при конфигурации использовал --prefix=/opt/asterisk
запускал:
[root@centosAst1 asterisk]# /opt/asterisk/sbin/safe_asterisk
Asterisk is already running. /opt/asterisk/sbin/safe_asterisk will exit now.
при попытке зайти в CLI получаю сабж.
asterisk.conf:
[directories](!)
astetcdir => /opt/asterisk/etc/asterisk
astmoddir => /opt/asterisk/lib/asterisk/modules
astvarlibdir => /opt/asterisk/var/lib/asterisk
astdbdir => /opt/asterisk/var/lib/asterisk
astkeydir => /opt/asterisk/var/lib/asterisk
astdatadir => /opt/asterisk/var/lib/asterisk
astagidir => /opt/asterisk/var/lib/asterisk/agi-bin
astspooldir => /opt/asterisk/var/spool/asterisk
astrundir => /opt/asterisk/var/run/asterisk
astlogdir => /opt/asterisk/var/log/asterisk
astsbindir => /opt/asterisk/sbin
[options]
documentation_language = en_US
[compat]
pbx_realtime=1.6
res_agi=1.6
app_set=1.6только вот не представляю как это сделать.
