[2013-02-06 06:07:53]
! --- Event -----------------------------------------------------------
! Event --> Dial
! Privilege --> call,all
! SubEvent --> Begin
! Channel --> SIP/7273383626 -00000050
! Destination --> SIP/1101-00000052
! CallerIDNum --> 87272979695
! CallerIDName --> Meloman
! ConnectedLineNum --> 1101
! ConnectedLineName --> device
! UniqueID --> 1360130866.240
! DestUniqueID --> 1360130873.244
! Dialstring --> 1101
! Dial Event src=SIP/7273383626 -00000050 dest=SIP/1101-00000052
! Successfully created CALL record with id=72b07580-a6aa-e8d3-eb80-5111f31199db
Stripping callout prefix:
Stripping callin prefix:
CallerID is: 87272979695
Inbound state detected... /^(sip\/[1-9][0-9][0-9]?[0-9]?-|Local)/i is astMatchInternal eChannel= SIP/7273383626 -00000050 eDestination=SIP/1101-00000052
! AMI Event 'ExtensionStatus suppressed.
! AMI Event 'Newstate suppressed.
! Event --> Hangup
! Channel --> Local/1101@from-queue-00000050;2
! Uniqueid --> 1360130866.242
! Cause --> 18
! Cause-txt --> No user responding
# +++ findCallByAsteriskId(1360130866.242)
! Warning, results set was empty!
[1360130866.242] FAILED TO FIND A CALL (note: there are two hangups per call, so this might not be an error)
<--- SIP read from UDP:172.16.2.1:5060 --->
INVITE sip:7273383700@172.16.10.2 SIP/2.0
Via: SIP/2.0/UDP 172.16.2.1:5060;branch=z9hG4bKgjv32830agch4fl785s0.1
From: <sip:87272979646@10.14.0.2;user=phone>;tag=347009509-1360132478234-
To: "7273383700 TOVARISCHESTVO S OGRANICHENNOI"<sip:7273383700@sip.telecom.kz>
Call-ID: BW1234382330602132020119451@10.14.0.2
CSeq: 387664525 INVITE
Contact: <sip:87272979646@172.16.2.1:5060;transport=udp>
Supported: 100rel,timer
Allow: ACK,BYE,CANCEL,INFO,INVITE,OPTIONS,PRACK,REFER,NOTIFY
Accept: multipart/mixed,application/media_control+xml,application/sdp
Min-SE: 90
Session-Expires: 1800;refresher=uac
Max-Forwards: 69
Content-Length: 198
v=0
o=BroadWorks 391940050 1 IN IP4 172.16.2.1
s=-
c=IN IP4 172.16.2.1
t=0 0
m=audio 8924 RTP/AVP 8 18 101
a=fmtp:18 annexb=no
a=fmtp:101 0-15
a=ptime:20
--- (15 headers 10 lines) ---
Sending to 172.16.2.1:5060 (NAT)
Using INVITE request as basis request - BW1234382330602132020119451@10.14.0.2
Found peer '7273383626 ' for '87272979646' from 172.16.2.1:5060
== Using SIP RTP TOS bits 184
Found RTP audio format 8
Found RTP audio format 18
Found RTP audio format 101
Capabilities: us - 0x108 (alaw|g729), peer - audio=0x108 (alaw|g729)/video=0x0 (nothing)/text=0x0 (nothing), combined - 0x108 (alaw|g729)
Peer audio RTP is at port 172.16.2.1:8924
Looking for 7273383700 in from-trunk (domain 172.16.10.2)
list_route: hop: <sip:87272979646@172.16.2.1:5060;transport=udp>
<--- Transmitting (no NAT) to 172.16.2.1:5060 --->
SIP/2.0 100 Trying
Via: SIP/2.0/UDP 172.16.2.1:5060;branch=z9hG4bKgjv32830agch4fl785s0.1;received=172.16.2.1
Server: FPBX-2.8.1(1.8.20.0)
Contact: <sip:7273383700@172.16.10.2:5060>
-- Executing [7273383700@from-trunk:1] Set("SIP/7273383626 -00000076", "__FROM_DID=7273383700") in new stack
-- Executing [7273383700@from-trunk:2] Gosub("SIP/7273383626 -00000076", "app-blacklist-check,s,1") in new stack
-- Executing [s@app-blacklist-check:1] GotoIf("SIP/7273383626 -00000076", "0?blacklisted") in new stack
-- Executing [s@app-blacklist-check:2] Set("SIP/7273383626 -00000076", "CALLED_BLACKLIST=1") in new stack
