не могу подключить кодеки h264
mikeles
Сообщение mikeles »
Не могу подключить кодек h264. Кодеки в папке modules есть
В настройках core show codecs отображаются.
Но при проверки sip show settings видит только аудио. Подскажите решение.спасибо
Re: не могу подключить кодеки h264
sip.conf
videosupport=yes
allow=ulaw
allow=h264
allow=h263p
allow=h263
и так далее
http://www.voip-info.org/wiki/view/Asterisk+codecs
http://www.voip-info.org/wiki/view/Asterisk+video
mikeles
Сообщение mikeles »
Все это есть. Стоит :)
Дистрибутив AsteriskNOW.
sip.conf
videosupport=yes
allow=ulaw
allow=h264
localhost*CLI> sip show settings
Global Settings:
  UDP Bindaddress:        0.0.0.0:5060
  TCP SIP Bindaddress:    Disabled
  TLS SIP Bindaddress:    Disabled
  Videosupport:           Yes
  Textsupport:            No
  Ignore SDP sess. ver.:  No
  AutoCreate Peer:        No
  Match Auth Username:    No
  Allow unknown access:   Yes
  Allow subscriptions:    Yes
  Allow overlap dialing:  Yes
  Allow promisc. redir:   No
  Enable call counters:   No
  SIP domain support:     No
  Realm. auth:            No
  Our auth realm          asterisk
  Use domains as realms:  No
  Call to non-local dom.: Yes
  URI user is phone no:   No
  Always auth rejects:    Yes
  Direct RTP setup:       No
  User Agent:             FPBX-2.10.0rc1(1.8.11)
  SDP Session Name:       Asterisk PBX 1.8.11-cert1
  SDP Owner Name:         root
  Reg. context:           (not set)
  Regexten on Qualify:    No
  Legacy userfield parse: No
  Caller ID:              Unknown
  Record SIP history:     Off
  Call Events:            Off
  Auth. Failure Events:   Off
  T.38 support:           No
  T.38 EC mode:           Unknown
  T.38 MaxDtgrm:          -1
  SIP realtime:           Disabled
  Qualify Freq :          60000 ms
  Q.850 Reason header:    No
  Store SIP_CAUSE:        No
Network QoS Settings:
  IP ToS SIP:             CS3
  IP ToS RTP audio:       EF
  IP ToS RTP video:       AF41
  IP ToS RTP text:        CS0
  802.1p CoS SIP:         4
  802.1p CoS RTP audio:   5
  802.1p CoS RTP video:   6
  802.1p CoS RTP text:    5
  Jitterbuffer enabled:   No
Network Settings:
  SIP address remapping:  Disabled, no localnet list
  Externhost:             <none>
  Externaddr:             (null)
  Externrefresh:          10
Global Signalling Settings:
  Codecs:                 0xc (ulaw|alaw)
  Codec Order:            ulaw:20,alaw:20
  Relax DTMF:             No
  RFC2833 Compensation:   No
  Symmetric RTP:          No
  Compact SIP headers:    No
  RTP Keepalive:          0 (Disabled)
  RTP Timeout:            0 (Disabled)
  RTP Hold Timeout:       0 (Disabled)
  MWI NOTIFY mime type:   application/simple-message-summary
  DNS SRV lookup:         Yes
  Pedantic SIP support:   Yes
  Reg. min duration       60 secs
  Reg. max duration:      3600 secs
  Reg. default duration:  120 secs
  Outbound reg. timeout:  20 secs
  Outbound reg. attempts: 0
  Notify ringing state:   Yes
    Include CID:          No
  Notify hold state:      Yes
  SIP Transfer mode:      open
  Max Call Bitrate:       384 kbps
  Auto-Framing:           No
  Outb. proxy:            <not set>
  Session Timers:         Accept
  Session Refresher:      uas
  Session Expires:        1800 secs
  Session Min-SE:         90 secs
  Timer T1:               500
  Timer T1 minimum:       100
  Timer B:                32000
  No premature media:     Yes
  Max forwards:           70
Default Settings:
  Allowed transports:     UDP
  Outbound transport:     UDP
  Context:                from-sip-external
  Force rport:            Yes
  DTMF:                   rfc2833
  Qualify:                0
  Use ClientCode:         No
  Progress inband:        Never
  Language:
  MOH Interpret:          default
  MOH Suggest:
  Voice Mail Extension:   *97
 core show codecs
Disclaimer: this command is for informational purposes only.
