Проблемы с картой Sangoma A102
Neo0
Сообщение Neo0 »
Приветствую,
Вкратце проблема (до вчера работало лет 5, конфиг не менялся):
FreeBSD  7.0-RELEASE FreeBSD 7.0-RELEASE
Asterisk 1.4.21.2
Zaptel Version: 1.4.0-BSD
Удивило это (пусто!):
[root@ /usr/local/sbin]# wanrouter hwprobe
| Wanpipe Hardware Probe Info |
Card Cnt:
[root@ /usr/local/sbin]# ztcfg -vvvv
Keyword: [loadzone], Value: [ru]
Keyword: [defaultzone], Value: [ru]
Keyword: [span], Value: [1,0,0,ccs,hdb3]
Keyword: [bchan], Value: [1-15,17-29]
Keyword: [dchan], Value: [16]
Keyword: [span], Value: [2,0,0,ccs,hdb3]
Keyword: [bchan], Value: [32-46,48-62]
Keyword: [dchan], Value: [47]
Echo Canceller: MG2
Configuration
SPAN 1: CCS/HDB3 Build-out: 0 db (CSU)/0-133 feet (DSX-1)
SPAN 2: CCS/HDB3 Build-out: 0 db (CSU)/0-133 feet (DSX-1)
Channel map:
Channel 01: Clear channel (Default) (Slaves: 01)
Channel 02: Clear channel (Default) (Slaves: 02)
Channel 03: Clear channel (Default) (Slaves: 03)
Channel 04: Clear channel (Default) (Slaves: 04)
Channel 05: Clear channel (Default) (Slaves: 05)
Channel 06: Clear channel (Default) (Slaves: 06)
Channel 07: Clear channel (Default) (Slaves: 07)
Channel 08: Clear channel (Default) (Slaves: 08)
Channel 09: Clear channel (Default) (Slaves: 09)
Channel 10: Clear channel (Default) (Slaves: 10)
Channel 11: Clear channel (Default) (Slaves: 11)
Channel 12: Clear channel (Default) (Slaves: 12)
Channel 13: Clear channel (Default) (Slaves: 13)
Channel 14: Clear channel (Default) (Slaves: 14)
Channel 15: Clear channel (Default) (Slaves: 15)
Channel 16: D-channel (Default) (Slaves: 16)
Channel 17: Clear channel (Default) (Slaves: 17)
Channel 18: Clear channel (Default) (Slaves: 18)
Channel 19: Clear channel (Default) (Slaves: 19)
Channel 20: Clear channel (Default) (Slaves: 20)
Channel 21: Clear channel (Default) (Slaves: 21)
Channel 22: Clear channel (Default) (Slaves: 22)
Channel 23: Clear channel (Default) (Slaves: 23)
Channel 24: Clear channel (Default) (Slaves: 24)
Channel 25: Clear channel (Default) (Slaves: 25)
Channel 26: Clear channel (Default) (Slaves: 26)
Channel 27: Clear channel (Default) (Slaves: 27)
Channel 28: Clear channel (Default) (Slaves: 28)
Channel 29: Clear channel (Default) (Slaves: 29)
Channel 32: Clear channel (Default) (Slaves: 32)
Channel 33: Clear channel (Default) (Slaves: 33)
Channel 34: Clear channel (Default) (Slaves: 34)
Channel 35: Clear channel (Default) (Slaves: 35)
Channel 36: Clear channel (Default) (Slaves: 36)
Channel 37: Clear channel (Default) (Slaves: 37)
Channel 38: Clear channel (Default) (Slaves: 38)
Channel 39: Clear channel (Default) (Slaves: 39)
Channel 40: Clear channel (Default) (Slaves: 40)
Channel 41: Clear channel (Default) (Slaves: 41)
Channel 42: Clear channel (Default) (Slaves: 42)
Channel 43: Clear channel (Default) (Slaves: 43)
Channel 44: Clear channel (Default) (Slaves: 44)
Channel 45: Clear channel (Default) (Slaves: 45)
Channel 46: Clear channel (Default) (Slaves: 46)
Channel 47: D-channel (Default) (Slaves: 47)
Channel 48: Clear channel (Default) (Slaves: 48)
Channel 49: Clear channel (Default) (Slaves: 49)
Channel 50: Clear channel (Default) (Slaves: 50)
Channel 51: Clear channel (Default) (Slaves: 51)
Channel 52: Clear channel (Default) (Slaves: 52)
Channel 53: Clear channel (Default) (Slaves: 53)
Channel 54: Clear channel (Default) (Slaves: 54)
Channel 55: Clear channel (Default) (Slaves: 55)
Channel 56: Clear channel (Default) (Slaves: 56)
Channel 57: Clear channel (Default) (Slaves: 57)
Channel 58: Clear channel (Default) (Slaves: 58)
Channel 59: Clear channel (Default) (Slaves: 59)
Channel 60: Clear channel (Default) (Slaves: 60)
Channel 61: Clear channel (Default) (Slaves: 61)
Channel 62: Clear channel (Default) (Slaves: 62)
60 channels configured.
