addpac gs-1001A проседает сеть
Aeooe
Сообщение Aeooe »
Пробую сделать звонок на gsm шлюз в любую сторону и получаю вот такую сетевую аномалию:
64 bytes from 192.168.0.208: icmp_req=256 ttl=64 time=0.128 ms
64 bytes from 192.168.0.208: icmp_req=257 ttl=64 time=0.132 ms
64 bytes from 192.168.0.208: icmp_req=258 ttl=64 time=0.127 ms
64 bytes from 192.168.0.208: icmp_req=259 ttl=64 time=0.131 ms
64 bytes from 192.168.0.208: icmp_req=260 ttl=64 time=0.122 ms
64 bytes from 192.168.0.208: icmp_req=261 ttl=64 time=0.129 ms
64 bytes from 192.168.0.208: icmp_req=262 ttl=64 time=0.125 ms
64 bytes from 192.168.0.208: icmp_req=263 ttl=64 time=0.130 ms
64 bytes from 192.168.0.208: icmp_req=264 ttl=64 time=0.126 ms
64 bytes from 192.168.0.208: icmp_req=265 ttl=64 time=4141 ms
64 bytes from 192.168.0.208: icmp_req=266 ttl=64 time=3141 ms
64 bytes from 192.168.0.208: icmp_req=267 ttl=64 time=2142 ms
64 bytes from 192.168.0.208: icmp_req=268 ttl=64 time=1143 ms
64 bytes from 192.168.0.208: icmp_req=269 ttl=64 time=144 ms
64 bytes from 192.168.0.208: icmp_req=270 ttl=64 time=0.105 ms
Как видно сетка проседает в момент звонка переодически.
Предполагаю что проблема в конфигурации шлюза. Конфигурация:
PRIME_BBCODE_SPOILER_SHOW PRIME_BBCODE_SPOILER: apos.cfg
! APOS(tm) configuration saved from vty
! 2013/11/07 13:51:15
version 8.51.002
hostname GS1001
username root password router administrator
username guest password guest user
interface Loopback0
ip address 127.0.0.1 255.0.0.0
interface FastEthernet0/0
ip address dhcp
no ip dhcp unicast
ip nat outside
shutdown
speed auto
no qos-control
interface FastEthernet0/1
ip address 192.168.0.225 255.255.255.0
ip nat inside
speed auto
no qos-control
access-list 100 permit ip host 192.168.0.225 any
http server
logging command
logging event 4-warning
logging on
! VoIP configuration.
! Voice service voip configuration.
voice service voip
protocol sip
dtmf-relay rfc-2833
fax protocol t38 redundancy 0
fax rate 9600
h323 call start fast
h323 call tunnel enable
no call-barring unconfigured-ip-address
no voip-inbound-call-barring enable
! Voice port configuration.
! GSM
voice-port 0/0
connection plar 89066954640
caller-id enable
! service port group configuration.
! Pots peer configuration.
dial-peer voice 1000 pots
destination-pattern T
port 0/0
call-waiting
user-name addpac
user-password 123
! Voip peer configuration.
dial-peer voice 2000 voip
destination-pattern 89066954640
session target ip 192.168.0.208 5060
session protocol sip
voice-class codec 0
no vad
dtmf-relay rtp-2833
description asterisk
gatekeeper
! Gateway configuration.
gateway
h323-id voip.192.168.0.225
no ignore-msg-from-other-gk
! Codec classes configuration.
voice class codec 0
codec preference 1 g711alaw
codec preference 2 g711ulaw
codec preference 3 g729
! SIP UA configuration.
sip-ua
sip-username addpac
sip-password 123
sip-server 192.168.0.208
! Tones
voip-interface ip FastEthernet0/1
line console
line vty
gsm dev-restart-by-unreg 300
gsm 0/0
sms-language utf8
Подсобите в проблеме. Опыта в конфигурации подобного оборудования нет =) С цискостайл консолью не общался. Учусь. =)
Re: addpac gs-1001A проседает сеть
duplex full на 0/1
что то мне подсказывает что конфиг вы надергали из разных мест
потому как
и sip server
вроде совсем не совместимы
и опять же регистрация в 2 местах: и по портам и как gateway - так не должно быть
ищите рабочую конфигурацию
Aeooe
Сообщение Aeooe »
Пользовался вот этим примером конфигурации.
PS Может собака не в этом зарыта? может есть еще какие то факторы из-за которых проседает сеть?
Aeooe
Сообщение Aeooe »
Если звонить с машины на которой установлен астриск - сетка не проседает.
Проседает вся сетка, глюки в работе сети наблюдают все машины во время звонка.
в примере что то вот этого
не заметил
и как это проявляет себя акромя времени отклика на icmp?
Aeooe писал(а):может есть еще какие то факторы из-за которых проседает сеть?
Этих факторов вагон, телега и ещё вагон.
Aeooe писал(а):Проседает вся сетка, глюки в работе сети наблюдают все машины во время звонка.
Схема ? Оборудование ? Пинг большими пакетами ? Состояние портов коммутатора: скорость, дуплекс, ошибки ?
awsswa писал(а):ищите рабочую конфигурацию
Не правильный совет. Не нужно искать рабочую конфигурацию, её нужно создавать самому. Для каждой сети своя рабочая конфигурация.
Правильный совет -> читаем мануал, смотрим дебаг до полного просветления.
Aeooe писал(а):Пользовался вот этим примером конфигурации.
Пример на то и пример, чтобы человеку прочитавшему мануал было более понятнее применение настроек на практике.
Бездумный копипаст - причина многих проблем. А потом сидите и удивляетесь глюкам..... не понимаю...
Aeooe
Сообщение Aeooe »
Убедился в источнике проблемы - это нерадивый свитч колбасится под нагрузкой. Пробывал делать загрузку по tftp - ситуация аналогичная! без свитча все работает как часы!
