Realtime Queue не видит своих members
ovoshlook
Сообщение ovoshlook »
Вот такакая загадочная ситуация у меня произошла. не видит members.
При запроси из консоли
queue show My_Queue.33
Вижу следующее:
pavelsc.device-26 (SIP/pavelsc.device-26 from SIP/pavelsc.device-26) with penalty 1 (ringinuse enabled) (realtime) (Invalid) has taken no calls yet
pavelsc.device-79 (SIP/pavelsc.device-79 from SIP/pavelsc.device-79) with penalty 2 (ringinuse enabled) (realtime) (Invalid) has taken no calls yet
При звонке на очередь через NoOp вывожу себе QUEUE_MEMBER_LIST (На всякий случай- взял инфу из дебага, а не из вывоа NoOp)
DEBUG pbx_substitute_variables_helper_full: Function QUEUE_MEMBER_LIST(My_Queue.33) result is 'SIP/pavelsc.device-26,SIP/pavelsc.device-79
При вызове в диалплане Queue(My_Queue.33) Дебаг выдает вот что:
DEBUG res_config_odbc.c:93 custom_prepare: Skip: 0; SQL: SELECT * FROM asterisk_db_queue WHERE name = ?
DEBUG res_config_odbc.c:109 custom_prepare: Parameter 1 ('name') = 'My_Queue.33'
DEBUG res_config_odbc.c:93 custom_prepare: Skip: 0; SQL: SELECT * FROM asterisk_db_members WHERE interface LIKE ? AND queue_name = ? ORDER BY interface
DEBUG res_config_odbc.c:109 custom_prepare: Parameter 1 ('interface LIKE') = '%'
DEBUG res_config_odbc.c:109 custom_prepare: Parameter 2 ('queue_name') = 'My_Queue.33'
DEBUG res_odbc.c:1058 odbc_release_obj2: odbc_release_obj2(0x2b93548) called (obj->txf = (nil))
DEBUG devicestate.c:442 devstate_event: device 'Queue:My_Queue.33_avail' state '2'
DEBUG app_queue.c:1809 handle_statechange: Device 'Queue:My_Queue.33_avail' changed to state '2' (In use) but we don't care because they're not a member of any queue.
DEBUG devicestate.c:442 devstate_event: device 'Queue:My_Queue.33' state '6'
DEBUG app_queue.c:3006 join_queue: Queue 'My_Queue.33' Join, Channel 'SIP/developer.device-79-00000001', Position '1'
DEBUG app_queue.c:1809 handle_statechange: Device 'Queue:My_Queue.33' changed to state '6' (Ringing) but we don't care because they're not a member of any queue.
DEBUG app_queue.c:4650 is_our_turn: There are 0 available members.
DEBUG app_queue.c:4668 is_our_turn: It's not our turn (SIP/developer.device-79-00000001)
Собственно при local канале пользователей- так же пользователей не находит.
в настройках очереди
strategy=ringall
autofill=yes
Остальное все стандартно
Кто мне подскажет кто расскажет где оно где оно?
На подобной системе на другом сетвете идентичны очееди через local_chan работают. Уже извращался как только мог....
Re: Realtime Queue не видит своих members
Уж больно интересно посмотреть на
sip show peers like pavelsc.device-79
