проблема с потоком E1
AndreyATC
Сообщение AndreyATC »
Есть карта Digium Wildcard TE110P T1/E1 чудессно себе работала пол года но два дня назад появилась проблема с исходящими звонками
при попітка сделать звонок возвращает Span 1: Channel 0/1 got hangup, cause 18 при етом входящие работают без проблем есть особеность один а может 2 звонка после dahdi reset проходят нормально потом cause 18
вот дебаг:
-- Making new call for cref 32780
> DL-DATA request
> Protocol Discriminator: Q.931 (8) len=35
> TEI=0 Call Ref: len= 2 (reference 12/0xC) (Sent from originator)
> Message Type: SETUP (5)
TEI=0 Transmitting N(S)=54, window is open V(A)=54 K=7
> [04 03 80 90 a3]
> Bearer Capability (len= 5) [ Ext: 1 Coding-Std: 0 Info transfer capability: Speech (0)
> Ext: 1 Trans mode/rate: 64kbps, circuit-mode (16)
> User information layer 1: A-Law (35)
> [18 03 a1 83 81]
> Channel ID (len= 5) [ Ext: 1 IntID: Implicit Other(PRI) Spare: 0 Preferred Dchan: 0
> ChanSel: As indicated in following octets
> Ext: 1 Coding: 0 Number Specified Channel Type: 3
> Ext: 1 Channel: 1 Type: CPE]
> [6c 08 21 80 35 35 35 35 34 34]
> Calling Party Number (len=10) [ Ext: 0 TON: National Number (2) NPI: ISDN/Telephony Numbering Plan (E.164/E.163) (1)
> Presentation: Presentation allowed, User-provided, not screened (0) '55ХХХХ' ]
> [70 07 80 35 30 37 36 37 38]
> Called Party Number (len= 9) [ Ext: 1 TON: Unknown Number Type (0) NPI: Unknown Number Plan (0) '50ХХХХ' ]
> [a1]
> Sending Complete (len= 1)
q931.c:6334 q931_setup: Call 32780 enters state 1 (Call Initiated). Hold state: Idle
T303 timed out. cref:32780
> DL-DATA request
TEI=0 Transmitting N(S)=55, window is open V(A)=55 K=7
> [04 03 80 90 a3]
> [18 03 a1 83 81]
> [a1]
q931.c:6223 t303_expiry: Call 32780 enters state 0 (Null). Hold state: Idle
Fake clearing. cref:32780
q931.c:9606 pri_internal_clear: alive 1, hangupack 1
q931.c:7135 q931_hangup: Hangup other cref:32780
q931.c:6892 __q931_hangup: ourstate Null, peerstate Null, hold-state Idle
Destroying call 0x7fc1fc003ee0, ourstate Null, peerstate Null, hold-state Idle
два дня парюсь не могу понять карта у меня сдохла или провайдер, хотя провайдер говорит что у них все ок и моих звонков они не видят!
Re: проблема с потоком E1
AndreyATC писал(а):Есть карта Digium Wildcard TE110P T1/E1 чудессно себе работала пол года но два дня назад появилась проблема с исходящими звонками
Cause No. 18 - no user responding.
This cause is used when a called party does not respond to a call establishment message with either an alerting or connect indication within the prescribed period of time allocated.
означает что провайдер ждёт не 55ХХХХ, а десятизнак (len=10) - национальный формат для РФ.
