Asterisk и Panasonic TDE
Astronomik
Сообщение Astronomik »
Пробовал настроить подключение астериска к панасонику по sip. Звонки ходят только с панасоника на астериск. В обратную не идут.
вот что выдает дебаг
sip set debug on
SIP Debugging enabled
<--- SIP read from UDP:192.168.1.13:62700 --->
<--- SIP read from UDP:192.168.1.10:21482 --->
INVITE sip:4401@192.168.1.1 SIP/2.0
Via: SIP/2.0/UDP 192.168.1.10:21482;branch=z9hG4bK-d8754z-962d75e3b1a58d20-1---d8754z-;rport
Contact: <sip:4700@192.168.1.10:21482>
To: <sip:4401@192.168.1.1>
Call-ID: OTAzNzk3NTVkYTA0YmUzZjE5Y2IwZWMyMDI4M2JmZjU.
CSeq: 1 INVITE
Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REFER, NOTIFY, MESSAGE, SUBSCRIBE, INFO
Supported: replaces
User-Agent: X-Lite 4 release 4.0 stamp 58832
Content-Length: 406
v=0
o=- 12944217441319096 1 IN IP4 192.168.1.10
s=CounterPath X-Lite 4.0
c=IN IP4 192.168.1.10
t=0 0
a=ice-ufrag:1978f5
a=ice-pwd:e7c1cdc598999218392b97df7b5bdbb1
m=audio 57956 RTP/AVP 107 0 8 101
a=rtpmap:107 BV32/16000
a=fmtp:101 0-15
a=sendrecv
a=candidate:1 1 UDP 659136 192.168.1.10 57956 typ host
a=candidate:1 2 UDP 659134 192.168.1.10 57957 typ host
--- (13 headers 14 lines) ---
Sending to 192.168.1.10 : 21482 (no NAT)
Using INVITE request as basis request - OTAzNzk3NTVkYTA0YmUzZjE5Y2IwZWMyMDI4M2JmZjU.
Found peer '4700' for '4700' from 192.168.1.10:21482
<--- Reliably Transmitting (no NAT) to 192.168.1.10:21482 --->
SIP/2.0 401 Unauthorized
Via: SIP/2.0/UDP 192.168.1.10:21482;branch=z9hG4bK-d8754z-962d75e3b1a58d20-1---d8754z-;received=192.168.1.10;rport=21482
To: <sip:4401@192.168.1.1>;tag=as44a729b8
CSeq: 1 INVITE
Server: Asterisk PBX
WWW-Authenticate: Digest algorithm=MD5, realm="asterisk", nonce="4c1811f2"
Scheduling destruction of SIP dialog 'OTAzNzk3NTVkYTA0YmUzZjE5Y2IwZWMyMDI4M2JmZjU.' in 32000 ms (Method: INVITE)
ACK sip:4401@192.168.1.1 SIP/2.0
CSeq: 1 ACK
--- (8 headers 0 lines) ---
Via: SIP/2.0/UDP 192.168.1.10:21482;branch=z9hG4bK-d8754z-d9ba4f314d15c442-1---d8754z-;rport
CSeq: 2 INVITE
Supported: replaces
Authorization: Digest username="4700",realm="asterisk",nonce="4c1811f2",uri="sip:4401@192.168.1.1",response="1a54ff8988179f4ba829f499e0cd5d59",algorithm=MD5
Content-Length: 406
v=0
t=0 0
a=ice-ufrag:1978f5
a=fmtp:101 0-15
a=sendrecv
--- (14 headers 14 lines) ---
Found RTP audio format 107
Found RTP audio format 0
Found RTP audio format 8
Found RTP audio format 101
Found audio description format BV32 for ID 107
Capabilities: us - 0x6 (gsm|ulaw), peer - audio=0xc (ulaw|alaw)/video=0x0 (nothing)/text=0x0 (nothing), combined - 0x4 (ulaw)
Non-codec capabilities (dtmf): us - 0x1 (telephone-event), peer - 0x1 (telephone-event), combined - 0x1 (telephone-event)
Peer audio RTP is at port 192.168.1.10:57956
Looking for 4401 in DLPN_test (domain 192.168.1.1)
list_route: hop: <sip:4700@192.168.1.10:21482>
<--- Transmitting (no NAT) to 192.168.1.10:21482 --->
SIP/2.0 100 Trying
Via: SIP/2.0/UDP 192.168.1.10:21482;branch=z9hG4bK-d8754z-d9ba4f314d15c442-1---d8754z-;received=192.168.1.10;rport=21482
