Elastix (Asterisk 11.4.0) и Cisco 7940
Sa2
Сообщение Sa2 »
Здравствуйте.
Не регистрируются телефоны cisco 7940 на астериске.
# uname -a
Linux pbx4.local 2.6.18-348.12.1.el5 #1 SMP Wed Jul 10 05:28:41 EDT 2013 x86_64 x86_64 x86_64 GNU/Linux
# cat SIPDefault.cnf
# Image Version
image_version: "P0S3-8-12-00"
# NAT/Firewall Traversal
nat_enable: "1"
nat_address: ""
voip_control_port: "5060"
start_media_port: "16384"
end_media_port:  "32766"
nat_received_processing: "1"
# Proxy Registration (0-disable (default), 1-enable)
proxy_register: "1"
## http://www.cisco.com/en/US/docs/voice_ip_comm/cuipph/7960g_7940g/sip/7_5/english/administration/guide/sipins75.html
# Time Server
sntp_mode : Unicast
sntp_server : 192.168.50.1
time_zone : ZP6
time_format_24hr : 1
date_format : D/M/Y
telnet_level: "1"
# cat SIP000BBE126386.cnf
proxy1_address: "192.168.50.1"
# Line 1 Settings
line1_name: "750"
line1_shortname: "750"
line1_displayname: "750"
line1_authname: "750"
line1_password: "8487DJDAcm"
телефон находится в локальной сети сервера и я в сети вижу только такие вот пакеты в одну сторону:
17:43:53.371423 IP (tos 0x60, ttl  64, id 9702, offset 0, flags [none], proto: UDP (17), length: 572) 192.168.50.175.sip > 192.168.50.1.sip: [no cksum] SIP, length: 544
        REGISTER sip:192.168.50.1 SIP/2.0
        Via: SIP/2.0/UDP 192.168.50.175:5060;branch=z9hG4bK61f0a12d
        From: <sip:750@192.168.50.1>;tag=000bbe126386002346839199-255a9c78
        To: <sip:750@192.168.50.1>
        Call-ID: 000bbe12-63860002-7d5c5d15-6fa86809@192.168.50.175
        Date: Tue, 30 Jul 2013 10:43:42 GMT
        CSeq: 134 REGISTER
        User-Agent: Cisco-CP7940G/8.0
        Contact: <sip:750@192.168.50.175:5060;transport=udp>;+sip.instance="<urn:uuid:00000000-0000-0000-0000-000bbe126386>";+u.sip!model.ccm.cisco.com="8"
        Expires: 3600
        0x0000:  5245 4749 5354 4552 2073 6970 3a31 3932
        0x0010:  2e31 3638 2e35 302e 3120 5349 502f 322e
        0x0020:  300d 0a56 6961 3a20 5349 502f 322e 302f
        0x0030:  5544 5020 3139 322e 3136 382e 3530 2e31
        0x0040:  3735 3a35 3036 303b 6272 616e 6368 3d7a
        0x0050:  3968 4734 624b 3631 6630 6131 3264 0d0a
        0x0060:  4672 6f6d 3a20 3c73 6970 3a37 3530 4031
        0x0070:  3932 2e31 3638 2e35 302e 313e 3b74 6167
        0x0080:  3d30 3030 6262 6531 3236 3338 3630 3032
        0x0090:  3334 3638 3339 3139 392d 3235 3561 3963
        0x00a0:  3738 0d0a 546f 3a20 3c73 6970 3a37 3530
        0x00b0:  4031 3932 2e31 3638 2e35 302e 313e 0d0a
        0x00c0:  4361 6c6c 2d49 443a 2030 3030 6262 6531
        0x00d0:  322d 3633 3836 3030 3032 2d37 6435 6335
        0x00e0:  6431 352d 3666 6138 3638 3039 4031 3932
        0x00f0:  2e31 3638 2e35 302e 3137 350d 0a4d 6178
        0x0100:  2d46 6f72 7761 7264 733a 2037 300d 0a44
        0x0110:  6174 653a 2054 7565 2c20 3330 204a 756c
        0x0120:  2032 3031 3320 3130 3a34 333a 3432 2047
        0x0130:  4d54 0d0a 4353 6571 3a20 3133 3420 5245
        0x0140:  4749 5354 4552 0d0a 5573 6572 2d41 6765
        0x0150:  6e74 3a20 4369 7363 6f2d 4350 3739 3430
