Конференция
sergiks
Конференция
Сообщение sergiks »
Настроена конференция, в файл-листе прописано 12 номеров, которые должны участвовать в конференции, в последнее время почему-то стал отсекаться последний номер, не идет на него вызов, добавляю 13 номер к примеру, 13 - отсекается, а на 12 приходит вызов. В чем дело не пойму
Re: Конференция
логи где ?
sergiks
Re: Конференция
Сообщение sergiks »
[Feb 25 09:47:30] NOTICE[16440][C-000013f4] channel.c: Unable to request channel SIP/textil-637
[Feb 25 09:47:30] NOTICE[16440] pbx_spool.c: Call failed to go through, reason (0) Call Failure (not BUSY, and not NO_ANSWER, maybe Circuit busy or down?)
[Feb 25 09:47:30] NOTICE[16447][C-000013f5] channel.c: Unable to request channel SIP/textil-925
[Feb 25 09:47:30] NOTICE[16447] pbx_spool.c: Call failed to go through, reason (0) Call Failure (not BUSY, and not NO_ANSWER, maybe Circuit busy or down?)
[Feb 25 09:47:48] NOTICE[16476] pbx_spool.c: Call completed to SIP/textil-636
[Feb 25 09:47:50] NOTICE[16973][C-000013fc] channel.c: Unable to request channel SIP/textil-637
[Feb 25 09:47:50] NOTICE[16973] pbx_spool.c: Call failed to go through, reason (0) Call Failure (not BUSY, and not NO_ANSWER, maybe Circuit busy or down?)
[Feb 25 09:47:50] NOTICE[16974][C-000013fd] channel.c: Unable to request channel SIP/textil-925
[Feb 25 09:47:50] NOTICE[16974] pbx_spool.c: Call failed to go through, reason (0) Call Failure (not BUSY, and not NO_ANSWER, maybe Circuit busy or down?)
[Feb 25 09:48:00] NOTICE[16418] pbx_spool.c: Call failed to go through, reason (3) Remote end Ringing
[Feb 25 09:48:00] NOTICE[16425] pbx_spool.c: Call failed to go through, reason (3) Remote end Ringing
[Feb 25 09:48:00] NOTICE[16455] pbx_spool.c: Call failed to go through, reason (3) Remote end Ringing
[Feb 25 09:48:00] NOTICE[16469] pbx_spool.c: Call failed to go through, reason (3) Remote end Ringing
[Feb 25 09:48:00] NOTICE[16462] pbx_spool.c: Call failed to go through, reason (3) Remote end Ringing
[Feb 25 09:48:10] NOTICE[17460][C-00001402] channel.c: Unable to request channel SIP/textil-637
[Feb 25 09:48:10] NOTICE[17460] pbx_spool.c: Call failed to go through, reason (0) Call Failure (not BUSY, and not NO_ANSWER, maybe Circuit busy or down?)
[Feb 25 09:48:10] NOTICE[17460] pbx_spool.c: Queued call to SIP/textil-637 expired without completion after 2 attempts
[Feb 25 09:48:10] NOTICE[17461][C-00001404] channel.c: Unable to request channel SIP/textil-925
[Feb 25 09:48:10] NOTICE[17461] pbx_spool.c: Call failed to go through, reason (0) Call Failure (not BUSY, and not NO_ANSWER, maybe Circuit busy or down?)
[Feb 25 09:48:10] NOTICE[17461] pbx_spool.c: Queued call to SIP/textil-925 expired without completion after 2 attempts
[Feb 25 09:48:22] NOTICE[16411] pbx_spool.c: Call completed to SIP/textil-188
[Feb 25 09:48:24] NOTICE[16483] pbx_spool.c: Call completed to SIP/textil-191
[Feb 25 09:48:37] NOTICE[16432] pbx_spool.c: Call completed to SIP/textil-603
[Feb 25 09:48:40] NOTICE[17459] pbx_spool.c: Call failed to go through, reason (3) Remote end Ringing
[Feb 25 09:48:40] NOTICE[17463] pbx_spool.c: Call failed to go through, reason (3) Remote end Ringing
[Feb 25 09:48:40] NOTICE[17458] pbx_spool.c: Call failed to go through, reason (3) Remote end Ringing
[Feb 25 09:48:40] NOTICE[17464] pbx_spool.c: Call failed to go through, reason (3) Remote end Ringing
[Feb 25 09:48:40] NOTICE[17462] pbx_spool.c: Call failed to go through, reason (3) Remote end Ringing
[Feb 25 09:49:10] NOTICE[18208] pbx_spool.c: Call failed to go through, reason (3) Remote end Ringing
[Feb 25 09:49:10] NOTICE[18208] pbx_spool.c: Queued call to SIP/textil-686 expired without completion after 2 attempts
[Feb 25 09:49:10] NOTICE[18209] pbx_spool.c: Call failed to go through, reason (3) Remote end Ringing
[Feb 25 09:49:10] NOTICE[18209] pbx_spool.c: Queued call to SIP/textil-222 expired without completion after 2 attempts
[Feb 25 09:49:10] NOTICE[18207] pbx_spool.c: Call failed to go through, reason (3) Remote end Ringing
[Feb 25 09:49:10] NOTICE[18207] pbx_spool.c: Queued call to SIP/textil-169 expired without completion after 2 attempts
[Feb 25 09:49:20] NOTICE[18441] pbx_spool.c: Call failed to go through, reason (3) Remote end Ringing
[Feb 25 09:49:20] NOTICE[18441] pbx_spool.c: Queued call to SIP/textil-170 expired without completion after 2 attempts
[Feb 25 09:49:20] NOTICE[18442] pbx_spool.c: Call failed to go through, reason (3) Remote end Ringing
[Feb 25 09:49:20] NOTICE[18442] pbx_spool.c: Queued call to SIP/textil-625 expired without completion after 2 attempts
A
Последний раз редактировалось sergiks 25 фев 2014, 11:08, всего редактировалось 1 раз.
