Addpack ap-gs1002 + Asterisk исходящие на вторую SIM карту
Menog
Сообщение Menog »
не пойму что не так, не могу позвонить через вторую симку извне. входящие все ок, а исходящие идут только через 1-ю симку , даже если чётко указать GSM2 пир.
addpack.cfg
Current configuration:
version 8.51.008
hostname GS1002
username root password router administrator
username guest password guest user
script ntpdate default
 resynchronize 1 0
 server ip time.yandex.ru
interface Loopback0
 ip address 127.0.0.1 255.0.0.0
interface FastEthernet0/0
 ip address 192.168.1.198 255.255.255.0
 speed auto
 no qos-control
interface FastEthernet0/1
 no ip address
 speed auto
 no qos-control
interface FastEthernet0/1:1
 ip address 192.168.10.1 255.255.255.0
ip route 0.0.0.0 0.0.0.0 192.168.1.100 10
dhcp server
http server
dns name-server 192.168.1.100
logging command
logging event 4-warning
logging on
! VoIP configuration.
! Voice service voip configuration.
voice service voip
 protocol sip
 dtmf-relay out-of-band
 fax protocol t38 redundancy 0
 fax rate 9600
 h323 call start fast
 h323 call tunnel enable
 no call-barring unconfigured-ip-address
 no voip-inbound-call-barring enable
! Voice port configuration.
! GSM
voice-port 0/0
 connection plar 881
 ring detect-timeout 70
 dial-tone-generate
 caller-id enable
 caller-id type etsi
 caller-id name disable
 gsm-auto-recharge balance-check-time 0
! GSM
voice-port 0/1
 connection plar 882
 dial-tone-generate
 caller-id enable
 caller-id type etsi
! FXS
voice-port 0/2
 caller-id enable
! FXS
voice-port 0/3
 caller-id enable
! service port group configuration.
! Pots peer configuration.
dial-peer voice 1512 pots
 destination-pattern 307
 port 0/2
 no register e164
 user-name fxs1
 user-password fxs1pass
dial-peer voice 1513 pots
 destination-pattern 308
 port 0/3
 no register e164
 user-name fxs2
 user-password fxs2pass
dial-peer voice 3048 pots
 destination-pattern .T
 port 0/0
 call-waiting
 user-name gsm1
 user-password gsm1pass
 preference 2
dial-peer voice 3049 pots
 port 0/1
 call-waiting
 user-name gsm2
 user-password gsm2pass
 preference 3
! Voip peer configuration.
dial-peer voice 10100 voip
 destination-pattern 88[12]
 session target sip-server
 session protocol sip
 voice-class codec 0
 no vad
 dtmf-relay rtp-2833
 description asterisk
gatekeeper
! Gateway configuration.
gateway
 h323-id voip.192.168.1.198
 no ignore-msg-from-other-gk
! Codec classes configuration.
voice class codec 0
 codec preference 1 g711alaw
 codec preference 2 g711ulaw
 codec preference 3 g729
 codec preference 4 g7231r53
 codec preference 5 g726r16
 codec preference 6 g726r32
! Translation Rule configuration.
translation-rule 10100
 rule 0      88[12]                   %01%99
! SIP UA configuration.
sip-ua
 user-register
 sip-server 192.168.1.100 5060 126
 called-party-number to-field
 register e164
! Tones
! SMTP sendmail configuration
sms-delivery
line console
line vty
mobile dev-restart-by-unreg 300
mobile 0/0
 gsm sms-language utf8
mobile 0/1
end
sip.cfg
[addpac]
username=addpac
insecure=port,invite
context=incoming
dtmfmode=auto
host=192.168.1.198
allow=gsm ; GSM consumes far less bandwidth than ulaw
allow=ulaw
nat=no
canreinvite=yes
[881]
context=incoming
dtmfmode=auto
[882]
context=incoming
dtmfmode=auto
[gsm1]
username=gsm1
secret=gsm1pass
context=outbound-local
dtmfmode=rfc2833
deny=0.0.0.0/0.0.0.0
permit=192.168.1.198/255.255.255.255
[gsm2]
username=gsm2
secret=gsm2pass
dtmfmode=rfc2833
[gs715](!) ; <== обратите внимание, восклицательный знак
; взят в круглые скобки. Это признак шаблона.
context=phones
allow=ulaw
dtmfmode=rfc2833
secret=qwerty
[xlite](!)
; Turn off silence suppression in X-Lite ("Transmit Silence"=YES)!
