Астер находится за коммутатором и иногда звонки обрываются.
Проблемачто cause 16 это вызываемый положил трубку, но он категорически отрицает
Вот логи от pri и по мне вроде как все нормално
[Apr 1 14:43:00] VERBOSE[28093] chan_dahdi.c: PRI Span: 1
[Apr 1 14:43:00] VERBOSE[28093] chan_dahdi.c: PRI Span: 1 < Protocol Discriminator: Q.931 (8) len=9
[Apr 1 14:43:00] VERBOSE[28093] chan_dahdi.c: PRI Span: 1 < TEI=0 Call Ref: len= 2 (reference 512/0x200) (Sent to originator)
[Apr 1 14:43:00] VERBOSE[28093] chan_dahdi.c: PRI Span: 1 < Message Type: DISCONNECT (69)
[Apr 1 14:43:00] VERBOSE[28093] chan_dahdi.c: PRI Span: 1 < [08 02 81 90]
[Apr 1 14:43:00] VERBOSE[28093] chan_dahdi.c: PRI Span: 1 < Cause (len= 4) [ Ext: 1 Coding: CCITT (ITU) standard (0) Spare: 0 Location: Private network serving the local user (1)
[Apr 1 14:43:00] VERBOSE[28093] chan_dahdi.c: PRI Span: 1 < Ext: 1 Cause: Normal Clearing (16), class = Normal Event (1) ]
[Apr 1 14:43:00] VERBOSE[28093] chan_dahdi.c: PRI Span: 1 Received message for call 0x9a294b0 on link 0x965ebf4 TEI/SAPI 0/0
[Apr 1 14:43:00] VERBOSE[28093] chan_dahdi.c: PRI Span: 1 -- Processing IE 8 (cs0, Cause)
[Apr 1 14:43:00] VERBOSE[28093] chan_dahdi.c: PRI Span: 1 -- Found active call: 0x9a294b0 cref:33280
[Apr 1 14:43:00] VERBOSE[28093] chan_dahdi.c: PRI Span: 1 q931.c:9084 post_handle_q931_message: Call 33280 enters state 12 (Disconnect Indication). Hold state: Idle
[Apr 1 14:43:00] VERBOSE[28093] sig_pri.c: Span 1: Processing event PRI_EVENT_HANGUP_REQ
[Apr 1 14:43:00] VERBOSE[28093] sig_pri.c: -- Span 1: Channel 0/2 got hangup request, cause 16
[Apr 1 14:43:00] VERBOSE[4070] chan_dahdi.c: PRI Span: 1 q931.c:7135 q931_hangup: Hangup other cref:33280
[Apr 1 14:43:00] VERBOSE[4070] chan_dahdi.c: PRI Span: 1 q931.c:6892 __q931_hangup: ourstate Disconnect Indication, peerstate Disconnect Request, hold-state Idle
[Apr 1 14:43:00] VERBOSE[4070] chan_dahdi.c: PRI Span: 1 q931.c:5930 q931_release: Call 33280 enters state 19 (Release Request). Hold state: Idle
[Apr 1 14:43:00] VERBOSE[4070] chan_dahdi.c: PRI Span: 1 > DL-DATA request
[Apr 1 14:43:00] VERBOSE[4070] chan_dahdi.c: PRI Span: 1 > Protocol Discriminator: Q.931 (8) len=9
[Apr 1 14:43:00] VERBOSE[4070] chan_dahdi.c: PRI Span: 1 > TEI=0 Call Ref: len= 2 (reference 512/0x200) (Sent from originator)
[Apr 1 14:43:00] VERBOSE[4070] chan_dahdi.c: PRI Span: 1 > Message Type: RELEASE (77)
[Apr 1 14:43:00] VERBOSE[4070] chan_dahdi.c: PRI Span: 1 TEI=0 Transmitting N(S)=84, window is open V(A)=84 K=7
[Apr 1 14:43:00] VERBOSE[4070] chan_dahdi.c: PRI Span: 1 > [08 02 81 90]
[Apr 1 14:43:00] VERBOSE[4070] chan_dahdi.c: PRI Span: 1 > Cause (len= 4) [ Ext: 1 Coding: CCITT (ITU) standard (0) Spare: 0 Location: Private network serving the local user (1)
[Apr 1 14:43:00] VERBOSE[4070] chan_dahdi.c: PRI Span: 1 > Ext: 1 Cause: Normal Clearing (16), class = Normal Event (1) ]
[Apr 1 14:43:00] VERBOSE[4070] chan_dahdi.c: -- Hungup 'DAHDI/i1/00XXXXXXXX-3c1'
Да забыл недели 2 назад случаев было по больше но после установки
ситуация намного улутшиласьcallprogress = no
Версия астера 1.8.16.0
