Новые модели GSM шлюзов от OpenVox
VS-GW1202-8G, VS-GW1200-4G и VS-GW1600
The VS-GW1202-8G and VS-GW1202-16S with the Modular Design come with 2 plug-in gateway modules and 2 Ethernet ports which could support 8 GSM channels and 16 FXS ports respectively, developed for interconnecting a wide selection of codecs, including G.711A, G.711U, G.729, G.722, G.723, G.726 & GSM, to quickly reduce telecommunication expenses and maximize cost-savings. Particularly, the GSM gateways can support diverse SIP, IAX2(coming soon) signaling protocol. With the unique design of the VoxStack Gateway, they can support hot-swap for gateway modules. Users can simply add or remove the modules for hardware expansion or exchange. Each gateway module runs an independent asterisk system inside. With the same size as VS-GW1200-4G/8S, they are easy to use and space saving. What’s more, they can save quite a lot shipping cost comparing with the VS-GW1600-8G/16S.
http://www.openvox.cn/store/VS-GW1600-20G-p-148.html
Цена радует!
Samael28
Re: Новые модели GSM шлюзов от OpenVox
Сообщение Samael28 »
Чистый GSM - уже не кошер :) Вон, китайцы лепят GSM/CDMA гейтвеи :)
Мой профайл на Upwork
klistrod
Сообщение klistrod »
Если надо настроить OpenVox то вот:
http://skytel.by/manual/openvox/119-nas ... -vs-gw1600