; Note that Xlite sends NAT keep-alive packets, so qualify=yes is not needed
;regexten=1234                   ; When they register, create extension 1234
context=phones
host=dynamic                    ; This device needs to register
secret=qwerty
directmedia=no                  ; Typically set to NO if behind NAT
allow=ulaw
[101](gs715)
callerid = "Secretary" <101>
callgroup=1
pickupgroup=1
[103](gs715)
callerid = "User 103" <103>
callgroup=1
pickupgroup=1
extension.cfg
[globals]
autofallthrough=yes
[incoming]
exten => 881,1,Dial(SIP/101)
exten => 881,n,Hangup()
exten => 882,1,Dial(SIP/101)
exten => 882,n,Hangup()
include => employees
include => phones
[outbound-local]
exten => _8XXXXXXXXXX,1,Dial(SIP/addpac/${EXTEN},30)
exten => _8XXXXXXXXXX,n,HangUp()
[outbound-global]
exten => _9XXXXXXXXXXX,1,Dial(SIP/addpac/+${EXTEN:1},40)
exten => _9XXXXXXXXXXX,n,HangUp()
exten => _9XXXXXXXXXXXX,1,Dial(SIP/addpac/+${EXTEN:1},40)
exten => _9XXXXXXXXXXXX,n,HangUp()
exten => 910,1,Dial(SIP/gsm2/+79261111111,40) ; Проверка GSM1 пира
exten => 910,HangUp()
exten => 911,1,Dial(SIP/gsm2/+79261111111,40) ; Проверка GSM2 пира - звонит Всё равно через первый!!!!!
exten => 911,HangUp()
exten => 912,1,Dial(SIP/gsm2/+79261111111,40) ; Проверка общего addpack пира - не звонит, если первый GSM1 занят!!!
exten => 912,HangUp()
[phones]
include => outbound-local
include => outbound-global
[employees]
exten => _1XX,1,Dial(SIP/${EXTEN})
exten => _2XX,1,Dial(SIP/${EXTEN})
exten => _3XX,1,Dial(SIP/${EXTEN})
exten => _4XX,1,Dial(SIP/${EXTEN})
exten => _5XX,1,Dial(SIP/${EXTEN})
exten => _6XX,1,Dial(SIP/${EXTEN})
exten => _7XX,1,Dial(SIP/${EXTEN})
exten => 307,1,Dial(SIP/addpac/${EXTEN},20)
exten => 307,n,HangUp()
exten => 308,1,Dial(SIP/addpac/${EXTEN},20)
exten => 308,n,HangUp()
Последний раз редактировалось Menog 20 ноя 2013, 10:00, всего редактировалось 1 раз.
Re: Addpack ap-gs1002 + Asterisk исходящие на вторую SIM кар
потому
port 0/1
Menog
Сообщение Menog »
и?
что не так в этих строках?
preferense 2 и 3 же стоит
просто хотелось бы прижелании звонить через определенный GSM пир (SIP/GSM1 or SIP/GSM2)
а по умолчанию чтобы звонила на первый свободный (SIP/Addpac)
шлюз не в состоянии различить через какой пир вы набрали, т.к. с точки зрения протокола INVITE через разные пиры ничем не отличаются
можете убедиться сами включив sip debug
для отправки через разные порты на стороне астериска нужно добавлять префикс, а на шлюзе его отрезать
Menog
Сообщение Menog »
ок, это я сделаю, но без префиксов, если порт 0/0 занят, шлюз должен же зхвонить через 0/1 а он этого не делает!
хм....
а теперь делает!))
тогда не понятны мне cследующие записи в sip.cfg
[gsm1]
username=gsm1
secret=gsm1pass
dtmfmode=rfc2833
[gsm2]
username=gsm2
secret=gsm2pass
dtmfmode=rfc2833
если они всё равно звонят куда попало, то следует их вообще удалить и тупо использовать sip/addpac ?
вариантов настройки несколько
1. шлюз не регистрируется. на астериске один пир.
2. шлюз регистрируется. на астериске по одному пиру на линию.
3. комбинация из 1 и 2
Menog
Сообщение Menog »
хм, тогда очередной нубский вопрос:
как правильно зарегистрировать шлюз, чтобы с астерикса можно было звонить на определенный пир без префиксов?
никак
У Вас вопросы по AddPac? Вам сюда -
http://www.voipinfo.ru/forum/viewforum.php?f=9
проще по префиксу разделять
В астере добавляете 77 к номеру - а в addpac при виде 77 в начале номера, отрезаете 77 и отправляете по определенному каналу
