chan_sip.c:20870 handle_response_invite
test-sip
Сообщение test-sip »
Здравсвуйте!
Пытаюсь настроить Asterisk.
Вот мои конфиги:
sip.conf
context=default
allowguest=no
allowoverlap=no
udpbindaddr=192.168.111.111
tcpenable=no
tcpbindaddr=192.168.111.111
srvlookup=yes
language=ru
callevents=yes
alwaysauthreject = yes
t38pt_udptl=no
[asterisk-1]
secret=qwerty
nat=no
host=192.168.100.111
dtmfmode=rfc2833
context=to-asterisk1
canreinvite=no
insecure=invite,port
[codecs](!)
[phones](!,codecs)
type=peer
canreinvite=no
context=from-phones
subscribecontext=test-phones
callcounter=yes
secret=test123
nat=no
[localip](!,phones)
[201](localip)
[202](localip)
[203](localip)
[204](localip)
[205](localip)
[206](localip)
[207](localip)
[208](localip)
[209](localip)
[210](localip)
extensions.conf
[default]
exten => _X.,1,Hangup
[all_phones]
exten => _[12345]XX,1,Dial(SIP/asterisk-1/${EXTEN})
same =>            n,Hangup
exten => _98XXXXXXXXXX,1,Dial(SIP/asterisk-1/${EXTEN})
same =>                n,Hangup
[test-phones]
exten => 201,1,Dial(SIP/201,90,t)
same  =>      n,Hangup
exten => 202,1,Dial(SIP/202,90,t)
same  =>      n,Hangup
exten => 203,1,Dial(SIP/203,90,t)
same  =>      n,Hangup
exten => 204,1,Dial(SIP/204,90,t)
[from-phones]
include => test-phones
include => all_phones
[to-asterisk1]
same  =>      n,Hangup
same  =>      n,Hangup
same  =>      n,Hangup
same  =>      n,Hangup
same =>            n,Hangup
same =>                n,Hangup
sip show peers
Name/username              Host                                    Dyn Forcerport ACL Port     Status
201/201                    192.168.0.101                            D                 5060     OK (4 ms)
202/202                    192.168.0.102                            D                 5060     OK (5 ms)
203                        (Unspecified)                            D                 0        UNKNOWN
204                        (Unspecified)                            D                 0        UNKNOWN
205                        (Unspecified)                            D                 0        UNKNOWN
206                        (Unspecified)                            D                 0        UNKNOWN
207                        (Unspecified)                            D                 0        UNKNOWN
208                        (Unspecified)                            D                 0        UNKNOWN
209                        (Unspecified)                            D                 0        UNKNOWN
210                        (Unspecified)                            D                 0        UNKNOWN
asterisk-1                 192.168.100.111                                            5060     OK (1 ms)
sip show peer 202
  * Name       : 202
  Secret       : <Set>
  MD5Secret    : <Not set>
  Remote Secret: <Not set>
  Context      : from-phones
  Subscr.Cont. : test-phones
  Language     : ru
  AMA flags    : Unknown
  Transfer mode: open
  Callgroup    :
  Pickupgroup  :
  MOH Suggest  :
  Mailbox      :
  VM Extension : asterisk
  LastMsgsSent : 32767/65535
  Call limit   : 2147483647
  Max forwards : 0
  Dynamic      : Yes
  Callerid     : "" <>
  MaxCallBR    : 384 kbps
  Expire       : 36
  Insecure     : no
  Force rport  : No
  ACL          : No
  DirectMedACL : No
  T.38 support : No
  T.38 EC mode : Unknown
  T.38 MaxDtgrm: -1
  DirectMedia  : No
  PromiscRedir : No
  User=Phone   : No
  Video Support: No
  Text Support : No
  Ign SDP ver  : No
  Trust RPID   : No
  Send RPID    : No
  Subscriptions: Yes
  Overlap dial : No
  DTMFmode     : rfc2833
  Timer T1     : 500
  Timer B      : 32000
  ToHost       :
  Addr->IP     : 192.168.0.102:5060
  Defaddr->IP  : (null)
  Prim.Transp. : UDP
  Allowed.Trsp : UDP
  Def. Username: 498
  SIP Options  : (none)
  Codecs       : 0x8 (alaw)
  Codec Order  : (alaw:20)
  Auto-Framing :  No
  Status       : OK (5 ms)
  Useragent    : Voip Phone 1.0
  Reg. Contact : sip:202@192.168.0.102:5060
  Qualify Freq : 60000 ms
  Sess-Timers  : Accept
  Sess-Refresh : uas
  Sess-Expires : 1800 secs
  Min-Sess     : 90 secs
  RTP Engine   : asterisk
  Parkinglot   :
  Use Reason   : No
  Encryption   : No
При звонке с телефона 201 на номер 333 звонок проходит.
