Asterisk в разрыв E1 потока до LG LDK-300
Cincinnut
Сообщение Cincinnut »
Доброе утро!
Ставлю * с двухканальной платой E1 Parabel Quasar mini в разрыв существующего потока от провайдера до моей АТС LG LDK-300.
Настройки сразу хочу делать уже через FreePBX. Соответственно через него настроил DAHDI (скачанный с парабелла). Статус в dahdi_tool нормальный - ОК.
как настроить транк через freepbx так не понял, поэтому делал через custom extension
в /etc/extension_custom.conf
[from-ats]
exten=>_.,1,Dial(DAHDI/g1/${EXTEN})
exten=>_.,n,Hangup()
[from-e1]
exten=>_.,1,Dial(DAHDI/g0/${EXTEN})
/etc/asterisk/chan_dahdi.conf
; Do NOT edit this file as it is auto-generated by FreePBX. All modifications to ;
; this file must be done via the web gui. There are alternative files to make    ;
; custom modifications, details at: http://freepbx.org/configuration_files       ;
; generated by module
#include chan_dahdi_general.conf
; for user additions not provided by module
#include chan_dahdi_general_custom.conf
[channels]
language=en
busydetect=yes
busycount=10
usecallerid=yes
callwaiting=yes
usecallingpres=yes
threewaycalling=yes
transfer=yes
cancallforward=yes
callreturn=yes
echocancel=yes
echocancelwhenbridged=yes
echotraining=no
immediate=no
faxdetect=yes
rxgain=0.0
txgain=0.0
overlapdial=yes
#include chan_dahdi_channels_custom.conf
; include dahdi groups defined by DAHDI module of FreePBX
#include chan_dahdi_groups.conf
; include dahdi extensions defined in FreePBX
#include chan_dahdi_additional.conf
; [span_1]
signalling=pri_cpe
switchtype=national
pridialplan=national
prilocaldialplan=unknown
group=0
context=from-e1
channel=1-15,17-31
priexclusive=no
; [span_2]
signalling=pri_net
switchtype=national
group=1
context=from-ats
channel=32-46,48-62
priexclusive=no
/etc/dahdi/system.conf
# Do NOT edit this file as it is auto-generated by FreePBX. All modifications to ;
# this file must be done via the web gui. There are alternative files to make    ;
# custom modifications, details at: http://freepbx.org/configuration_files       ;
span=1,1,0,CCS,HDB3,CRC4
span=2,0,0,CCS,HDB3
bchan=1-15,17-31,32-46,48-62
dchan=16,47
loadzone=us
defaultzone=us
ну и собственно при вызове из атс лог
   -- Accepting overlap call from '28' to '<unspecified>' on channel 0/31, span 2
    -- Starting simple switch on 'DAHDI/i2/28-1'
    -- Executing [89111111111@from-ats:1] Dial("DAHDI/i2/28-1", "DAHDI/g1/89111111111") in new stack
    -- Called DAHDI/g1/89111111111
    -- DAHDI/i2/89111111111-2 is making progress passing it to DAHDI/i2/28-1
    -- DAHDI/i2/89111111111-2 is proceeding passing it to DAHDI/i2/28-1
    -- DAHDI/i2/89111111111-2 is ringing
    -- DAHDI/i2/89111111111-2 answered DAHDI/i2/28-1
    -- Span 2: Channel 0/31 got hangup request, cause 16
    -- Executing [h@from-ats:1] Dial("DAHDI/i2/28-1", "DAHDI/g1/h") in new stack
[2013-02-19 07:50:35] WARNING[7807][C-00000084]: sig_pri.c:7953 sig_pri_call: Unrecognized pridialplan NPI modifier: h
    -- Called DAHDI/g1/h
    -- Hungup 'DAHDI/i2/-3'
  == Spawn extension (from-ats, h, 1) exited non-zero on 'DAHDI/i2/28-1'
    -- Hungup 'DAHDI/i2/89111111111-2'
  == Spawn extension (from-ats, 89111111111, 1) exited non-zero on 'DAHDI/i2/28-1'
    -- Hungup 'DAHDI/i2/28-1'
    -- Starting simple switch on 'DAHDI/i2/28-4'
    -- Hungup 'DAHDI/i2/28-4'
    -- Accepting call from '28' to '89111111111' on channel 0/31, span 2
    -- Executing [89111111111@from-ats:1] Dial("DAHDI/i2/28-5", "DAHDI/g1/89111111111") in new stack
    -- DAHDI/i2/89111111111-6 is making progress passing it to DAHDI/i2/28-5
    -- DAHDI/i2/89111111111-6 is proceeding passing it to DAHDI/i2/28-5
    -- DAHDI/i2/89111111111-6 is ringing
    -- DAHDI/i2/89111111111-6 answered DAHDI/i2/28-5
    -- Executing [h@from-ats:1] Dial("DAHDI/i2/28-5", "DAHDI/g1/h") in new stack
[2013-02-19 07:51:18] WARNING[7810][C-00000086]: sig_pri.c:7953 sig_pri_call: Unrecognized pridialplan NPI modifier: h
    -- Hungup 'DAHDI/i2/-7'
  == Spawn extension (from-ats, h, 1) exited non-zero on 'DAHDI/i2/28-5'
    -- Hungup 'DAHDI/i2/89111111111-6'
  == Spawn extension (from-ats, 89111111111, 1) exited non-zero on 'DAHDI/i2/28-5'
    -- Hungup 'DAHDI/i2/28-5'
при вызове на АТС из внешки