        It does not indicate anything about your configuration.
                INT    BINARY                  HEX   TYPE       NAME   DESCRIPTION
                  1 (1 <<  0)                (0x1)  audio       g723   (G.723.1)
                  2 (1 <<  1)                (0x2)  audio        gsm   (GSM)
                  4 (1 <<  2)                (0x4)  audio       ulaw   (G.711 u-law)
                  8 (1 <<  3)                (0x8)  audio       alaw   (G.711 A-law)
                 16 (1 <<  4)               (0x10)  audio   g726aal2   (G.726 AAL2)
                 32 (1 <<  5)               (0x20)  audio      adpcm   (ADPCM)
                 64 (1 <<  6)               (0x40)  audio       slin   (16 bit Signed Linear PCM)
                128 (1 <<  7)               (0x80)  audio      lpc10   (LPC10)
                256 (1 <<  8)              (0x100)  audio       g729   (G.729A)
                512 (1 <<  9)              (0x200)  audio      speex   (SpeeX)
               1024 (1 << 10)              (0x400)  audio       ilbc   (iLBC)
               2048 (1 << 11)              (0x800)  audio       g726   (G.726 RFC3551)
               4096 (1 << 12)             (0x1000)  audio       g722   (G722)
               8192 (1 << 13)             (0x2000)  audio     siren7   (ITU G.722.1 (Siren7, licensed from Polycom))
              16384 (1 << 14)             (0x4000)  audio    siren14   (ITU G.722.1 Annex C, (Siren14, licensed from Polycom))
              32768 (1 << 15)             (0x8000)  audio     slin16   (16 bit Signed Linear PCM (16kHz))
              65536 (1 << 16)            (0x10000)  image       jpeg   (JPEG image)
             131072 (1 << 17)            (0x20000)  image        png   (PNG image)
             262144 (1 << 18)            (0x40000)  video       h261   (H.261 Video)
             524288 (1 << 19)            (0x80000)  video       h263   (H.263 Video)
            1048576 (1 << 20)           (0x100000)  video      h263p   (H.263+ Video)
            2097152 (1 << 21)           (0x200000)  video       h264   (H.264 Video)
            4194304 (1 << 22)           (0x400000)  video      mpeg4   (MPEG4 Video)
            8388608 (1 << 23)           (0x800000)  video    unknown   (unknown)
           16777216 (1 << 24)          (0x1000000)  video    unknown   (unknown)
           33554432 (1 << 25)          (0x2000000)   text    unknown   (unknown)
           67108864 (1 << 26)          (0x4000000)   text        red   (T.140 Realtime Text with redundancy)
          134217728 (1 << 27)          (0x8000000)   text       t140   (Passthrough T.140 Realtime Text)
          268435456 (1 << 28)         (0x10000000)   text    unknown   (unknown)
          536870912 (1 << 29)         (0x20000000)   text    unknown   (unknown)
         1073741824 (1 << 30)         (0x40000000)  (unk)    unknown   (unknown)
         2147483648 (1 << 31)         (0x80000000)  (unk)    unknown   (unknown)
         4294967296 (1 << 32)        (0x100000000)  audio       g719   (ITU G.719)
         8589934592 (1 << 33)        (0x200000000)  audio    speex16   (SpeeX 16khz)
        17179869184 (1 << 34)        (0x400000000)  audio    unknown   (unknown)
        34359738368 (1 << 35)        (0x800000000)  audio    unknown   (unknown)
        68719476736 (1 << 36)       (0x1000000000)  audio    unknown   (unknown)
       137438953472 (1 << 37)       (0x2000000000)  audio    unknown   (unknown)
