нет гудков вызова после считывания DTMF
vaskodegama
Сообщение vaskodegama »
exten => 777, 1,Verbose(dial callback);
exten => 777,n,Read(NUMBER,,60);
exten => 777,n.Dial(SIP/${NUMBER},,r);
после срабатывания Dial - в трубке вызывающего молчок (ключик r не помогает)
та же ситуация с Authenticate и WaitExten
Re: нет гудков вызова после считывания DTMF
Proof it - put the part of CLI log here with Dial line!
vaskodegama
-- Executing [777@factory:1] Verbose("SIP/201-00000074", "Dial Callback") in new stack
Dial Callback
-- Executing [777@factory:2] BackGround("SIP/201-00000074", "beep") in new stack
-- <SIP/201-00000074> Playing 'beep.ulaw' (language 'ru')
-- Executing [777@factory:3] Read("SIP/201-00000074", "NUMBER,,40") in new stack
-- Accepting a maximum of 40 digits.
[Oct 3 19:15:26] DTMF[4245][C-0000005b]: channel.c:4170 __ast_read: DTMF begin '2' received on SIP/201-00000074
[Oct 3 19:15:26] DTMF[4245][C-0000005b]: channel.c:4174 __ast_read: DTMF begin ignored '2' on SIP/201-00000074
[Oct 3 19:15:27] DTMF[4245][C-0000005b]: channel.c:4084 __ast_read: DTMF end '2' received on SIP/201-00000074, duration 160 ms
[Oct 3 19:15:27] DTMF[4245][C-0000005b]: channel.c:4154 __ast_read: DTMF end passthrough '2' on SIP/201-00000074
[Oct 3 19:15:27] DTMF[4245][C-0000005b]: channel.c:4170 __ast_read: DTMF begin '0' received on SIP/201-00000074
[Oct 3 19:15:27] DTMF[4245][C-0000005b]: channel.c:4174 __ast_read: DTMF begin ignored '0' on SIP/201-00000074
[Oct 3 19:15:27] DTMF[4245][C-0000005b]: channel.c:4084 __ast_read: DTMF end '0' received on SIP/201-00000074, duration 160 ms
[Oct 3 19:15:27] DTMF[4245][C-0000005b]: channel.c:4154 __ast_read: DTMF end passthrough '0' on SIP/201-00000074
[Oct 3 19:15:28] DTMF[4245][C-0000005b]: channel.c:4170 __ast_read: DTMF begin '#' received on SIP/201-00000074
[Oct 3 19:15:28] DTMF[4245][C-0000005b]: channel.c:4174 __ast_read: DTMF begin ignored '#' on SIP/201-00000074
[Oct 3 19:15:28] DTMF[4245][C-0000005b]: channel.c:4084 __ast_read: DTMF end '#' received on SIP/201-00000074, duration 160 ms
[Oct 3 19:15:28] DTMF[4245][C-0000005b]: channel.c:4154 __ast_read: DTMF end passthrough '#' on SIP/201-00000074
-- User entered '200'
-- Executing [777@factory:4] Dial("SIP/201-00000074", "SIP/200,,r") in new stack
-- Called SIP/200
-- SIP/200-00000075 is ringing
SIP/201 - какой-то софт-фон?
vaskodegama
sip dilaer на андроиде
xlite на pc
Gigaset C610A IP
все ведут себя одинаково
vaskodegama
факсовый аппарат через fxo шлюз тоже молчит
vaskodegama
выяснилось, что не только Read, WaitExten
после Answer, Playback и тд тоже самое
-- Executing [777@factory:1] Verbose("SIP/200-00000089", "Dial Callback") in new stack
Dial Callback
-- Executing [777@factory:2] Answer("SIP/200-00000089", "") in new stack
-- Executing [777@factory:3] Set("SIP/200-00000089", "NUMBER=201") in new stack
-- Executing [777@factory:4] Dial("SIP/200-00000089", "SIP/201,,r") in new stack
-- Called SIP/201
-- SIP/201-0000008a is ringing
vaskodegama
где-то я наваракосил в найстройках.
поднял сейчас старую виртуалку с астериском, там работает. перетащу конфиги и буду методом тыка искать
vaskodegama
дело оказалось в отсутствии indications.conf
оказывается, нужная и полезная вещь