ZT_SPANCONFIG failed on span 1: Device not configured (6)
[root@ /usr/local/sbin]# ./wanrouter start
Starting up device: wanpipe1
        wanconfig: WAN device wanpipe1 driver load failed !!
                 : ioctl(wanpipe1,ROUTER_VER) failed:
                 :      22 - Unknown error: -22
                 : Wanpipe Module Installation Failure!
                 :   1. New Wanpipe modules failed to install
                 :   during wanpipe installation.
                 :   2. Wanpipe device doesn't exists in a list.
                 :   3. Wanpipe data structure is corrupted.
Starting up device: wanpipe2
        wanconfig: WAN device wanpipe2 driver load failed !!
                 : ioctl(wanpipe2,ROUTER_VER) failed:
Configuring interfaces: wag1 ifconfig: interface wag1 does not exist
done.
Configuring interfaces: wbg1 ifconfig: interface wbg1 does not exist
done.
Echo Canceller: MG2
Configuration
Конфиг wanpipe1 и wanpipe2
[devices]
wanpipe1 = WAN_AFT_TE1, Comment
[interfaces]
wag1 = wanpipe1, , TDM_VOICE, Comment
[wanpipe1]
CARD_TYPE 	= AFT
S514CPU 	= A
CommPort 	= PRI
AUTO_PCISLOT 	= NO
PCISLOT 	= 11
PCIBUS  	= 1
FE_MEDIA	= E1
FE_LCODE	= HDB3
FE_FRAME	= NCRC4
FE_LINE		= 1
TE_CLOCK 	= NORMAL
TE_REF_CLOCK    = 0
TE_SIG_MODE     = CCS
TE_HIGHIMPEDANCE	= NO
LBO 		= 120OH
FE_TXTRISTATE	= NO
MTU 		= 1500
UDPPORT 	= 9000
TTL		= 255
IGNORE_FRONT_END = NO
TDMV_SPAN	= 1
TDMV_DCHAN	= 0
TDMV_HW_DTMF	= NO
[wag1]
ACTIVE_CH	= ALL
TDMV_ECHO_OFF	= NO
TDMV_HWEC	= NO
[devices]
wanpipe2 = WAN_AFT_TE1, Comment
[interfaces]
wbg1 = wanpipe2, , TDM_VOICE, Comment
[wanpipe2]
CARD_TYPE 	= AFT
S514CPU 	= A
CommPort 	= PRI
AUTO_PCISLOT 	= NO
PCISLOT 	= 11
PCIBUS  	= 1
FE_MEDIA	= E1
FE_LCODE	= HDB3
FE_FRAME	= NCRC4
FE_LINE		= 2
TE_CLOCK 	= MASTER
TE_REF_CLOCK    = 1
TE_SIG_MODE     = CCS
LBO 		= 120OH
FE_TXTRISTATE	= NO
MTU 		= 1500
UDPPORT 	= 9000
TTL		= 255
TDMV_SPAN	= 2
TDMV_DCHAN	= 0
TDMV_HW_DTMF	= NO
[wbg1]
ACTIVE_CH	= ALL
TDMV_ECHO_OFF	= NO
TDMV_HWEC	= NO
Конфиги zapata.conf и zaptel.conf:
;Zaptel Channels Configurations (zapata.conf)
;For detailed zapata options, view /etc/asterisk/zapata.conf.orig
[trunkgroups]
[channels]
context=default
usecallerid=yes
hidecallerid=no
callwaiting=yes
usecallingpres=yes
callwaitingcallerid=yes
threewaycalling=yes
transfer=yes
canpark=yes
cancallforward=yes
callreturn=yes
echocancel=yes
echocancelwhenbridged=yes
relaxdtmf=yes
