Глючит Cisco/SPA122
gofer_k
Глючит Cisco/SPA122
Сообщение gofer_k »
Привет всем
есть aster 1.8 к нему зацеплены 2 шлюза
1-ый Dlink 5004S
2-ой Cisco/SPA122
Оба шлюза и астер торчат в одном свиче.
Так вот Cisco/SPA122 постоянно отваливается в лог сыпется
[Jan  1 10:09:18] NOTICE[329]: chan_sip.c:27018 sip_poke_noanswer: Peer '4804' is now UNREACHABLE!  Last qualify: 43
[Jan  1 10:09:18] NOTICE[329]: chan_sip.c:27018 sip_poke_noanswer: Peer '4805' is now UNREACHABLE!  Last qualify: 41
[Jan  1 10:09:28] NOTICE[329]: chan_sip.c:21577 handle_response_peerpoke: Peer '4804' is now Reachable. (42ms / 2000ms)
[Jan  1 10:09:28] NOTICE[329]: chan_sip.c:21577 handle_response_peerpoke: Peer '4805' is now Reachable. (42ms / 2000ms)
[Jan  1 10:12:32] NOTICE[329]: chan_sip.c:27018 sip_poke_noanswer: Peer '4804' is now UNREACHABLE!  Last qualify: 43
[Jan  1 10:12:32] NOTICE[329]: chan_sip.c:27018 sip_poke_noanswer: Peer '4805' is now UNREACHABLE!  Last qualify: 41
[Jan  1 10:12:42] NOTICE[329]: chan_sip.c:21577 handle_response_peerpoke: Peer '4804' is now Reachable. (43ms / 2000ms)
[Jan  1 10:12:42] NOTICE[329]: chan_sip.c:21577 handle_response_peerpoke: Peer '4805' is now Reachable. (40ms / 2000ms)
    -- Message count requested for mailbox 4802 but voicemail not loaded.
[Jan  1 10:14:46] NOTICE[329]: chan_sip.c:27018 sip_poke_noanswer: Peer '4804' is now UNREACHABLE!  Last qualify: 43
[Jan  1 10:14:46] NOTICE[329]: chan_sip.c:27018 sip_poke_noanswer: Peer '4805' is now UNREACHABLE!  Last qualify: 41
[Jan  1 10:14:56] NOTICE[329]: chan_sip.c:21577 handle_response_peerpoke: Peer '4804' is now Reachable. (42ms / 2000ms)
[Jan  1 10:14:56] NOTICE[329]: chan_sip.c:21577 handle_response_peerpoke: Peer '4805' is now Reachable. (41ms / 2000ms)
[Jan  1 10:18:06] NOTICE[329]: chan_sip.c:27018 sip_poke_noanswer: Peer '4804' is now UNREACHABLE!  Last qualify: 41
[Jan  1 10:18:06] NOTICE[329]: chan_sip.c:27018 sip_poke_noanswer: Peer '4805' is now UNREACHABLE!  Last qualify: 36
[Jan  1 10:18:16] NOTICE[329]: chan_sip.c:21577 handle_response_peerpoke: Peer '4804' is now Reachable. (42ms / 2000ms)
[Jan  1 10:18:16] NOTICE[329]: chan_sip.c:21577 handle_response_peerpoke: Peer '4805' is now Reachable. (36ms / 2000ms)
[Jan  1 10:21:20] NOTICE[329]: chan_sip.c:27018 sip_poke_noanswer: Peer '4804' is now UNREACHABLE!  Last qualify: 43
[Jan  1 10:21:20] NOTICE[329]: chan_sip.c:27018 sip_poke_noanswer: Peer '4805' is now UNREACHABLE!  Last qualify: 41
[Jan  1 10:21:30] NOTICE[329]: chan_sip.c:21577 handle_response_peerpoke: Peer '4804' is now Reachable. (42ms / 2000ms)
[Jan  1 10:21:30] NOTICE[329]: chan_sip.c:21577 handle_response_peerpoke: Peer '4805' is now Reachable. (42ms / 2000ms)
[Jan  1 10:23:34] NOTICE[329]: chan_sip.c:27018 sip_poke_noanswer: Peer '4804' is now UNREACHABLE!  Last qualify: 43
[Jan  1 10:23:34] NOTICE[329]: chan_sip.c:27018 sip_poke_noanswer: Peer '4805' is now UNREACHABLE!  Last qualify: 41
[Jan  1 10:23:44] NOTICE[329]: chan_sip.c:21577 handle_response_peerpoke: Peer '4804' is now Reachable. (46ms / 2000ms)
[Jan  1 10:23:44] NOTICE[329]: chan_sip.c:21577 handle_response_peerpoke: Peer '4805' is now Reachable. (44ms / 2000ms)
    -- Message count requested for mailbox 4819 but voicemail not loaded.