-- Executing [s@app-blacklist-check:3] Return("SIP/7273383626 -00000076", "") in new stack
-- Executing [7273383700@from-trunk:3] ExecIf("SIP/7273383626 -00000076", "1 ?Set(CALLERID(name)=87272979646)") in new stack
-- Executing [7273383700@from-trunk:4] Set("SIP/7273383626 -00000076", "__CALLINGPRES_SV=allowed_not_screened") in new stack
-- Executing [7273383700@from-trunk:5] Set("SIP/7273383626 -00000076", "CALLERPRES()=allowed_not_screened") in new stack
-- Executing [7273383700@from-trunk:6] Set("SIP/7273383626 -00000076", "_RGPREFIX=Meloman: ") in new stack
-- Executing [7273383700@from-trunk:7] Set("SIP/7273383626 -00000076", "CALLERID(name)=Meloman: 87272979646") in new stack
-- Executing [7273383700@from-trunk:8] Goto("SIP/7273383626 -00000076", "ext-group,601,1") in new stack
-- Goto (ext-group,601,1)
-- Executing [601@ext-group:1] Macro("SIP/7273383626 -00000076", "user-callerid,") in new stack
-- Executing [s@macro-user-callerid:1] Set("SIP/7273383626 -00000076", "AMPUSER=87272979646") in new stack
-- Executing [s@macro-user-callerid:2] GotoIf("SIP/7273383626 -00000076", "0?report") in new stack
-- Executing [s@macro-user-callerid:3] ExecIf("SIP/7273383626 -00000076", "1?Set(REALCALLERIDNUM=87272979646)") in new stack
-- Executing [s@macro-user-callerid:4] Set("SIP/7273383626 -00000076", "AMPUSER=") in new stack
-- Executing [s@macro-user-callerid:5] Set("SIP/7273383626 -00000076", "AMPUSERCIDNAME=") in new stack
-- Executing [s@macro-user-callerid:6] GotoIf("SIP/7273383626 -00000076", "1?report") in new stack
-- Goto (macro-user-callerid,s,10)
-- Executing [s@macro-user-callerid:10] GotoIf("SIP/7273383626 -00000076", "0?continue") in new stack
-- Executing [s@macro-user-callerid:11] Set("SIP/7273383626 -00000076", "__TTL=64") in new stack
-- Executing [s@macro-user-callerid:12] GotoIf("SIP/7273383626 -00000076", "1?continue") in new stack
-- Executing [s@macro-user-callerid:19] Set("SIP/7273383626 -00000076", "CALLERID(number)=87272979646") in new stack
-- Executing [s@macro-user-callerid:20] Set("SIP/7273383626 -00000076", "CALLERID(name)=Meloman: 87272979646") in new stack
-- Executing [s@macro-user-callerid:21] NoOp("SIP/7273383626 -00000076", "Using CallerID "Meloman: 87272979646" <87272979646>") in new stack
-- Executing [601@ext-group:2] GotoIf("SIP/7273383626 -00000076", "1?skipdb") in new stack
-- Goto (ext-group,601,4)
-- Executing [601@ext-group:4] Set("SIP/7273383626 -00000076", "__NODEST=") in new stack
-- Executing [601@ext-group:5] Set("SIP/7273383626 -00000076", "__BLKVM_OVERRIDE=BLKVM/601/SIP/7273383626 -00000076") in new stack
-- Executing [601@ext-group:6] Set("SIP/7273383626 -00000076", "__BLKVM_BASE=601") in new stack
-- Executing [601@ext-group:7] Set("SIP/7273383626 -00000076", "DB(BLKVM/601/SIP/7273383626 -00000076)=TRUE") in new stack
-- Executing [601@ext-group:8] Set("SIP/7273383626 -00000076", "RRNODEST=") in new stack
-- Executing [601@ext-group:9] Set("SIP/7273383626 -00000076", "__NODEST=601") in new stack
-- Executing [601@ext-group:10] GosubIf("SIP/7273383626 -00000076", "0?sub-rgsetcid,s,1") in new stack
-- Executing [601@ext-group:11] Set("SIP/7273383626 -00000076", "__CWIGNORE=TRUE") in new stack
-- Executing [601@ext-group:12] Set("SIP/7273383626 -00000076", "RecordMethod=Group") in new stack
-- Executing [601@ext-group:13] Macro("SIP/7273383626 -00000076", "record-enable,1101,Group") in new stack