Попробуйте изменить на Unknown Numbering Plan
AndreyATC
да это я знаю я звонил провайдеру и дебажили с ним все вместе но утверждает что все ок и к нему нечего не приходит я из украину у нас принимает наборы в 2-х форматах 0ZХХХХХХХХ и месная городская связь ZХХХXX при наборе в первом формате результат тот же могу скинуть дебаг
AndreyATC
PRI Span: 1 -- Making new call for cref 32778
PRI Span: 1
PRI Span: 1 > DL-DATA request
PRI Span: 1 > Protocol Discriminator: Q.931 (8) len=39
PRI Span: 1 > TEI=0 Call Ref: len= 2 (reference 10/0xA) (Sent from originator)
PRI Span: 1 > Message Type: SETUP (5)
PRI Span: 1 TEI=0 Transmitting N(S)=80, window is open V(A)=80 K=7
PRI Span: 1
PRI Span: 1 > [04 03 80 90 a3]
PRI Span: 1 > Bearer Capability (len= 5) [ Ext: 1 Coding-Std: 0 Info transfer capability: Speech (0)
PRI Span: 1 > Ext: 1 Trans mode/rate: 64kbps, circuit-mode (16)
PRI Span: 1 > User information layer 1: A-Law (35)
PRI Span: 1 > [18 03 a1 83 81]
PRI Span: 1 > Channel ID (len= 5) [ Ext: 1 IntID: Implicit Other(PRI) Spare: 0 Preferred Dchan: 0
PRI Span: 1 > ChanSel: As indicated in following octets
PRI Span: 1 > Ext: 1 Coding: 0 Number Specified Channel Type: 3
PRI Span: 1 > Ext: 1 Channel: 1 Type: CPE]
PRI Span: 1 > [6c 08 21 80 35 35 35 35 35 30]
PRI Span: 1 > Calling Party Number (len=10) [ Ext: 0 TON: National Number (2) NPI: ISDN/Telephony Numbering Plan (E.164/E.163) (1)
PRI Span: 1 > Presentation: Presentation allowed, User-provided, not screened (0) '55XXXX' ]
PRI Span: 1 > [70 0b 80 30 34 33 32 35 30 37 36 37 38]
PRI Span: 1 > Called Party Number (len=13) [ Ext: 1 TON: Unknown Number Type (0) NPI: Unknown Number Plan (0) '0432XXXXXX' ]
PRI Span: 1 > [a1]
PRI Span: 1 > Sending Complete (len= 1)
PRI Span: 1 q931.c:6334 q931_setup: Call 32778 enters state 1 (Call Initiated). Hold state: Idle
-- Called DAHDI/g0/0432XXXXXX
PRI Span: 1 T303 timed out. cref:32778
PRI Span: 1
PRI Span: 1 TEI=0 Transmitting N(S)=81, window is open V(A)=81 K=7
PRI Span: 1
PRI Span: 1 > [a1]
PRI Span: 1 q931.c:6223 t303_expiry: Call 32778 enters state 0 (Null). Hold state: Idle
PRI Span: 1 Fake clearing. cref:32778
PRI Span: 1 q931.c:9606 pri_internal_clear: alive 1, hangupack 1
Span 1: Processing event PRI_EVENT_HANGUP
-- Span 1: Channel 0/1 got hangup, cause 18
PRI Span: 1 q931.c:7135 q931_hangup: Hangup other cref:32778
PRI Span: 1 q931.c:6892 __q931_hangup: ourstate Null, peerstate Null, hold-state Idle
PRI Span: 1 Destroying call 0x7f063818aa00, ourstate Null, peerstate Null, hold-state Idle
-- Hungup 'DAHDI/i1/0432XXXXXX-13'
Последний раз редактировалось AndreyATC 06 июл 2013, 22:49, всего редактировалось 1 раз.
