDNum= 1000
CallerIDName= 1000
ConnectedLineIDNum= (N/A)
ConnectedLineIDName=(N/A)
DNIDDigits= 483292
RDNIS= (N/A)
Parkinglot= default
Language= ru
State= Ring (4)
Rings= 0
NativeFormat= 0x8 (alaw)
WriteFormat= 0x8 (alaw)
ReadFormat= 0x8 (alaw)
RawWriteFormat= 0x8 (alaw)
RawReadFormat= 0x8 (alaw)
WriteTranscode= No
ReadTranscode= No
1stFileDescriptor= 48
Framesin= 0
Framesout= 0
TimetoHangup= 0
ElapsedTime= 0h0m0s
DirectBridge= <none>
IndirectBridge= <none>
Context= tsn_hangup
Extension= s
Priority= 3
CallGroup=
PickupGroup=
Application= DumpChan
Data= (Empty)
Blocking_in= (Not Blocking)
Variables:
GOSUB_RETVAL=
hc=
ARGC=0
TSN_DIAL_OPTIONS=
TSN_FAR_TYPE=
TSN_FAR_PEER=ipcomm
TSN_FAR_NAME=483292
TSN_MONITOR_FILE=
SIPCALLID=579478FE-538D65FE@10.69.11.51
SIPDOMAIN=10.69.0.4
SIPURI=sip:1000@10.69.11.51:5060
-- Executing [s@tsn_hangup:4] GotoIf("SIP/IK-1_IP-000017bb", "0?5:15") in new stack
-- Goto (tsn_hangup,s,15)
-- Executing [s@tsn_hangup:15] NoOp("SIP/IK-1_IP-000017bb", "Finish if_tsn_hangup_51") in new stack
-- Executing [s@tsn_hangup:16] GotoIf("SIP/IK-1_IP-000017bb", "0?17:26") in new stack
-- Goto (tsn_hangup,s,26)
-- Executing [s@tsn_hangup:26] NoOp("SIP/IK-1_IP-000017bb", "Finish if_tsn_hangup_54") in new stack
-- Executing [s@tsn_hangup:27] Return("SIP/IK-1_IP-000017bb", "") in new stack
tsns*CLI>
Wapo
Re: Проблема с транзитом
Сообщение Wapo »
Ну, если "книжка в прочтении", то ТАКОЙ лог звонка из ГУЕВ вас приведет только к полному непониманию процессов.
См. в настройках почему:
busl
Сообщение busl »
Не знаю где в настройках этот ---Transit disabling---. И книга не помогает :?
Wapo
Сообщение Wapo »
Вам читать надо "Elastix без слез", а не "будущее телефонии" т.к. вы сами ЭТО будущее загнали в рамочки.
Думаю, что это не ГУИ.
Думаю, что диалпланы и макросы
tsn_monitor
tsn_router
tsn_interceptor
писал один разработчик, а эксплуатирует новый сисадмин (ТС) уже третий день. Поэтому понять не может, даже после книжки.
ТС, вот Вы поймёте, если я Вам назову причины, но на языке специалистов?
1) Набраный номер 483292 не уходит транзитом провайдеру, потому что имеет неопределённость по значности для выполнения глобального диалплана, нету регионального кода.
2) Из дебага также не видно ничего про оригинатора - Caller ID. А провайдеры этого не любят.
busl
Сообщение busl »
Транзит заработал. Покопался в этих скриптах-макросах, нашел что tsn_incoming_exchange дает запрет транзита транку, поменял в нужном транке на tsn_local_exchange и все :)