[Jan  1 10:26:48] NOTICE[329]: chan_sip.c:27018 sip_poke_noanswer: Peer '4804' is now UNREACHABLE!  Last qualify: 43
[Jan  1 10:26:48] NOTICE[329]: chan_sip.c:27018 sip_poke_noanswer: Peer '4805' is now UNREACHABLE!  Last qualify: 41
[Jan  1 10:26:58] NOTICE[329]: chan_sip.c:21577 handle_response_peerpoke: Peer '4804' is now Reachable. (42ms / 2000ms)
[Jan  1 10:26:58] NOTICE[329]: chan_sip.c:21577 handle_response_peerpoke: Peer '4805' is now Reachable. (38ms / 2000ms)
[Jan  1 10:29:02] NOTICE[329]: chan_sip.c:27018 sip_poke_noanswer: Peer '4804' is now UNREACHABLE!  Last qualify: 43
[Jan  1 10:29:02] NOTICE[329]: chan_sip.c:27018 sip_poke_noanswer: Peer '4805' is now UNREACHABLE!  Last qualify: 41
[Jan  1 10:29:12] NOTICE[329]: chan_sip.c:21577 handle_response_peerpoke: Peer '4804' is now Reachable. (43ms / 2000ms)
[Jan  1 10:29:12] NOTICE[329]: chan_sip.c:21577 handle_response_peerpoke: Peer '4805' is now Reachable. (40ms / 2000ms)
[Jan  1 10:31:16] NOTICE[329]: chan_sip.c:27018 sip_poke_noanswer: Peer '4804' is now UNREACHABLE!  Last qualify: 43
[Jan  1 10:31:16] NOTICE[329]: chan_sip.c:27018 sip_poke_noanswer: Peer '4805' is now UNREACHABLE!  Last qualify: 41
[Jan  1 10:31:26] NOTICE[329]: chan_sip.c:21577 handle_response_peerpoke: Peer '4804' is now Reachable. (42ms / 2000ms)
[Jan  1 10:31:26] NOTICE[329]: chan_sip.c:21577 handle_response_peerpoke: Peer '4805' is now Reachable. (40ms / 2000ms)
С сетью проблем не вижу как я сказал все торчит в одном свиче.