AndreyATC
еще один дебаг с набором 10 знаков результат тотже
AndreyATC
вот звонок после рестарта DAHDI после него звонки не идут
PRI Span: 1 -- Making new call for cref 32771
PRI Span: 1
PRI Span: 1 > Protocol Discriminator: Q.931 (8) len=35
PRI Span: 1 > TEI=0 Call Ref: len= 2 (reference 3/0x3) (Sent from originator)
PRI Span: 1 TEI=0 Transmitting N(S)=35, window is open V(A)=35 K=7
PRI Span: 1
PRI Span: 1 > [6c 08 00 80 35 35 35 35 35 30]
PRI Span: 1 > Calling Party Number (len=10) [ Ext: 0 TON: Unknown Number Type (0) NPI: Unknown Number Plan (0)
PRI Span: 1 > [70 07 80 35 30 37 36 37 38]
PRI Span: 1 > Called Party Number (len= 9) [ Ext: 1 TON: Unknown Number Type (0) NPI: Unknown Number Plan (0) '50XXXX' ]
PRI Span: 1 > [a1]
PRI Span: 1 q931.c:6334 q931_setup: Call 32771 enters state 1 (Call Initiated). Hold state: Idle
-- Called DAHDI/g0/50XXXX
PRI Span: 1
PRI Span: 1 < Protocol Discriminator: Q.931 (8) len=14
PRI Span: 1 < TEI=0 Call Ref: len= 2 (reference 3/0x3) (Sent to originator)
PRI Span: 1 < Message Type: CALL PROCEEDING (2)
PRI Span: 1 < [18 03 a9 83 81]
PRI Span: 1 < Channel ID (len= 5) [ Ext: 1 IntID: Implicit Other(PRI) Spare: 0 Exclusive Dchan: 0
PRI Span: 1 < ChanSel: As indicated in following octets
PRI Span: 1 < Ext: 1 Coding: 0 Number Specified Channel Type: 3
PRI Span: 1 < Ext: 1 Channel: 1 Type: CPE]
PRI Span: 1 < [1e 02 81 88]
PRI Span: 1 < Progress Indicator (len= 4) [ Ext: 1 Coding: CCITT (ITU) standard (0) 0: 0 Location: Private network serving the local user (1)
PRI Span: 1 < Ext: 1 Progress Description: Inband information or appropriate pattern now available. (8) ]
PRI Span: 1 Received message for call 0x7f064001b1d0 on link 0x3338790 TEI/SAPI 0/0
PRI Span: 1 -- Processing IE 24 (cs0, Channel ID)
PRI Span: 1 -- Processing IE 30 (cs0, Progress Indicator)
PRI Span: 1 q931.c:8831 post_handle_q931_message: Call 32771 enters state 3 (Outgoing Call Proceeding). Hold state: Idle
Span 1: Processing event PRI_EVENT_PROCEEDING
-- DAHDI/i1/507678-3 is proceeding passing it to Local/507678@from-internal-d117;2
-- Local/507678@from-internal-d117;1 is proceeding passing it to SIP/0931700045-00000025
-- DAHDI/i1/507678-3 is making progress passing it to Local/507678@from-internal-d117;2
-- Local/507678@from-internal-d117;1 is making progress passing it to SIP/0931700045-00000025
PRI Span: 1
PRI Span: 1 < Protocol Discriminator: Q.931 (8) len=9
PRI Span: 1 < Message Type: ALERTING (1)
PRI Span: 1 q931.c:8684 post_handle_q931_message: Call 32771 enters state 4 (Call Delivered). Hold state: Idle
Span 1: Processing event PRI_EVENT_RINGING
-- DAHDI/i1/50XXXX-3 is ringing
-- Local/50XXXX@from-internal-d117;1 is ringing
== Spawn extension (disa-dial, 507678, 2) exited non-zero on 'SIP/093XXXXXXX-00000025'
PRI Span: 1 q931.c:7135 q931_hangup: Hangup other cref:32771
PRI Span: 1 q931.c:6892 __q931_hangup: ourstate Call Delivered, peerstate Call Received, hold-state Idle
PRI Span: 1 q931.c:6081 q931_disconnect: Call 32771 enters state 11 (Disconnect Request). Hold state: Idle
PRI Span: 1
PRI Span: 1 > Protocol Discriminator: Q.931 (8) len=9
-- Executing [h@disa-dial:1] NoOp("SIP/093XXXXXXX-00000025", "called h in from-internal by ID: 1") in new stack
-- Executing [h@disa-dial:2] Dial("SIP/093XXXXXXX-00000025", "Local/h@from-internal,300,Hg") in new stack
-- Called Local/h@from-internal
== Spawn extension (disa-dial, h, 2) exited non-zero on 'SIP/093XXXXXXX-00000025'