А при звонке с телефона 202 на номер 333 звонок не проходит выдаётся ошибка:
[Mar 12 09:02:05] NOTICE[3124]: chan_sip.c:20870 handle_response_invite: Failed to authenticate on INVITE to '"Test202" <sip:202@192.168.111.111>;tag=as6bdc9894'
Оба телефона Fanvil BW210, настройки телефонов абсолютно одинаковые.
Re: chan_sip.c:20870 handle_response_invite
зачем эти все сокращения ? место на винте экономите ?
[301]
nat=no
defaultuser=301
fromuser=301
directmedia=no
secret=q301pro
dtmfmode=rfc2833
insecure=port,invite
callerid="301" <301>
context=from-local
call-limit=2
deny=0.0.0.0/0.0.0.0
permit=192.168.0.0/255.255.0.0 ;Внимание, прописываем свою локальную сеть, из которой регистрируются телефоны
callgroup=1 ; Группы перехвата вызова
pickupgroup=1 ; группы перехвата вызова
Вы даже не видите очевидного, что фразу Failed to authenticate on INVITE to '"Test202" Астериск выдаёт при попытке позвонить на SIP/asterisk-1 согласно нелепым контекстам
[from-phones]
вместо этого контекста, который содержит два вложения, надо просто сделать пока один контекст, и сразу будет видно: где искать 201? 202? Согласно
они назодятся на другом Астериске. А согласно
где-то тут рядом.
test-sip
Нет, просто удобнее.
У Вас это с какого астера call-limit помоему старело уже?
Переделал чтобы не эконопить место, всё равно таже ошибка:
test-sip
Хм... Т.е. работать так не будет, даже если я указал явно как звонить на 201, 202, 203 и это выше чем строчка exten => _[12345]XX,1,Dial(SIP/asterisk-1/${EXTEN}
Да и потом я же звоню не на 2ХХ, а на 333, звонок и должен уйти через канал SIP/asterisk-1
С 201 номера же уходит.
Сдаётся мне, что не справитесь. Вам другой Астериск отвечаетFailed to authenticate on INVITE to '"Test202" <sip:202@192.168.111.111> , другой Астериск пытается аутентифицировать юзера 202. Его можно конечно обмануть, подставив fromuser=201? но это кривота.
Конфиги там смотрите, а не тут.
Вяжите Астериски по IAX2, он не зря придуман.
test-sip
Это я понимаю, что отвечает другой Астериск.
Но номера 202 нету sip.conf на другом Asteriskе.
Почему он пытаете его там пытается аутентифицировать не понятно.
[asterisk-2]
- type=friend
+ type=peer
test-sip писал(а):Но номера 202 нету sip.conf на другом Asteriskе.
Ну и что? Каждый инвайт идентифицируется и аутентифицируется.
test-sip писал(а):Почему он пытаете его там пытается аутентифицировать не понятно.
Потому что так устроен SIP. Если бы Вы его узнали получше, то смогли бы убрать аутентификацию. Направление понятно?
Скоро Вы узнаете, что каждый SIP Invite аутентифицируется. А если не хочется - то allowguest=yes
и не будет.
И потом скоро-скоро ваш Астериск крякнут и нальют туда что смогут.
Вопросы новичков
Будущее прочитали?
test-sip
Конечно читал.
Убрал аутентификацию между Asteriskами, но ошибка не ушла.
С 201 звонок уходит
С 202 всё так же нет.
