Проблемы с кодеками
fedorchuk
Проблемы с кодеками
Сообщение fedorchuk »
Перестал работать один транк, насколько я понимаю проблема с кодеками, все кодеки установлены 729 и 723 в т.ч.
   -- Executing [380502402581@mera-callback-out2:4] Dial("SIP/multifon-0000000d", "SIP/igorporoh/0502402581,,m(manual)") in new stack
Audio is at 12090
Adding codec 100003 (ulaw) to SDP
Reliably Transmitting (NAT) to 217.27.xxx.xxx:5060:
INVITE sip:0502402581@217.27.xxx.xxx SIP/2.0
Via: SIP/2.0/UDP 37.59.239.64:5060;branch=z9hG4bK334736d6;rport
From: "asterisk" <sip:201601@37.59.xxx.xxx>;tag=as141660f4
To: <sip:0502402581@217.27.xxx.xxx>
Contact: <sip:201601@37.59.xxx.xxx:5060>
Call-ID: 4f30433e369de4d86e7fe07931001173@37.59.xxx.xxx:5060
CSeq: 102 INVITE
User-Agent: Siemens-Halske-8000-5.1.10
Date: Thu, 20 Dec 2012 21:21:23 GMT
Content-Length: 284
v=0
o=root 703404963 703404963 IN IP4 37.59.xxx.xxx
s=Asterisk PBX 10.8.0
c=IN IP4 37.59.239.64
t=0 0
m=audio 12090 RTP/AVP 0 8 101
a=rtpmap:0 PCMU/8000
a=rtpmap:8 PCMA/8000
a=fmtp:101 0-16
a=silenceSupp:off - - - -
a=ptime:20
a=sendrecv
    -- Called SIP/igorporoh/0502402581
    -- Started music on hold, class 'manual', on channel 'SIP/multifon-0000000d'
<--- SIP read from UDP:217.27.151.178:5060 --->
SIP/2.0 401 Unauthorized
Via: SIP/2.0/UDP 37.59.239.64:5060;branch=z9hG4bK334736d6;received=37.59.xxx.xxx;rport=5060
To: <sip:0502402581@217.27.xxx.xxx>;tag=as63400f4c
CSeq: 102 INVITE
Server: Asterisk PBX 1.6.2.10
WWW-Authenticate: Digest algorithm=MD5, realm="asterisk", nonce="7751648c"
--- (11 headers 0 lines) ---
ACK sip:0502402581@217.27.xxx.xxx SIP/2.0
Via: SIP/2.0/UDP 37.59.xxx.xxx:5060;branch=z9hG4bK334736d6;rport
CSeq: 102 ACK
Audio is at 12090
Via: SIP/2.0/UDP 37.59.xxx.xxx:5060;branch=z9hG4bK7f1cfa21;rport
CSeq: 103 INVITE
Authorization: Digest username="201601", realm="asterisk", algorithm=MD5, uri="sip:0502402581@217.27.xxx.xxx", nonce="7751648c", response="05955618e37e6a13367bac3611dc8121"
Content-Length: 284
v=0
o=root 703404963 703404964 IN IP4 37.59.xxx.xxx
c=IN IP4 37.59.xxx.xxx
t=0 0
a=fmtp:101 0-16
a=ptime:20
a=sendrecv
<--- SIP read from UDP:217.27.xxx.xxx:5060 --->
SIP/2.0 100 Trying
Via: SIP/2.0/UDP 37.59.xxx.xxx:5060;branch=z9hG4bK7f1cfa21;received=37.59.xxx.xxx;rport=5060
Call-ID: 4f30433e369de4d86e7fe07931001173@37.59.239.64:5060
CSeq: 103 INVITE
Require: timer
Session-Expires: 1800;refresher=uas
Contact: <sip:0502402581@217.27.xxx.xxx>
--- (13 headers 0 lines) ---
SIP/2.0 200 OK
Via: SIP/2.0/UDP 37.59.xxx.xxx:5060;branch=z9hG4bK7f1cfa21;received=37.59.239.64;rport=5060
To: <sip:0502402581@217.27.151.178>;tag=as4e725bea
CSeq: 103 INVITE
Require: timer
Content-Length: 263
v=0
o=root 489648069 489648069 IN IP4 217.27.xxx.xxx
s=Asterisk PBX 1.6.2.10
c=IN IP4 217.27.xxx.xxx
t=0 0
m=audio 19444 RTP/AVP 0 8 101
a=fmtp:101 0-16
a=ptime:20
a=sendrecv
--- (14 headers 12 lines) ---
Found RTP audio format 0
Found RTP audio format 8
Found RTP audio format 101
Capabilities: us - (ulaw|alaw), peer - audio=(ulaw|alaw)/video=(nothing)/text=(nothing), combined - (ulaw|alaw)
Peer audio RTP is at port 217.27.xxx.xxx:19444
list_route: hop: <sip:0502402581@217.27.xxx.xxx>
set_destination: Parsing <sip:0502402581@217.27.xxx.xxx> for address/port to send to
set_destination: set destination to 217.27.xxx.xxx:5060
Via: SIP/2.0/UDP 37.59.xxx.xxx:5060;branch=z9hG4bK0861675a;rport
To: <sip:0502402581@217.27.xxx.xxx>;tag=as4e725bea
CSeq: 103 ACK
    -- SIP/igorporoh-0000000e answered SIP/multifon-0000000d
    -- Stopped music on hold on SIP/multifon-0000000d
<--- SIP read from UDP:217.xxx.xxx.178:5060 --->