-- Executing [s@macro-record-enable:1] GotoIf("SIP/7273383626 -00000076", "1?check") in new stack
-- Executing [s@macro-record-enable:4] ExecIf("SIP/7273383626 -00000076", "0?MacroExit()") in new stack
-- Executing [s@macro-record-enable:5] GotoIf("SIP/7273383626 -00000076", "1?Group:OUT") in new stack
-- Goto (macro-record-enable,s,6)
-- Executing [s@macro-record-enable:6] Set("SIP/7273383626 -00000076", "LOOPCNT=1") in new stack
-- Executing [s@macro-record-enable:7] Set("SIP/7273383626 -00000076", "ITER=1") in new stack
-- Executing [s@macro-record-enable:8] GotoIf("SIP/7273383626 -00000076", "0?continue") in new stack
-- Executing [s@macro-record-enable:9] Set("SIP/7273383626 -00000076", "TEXTEN=1101") in new stack
-- Executing [s@macro-record-enable:10] NoOp("SIP/7273383626 -00000076", "Recording enable for 1101") in new stack
-- Executing [s@macro-record-enable:11] Set("SIP/7273383626 -00000076", "CALLFILENAME=g1101-20130206-123438-1360132477.280") in new stack
-- Executing [s@macro-record-enable:12] Goto("SIP/7273383626 -00000076", "record") in new stack
-- Goto (macro-record-enable,s,23)
-- Executing [s@macro-record-enable:23] MixMonitor("SIP/7273383626 -00000076", "g1101-20130206-123438-1360132477.280.wav,,") in new stack
-- Executing [s@macro-record-enable:24] Set("SIP/7273383626 -00000076", "CDR(userfield)=audio:g1101-20130206-123438-1360132477.280.wav") in new stack
== Begin MixMonitor Recording SIP/7273383626 -00000076
-- Executing [s@macro-record-enable:25] MacroExit("SIP/7273383626 -00000076", "") in new stack
-- Executing [601@ext-group:14] Set("SIP/7273383626 -00000076", "RingGroupMethod=hunt") in new stack
-- Executing [601@ext-group:15] Macro("SIP/7273383626 -00000076", "dial,20,tr,1101") in new stack
-- Executing [s@macro-dial:1] GotoIf("SIP/7273383626 -00000076", "1?dial") in new stack
-- Goto (macro-dial,s,3)
-- Executing [s@macro-dial:3] AGI("SIP/7273383626 -00000076", "dialparties.agi") in new stack
-- Launched AGI Script /var/lib/asterisk/agi-bin/dialparties.agi
dialparties.agi: Caller ID name is 'Meloman: 87272979646' number is '87272979646'
dialparties.agi: Methodology of ring is 'hunt'
-- dialparties.agi: Added extension 1101 to extension map
-- dialparties.agi: Extension 1101 cf is disabled
-- dialparties.agi: Extension 1101 do not disturb is disabled
dialparties.agi: EXTENSION_STATE: 0 (NOT_INUSE)
dialparties.agi: Extension 1101 has ExtensionState: 0
-- dialparties.agi: Checking CW and CFB status for extension 1101
-- dialparties.agi: Filtered ARG3: 1101
-- <SIP/7273383626 -00000076>AGI Script dialparties.agi completed, returning 0
-- Executing [s@macro-dial:20] NoOp("SIP/7273383626 -00000076", "Returned from dialparties with hunt groups to dial ") in new stack
-- Executing [s@macro-dial:21] Set("SIP/7273383626 -00000076", "HuntLoop=0") in new stack
-- Executing [s@macro-dial:22] GotoIf("SIP/7273383626 -00000076", "1?a30") in new stack
-- Goto (macro-dial,s,26)
-- Executing [s@macro-dial:26] Set("SIP/7273383626 -00000076", "HuntMember=HuntMember0") in new stack
-- Executing [s@macro-dial:27] GotoIf("SIP/7273383626 -00000076", "1?a32:a35") in new stack
-- Goto (macro-dial,s,28)
-- Executing [s@macro-dial:28] Set("SIP/7273383626 -00000076", "CT_EXTEN=1101") in new stack
-- Executing [s@macro-dial:29] Set("SIP/7273383626 -00000076", "DB(CALLTRACE/1101)=87272979646") in new stack