        0x0160:  472f 382e 300d 0a43 6f6e 7461 6374 3a20
        0x0170:  3c73 6970 3a37 3530 4031 3932 2e31 3638
        0x0180:  2e35 302e 3137 353a 3530 3630 3b74 7261
        0x0190:  6e73 706f 7274 3d75 6470 3e3b 2b73 6970
        0x01a0:  2e69 6e73 7461 6e63 653d 223c 7572 6e3a
        0x01b0:  7575 6964 3a30 3030 3030 3030 302d 3030
        0x01c0:  3030 2d30 3030 302d 3030 3030 2d30 3030
        0x01d0:  6262 6531 3236 3338 363e 223b 2b75 2e73
        0x01e0:  6970 216d 6f64 656c 2e63 636d 2e63 6973
        0x01f0:  636f 2e63 6f6d 3d22 3822 0d0a 436f 6e74
        0x0200:  656e 742d 4c65 6e67 7468 3a20 300d 0a45
        0x0210:  7870 6972 6573 3a20 3336 3030 0d0a 0d0a
В настройках екстеншена:
[750]
deny=0.0.0.0/0.0.0.0
secret=8487DJDAcm
dtmfmode=rfc2833
canreinvite=no
context=from-internal
nat=no
port=5060
callgroup=
pickupgroup=
allow=ulaw
dial=SIP/750
mailbox=750@device
permit=192.168.50.0/255.255.255.0
callerid=device <750>
callcounter=yes
faxdetect=no
Также в логах вижу:
[Jul 30 18:19:18] DEBUG[26325] netsock2.c: Splitting '192.168.50.175' into...
[Jul 30 18:19:18] DEBUG[26325] netsock2.c: ...host '192.168.50.175' and port ''.
Я пробовал отключать нат-настройки в SIPDefault.cnf и менять, не помогает.
Пожалуйста, помогите настроить астериск и цискофон для нормальной работы.
Спасибо.
Sa2
Re: Elastix (Asterisk 11.4.0) и Cisco 7940
Сообщение Sa2 »
пользователи ушли, я ребутнул сервер.
глянул -- все екстеншены поднялись и в статусе у всех ОК.
чудеса!
Есть ли у кого предположения что это было???
Expires: 3600
убавьте до 120
Sa2 писал(а):пользователи ушли, я ребутнул сервер.
чудеса!
Это было чудо! Я_гарантирую_это!
logdog
Сообщение logdog »
Есть предложение... у меня точно такая же проблема была при апгрейде с 11.4.0 на 11.5.0 для этих сisco 7940 и 7941, а fanvil не отвалились.
зы Я по быстрому откатился на 11.4.0, дебаг, думаю в выходные выложу, если проблема не будет ясна.
Sa2
Сообщение Sa2 »
awsswa писал(а):Expires: 3600
убавьте до 120
Убавил.
Перегрузил телефон один.
Не помогло.
телефон не регистрируется.
Sa2
Сообщение Sa2 »
чудеса!
Спасибо. Полезный ответ! :)
А как решить проблему.
Таки с утра тоже самое случилось...
После ребута сервера все телефоны опять быстренько зарегистрировались...
как решить проблему?
Sa2
Сообщение Sa2 »
logdog писал(а):Есть предложение... у меня точно такая же проблема была при апгрейде с 11.4.0 на 11.5.0 для этих сisco 7940 и 7941, а fanvil не отвалились.
Так а какое предложение? :(
У меня подобная связка (elastix + кучка cisco 7940) в совсем другом месте работает нормально.
Никто не жалуется.
logdog
Сообщение logdog »
Sa2 писал(а): После ребута сервера все телефоны опять быстренько зарегистрировались...
А только ребут помогает?
Не core reload
не core restart when convenient
не amportal restart
У вас телефон регистрируется с sip:750@192.168.50.175:5060 на Астериск 192.168.50.1, верно? Какой между ними NAT нафиг? Tcpdump host 192.168.50.175?
Попробуйте ещё что-нибудь, вдруг поможет? Это же Ваш метод?
Зачем Вы там указали nat_enable: "1"?
И ещё -
Вы на каждый рестарт телефона будете его перепрошивать?