       274877906944 (1 << 38)       (0x4000000000)  audio    unknown   (unknown)
       549755813888 (1 << 39)       (0x8000000000)  audio    unknown   (unknown)
      1099511627776 (1 << 40)      (0x10000000000)  audio    unknown   (unknown)
      2199023255552 (1 << 41)      (0x20000000000)  audio    unknown   (unknown)
      4398046511104 (1 << 42)      (0x40000000000)  audio    unknown   (unknown)
      8796093022208 (1 << 43)      (0x80000000000)  audio    unknown   (unknown)
     17592186044416 (1 << 44)     (0x100000000000)  audio    unknown   (unknown)
     35184372088832 (1 << 45)     (0x200000000000)  audio    unknown   (unknown)
     70368744177664 (1 << 46)     (0x400000000000)  audio    unknown   (unknown)
    140737488355328 (1 << 47)     (0x800000000000)  audio    testlaw   (G.711 test-law)
    281474976710656 (1 << 48)    (0x1000000000000)  video    unknown   (unknown)
    562949953421312 (1 << 49)    (0x2000000000000)  video    unknown   (unknown)
   1125899906842624 (1 << 50)    (0x4000000000000)  video    unknown   (unknown)
   2251799813685248 (1 << 51)    (0x8000000000000)  video    unknown   (unknown)
   4503599627370496 (1 << 52)   (0x10000000000000)  video    unknown   (unknown)
   9007199254740992 (1 << 53)   (0x20000000000000)  video    unknown   (unknown)
  18014398509481984 (1 << 54)   (0x40000000000000)  video    unknown   (unknown)
  36028797018963968 (1 << 55)   (0x80000000000000)  video    unknown   (unknown)
  72057594037927936 (1 << 56)  (0x100000000000000)  video    unknown   (unknown)
 144115188075855872 (1 << 57)  (0x200000000000000)  video    unknown   (unknown)
 288230376151711744 (1 << 58)  (0x400000000000000)  video    unknown   (unknown)
 576460752303423488 (1 << 59)  (0x800000000000000)  video    unknown   (unknown)
1152921504606846976 (1 << 60) (0x1000000000000000)  video    unknown   (unknown)
2305843009213693952 (1 << 61) (0x2000000000000000)  video    unknown   (unknown)
4611686018427387904 (1 << 62) (0x4000000000000000)  video    unknown   (unknown)
localhost*CLI>
modules.conf
load => format_h264.so
/modules
[root@localhost modules]# ls
app_adsiprog.so
app_alarmreceiver.so
app_amd.so
app_authenticate.so
app_cdr.so
app_celgenuserevent.so
app_chanisavail.so
app_channelredirect.so
app_chanspy.so
app_confbridge.so
app_controlplayback.so
app_dahdibarge.so
app_dahdiras.so
app_db.so
app_dial.so
app_dictate.so
app_directed_pickup.so
app_directory.so
app_disa.so
app_dumpchan.so
app_echo.so
app_exec.so
app_externalivr.so
app_festival.so
app_flash.so
app_followme.so
app_forkcdr.so
app_getcpeid.so
app_ices.so
app_image.so
app_macro.so
app_meetme.so
app_milliwatt.so
app_minivm.so
app_mixmonitor.so
app_morsecode.so
app_mp3.so
app_nbscat.so
app_originate.so
app_page.so
app_parkandannounce.so
app_playback.so
app_playtones.so
app_privacy.so
app_queue.so
app_readexten.so
app_readfile.so
app_read.so
app_record.so
app_sayunixtime.so
app_senddtmf.so
app_sendtext.so
app_setcallerid.so
app_sms.so
app_softhangup.so
app_speech_utils.so
app_stack.so
app_system.so
app_talkdetect.so
app_test.so
app_transfer.so
app_url.so
app_userevent.so
app_verbose.so
app_voicemail.so
app_waitforring.so
app_waitforsilence.so
app_waituntil.so
app_while.so
app_zapateller.so
bridge_builtin_features.so
bridge_multiplexed.so
bridge_simple.so
bridge_softmix.so
cdr_csv.so
cdr_custom.so
cdr_manager.so
cdr_syslog.so
cel_custom.so
cel_manager.so
chan_agent.so
chan_bridge.so
chan_dahdi.so
chan_iax2.so
chan_local.so
chan_multicast_rtp.so