-- Executing [s@macro-dial:30] Goto("SIP/7273383626 -00000076", "s,a42") in new stack
-- Goto (macro-dial,s,38)
-- Executing [s@macro-dial:38] Dial("SIP/7273383626 -00000076", "SIP/1101,20,trM(auto-blkvm)") in new stack
-- Called SIP/1101
SIP/2.0 180 Ringing
To: "7273383700 TOVARISCHESTVO S OGRANICHENNOI"<sip:7273383700@sip.telecom.kz>;tag=as1a6d79ec
CANCEL sip:7273383700@172.16.10.2 SIP/2.0
CSeq: 387664525 CANCEL
Max-Forwards: 69
--- (8 headers 0 lines) ---
Sending to 172.16.2.1:5060 (no NAT)
<--- Reliably Transmitting (no NAT) to 172.16.2.1:5060 --->
[2013-02-06 07:05:39]
! Event --> NewCallerid
! Channel --> SIP/7273383626 -00000082
! Uniqueid --> 1360134337.296
! CID-CallingPres --> 0 (Presentation Allowed, Not Screened)
1360134337.296 CallerID Changed to: 87272979695
! Event --> Join
! ConnectedLineNum --> unknown
! ConnectedLineName --> unknown
! Queue --> 4
! Position --> 1
! Count --> 1
PHP Notice: Undefined index: UniqueID in /var/www/html/sugarcrm/custom/modules/Asterisk/asteriskLogger.php on line 341
! Event --> MusicOnHold
! State --> Start
! UniqueID --> 1360134337.296
! Class --> default
! State --> Stop
! Event --> Leave
! Queue --> 4
! Count --> 0
! Position --> 1
NOTICE[8812] chan_sip.c: No field "From" present to copy
NOTICE[8812] chan_sip.c: No field "Call-ID" present to copy
NOTICE[8812] chan_sip.c: No field "QSec" present to copyКод: Выделить всё
! State --> Stop
! Channel --> SIP/7273383626 -000000e5
! UniqueID --> 1360138671.437
[2013-02-06 08:17:56]
! Event --> Leave
! Queue --> 4
! Count --> 0
! Position --> 1
! Uniqueid --> 1360138671.437
! Event --> NewAccountCode
! Channel --> SIP/1101-000000e6
! Uniqueid --> 1360138672.440
! AccountCode -->
! OldAccountCode -->
! Event --> Bridge
! Bridgestate --> Link
! Bridgetype --> core
! Channel1 --> SIP/7273383626 -000000e5
! Channel2 --> SIP/1101-000000e6
! Uniqueid1 --> 1360138671.437
! Uniqueid2 --> 1360138672.440
! CallerID1 --> 87272979695
! CallerID2 --> 1101
! Event --> Unlink
! Channel1 --> SIP/7273383626 -000000db
! Channel2 --> SIP/1101-000000dd
! Uniqueid1 --> 1360138325.409
! Uniqueid2 --> 1360138328.415
[2013-02-06 08:13:03]
! Event --> Hangup
! Channel --> SIP/1101-000000dd
! Uniqueid --> 1360138328.415
! CallerIDNum --> 1101
! CallerIDName --> device
! ConnectedLineNum --> 87272979695
! ConnectedLineName --> Meloman
! Cause --> 16
! Cause-txt --> Normal Clearing
# +++ findCallByAsteriskId(1360138328.415)
[1360138328.415] FAILED TO FIND A CALL (note: there are two hangups per call, so this might not be an error)
[2013-02-06 09:02:10]
! Channel --> SIP/1101-00000105
! Uniqueid --> 1360141319.521
! AccountCode -->
! Event --> Bridge
! Channel1 --> SIP/7273383626 -00000104
! Channel2 --> SIP/1101-00000105
! Uniqueid1 --> 1360141319.520
! Uniqueid2 --> 1360141319.521
! CallerID1 --> 87273860616
[2013-02-06 09:02:15]
! Event --> Unlink
[2013-02-06 09:02:16]
! Event --> Hangup
! ConnectedLineNum --> 87273860616
! ConnectedLineName --> Meloman:87273860616
! Cause --> 16
# +++ findCallByAsteriskDestId(1360141319.521)
! FindCallByAsteriskDestId - Found entry in asterisk_log recordId=f074f7f9-dcf5-24dc-0c64-51121c686ff1
Looking for user extension number in: SIP/1101-00000105
Channel Matched SIP/### style regex. Ext is:1101
### +++ findUserByAsteriskExtension(1101)
