Device                  : dongle0
  State                   : GSM not registered
  Audio                   : /dev/ttyUSB1
  Data                    : /dev/ttyUSB2
  Voice                   : Yes
  SMS                     : Yes
  Manufacturer            : huawei
  Model                   : E173
  Firmware                : 11.126.85.00.114
  IMEI                    : 35561XXXXXXXXXX
  IMSI                    : 25001XXXXXXXXXX
  GSM Registration Status : Not registered, but searching
  RSSI                    : 31, >= -75 dBm
  Mode                    : GSM/GPRS
  Submode                 : EDGE
  Provider Name           : NONE
  Location area code      : DF
  Cell ID                 : 4A7
  Subscriber Number       : Unknown
  SMS Service Center      : +79112009993
  Use UCS-2 encoding      : Yes
  USSD use 7 bit encoding : Yes
  USSD use UCS-2 decoding : No
  Tasks in queue          : 0
  Commands in queue       : 0
  Call Waiting            : Disabled
  Current device state    : start
  Desired device state    : start
  When change state       : now
  Calls/Channels          : 0
    Active                : 0
    Held                  : 0
    Dialing               : 0
    Alerting              : 0
    Incoming              : 0
    Waiting               : 0
    Releasing             : 0
Если сделать dongle reload now, то некоторое время все Ok, потом опять отваливается.