[2013-02-19 07:53:45] NOTICE[7788]: chan_dahdi.c:3234 my_handle_dchan_exception: PRI got event: HDLC Bad FCS (8) on D-channel of span 1
    -- Accepting overlap call from '89111111111' to '303028' on channel 0/1, span 1
    -- Starting simple switch on 'DAHDI/i1/89111111111-1'
    -- Executing [303028@from-e1:1] Dial("DAHDI/i1/89111111111-1", "DAHDI/g0/305128") in new stack
    -- Called DAHDI/g0/303028
    -- DAHDI/i1/303028-2 is making progress passing it to DAHDI/i1/89111111111-1
[2013-02-19 07:54:25] NOTICE[7788]: chan_dahdi.c:3234 my_handle_dchan_exception: PRI got event: HDLC Abort (6) on D-channel of span 1
    -- Span 1: Channel 0/1 got hangup request, cause 102
    -- Hungup 'DAHDI/i1/303028-2'
  == Spawn extension (from-e1, 303028, 1) exited non-zero on 'DAHDI/i1/89111111111-1'
    -- Executing [h@from-e1:1] Dial("DAHDI/i1/89111111111-1", "DAHDI/g0/h") in new stack
[2013-02-19 07:54:36] WARNING[7846][C-00000087]: sig_pri.c:7953 sig_pri_call: Unrecognized pridialplan NPI modifier: h
    -- Called DAHDI/g0/h
    -- Hungup 'DAHDI/i1/-3'
  == Spawn extension (from-e1, h, 1) exited non-zero on 'DAHDI/i1/89111111111-1'
    -- Hungup 'DAHDI/i1/89111111111-1'
с атс используется префикс 9 для выхода в город, после набора 9-ки гудок есть, потом набираю, ждёт секунд 10 и вылетает по таймауту.
поиском нашёл что надо overlapdial ставить в yes, для передачи тонов. пробовал ещё ISDN ENBLCK SEND ставить в ON на LDK.
подскажите пожалуйста в чём ещё может быть дело
Cincinnut
Re: Asterisk в разрыв E1 потока до LG LDK-300
Без опыта использования инструментов в начале есть сложности.
В данном случае боюсь что может быть надо что-то допиливать со стороны LDK.
К тоже же на обучении мы рассматривали чистый asterisk, а мне хочется сразу на freepbx, чтоб потом было проще. хотя желание снести уже эти костыли, логика работы которых с настройками asterisk`а не всегда очевидна, растёт каждый час.
span=2,2,0,CCS,HDB3
или
span=1,2,0,CCS,HDB3,CRC4
span=2,1,0,CCS,HDB3
смотря что в какой порт включено.
Обязательно посмотреть статус ОК на портах через dahdi_tools
Ну и
switchtype=national - это вряд ли
pridialplan=national - это вряд ли
Cincinnut
ded писал(а): span=1,1,0,CCS,HDB3,CRC4
span=2,2,0,CCS,HDB3
или
span=2,1,0,CCS,HDB3
ну тогда вопрос по freepbx получается, там в св-вах dahdi "Sync/Clock Source:" можно выбрать или 0, или 1. Как поставить меньший приоритет, в виде 2? в конфиг проставлю, freepbx же потом перезапишет?
И в данном случае есть разница между 0/1 и 1/2?
ded писал(а): Ну и
switchtype пробовал и euroisdn - и так тоже поток подымается.
а вот pridialplan=unknown - творится какая-то фигня (подключённый к провайдеру). идёт куча наборов как будто в цикле, лог не сохранил к сожалению.
dahdi_tool показывает OK, без этого и не пробую набор.
switch писал(а):А ведь я вам предлагал использовать готовое решение. Но вы пошли своим путем, считая что это просто.
я думал будет проще конечно, обучение же прошёл, всё знаю, страшно представить что будет дальше, я уже добавил forum.asterisk.ru в speeddial, ждите моих вопросов дальше :)
Cincinnut, мы различаем строителей и эксплуатационщиков.
Например, строители возвели гидроэлектростанцию, вывели на рабочую мощность и сдали эксплуатационщикам.
Вы попытались сами построить гидроэлектростанцию, хотя по уровню знаний и по этим вопросам - Вам только эксплуатировать. Это относительно легче, чем строить. Параметры span=1,2,0,CCS,HDB3,CRC4 настроенные много лет назат работают долго и первичные трудности настройки забываются напрочь.
Есть. Не хотите книжки почитать?
Cincinnut писал(а):как настроить транк через freepbx так не понял, поэтому делал через custom extension
OMG!
В настройках группы каналов dahdi для потока из станции поставить
context=from-internal
а для потока из города - поставить
context=from-pstn
В extension_custom ничего не писать.
Что показывает
CLI> dahdi show channels?
1. Создать во freePBX сначала дефолтный тупик во входящей маршрутизации - Any DID / Any CID и замагнитить в музыку - Put caller on Hold forever, чтобы принять и посмотреть в каком формате приходят номера DIDs, по которым потом уже разруливать в дальнейшем входящие.
2. Попробовать исходящие с LDK покидать на тестовый внутренний номер SIP, на который завесить какой-нить софт-фон.