CSeq: 2 INVITE
Contact: <sip:4401@192.168.1.1>
Audio is at 192.168.4.1 port 13712
Reliably Transmitting (no NAT) to 192.168.4.2:5060:
INVITE sip:4401@192.168.4.2 SIP/2.0
Via: SIP/2.0/UDP 192.168.4.1:5060;branch=z9hG4bK09df928c;rport
From: "asterisk" <sip:asterisk@192.168.4.1>;tag=as49b4aea0
To: <sip:4401@192.168.4.2>
Contact: <sip:asterisk@192.168.4.1>
Call-ID: 3310cbc954289ce637a92d0d4ab1eb35@192.168.4.1
CSeq: 102 INVITE
User-Agent: Asterisk PBX
Date: Thu, 10 Mar 2011 07:57:45 GMT
Content-Length: 243
v=0
o=root 106643526 106643526 IN IP4 192.168.4.1
s=Asterisk PBX 1.6.2.9-2+squeeze1
c=IN IP4 192.168.4.1
t=0 0
m=audio 13712 RTP/AVP 8 101
a=rtpmap:8 PCMA/8000
a=fmtp:101 0-16
a=ptime:20
a=sendrecv
Retransmitting #1 (no NAT) to 192.168.4.2:5060:
CSeq: 102 INVITE
Content-Length: 243
v=0
t=0 0
a=fmtp:101 0-16
a=ptime:20
a=sendrecv
Retransmitting #2 (no NAT) to 192.168.4.2:5060:
CSeq: 102 INVITE
Content-Length: 243
v=0
t=0 0
a=fmtp:101 0-16
a=ptime:20
a=sendrecv
Retransmitting #3 (no NAT) to 192.168.4.2:5060:
CSeq: 102 INVITE
Content-Length: 243
v=0
t=0 0
a=fmtp:101 0-16
a=ptime:20
a=sendrecv
Retransmitting #4 (no NAT) to 192.168.4.2:5060:
CSeq: 102 INVITE
Content-Length: 243
v=0
t=0 0
a=fmtp:101 0-16
a=ptime:20
a=sendrecv
Retransmitting #5 (no NAT) to 192.168.4.2:5060:
CSeq: 102 INVITE
Content-Length: 243
v=0
t=0 0
a=fmtp:101 0-16
a=ptime:20
a=sendrecv
Nastja*CLI> sip set debug off
SIP Debugging Disabled
Nastja*CLI> sip set debug on
<--- SIP read from UDP:192.168.4.2:35060 --->
INVITE sip:4700@192.168.4.1 SIP/2.0
Via: SIP/2.0/UDP 192.168.4.2:35060;branch=z9hG4bK00005633;rport
To: sip:4700@192.168.4.1
Call-ID: 00006de6-1f2a63de00d2100097cb0080f0b80fe8@192.168.4.2
CSeq: 1 INVITE
Contact: sip:tde@192.168.4.2:35060
Supported: timer,100rel
Session-Expires: 180
Allow: INVITE,ACK,CANCEL,BYE,PRACK,OPTIONS,REGISTER,INFO,UPDATE
User-Agent: Panasonic-MPR07-VSIPGW/V3.0007
Content-Length: 264
v=0
o=- 1 1 IN IP4 192.168.4.3
s=-
c=IN IP4 192.168.4.3
t=0 0
m=audio 12154 RTP/AVP 8 0 18 101
a=rtpmap:8 PCMA/8000/1
a=rtpmap:0 PCMU/8000/1
a=rtpmap:18 G729/8000/1
a=fmtp:101 0-15
a=sendrecv
a=ptime:20
a=rtcp:12155
Sending to 192.168.4.2 : 35060 (no NAT)
Using INVITE request as basis request - 00006de6-1f2a63de00d2100097cb0080f0b80fe8@192.168.4.2
Found peer 'tde' for 'tde' from 192.168.4.2:35060
<--- Reliably Transmitting (no NAT) to 192.168.4.2:35060 --->
Via: SIP/2.0/UDP 192.168.4.2:35060;branch=z9hG4bK00005633;received=192.168.4.2;rport=35060
To: sip:4700@192.168.4.1;tag=as0adef143
CSeq: 1 INVITE
WWW-Authenticate: Digest algorithm=MD5, realm="asterisk", nonce="37908468"
Scheduling destruction of SIP dialog '00006de6-1f2a63de00d2100097cb0080f0b80fe8@192.168.4.2' in 32000 ms (Method: INVITE)
ACK sip:4700@192.168.4.1 SIP/2.0
CSeq: 1 ACK
Via: SIP/2.0/UDP 192.168.4.2:35060;branch=z9hG4bK000040f4;rport
CSeq: 2 INVITE
Authorization: Digest realm="asterisk", nonce="37908468", algorithm=MD5, uri="sip:4700@192.168.4.1", username="tde", response="e98aa9b44b81049dd5b43519eeb92ff5"