rxgain=0.0
txgain=0.0
group=1
callgroup=1
pickupgroup=1
immediate=no
resetinterval=never
;faxdetect=both
;Sangoma A102 port 1 [slot:11 bus:1 span:1] <wanpipe1>
switchtype=euroisdn
;switchtype=national
context=from-pstn
group=0
signalling=pri_cpe
channel =>1-15,17-28
;Sangoma A102 port 2 [slot:11 bus:1 span:2] <wanpipe2>
switchtype=euroisdn
context=from-meridian
group=1
signalling=pri_net
channel =>32-46,48-62
# Zaptel Channels Configurations (zaptel.conf)
loadzone=ru
defaultzone=ru
#Sangoma A102 port 1 [slot:11 bus:1 span:1] <wanpipe1>
span=1,0,0,ccs,hdb3
bchan=1-15,17-29
dchan=16
#Sangoma A102 port 2 [slot:11 bus:1 span:2] <wanpipe2>
span=2,0,0,ccs,hdb3
bchan=32-46,48-62
dchan=47
Не могу понять, не работает сама карта на аппаратном уровне или проблема с wanpipe?
Если в wanpipe поможет ли его пересборка\переустановка?
Интерфейсов самой карты нет в ifconfig.
Канал E1 проверял через провайдера путём замыкания порта заглушкой (Tx на Rx), всё работает. Линки на карте горят зелёным. Звонки с внешних (например мобильных) сразу отваливаются.
P.S.
[root@ /usr/local/sbin]# ./wancfg_zaptel
#    Sangoma Wanpipe:  Zaptel/SMG/TDMAPI/BOOT Configuration Script     #
#                             v2.13                                    #
#                     Sangoma Technologies Inc.                        #
#                        Copyright(c) 2008.                            #
Would you like to generate /usr/local/etc/asterisk/zapata.conf
 1. YES
 2. NO
[1-2]:2
Configuring T1/E1 cards [A101/A102/A104/A108]
Configuring analog cards [A200/A400]
#                             SUMMARY                             #
No Sangoma voice compatible cards found/configured
Neo0
Re: Проблемы с картой Sangoma A102
Сообщение Neo0 »
Не видно?:) Ок
Схема E1 > Asterisk1 > LAN/WLAN (по SIP протоколу)> Asterisk2 > ATC
При исходящем звонке c АТС лог на Asterisk2:
...    -- Got SIP response 503 "Service Unavailable" back from ***ip****
       -- SIP/Asterisk2-11ec2330 is circuit-busy  ...
В это время на Asterisk1 лог в sip debug:
...[Feb  5 15:49:20] WARNING[2070]: channel.c:3009 ast_request: No channel type registered for 'Zap'
   [Feb  5 15:49:20] WARNING[2070]: app_dial.c:1236 dial_exec_full: Unable to create channel of type 'Zap' (cause 66 - Channel not implemented)...
При звонке на свой номер (например с мобильного) как я и писал звонок у вызывающего сразу отпадает.
