asterisk 11 + fail2ban (перестал банить)
kom-pik
Сообщение kom-pik »
fail2ban перестал банить
./jail.conf
[DEFAULT]
ignoreip =
bantime  = 600
findtime  = 600
maxretry = 3
backend = auto
[asterisk-iptables]
enabled  = true
filter   = asterisk
action   = iptables-allports[name=ASTERISK, protocol=all]
           sendmail-whois[name=ASTERISK, dest=root, sender=asterisk-iptables]
logpath  = /var/log/asterisk/messages
maxretry = 3
findtime = 3600
bantime = 36000
destemail = support@domain.ru
ignoreip = wan/24  lan/12
./filter.d/asterisk.conf
[INCLUDES]
[Definition]
failregex = .*NOTICE.* .*: Registration from '.*' failed for '<HOST>' - Wrong password
            .*NOTICE.* .*: Registration from '.*' failed for '<HOST>' - Peer is not supposed to register
            .*NOTICE.* .*: Registration from '.*' failed for '<HOST>:.*' - Wrong password
            .*NOTICE.* .*: Registration from '.*' failed for '<HOST>' - No matching peer found
            .*NOTICE.* .*: Registration from '.*' failed for '<HOST>:.*' - No matching peer found
            .*NOTICE.* .*: Registration from '.*' failed for '<HOST>:.*' - Username/auth name mismatch
            .*NOTICE.* .*: Registration from '.*' failed for '<HOST>:.*' - Device does not match ACL
            .*NOTICE.* .*: Registration from '.*' failed for '<HOST>:.*' - Peer is not supposed to register
            .*NOTICE.* .*: Registration from '.*' failed for '<HOST>:.*' - ACL error (permit/deny)
            .*NOTICE.* .*: Registration from '\".*\".*' failed for '<HOST>:.*' - No matching peer found
            .*NOTICE.* .*: Registration from '\".*\".*' failed for '<HOST>:.*' - Wrong password
            .*NOTICE.* <HOST> failed to authenticate as '.*'$
            .*NOTICE.* .*: No registration for peer '.*' \(from <HOST>\)
            .*NOTICE.* .*: Host <HOST> failed MD5 authentication for '.*' (.*)
            .*NOTICE.* .*: Failed to authenticate user .*@<HOST>.*
            .*NOTICE.* .*[logfiles]: <HOST> failed to authenticate as '.*'
            .*NOTICE.* .*: <HOST> tried  to authenticate with nonexistent user '.*'
            .*VERBOSE.*SIP/<HOST>-.*Received incoming SIP connection from unknown peer
            .*NOTICE.* .*: Sending fake auth rejection for device.* \[IP: <HOST>:.*\]
ignoreregex =
./asterisk/logger.conf
dateformat=%F %T
[logfiles]
console => notice,warning,error
messages => notice,warning,error
messages => security
full => notice,warning,error,debug,verbose,dtmf,fax
Connected to Asterisk 11.5.0 currently running on server (pid = 1152)
[2013-12-26 08:30:18] NOTICE[1238]: chan_sip.c:27919 handle_request_register: Registration from '"0002499037" <sip:0002499037@ip>' failed for '176.74.14.86:5060' - Wrong password
[2013-12-26 08:30:18] NOTICE[1238]: chan_sip.c:27919 handle_request_register: Registration from '"0002499038" <sip:0002499038@ip>' failed for '176.74.14.86:5060' - Wrong password
[2013-12-26 08:33:18] NOTICE[1238]: chan_sip.c:27919 handle_request_register: Registration from '"0002499037" <sip:0002499037@ip>' failed for '176.74.14.86:5060' - Wrong password
[2013-12-26 08:33:18] NOTICE[1238]: chan_sip.c:27919 handle_request_register: Registration from '"0002499038" <sip:0002499038@ip>' failed for '176.74.14.86:5060' - Wrong password
[2013-12-26 08:33:18] NOTICE[1238] chan_sip.c: Registration from '"0002499037" <sip:0002499037@ip>' failed for '176.74.14.86:5060' - Wrong password