Content-Length: 264
v=0
s=-
t=0 0
a=fmtp:101 0-15
a=sendrecv
a=ptime:20
a=rtcp:12155
--- (15 headers 14 lines) ---
Found RTP audio format 18
Capabilities: us - 0x4 (ulaw), peer - audio=0x10c (ulaw|alaw|g729)/video=0x0 (nothing)/text=0x0 (nothing), combined - 0x4 (ulaw)
Peer audio RTP is at port 192.168.4.3:12154
Looking for 4700 in DLPN_test (domain 192.168.4.1)
list_route: hop: <sip:tde@192.168.4.2:35060>
<--- Transmitting (no NAT) to 192.168.4.2:35060 --->
SIP/2.0 100 Trying
Via: SIP/2.0/UDP 192.168.4.2:35060;branch=z9hG4bK000040f4;received=192.168.4.2;rport=35060
CSeq: 2 INVITE
Require: timer
Session-Expires: 180;refresher=uas
Contact: <sip:4700@192.168.4.1>
Audio is at 192.168.1.1 port 19590
Adding codec 0x2 (gsm) to SDP
Reliably Transmitting (no NAT) to 192.168.1.10:21482:
INVITE sip:4700@192.168.1.10:21482;rinstance=9ac68965a18c9154 SIP/2.0
Via: SIP/2.0/UDP 192.168.1.1:5060;branch=z9hG4bK78bfc1e2;rport
From: "New User" <sip:tde@192.168.1.1>;tag=as36e0e832
To: <sip:4700@192.168.1.10:21482;rinstance=9ac68965a18c9154>
Contact: <sip:tde@192.168.1.1>
Call-ID: 79f24d2a6a97c6bb3757e6ef249a1cd6@192.168.1.1
CSeq: 102 INVITE
Date: Thu, 10 Mar 2011 08:00:07 GMT
Content-Length: 266
v=0
o=root 838342918 838342918 IN IP4 192.168.1.1
t=0 0
m=audio 19590 RTP/AVP 0 3 101
a=rtpmap:3 GSM/8000
a=fmtp:101 0-16
a=ptime:20
a=sendrecv
[Mar 10 10:00:07] WARNING[1563]: app_dial.c:1747 dial_exec_full: Unable to create channel of type 'IAX2' (cause 20 - Unknown)
SIP/2.0 180 Ringing
Via: SIP/2.0/UDP 192.168.1.1:5060;branch=z9hG4bK78bfc1e2;rport=5060
Contact: <sip:4700@192.168.1.10:21482;rinstance=9ac68965a18c9154>
To: <sip:4700@192.168.1.10:21482;rinstance=9ac68965a18c9154>;tag=1f6f1b4b
From: "New User"<sip:tde@192.168.1.1>;tag=as36e0e832
CSeq: 102 INVITE
--- (9 headers 0 lines) ---
SIP/2.0 180 Ringing
To: sip:4700@192.168.4.1;tag=as13c83f5c
CSeq: 2 INVITE
Require: timer
CANCEL sip:4700@192.168.4.1 SIP/2.0
CSeq: 2 CANCEL
Authorization: Digest realm="asterisk", nonce="37908468", algorithm=MD5, uri="sip:4700@192.168.4.1", username="tde", response="3dbceb16e623f90f519704094ccd016d"
--- (10 headers 0 lines) ---
CSeq: 2 INVITE
SIP/2.0 200 OK
CSeq: 2 CANCEL
Scheduling destruction of SIP dialog '79f24d2a6a97c6bb3757e6ef249a1cd6@192.168.1.1' in 32000 ms (Method: INVITE)
CANCEL sip:4700@192.168.1.10:21482;rinstance=9ac68965a18c9154 SIP/2.0
CSeq: 102 CANCEL
CSeq: 2 ACK
Authorization: Digest realm="asterisk", nonce="37908468", algorithm=MD5, uri="sip:4700@192.168.4.1", username="tde", response="20a13c70e080374fcf77ece4e99f9b94"
SIP/2.0 200 OK
CSeq: 102 CANCEL
CSeq: 102 INVITE
ACK sip:4700@192.168.1.10:21482;rinstance=9ac68965a18c9154 SIP/2.0
CSeq: 102 ACK
Really destroying SIP dialog '79f24d2a6a97c6bb3757e6ef249a1cd6@192.168.1.1' Method: INVITE
Насколько я понял астериск отдает панасонику не номер на кого набрать а какую-то хрень. кто поскажет как это исправить чтобы звонки шли в обоих направлениях?