BYE sip:201601@37.59.xxx.xxx:5060 SIP/2.0
Via: SIP/2.0/UDP 217.27.xxx.xxx:5060;branch=z9hG4bK25b002fa;rport
From: <sip:0502402581@217.27.xxx.xxx>;tag=as4e725bea
To: "asterisk" <sip:201601@37.59.xxx.xxx>;tag=as141660f4
CSeq: 102 BYE
User-Agent: Asterisk PBX 1.6.2.10
Sending to 217.27.xxx.xxx:5060 (NAT)
Scheduling destruction of SIP dialog '4f30433e369de4d86e7fe07931001173@37.59.xxx.xxx:5060' in 32000 ms (Method: BYE)
<--- Transmitting (NAT) to 217.27.xxx.xxx:5060 --->
SIP/2.0 200 OK
Via: SIP/2.0/UDP 217.27.xxx.xxx:5060;branch=z9hG4bK25b002fa;received=217.27.xxx.xxx;rport=5060
CSeq: 102 BYE
Server: Siemens-Halske-8000-5.1.10
    -- Executing [h@mera-callback-out2:1] Set("SIP/multifon-0000000d", "CDR(codec1)=ulaw") in new stack
    -- Executing [h@mera-callback-out2:2] Set("SIP/multifon-0000000d", "CDR(codec2)=ulaw") in new stack
  == Spawn extension (mera-callback-out2, 380502402581, 4) exited non-zero on 'SIP/multifon-0000000d'
Scheduling destruction of SIP dialog '5a78f3e74c979d8172151ad441d28302@multifon.ru' in 6400 ms (Method: INVITE)
set_destination: Parsing <sip:79251891044@193.201.xxx.xxx:5060;transport=udp> for address/port to send to
set_destination: set destination to 193.201.xxx.xxx:5060
Reliably Transmitting (NAT) to 193.201.xxx.xxx:5060:
BYE sip:79251891044@193.201.xxx.xxx:5060;transport=udp SIP/2.0
Via: SIP/2.0/UDP 37.59.xxx.xxx:5060;branch=z9hG4bK0dbb5312;rport
From: "asterisk" <sip:79261945633@multifon.ru>;tag=as6baf68ba
To: <sip:79251891033@multifon.ru>;tag=C8BD32463135364131807700
Call-ID: 5a78f3e74c979d8172151ad441d28302@multifon.ru
CSeq: 104 BYE
Proxy-Authorization: Digest username="79261945633", realm="BREDBAND", algorithm=MD5, uri="sip:79251891044@193.201.xxxxxxx:5060", nonce="MTM1NjAzODMwNTrGw6hYMUeQ7jUVPui6mPaU", response="b4136a5d5e542a56d5c72ec4e6a85480", opaque="MTM1NjAzODMwNTrGw6hYMUeQ7jUVPui6mPaU", qop=auth, cnonce="30bf3a88", nc=00000002
[Dec 21 01:21:27] NOTICE[8193]: pbx_spool.c:373 attempt_thread: Call completed to SIP/multifon/79251891033
<--- SIP read from UDP:193.201.xxx.xxx:5060 --->
SIP/2.0 200 OK
Via: SIP/2.0/UDP 37.59.xxx.xxx:5060;received=37.59.xxx.xxx;branch=z9hG4bK0dbb5312;rport=5060
CSeq: 104 BYE
Что можно сделать?
Re: Проблемы с кодеками
Неи проблемы с кодеками. Учитесь читать логи. Содинение проходит с кодеками alw & ulaw, но удалённый сервер сразу посылает вам BYE.
Почему? Ответ в диалплане и логах этого Астериска.
fedorchuk
У меня в плане набора следующей строчкой еще один провайдер, почему он не пытается дозвониться по нему?
А мы тут телепаты и видим эту строчку на расстоянии.
fedorchuk
mts => igorporoh/
mts2 => vegatele/+
exten => _38050XXXXXXX,1,Set(CDR(direction)=Ukraine-MTC)
exten => _38050XXXXXXX,n,Playback(priv-trying)
exten => _38050XXXXXXX,n,Dial(SIP/${mts}${EXTEN:-10},,m(manual))
exten => _38050XXXXXXX,n,Dial(SIP/${mts2}${EXTEN},,m(manual))
exten => _38050XXXXXXX,n,HangUp
А с чего он должен начать звонить по второй строке ?
Отбой пришел верный, он и посчитал что первый звонок прошел успешно и дальше не пошел.
mts2 => vegatele/+
mts2 => vegatele ; а плюс тут зачем, номер до +7 догоняете ?
exten => _38050XXXXXXX,n,Dial(SIP/${mts2} / +${EXTEN},,m(manual))
fedorchuk
Понятно,
вегател принимает либо 050xxxxxxx либо +38050xxxxxxx, так как я номер набираю 380..., то проще было добавить плюс..
У меня такой диалплан с вегателом работал, потом появился второй провайдер (дешевле) я его и вписал на первое место. Но как я понимаю слеши все равно где ставить либо в плане либо в переменной, мне проще в переменной, захочу поменять оператора, который будет принимать без +, сразу здесь и подправлю.