sergiks
Re: Конференция
Сообщение sergiks »
последний номер в списке 333, в логах его нету даже
Re: Конференция
sergiks писал(а):Настроена конференция
это конечно же здорово. а настроена она на утюге калибра 5.62 ?
sergiks писал(а):в файл-листе прописано 12
это конечно же моментально дало нам информацию о том в каком файле, как прописано и каким образом осуществляется обзвон
ну ведь это и так все понятно, да sergiks ? глупые вопросы...
sergiks писал(а):в последнее время почему-то стал отсекаться последний номер
connecting to the universe...
please wait...
connection is established !
нет перевода каретки в конце файла
P.S. sergiks, откройте для себя функционал форума, а именно теги CODE и SPOLER
sergiks
Re: Конференция
Сообщение sergiks »
извиняюсь, конечно же, я новичок в этом деле, продали нам оборудование с астериском, настроили и обслуживание закончилось
скрипт конференции:
#!/bin/sh
while read number; do
cat <<EOF > /var/spool/asterisk/textil-$number
Channel: SIP/textil-$number
Callerid: textil-$number
MaxRetries: 2
RetryTime: 20
WaitTime: 30
Context: conf-textil
Extension: conf
Priority: 1
Set: CDR(userfield)=${REASON}
EOF
mv /var/spool/asterisk/textil-$number /var/spool/asterisk/outgoing
echo "textil-$number"
number=`expr $number + 1`
while [ "$?" -eq "0" ]
do
count_files ()
count_f=`ls /var/spool/asterisk/outgoing | wc -l`
if [ "$count_f" -eq "15" ]; then
sleep 10
return 0
else
return 1
fi
count_files
done
done < /var/spool/asterisk/textil-conf.txt
exit 0
соответственно номера участников конференции прописано в файле textil-conf.txt
он выглядит вот так:
188
170
169
603
333
sergiks
Re: Конференция
Сообщение sergiks »
разобрался, спасибо, тему можно крыть
Re: Конференция
sergiks писал(а):извиняюсь, конечно же, я новичок в этом деле, продали нам оборудование с астериском, настроили и обслуживание закончилось
Чужой скрипт ковырять - гиблое дело! Лучше восстанавливайте отношения с теми, кто настраивал. Чтобы поддерживали, небесплатно, конечно же. Это и есть платный суппорт.
Иначе - изучать самостоятельно - Астериск, будущее, телефонию, shell, Burn again shell, etc.
Re: Конференция
sergiks писал(а):я новичок в этом деле
честно сказать я не понимаю, почему отсутствие внятного объяснения своей проблемы объясняют просто "я новичок". Это тут причем ? Вы новичок в изложении собственной проблемы и понимания того что гадалок тут нет ? Правильно заданный вопрос это уже 50% ответа на него.
sergiks писал(а):настроили и обслуживание закончилось
значит стоит это обслуживание продлить, т.к. уже ясно, что самостоятельно вам не потянуть.
sergiks писал(а):разобрался, спасибо, тему можно крыть
опять же "умиляюсь" -> всем спасибо ! все свободны !
а дописать "проблема была потому что..." религия не позволяет ? жалко потратить свое время на других ?
P.S. Прошу прощения за грубость, но реально НАДОЕЛО ! Каждый день одно и тоже... поток сознания, а потом сообщение "разобрался !". Абсолютное желание помочь ТОЛЬКО себе, а на других плевать, т.к. другие могут потом найти топик через гугл, обрадоваться тому что его проблема схожа, а потом резко обломиться, т.к. в конце только "разобрался!" и никаких намеков на то в чем именно была проблема. Неужели вы сами не сталкивались с подобным разочарованием никогда ?
Научитесь думать не только о СЕБЕ.
sergiks
Re: Конференция
Сообщение sergiks »
новичок - это значит новичок и мне еще многое непонятно, указанные Вами выше слова(например "каретка", теги CODE и SPOLER).
обслуживание отказались продлевать, мотивируя тем, что прошло некоторое время после окончания договора обслуживания и мы там могли многое уже накосячить (в астериске, хотя в самой телефонии нет проблем, только в конференции вот всплыл вопрос, и за отдельную оплату тоже отказались) и вообще нам некогда (примерно вот такой был ответ).
почему отсекался последний номер разобрался, дело было в том, что просто курсор после последнего номера был не переведен на следующую пустую строку
p.s. virus_net на критику отреагировал нормально, спасибо
