SIP trunk исходящие через ССМ 4.1
disnet
Сообщение disnet »
день добрый
asterisk =>SIP trunk => cisco callmanager 4.1 => cisco 2821 => SIP => VPS
trunk зарегистрирован на asterisk, звонки в город уходят нормально, а вот на мобильные - трабла.
extensions.conf
static=yes
writeprotect=no
clearglobalvars=no
context=internal
; CALLS TO LOCAL ASTERISK
[internal]
exten => _XXXX,1,Dial(SIP/${EXTEN})
exten => _XXXX,n,Hangup
include => to_callman01
; CALLS TO CISCO  CALLMANAGER
[to_callman01]
exten => _XXX,1,Dial(SIP/callman01/${EXTEN})
exten => _XXX,n,Hangup
exten => _08495XXXXXXX,1,Dial(SIP/callman01/${EXTEN})  - звонок в город проходит
exten => _089XXXXXXXXX,1,Dial(SIP/callman01/${EXTEN}) - звонок на мобильные ошибка
include => internal
sip.conf
[callman01]
context=to_callman01
host=192.168.10.3
allow=ulaw
nat=no
canreinvite=yes
qualify=no
insecure=port,invite
на 2821 отшибаются 0 и оператору уходит в нужном формате.
ошибка в asterisk>
    -- Executing [089251234567@internal:1] Dial("SIP/1000-0000004c", "SIP/callman01/089251234567") in new stack
Audio is at 17556
Adding codec 100003 (ulaw) to SDP
Reliably Transmitting (no NAT) to 192.168.10.3:5060:
INVITE sip:089251234567@192.168.10.3 SIP/2.0
Via: SIP/2.0/UDP 172.16.10.1:5060;branch=z9hG4bK554c23f6
To: <sip:089251234567@192.168.10.3>
Contact: <sip:1000@172.16.10.1:5060>
Call-ID: 260df8036a71ac4a76caebf24f1c12d2@172.16.10.1:5060
CSeq: 102 INVITE
User-Agent: Asterisk PBX 11.3.0
Date: Tue, 09 Apr 2013 07:16:07 GMT
Content-Length: 257
v=0
o=root 1457650835 1457650835 IN IP4 172.16.10.1
s=Asterisk PBX 11.3.0
c=IN IP4 172.16.10.1
t=0 0
m=audio 17556 RTP/AVP 0 8 101
a=rtpmap:0 PCMU/8000
a=rtpmap:8 PCMA/8000
a=fmtp:101 0-16
a=ptime:20
a=sendrecv
    -- Called SIP/callman01/089251234567
<--- SIP read from UDP:192.168.10.3:5060 --->
SIP/2.0 100 Trying
To: <sip:089251234567@192.168.10.3>;tag=17090459
Date: Tue, 09 Apr 2013 07:16:25 GMT
CSeq: 102 INVITE
Allow-Events: telephone-event
--- (9 headers 0 lines) ---
SIP/2.0 404 Not Found
CSeq: 102 INVITE
ACK sip:089251234567@192.168.10.3 SIP/2.0
CSeq: 102 ACK
Scheduling destruction of SIP dialog '260df8036a71ac4a76caebf24f1c12d2@172.16.10.1:5060' in 32000 ms (Method: INVITE)
    -- Auto fallthrough, channel 'SIP/1000-0000004c' status is 'CHANUNAVAIL'
я так понимаю callmanager что то не устраивает, что именно не могу вкурить
Re: SIP trunk исходящие через ССМ 4.1
SIP/2.0 404 Not Found может быть как честный ответ (на языке Астериска - нет такого entry в моём диалплане), так и отлуп по несоответствию Caller ID.
Надо дебажить SIP на уровне 2821.
Схема слишком избыточна.ССМ 4.1 - лишний.
disnet
Сообщение disnet »
смотрю на трансляцию на 2821 ибо немного обманул со схемой. звонки в город идут через Е1 (2821), а на сотовые через sip(2821). соответственно правило выхода в город простое 0849.!, а на сотовые несколько префиксов. имхо до 2821 долетает неверный формат номера.
действующая схема: ccm => 2821 => (sip)(e1)
астерикс воткнул для изучения, так что в данном случае он лишний -)
астерикс воткнул для излучения.
Ну тогда Вам лучше на http://www.voipinfo.ru/forum/viewforum.php?f=3
И Максим Денисов Вам очень толково расскажет что не так.
disnet
Сообщение disnet »
проблема была в доставке номера до 2821 в нужном формате. в процессе пути формат искажался, в итоге циска не знает что с ним делать и отлуп.
Всё ясно и просто.
