Звонок через AGI с помощью pyst
ihard
Сообщение ihard »
Пытаюсь совершить звонок через AGI с помощью Python и модуля pyst. Версия Asterisk 1.8.10 ОС Ubuntu 12.04
В логе SIP проблема заключается как я понял в этом:
в INVITE:
From: "Anonymous" <sip:79211234567@anonymous.invalid>;
и ответ сервера (мегафоновский Мультифон):
Received response: "Forbidden" from '"Anonymous" <sip:79211234567@anonymous.invalid>;
Настройки:
sip.conf
callerid="79211234567"
context=default                 ; Default context for incoming calls
allowguest=no                  ; Allow or reject guest calls (default is yes)
allowoverlap=no                 ; Disable overlap dialing support. (Default is yes)
udpbindaddr=0.0.0.0             ; IP address to bind UDP listen socket to (0.0.0.0 binds to all)
tcpenable=yes                   ; Enable server for incoming TCP connections (default is no)
tcpbindaddr=0.0.0.0             ; IP address for TCP server to bind to (0.0.0.0 binds to all interfaces)
srvlookup=yes                   ; Enable DNS SRV lookups on outbound calls
allow=all                    ; Allow codecs in order of preference
useragent=X-Lite release 1011s stamp 41150
registertimeout=60             ; retry registration calls every 20 seconds (default)
register => 79211234567@multifon.ru:secret:79211234567@sbc.megafon.ru:5060/79211234567
sendrpid=yes
[authentication]
[basic-options](!)                ; a template
        dtmfmode=rfc2833
        context=from-office
[natted-phone](!,basic-options)   ; another template inheriting basic-options
        directmedia=no
[public-phone](!,basic-options)   ; another template inheriting basic-options
        directmedia=yes
[my-codecs](!)                    ; a template for my preferred codecs
        allow=ilbc
        allow=g729
        allow=gsm
        allow=g723
        allow=ulaw
[ulaw-phone](!)                   ; and another one for ulaw-only
        allow=ulaw
[multifon]
dtmfmode=inband
username=79211234567
type=peer
secret=secret
host=sbc.megafon.ru
fromuser=79211234567
fromdomain=multifon.ru
port=5060
nat=no
context=incoming
insecure=port,invite
transport=tcp
qualify=no
callerid="79211234567" <79211234567>
extensions.conf
[out]
exten =>_.,1,Dial(SIP/multifon/${EXTEN},60,t)
exten => h,1,NoOp(Call hunged up)
Код скрипта:
test.py
#!/usr/bin/python
# -*- coding: utf-8 -*-
import asterisk.manager
import sys
manager = asterisk.manager.Manager()
try:
	try:
		manager.connect('localhost')
		manager.login('zabbix', 'zabbix')
		response = manager.originate('SIP/79219876543@multifon','1',context='out',priority='1')
		print response
		manager.logoff()
	except asterisk.manager.ManagerSocketException, (errno, reason):
		print "Error connecting to the manager: %s" % reason
		sys.exit(1)
	except asterisk.manager.ManagerAuthException, reason:
		print "Error logging in to the manager: %s" % reason
		sys.exit(1)
	except asterisk.manager.ManagerException, reason:
		print "Error: %s" % reason
		sys.exit(1)
finally:
	manager.close()
Подскажите куда копать? Есть ли решение?
Через SoftPhone звонки совершаются нормально, однако хотелось бы заставить работать и этот вариант.
Samael28
Re: Звонок через AGI с помощью pyst
Сообщение Samael28 »
Посмотрите на параметр CallerID команды Originate
Мой профайл на Upwork
ihard
Сообщение ihard »
Ошибка ушла, звонок идет, спасибо!