В дебаге по этим пирам тоже ничего особенного
Dlink-Aster*CLI> sip set debug peer 4805
SIP Debugging Enabled for IP: 192.168.180.112
Reliably Transmitting (NAT) to 192.168.180.112:5061:
OPTIONS sip:4805@192.168.180.112:5061 SIP/2.0
Via: SIP/2.0/UDP 192.168.180.110:5060;branch=z9hG4bK5e508255;rport
From: "asterisk" <sip:asterisk@192.168.180.110>;tag=as3732afa8
To: <sip:4805@192.168.180.112:5061>
Contact: <sip:asterisk@192.168.180.110:5060>
Call-ID: 651f8d150dc414961745a13c570462c0@192.168.180.110:5060
CSeq: 102 OPTIONS
User-Agent: Asterisk PBX 1.8.24.0
Date: Thu, 01 Jan 1970 10:46:37 GMT
<--- SIP read from UDP:192.168.180.112:5061 --->
SIP/2.0 200 OK
To: <sip:4805@192.168.180.112:5061>;tag=ce78b3a5b0451ccbi1
CSeq: 102 OPTIONS
Server: Cisco/SPA122-1.3.2-XU(014)
Allow: ACK, BYE, CANCEL, INFO, INVITE, NOTIFY, OPTIONS, REFER
Supported: replaces
--- (10 headers 0 lines) ---
Really destroying SIP dialog '651f8d150dc414961745a13c570462c0@192.168.180.110:5060' Method: OPTIONS
Via: SIP/2.0/UDP 192.168.180.110:5060;branch=z9hG4bK1ce5b76f;rport
From: "asterisk" <sip:asterisk@192.168.180.110>;tag=as3ae8b2ff
Call-ID: 59f71ff0734a09a02dc379e449e9c710@192.168.180.110:5060
CSeq: 102 OPTIONS
Date: Thu, 01 Jan 1970 10:47:37 GMT
Retransmitting #1 (NAT) to 192.168.180.112:5061:
CSeq: 102 OPTIONS
Retransmitting #2 (NAT) to 192.168.180.112:5061:
CSeq: 102 OPTIONS
Retransmitting #3 (NAT) to 192.168.180.112:5061:
CSeq: 102 OPTIONS
[Jan  1 10:47:41] NOTICE[329]: chan_sip.c:27018 sip_poke_noanswer: Peer '4804' is now UNREACHABLE!  Last qualify: 43
Retransmitting #4 (NAT) to 192.168.180.112:5061:
CSeq: 102 OPTIONS
[Jan  1 10:47:41] NOTICE[329]: chan_sip.c:27018 sip_poke_noanswer: Peer '4805' is now UNREACHABLE!  Last qualify: 42
Really destroying SIP dialog '59f71ff0734a09a02dc379e449e9c710@192.168.180.110:5060' Method: OPTIONS
Via: SIP/2.0/UDP 192.168.180.110:5060;branch=z9hG4bK6fba9c91;rport
From: "asterisk" <sip:asterisk@192.168.180.110>;tag=as49064dd2
Call-ID: 6795969f11aca57451bb89405252bb4e@192.168.180.110:5060
CSeq: 102 OPTIONS
Date: Thu, 01 Jan 1970 10:47:51 GMT
[Jan  1 10:47:51] NOTICE[329]: chan_sip.c:21577 handle_response_peerpoke: Peer '4804' is now Reachable. (41ms / 2000ms)
SIP/2.0 200 OK
CSeq: 102 OPTIONS
Supported: replaces
[Jan  1 10:47:51] NOTICE[329]: chan_sip.c:21577 handle_response_peerpoke: Peer '4805' is now Reachable. (39ms / 2000ms)
Really destroying SIP dialog '6795969f11aca57451bb89405252bb4e@192.168.180.110:5060' Method: OPTIONS
Dlink-Aster*CLI> sip set debug off
SIP Debugging Disabled
запускал пинги в отдельном окне все пингуется связь не рвется на момент UNREACHABLE
Че за херня ума не приложу?
Re: Глючит Cisco/SPA122
qualify=no для Cisco SPA122 и забыли проблему. Они же в одном свиче? Зачем его бомбить OPTIONS?
gofer_k
Сообщение gofer_k »
:D зачем лечить болезнь если можно загасить симптом.
gofer_k писал(а):С сетью проблем не вижу как я сказал все торчит в одном свиче.
пять баллов. и ещё, видимо, все торчит в одном порту и на одном кабеле - так ? :)
вывод что с сетью проблем нет можно сделать только после траблшута. как минимум посмотреть скорость/дуплекс порта, каунтеры ошибок на порту и т.п.
то что оно "торчит в одном свиче" нИоЧем !
ded писал(а):Они же в одном свиче? Зачем его бомбить OPTIONS?
+1
gofer_k писал(а)::D зачем лечить болезнь если можно загасить симптом.
Зачем спрашивать советов, если Вы всё знаете?
Лечите болезнь: перепишите SIP прошивку Cisco SPA122 .
