Не работают исходящие
absolut
Сообщение absolut »
Входящие работают, не работают исходящие. При этом на стороннем клиенте исходящие работают.
Trunk:
username=74996851111
tcpenable=yes
type=peer
secret=xxxxx
insecure=very
fromuser=74996851111
host=85.94.32.244
fromdomain=85.94.32.244
dtmfmode=rfc2833
canreinvite=no
canredirect=no
allow=g729&alaw
При звонке:
-- Executing [84959165581@from-internal:1] ResetCDR("SIP/222-0000001c", "") in new stack
-- Executing [84959165581@from-internal:2] NoCDR("SIP/222-0000001c", "") in new stack
-- Executing [84959165581@from-internal:3] Progress("SIP/222-0000001c", "") in new stack
-- Executing [84959165581@from-internal:4] Wait("SIP/222-0000001c", "1") in new stack
-- Executing [84959165581@from-internal:5] Progress("SIP/222-0000001c", "") in new stack
-- Executing [84959165581@from-internal:6] Playback("SIP/222-0000001c", "silence/1&cannot-complete-as-dialed&check-number-dial-again,noanswer") in new stack
-- <SIP/222-0000001c> Playing 'silence/1.gsm' (language 'en')
-- <SIP/222-0000001c> Playing 'cannot-complete-as-dialed.gsm' (language 'en')
-- <SIP/222-0000001c> Playing 'check-number-dial-again.gsm' (language 'en')
-- Executing [84959165581@from-internal:7] Wait("SIP/222-0000001c", "1") in new stack
-- Executing [84959165581@from-internal:8] Congestion("SIP/222-0000001c", "20") in new stack
== Spawn extension (from-internal, 84959165581, 8) exited non-zero on 'SIP/222-0000001c'
-- Executing [h@from-internal:1] Macro("SIP/222-0000001c", "hangupcall") in new stack
-- Executing [s@macro-hangupcall:1] GotoIf("SIP/222-0000001c", "1?endmixmoncheck") in new stack
-- Executing [s@macro-hangupcall:9] NoOp("SIP/222-0000001c", "End of MIXMON check") in new stack
-- Executing [s@macro-hangupcall:10] GotoIf("SIP/222-0000001c", "1?nomeetmemon") in new stack
-- Goto (macro-hangupcall,s,28)
-- Executing [s@macro-hangupcall:28] NoOp("SIP/222-0000001c", "End of MEETME check") in new stack
-- Executing [s@macro-hangupcall:29] GotoIf("SIP/222-0000001c", "1?noautomon") in new stack
-- Goto (macro-hangupcall,s,34)
-- Executing [s@macro-hangupcall:34] NoOp("SIP/222-0000001c", "TOUCH_MONITOR_OUTPUT=") in new stack
-- Executing [s@macro-hangupcall:35] GotoIf("SIP/222-0000001c", "1?noautomon2") in new stack
-- Goto (macro-hangupcall,s,41)
-- Executing [s@macro-hangupcall:41] NoOp("SIP/222-0000001c", "MONITOR_FILENAME=") in new stack
-- Executing [s@macro-hangupcall:42] GotoIf("SIP/222-0000001c", "1?skiprg") in new stack
-- Goto (macro-hangupcall,s,45)
-- Executing [s@macro-hangupcall:45] GotoIf("SIP/222-0000001c", "1?skipblkvm") in new stack
-- Goto (macro-hangupcall,s,48)
-- Executing [s@macro-hangupcall:48] GotoIf("SIP/222-0000001c", "1?theend") in new stack
-- Goto (macro-hangupcall,s,50)
-- Executing [s@macro-hangupcall:50] AGI("SIP/222-0000001c", "hangup.agi") in new stack
-- Launched AGI Script /var/lib/asterisk/agi-bin/hangup.agi
-- <SIP/222-0000001c>AGI Script hangup.agi completed, returning 0
-- Executing [s@macro-hangupcall:51] Hangup("SIP/222-0000001c", "") in new stack
== Spawn extension (macro-hangupcall, s, 51) exited non-zero on 'SIP/222-0000001c' in macro 'hangupcall'
== Spawn extension (from-internal, h, 1) exited non-zero on 'SIP/222-0000001c'
Или дело может быть еще в чем-то другом?
Re: Не работают исходящие
У Вас не прописано правило для исходящей маршрутизации , поэтому звонок не направляется непосредственно в транк.
Судя по логу - используется freePBX, смотреть в вэб интерфейс - Исходящая маршрутизация.
absolut
Сообщение absolut »
Outbound routes:
Ваш шаблон говоит: направлять набранные номера, начинающиеся с 810... с любым количеством цифр в транк МСК.
А у вас было набрано (судя по логу) - 84959165581
Не хотите книжки почитать, про шаблоны, префиксы?
сами то как думаете попадет под патерн 810X. номер 84959165581?
Vlad1983 писал(а):сами то как думаете
Ответ должен быть сюда по всему таким:
Думаете ? Хм... А как это ? Так бывает ?
Я просто "смотрю в книгу, а вижу фигу". Ведь я в этом не разбираюсь, т.к. я бухгалтер, читать мне некогда, т.к. это надо "вчера". Да, да, я потом почитаю обязательно, просто сейчас мне некогда.
Я тоже не могу мозгом осознать о чем думает человек глядя на 810X. и набирая 8495Х.
Ведь даже если не знать ничего, то как минимум цифры 810 на экране и набор 8495 должны же наводить на хоть какие то мысли.
absolut писал(а):Или дело может быть еще в чем-то другом?
Дело в отсутствии необходимых минимальных знаний, которые необходимы для того чтобы понимать куда смотреть для дебага проблемы.
absolut
Сообщение absolut »
virus_net писал(а):Я тоже не могу мозгом осознать о чем думает человек глядя на 810X. и набирая 8495Х.
Не наводят. Я вижу asterisk во второй раз в жизни. Так что простительно :)
На самом деле сложно понять логику разработчиков. Было бы куда проще вместе псевдо-модификаторов ZXN (что там еще есть?) встроить обычный regexp. Зачем было мудрить левые буквы, когда есть старый стандарт?
Так или иначе, спасибо "ded" и "zzuz" за верное направление. Сейчас почти все работает :)
absolut писал(а):На самом деле сложно понять логику разработчиков
Да нет, их понять можно, а вот тебя нет:
absolut писал(а):Я вижу asterisk во второй раз в жизни
И даже книжку не удосужился открыть.
absolut писал(а):Так что простительно
Не а, ни разу.
absolut
Сообщение absolut »
virus_net, перечитал твои ранние сообщения. Везде троллишь новичков. Что-то у тебя с психикой не в порядке. Доставляет удовольствие пинать всех, кто чуть позже тебя начал изучать и меньше знает?
ЗЫ. Проблемы в сексе? Бабы не дают?
