voip gsm gateway mv-372 +asterisk 11.3
arlekin_s
Сообщение arlekin_s »
Доброго всем дня. Помогите разобраться. Есть связка voip gsm gateway mv-372 +asterisk 11.3 и при звонке с ГСМ шлюза не виден номер звонившего при записи разговоров.
  == Using SIP VIDEO CoS mark 6
    -- Executing [280@test2:1] Answer("SIP/gsm-gate-00000963", "") in new stack
    -- Executing [280@test2:2] Set("SIP/gsm-gate-00000963", "CALLERID(all)=+3806        33348350") in new stack
    -- Executing [280@test2:3] Goto("SIP/gsm-gate-00000963", "s,1") in new stack
    -- Goto (test2,s,1)
    -- Executing [s@test2:1] Wait("SIP/gsm-gate-00000963", "1") in new stack
    -- Executing [s@test2:2] MixMonitor("SIP/gsm-gate-00000963", "/voip/2013-05-        20 14:33:57-101-280-inko2--.wav") in new stack
extensions.conf
[test2]
exten => s,1,Wait(1)
exten => s,n,MixMonitor(/voip/${CDR(start)}-${CDR(src)}-${CDR(dst)}-${CDR(dcontext)}-${CDR(accountcode)}-${CDR(user field)}.wav)
exten => s,n,Background(aviar)
exten => s,n,Goto(t,3)
;******************* if press 1 botton *************************
exten => 1,1,Dial(SIP/208&SIP/214&SIP/270&SIP/218,15,r)
exten => 1,2,Dial(SIP/208&SIP/214&SIP/218&SIP/205&SIP/202,30,r)
exten => 1,3,Dial(Dongle/dongle0/holdother,+3***********,30,r)
exten => 1,4,Playback(zanyato1)
exten => 1,5,VoiceMail(support@mail,s)
exten => 1,n,Hangup()
;******************** if press 2 button ************************
exten => 2,1,Dial(SIP/271&SIP/209&SIP/206&SIP/204&SIP/211,15,r) ;chose 2
exten => 2,2,Dial(SIP/270&SIP/205&SIP/202,30,r)
exten => 2,3,Playback(zanyato1)
exten => 2,4,VoiceMail(sales@mail,s)
exten => 2,n,Hangup()
exten => i,1,Goto(s,2)
exten => t,1,WaitExten(10)
exten => t,2,Background(aviar)
exten => t,3,Dial(SIP/213&SIP/217&SIP/218&SIP/209&SIP/210&SIP/211&SIP/214&SIP/208,30,r)
exten => t,4,Playback(zanyato1)
exten => t,5,VoiceMail(info@mail,s)
exten => t,n,Hangup()
exten => 0,1,Dial(SIP/207&SIP/213&SIP/217&SIP/218&SIP/208&SIP/209&SIP/210&SIP/211&SIP/214&SIP/208,30,r)
exten => 0,2,Playback(zanyato1)
exten => 0,3,VoiceMail(info@mail,s)
exten => 0,4,Dial(SIP/250) ;fax
exten => 0,n,Hangup()
sip.conf
[gsm-gate]
context=test2
type=peer
host=192.168.143.66
username=gsm-gate
allow=all
Re: voip gsm gateway mv-372 +asterisk 11.3
У Вас при входящем (если я правильно понял) насильно ставится всем CALLERID(all)=+380633348350
    -- Executing [280@test2:2] Set("SIP/gsm-gate-00000963", "CALLERID(all)=+380633348350") in new stack
Поэтому какой бы он ни прибежал - Вы его не увидите, потому что перебиваете.
1) Кто Вам это настраивал?
2) Если это тот, кто писал
if press 1 botton
то, это право, как-то ... мимо....
arlekin_s
а как сделать чтобы его увидеть ?
Закомментировать строку
Set(CALLERID(all)=+380633348350)
и добавить
NoOp(CallerID = ${CALLERID(all)})
Так кто же всё-таки Вам писал эту безграмотную ерунду? botton?
arlekin_s
спасибо большое ... выводит теперь вот так..
    -- Executing [280@test2:1] Answer("SIP/gsm-gate-00000ab1", "") in new stack
    -- Executing [280@test2:2] NoOp("SIP/gsm-gate-00000ab1", "CallerID = "+38050*******" <101>") in new stack
    -- Executing [280@test2:3] Goto("SIP/gsm-gate-00000ab1", "s,1") in new stack
    -- Goto (inko2,s,1)
    -- Executing [s@test2:1] Wait("SIP/gsm-gate-00000ab1", "1") in new stack
    -- Executing [s@test2:2] MixMonitor("SIP/gsm-gate-00000ab1", "/voip/2013-05-21 13:00:44-101-280-test2--.wav") in new stack
а что надо добавить сюда.. чтобы тоже в имени файла показывался номер.
exten => s,n,MixMonitor(/voip/${CDR(start)}-${CDR(src)}-${CDR(dst)}-${CDR(dcontext)}-${CDR(all)}.wav)
А кто же всё-таки Вам писал эту безграмотную ерунду? botton?
arlekin_s
Как кто... человек ))))))) которого я попросил... т.к. сам еще не полностью освоил астериск.
Ну так и продолжайте его просить. Вы же еще не полностью освоили астериск?
arlekin_s
Ну а форум для чего ???
Aven писал(а):Вот мы и пришли к этому вопросу.
Зачем нужен форум?