-- Executing [h@from-internal:1] Hangup("Local/h@from-internal-ce3b;2", "") in new stack
== Spawn extension (from-internal, h, 1) exited non-zero on 'Local/h@from-internal-ce3b;2'
PRI Span: 1 > Message Type: DISCONNECT (69)
PRI Span: 1 TEI=0 Transmitting N(S)=36, window is open V(A)=36 K=7
PRI Span: 1
PRI Span: 1 > [08 02 81 90]
PRI Span: 1 > Cause (len= 4) [ Ext: 1 Coding: CCITT (ITU) standard (0) Spare: 0 Location: Private network serving the local user (1)
PRI Span: 1 > Ext: 1 Cause: Normal Clearing (16), class = Normal Event (1) ]
-- Hungup 'DAHDI/i1/50XXXX-3'
== Spawn extension (macro-dialout-trunk, s, 22) exited non-zero on 'Local/50XXXX@from-internal-d117;2' in macro 'dialout-trunk'
== Spawn extension (from-internal, 50XXXX, 5) exited non-zero on 'Local/50XXXX@from-internal-d117;2'
-- Executing [h@from-internal:1] Hangup("Local/50XXXX@from-internal-d117;2", "") in new stack
== Spawn extension (from-internal, h, 1) exited non-zero on 'Local/50XXXX@from-internal-d117;2'
PRI Span: 1
PRI Span: 1 < Message Type: RELEASE (77)
PRI Span: 1 < [08 02 81 90]
PRI Span: 1 < Cause (len= 4) [ Ext: 1 Coding: CCITT (ITU) standard (0) Spare: 0 Location: Private network serving the local user (1)
PRI Span: 1 < Ext: 1 Cause: Normal Clearing (16), class = Normal Event (1) ]
PRI Span: 1 -- Processing IE 8 (cs0, Cause)
PRI Span: 1 q931.c:8997 post_handle_q931_message: Call 32771 enters state 0 (Null). Hold state: Idle
PRI Span: 1 q931.c:6892 __q931_hangup: ourstate Null, peerstate Release Request, hold-state Idle
PRI Span: 1
PRI Span: 1 > Message Type: RELEASE COMPLETE (90)
PRI Span: 1 TEI=0 Transmitting N(S)=37, window is open V(A)=37 K=7
PRI Span: 1
PRI Span: 1 Destroying call 0x7f064001b1d0, ourstate Null, peerstate Null, hold-state Idle
AndreyATC писал(а):Есть карта Digium Wildcard TE110P T1/E1 чудессно себе работала пол года но два дня назад появилась проблема с исходящими звонками !
Я думаю у провайдера изменения: какая-то новая шняга, типа СОРМ, он вам не скажет. Но изменился там диал-план, и он это не видит или не понимает?
1) Научитесь прятать ваши большие портянки логов под спойлер.
2) С каким набором 10 знаков? О чём Вы пишете? Вот этим?
Вы смотрите в свой логи вообще? Читаете что там написано? 55XXXX? 50XXXX? Где 10 знаков?
Последний звонок, кстати, нормальное завершение - Cause 16/
AndreyATC
Свои логи смотрел и не однократно - внесу ясность
0 - входящие вызовы принимает всегда проблем нет никаких.
1 - первый дебаг городской набор 6 знаков - неудачный
2 - второй дебаг межгород 10 знаков тоже неудачный
3 - третий дебаг первый звонок после dahdi restаrt удачный для примера
После рестарта один звонок проходит всегда не зависимо от набора все последующие вылетают по таймауту понять почему не могу.
При неправильном наборе или callerid оператор збрасывает и это видно в логе т.е. оператор не сбрасывает точно, а так как первый после рестарта проходит и все входящие проходят всегда смею предположить что глюк у меня! понять где не могу.
- неправда , нет такого.
Не понять мне - почему ваши звонки через локальный канал? Local/50XXXX@from-internal - это какк-то не верно, такое порождают call files, тут шестизнак всё равно, а не десять -DAHDI/i1/507678-3 (не надо закрываться ХХХ, номера ваши не секрет)
а прямые наборы будут выглядить в логе так:
Dial("SIP/0931700045-00000025", "DAHDI/g1/507678-3") in new stack