Re: Asterisk и Panasonic TDE
Астериск посылает не какую то хрень, а именно номер, который набрать (и кто ему звонит)
А вот хрень у Вас, уважаемый Лёха с ИП адресацией - в приведённом дебаге фигурируют пакеты 192.168.1.1, 192.168.1.10, 192.168.4.1, 192.168.4.2 - на которые при INVITE ретрансмитит (перепосылает) много раз без ответа.
Другая хрень - неудачно придуманый диал-план: 4700 номер на Астериске и 4401 - на Панасонике. Разделили бы хоть по первой цифре, что ли...
Справитесь?
vlego
Сообщение vlego »
номер конечно на панасе может существовать любой. ..если он конечно обслуживается диалпланом и нет такого же на астериске.
вот только в толк не возьму - как Вы организовали связь панас<->астериск ?
к этому вопросу это конечно не относится но все же, у Вас в логе - присутствует интересная запись ---
Astronomik
Справитесь?
На сервере 4 интерфейса. Панасоник в своей подсети (192.168.4.0/24). Астерикс на маршутизаторе(подсеть 192.168.10/24). Ната нету. В чем проблема с адресацией? В том куске что вы вырезали идет обращение от телефона к астериску. Далее номер посылается на панасоник
Подскажите в чем может быть затык?
Неудачно придуманный диалплан не поправишь. Узловая АТС понимает только номера вида 4ХХХ. План набора на панасоник:
[CallingRule_panas4]
exten => _44XX,1,Macro(trunkdial-panasonic,${panasonic}/${EXTEN:0},,panasonic,)
exten => _40XX,1,Macro(trunkdial-panasonic,${panasonic}/${EXTEN:0},,panasonic,)
exten => _41XX,1,Macro(trunkdial-panasonic,${panasonic}/${EXTEN:0},,panasonic,)
exten => _42XX,1,Macro(trunkdial-panasonic,${panasonic}/${EXTEN:0},,panasonic,)
exten => _43XX,1,Macro(trunkdial-panasonic,${panasonic}/${EXTEN:0},,panasonic,)
exten => _45XX,1,Macro(trunkdial-panasonic,${panasonic}/${EXTEN:0},,panasonic,)
exten => _48XX,1,Macro(trunkdial-panasonic,${panasonic}/${EXTEN:0},,panasonic,)
exten => _49XX,1,Macro(trunkdial-panasonic,${panasonic}/${EXTEN:0},,panasonic,)
exten => _17XX,1,Macro(trunkdial-panasonic,${panasonic}/${EXTEN:0},,panasonic,)
exten => _15XX,1,Macro(trunkdial-panasonic,${panasonic}/${EXTEN:0},,panasonic,)
exten => _2XXXXXX,1,Macro(trunkdial-panasonic,${panasonic}/${EXTEN:0},,panasonic,)
exten => _3XXXXXX,1,Macro(trunkdial-panasonic,${panasonic}/${EXTEN:0},,panasonic,)
exten => _5XXXXXX,1,Macro(trunkdial-panasonic,${panasonic}/${EXTEN:0},,panasonic,)
exten => _8wXXXXXXXX,1,Macro(trunkdial-panasonic,${panasonic}/${EXTEN:0},,panasonic,)
vlego
По SIP-транку. В цифровых панасониках реализовали таки нормальный SIP.