Ну и пусто здесь
Card Cnt:
Да ещё, в /var/log/asterisk/mesages при перезапуске драйвера wanpipe:
Feb  5 14:03:05  kernel: wanpipe1: ERROR: Failed to find this device in a list!
Feb  5 14:03:05  kernel: wanpipe2: ERROR: Failed to find this device in a list!
Последний раз редактировалось Neo0 05 фев 2014, 16:02, всего редактировалось 1 раз.
Neo0
Сообщение Neo0 »
Абсолютно.
Недели 1.5 назад переносили волокна оптики и модем E1 с первым Asterisk сервером (с которым проблема) на другое место. Но это по физике. По логике ничего не делалось.
Всё это время телефония после переноса работала в обычном режиме.
Neo0
Сообщение Neo0 »
Да нет не первый раз конечно перезагрузился:) Я имею ввиду что телефония работала без особых проблем это время. Так то перезагрузки естественно были и по питанию тоже.
P.S. Есть вторая такая же плата, сейчас попробую поставить вместо той, в тот же слот PCI.
Упал низкоуровненвый драйвер ядра wanpipe E1
и, как следствие, нету каналов ZAP
Я думаю надо посмотреть dmesg и журнал /var/log/messages
и попытаться загрузить драйвер ядра командой, если успешно (смотрим dmesg!), то уже module reload chan_zap.so
Neo0
Сообщение Neo0 »
Не успел листинг команд сбросить который вы просили потому что уже выключил сервер.
Переставил карту в другой слот PCI пока, ту же карту.
Листинг (но нужно учесть что карта уже видится по крайней мере по команде wanrouter hwprobe)
pciconf -lv :
sdla0@pci0:1:9:0:       class=0x028000 card=0x3313a112 chip=0x00401923 rev=0x00 hdr=0x00
    vendor     = 'Sangoma Technologies Corp'
    device     = 'A200/Remora FXO/FXS Analog AFT card'
    class      = network
kldstat :
[root@ /usr/home/mfkuser]# kldstat
Id Refs Address    Size     Name
 1    9 0xc0400000 906518   kernel
 2    1 0xc0d07000 6a32c    acpi.ko
 3    3 0xc313b000 ea000    wanpipe.ko
 4    1 0xc3227000 34000    zaptel.ko
 5    2 0xc327f000 25000    sdladrv.ko
 6    3 0xc32a8000 8000     wanrouter.ko
 7    1 0xc32dc000 19000    wanpipe_lip.ko
 8    1 0xc32f9000 50000    wanec.ko
ded писал(а): module reload chan_zap.so
или как там в версии 1.4...
Neo0
Сообщение Neo0 »
Плата видится теперь по команде wanrouter hwprobe.
По команде ztcfg нет ошибок.
Интерфейсы обоих портов есть в ifconfig.
Конфиг wanpipe1 и wanpipe2 тот же что и был за исключением slot естественно (другой pci слот).
В zaptel.conf так же слот поправлен. Параметры потока те же
Сделал wanrouter start, оба интерфейса инициализировались без ошибок.
Но основная ошибка осталась та же (из sip debug):
[Feb  5 18:00:02] WARNING[1042]: channel.c:3009 ast_request: No channel type registered for 'Zap'
[Feb  5 18:00:02] WARNING[1042]: app_dial.c:1236 dial_exec_full: Unable to create channel of type 'Zap' (cause 66 - Channel not implemented)
Остальной листинг выложу позже, уже ушёл с места..
Не проходят звонки. Буду дальше копать.
P.S. Уходя забыл проверить в zapata.conf параметр switchtype
Поставил national всё заработало. (стоял euroisdn)
Всем спасибо:)
Последний раз редактировалось Neo0 05 фев 2014, 18:20, всего редактировалось 1 раз.
Нет каналов Zap, я уже писал выше. Надо
или выгрузить модуль канала и снова загрузить.
Прежде чем делать звонки убедитесь, что каналы есть
CLI> zap show channels