[2013-12-26 08:33:18] SECURITY[1165] res_security_log.c: SecurityEvent="InvalidPassword",EventTV="1388046798-520090",Severity="Error",Service="SIP",EventVersion="2",AccountID="0002499037",SessionID="0x7f0eedc82278",LocalAddress="IPV4/UDP/ip/5060",RemoteAddress="IPV4/UDP/176.74.14.86/5060",Challenge="2ffb348e",ReceivedChallenge="2ffb348e",ReceivedHash="fb80d1d181d8ba969b94c72836fbc9cc"
[2013-12-26 08:33:18] NOTICE[1238] chan_sip.c: Registration from '"0002499038" <sip:0002499038@ip>' failed for '176.74.14.86:5060' - Wrong password
[2013-12-26 08:33:18] SECURITY[1165] res_security_log.c: SecurityEvent="InvalidPassword",EventTV="1388046798-520764",Severity="Error",Service="SIP",EventVersion="2",AccountID="0002499038",SessionID="0x7f0eec6bbd28",LocalAddress="IPV4/UDP/ip/5060",RemoteAddress="IPV4/UDP/176.74.14.86/5060",Challenge="4e13c1bb",ReceivedChallenge="4e13c1bb",ReceivedHash="8c248aada11d99a6cb34157a9c796f64"
[2013-12-26 08:34:44] SECURITY[1165] res_security_log.c: SecurityEvent="ChallengeSent",EventTV="1388046884-703707",Severity="Informational",Service="SIP",EventVersion="1",AccountID="sip:0000001400@ip",SessionID="0x7f0eec70c008",LocalAddress="IPV4/UDP/ip/5060",RemoteAddress="IPV4/UDP/176.74.14.86/5060",Challenge="27d815f2"
Подскажите возможные причины
В какую сторону "рыть"?
Re: asterisk 11 + fail2ban (перестал банить)
Сообщения в логе (выше) 100% ловятся правилом
failregex = .*NOTICE.* .*: Registration from '.*' failed for '<HOST>:.*' - Wrong password
Проверил сам, только что.
Тестируйте сами
fail2ban-regex /etc/fail2ban/filter.d/asterisk.conf ./asterisk/logger.conf
kom-pik
Сообщение kom-pik »
Running tests
Use regex file : /etc/asterisk/logger.conf
No [Definition] section in /etc/asterisk/logger.conf
Очень рассчитываю на Ваше понимание, а не на умение копипастить.
Use regex file : /etc/asterisk/logger.conf - файл /etc/asterisk/logger.conf - это <LOG>, а не <REGEX> (regex file)
# fail2ban-regex
Usage: /usr/bin/fail2ban-regex [OPTIONS] <LOG> <REGEX> [IGNOREREGEX]
Fail2Ban v0.8.7 reads log file that contains password failure report
and bans the corresponding IP addresses using firewall rules.
This tools can test regular expressions for "fail2ban".
Options:
    -h, --help              display this help message
    -V, --version           print the version
    -v, --verbose           verbose output
Log:
    string                  a string representing a log line
    filename                path to a log file (/var/log/auth.log)
Regex:
    string                  a string representing a 'failregex'
    filename                path to a filter file (filter.d/sshd.conf)
IgnoreRegex:
    string                  a string representing an 'ignoreregex'
kom-pik
Сообщение kom-pik »
fail2ban-regex /var/log/asterisk/messages /etc/fail2ban/filter.d/asterisk.conf
Running tests
Use regex file : /etc/fail2ban/filter.d/asterisk.conf
Use log file   : /var/log/asterisk/messages
176.74.14.86 (Thu Dec 26 13:22:55 2013) (already matched)
    89.19.189.64 (Thu Dec 26 13:25:15 2013) (already matched)
    176.74.14.86 (Thu Dec 26 13:25:56 2013) (already matched)
Date template hits:
1411191 hit(s): Year-Month-Day Hour:Minute:Second
Success, the total number of match is 3792
However, look at the above section 'Running tests' which could contain important
information.
Всё работает, но fail2ban или не запущен, или сконфигурен неверно.
kom-pik
Сообщение kom-pik »
Банил же, пару дней назад перестал и ночью сегодня ломанули
Проковыряли дырочку через вэб интерфейс, остановили или повредили fail2ban, и готово!
Это их работа такая.
kom-pik
Сообщение kom-pik »
у нас на астере нет вебки
kom-pik
Сообщение kom-pik »
единственное есть скрипт php который парсит логи и кладет на билинг