откуда запись - не знаю. Астериск из репозитория Debian squeeze. Конфиги дописывал.
Внизу что писал для транка на панасоник:
[panasonic]
transfer = yes
type = friend
host = 192.168.4.2
username = tde
secret = tde
trunkname = panasonic ; GUI metadata
context = DID_panasonic
dtmfmode = rfc2833
insecure = no
disallow = all
allow = alaw:20
callcounter = yes
[tde]
secret = tde
transer = yes
host = dynamic
context = DLPN_test
type = friend
;username = tde
callcounter = yes
vlego
Сообщение vlego »
диалплан менять и не надо.
что у вас показывает команда
sip show registry ?
и потом, Вы ручками все реализовали ?, а не через freePBX - судя по Вашим сообщенииям.
Astronomik
sip show registry
Host dnsmgr Username Refresh State Reg.Time
0 SIP registrations.
Ничего)
Руками. Изначально пробовал ставить какие-то веб-интерфейсы, потом оказалось что мне с ними разобраться сложнее чем с консолью и конфигами.
vlego
Сообщение vlego »
попробуйте так
CLI> sip show peers
должно показывать прим-но след-е
Name/username Host Dyn Nat ACL Port Status
panasonic ip address 5060 OK (4 ms)
совершить вызов на панас можно либо с экстеншена того же контекста где регился
панас либо из
extensions_custom.conf
-> [from-internal-custom]
exten => ВАШ МЕСТН.НОМЕР ПАНАС,1,Dial(SIP/panasonic,,${EXTEN))
с любого номера сущ-го на астериске.
однако лучше все "строить" через FreePBX.
Руками только тогда, когда есть донабор например.
Зачем избретать велосипед ?
Через FreePBX завел транк
Создал исх-й маршрут
и т.д. и т.п.
гораздо приятней.
Последний раз редактировалось vlego 10 мар 2011, 15:47, всего редактировалось 1 раз.
На пире панасоника укажите canreinvite=no
Не обязательно его регистрировать. Регистрация нужна только для динамических хостов, а там всё статично.
exten => ВАШ МЕСТН.НОМЕР ПАНАС,1,Dial(SIP/panasonic/${EXTEN)) - вот так правильней.
Ну и вследствие именно этого
будут проблемы.
Долго объяснять. Вкратце: bindaddr=0.0.0.0 слушает то на всех 4-х интерфейсах, но отправляет только с одного.
Astronomik писал(а):Насколько я понял астериск отдает панасонику не номер на кого набрать а какую-то хрень.
Поясните свою мысль всё таки, где Вы не увидели номер который астериск отдает панасонику?
Последний раз редактировалось ded 10 мар 2011, 15:53, всего редактировалось 1 раз.
Astronomik
sip show peers
4700/4700 192.168.1.10 D 21482 Unmonitored
4701/4701 192.168.1.13 D 62700 Unmonitored
4702/4702 (Unspecified) D N 0 Unmonitored
panasonic/tde 192.168.4.2 5060 Unmonitored
tde/tde 192.168.4.2 D 35060 Unmonitored
trunk_1/testprov 87.250.250.3 5060 Unmonitored
6 sip peers [Monitored: 0 online, 0 offline Unmonitored: 5 online, 1 offline]
Тут все есть и все активно даже вроде.
секции такой как и файла нету
l | grep ext
-rw-r----- 1 asterisk asterisk 2462 Сен 7 2010 extconfig.conf
-rw-r----- 1 asterisk asterisk 12801 Сен 7 2010 extensions.ael
-rw-r----- 1 asterisk asterisk 39189 Фев 9 13:43 extensions.conf
-rw-r----- 1 asterisk asterisk 5408 Сен 7 2010 extensions.lua
-rw-r----- 1 asterisk asterisk 7481 Сен 7 2010 extensions_minivm.conf
все настройки лежат в extconfig.conf, но в принципе правила написаны по указанной вами схеме...
vlego
Сообщение vlego »
ded, проблемы с интерфейсами (4шт) у него похоже будут.
можно конечно сетки в пареметре localnet указать, но это не всегда спасает.
я бы поставил в пире панаса
bindaddr= можно указать в пире, вроде как не запрещено.