chan_oss.so
chan_phone.so
chan_sip.so
chan_skinny.so
chan_unistim.so
codec_adpcm.so
codec_alaw.so
codec_a_mu.so
codec_dahdi.so
codec_g722.so
codec_g726.so
codec_gsm.so
codec_ilbc.so
codec_lpc10.so
codec_ulaw.so
format_g719.so
format_g723.so
format_g726.so
format_g729.so
format_gsm.so
format_h263.so
format_h264.so
format_ilbc.so
format_jpeg.so
format_pcm.so
format_siren14.so
format_siren7.so
format_sln16.so
format_sln.so
format_vox.so
format_wav_gsm.so
format_wav.so
func_aes.so
func_audiohookinherit.so
func_base64.so
func_blacklist.so
func_callcompletion.so
func_callerid.so
func_cdr.so
func_channel.so
func_config.so
func_cut.so
func_db.so
func_devstate.so
func_dialgroup.so
func_dialplan.so
func_enum.so
func_env.so
func_extstate.so
func_frame_trace.so
func_global.so
func_groupcount.so
func_iconv.so
func_lock.so
func_logic.so
func_math.so
func_md5.so
func_module.so
func_pitchshift.so
func_presence_state.so
func_rand.so
func_realtime.so
func_sha1.so
func_shell.so
func_sprintf.so
func_srv.so
func_strings.so
func_sysinfo.so
func_timeout.so
func_uri.so
func_version.so
func_vmcount.so
func_volume.so
pbx_ael.so
pbx_config.so
pbx_dundi.so
pbx_loopback.so
pbx_realtime.so
pbx_spool.so
res_adsi.so
res_ael_share.so
res_agi.so
res_calendar.so
res_clialiases.so
res_clioriginate.so
res_convert.so
res_crypto.so
res_digium_phone.so
res_fax.so
res_limit.so
res_monitor.so
res_musiconhold.so
res_mutestream.so
res_phoneprov.so
res_realtime.so
res_rtp_asterisk.so
res_rtp_multicast.so
res_security_log.so
res_smdi.so
res_speech.so
res_stun_monitor.so
res_timing_dahdi.so
res_timing_pthread.so
mikeles
Сообщение mikeles »
Я улавливаю. Но это видео, и вроде как пишут что он именно так подгружается.
B как видите, в core show codecs все нормально отображается, видеокодек установлен!
Только почему-то не подгружается.
Подскажите пожалуйста, где можно найти codec_h264.so?
mikeles
Сообщение mikeles »
И я про тоже. Так каким образом тогда включить этот коде?
Кажется разобрался. Добавил в sip_general_custom.conf
videosupport=yes
maxcallbitrate=384
allow=h264
Теперь отображается вот так:
Codecs: 0x20000c (ulaw|alaw|h264)
Что такое Codec Order, и почему без h264?
mikeles писал(а):Я улавливаю. Но это видео, и вроде как пишут что он именно так подгружается.
Да ну? Вот прямо так и установлен? Кто же его установил? И, если установил, то почему нету codec_h264.so?
mikeles писал(а):Подскажите пожалуйста, где можно найти codec_h264.so?
Хочется Вас просто потроллить власть!
при проверке sip show settings ВСЕГДА видит только аудио.
Вы наверное, друг Марии? Вам - читать документацию, вопросы слишком наивны, чтобы всё-всё объяснить.
switch писал(а):Модуль для этого кодека не нужен, так как астериск не занимается его перекодированием, а просто пропускает трафик насквозь. Следовательно вся поддержка заключается в корректном распознавании соответствующего значения в SDP
mikeles
Сообщение mikeles »
Спасибо за ответы. Все заработало. Как и написал ранее.
Только остался нерешенный вопрос:
С обеих сторон Ekiga. Разрешения на клиентах выставлены 640х480.
А видео все равно идет с разрешением 176х144.
Простите, в какую сторону копать?
mikeles
Сообщение mikeles »
Увеличил. 1024 поставил.Все одно и тоже.
Может есть другие клиенты, с которыми все нормаль?
прочитал что тут нужно частоту кадров уменьшить.
http://wiki.ekiga.org/index.php/Trouble ... an_I_do.3F
Кстати. Пробую подконектится с помощью Sony PCS-XG80.
Просто аудио -нормально работает. С видео - не хочет(((
