Помогите разобраться с логом.
Andy
Сообщение Andy »
Добры день,
Подскажите, пожалуйста.
У нас астериск на виртуалке.
Версия 14.0.13.34
В момент отвалились телефоны.
При просмотре лога идёт запись:
[2022-04-15 11:28:23] ERROR[218534] channel.c: FRACK!, Failed assertion bad magic number 0x0 for object 0x7f902001c180 (0)
[2022-04-15 11:28:23] ERROR[218534] : Got 15 backtrace records
[2022-04-15 11:28:23] ERROR[218534] : Got 18 backtrace records
[2022-04-15 11:28:37] VERBOSE[111791] loader.c: Asterisk Dynamic Loader Starting:
[2022-04-15 11:28:37] NOTICE[111791] loader.c: 343 modules will be loaded.
[2022-04-15 11:28:38] VERBOSE[111791] loader.c: Loading res_odbc.so.
[2022-04-15 11:28:38] WARNING[111791] res_odbc.c: res_odbc: Error SQLConnect=-1 errno=0 [unixODBC][Driver Manager]Can't open lib '/usr/local/lib/mariadb/libmaodbc.so' : file not found
[2022-04-15 11:28:38] NOTICE[111791] res_odbc.c: Registered ODBC class 'asteriskcdrdb' dsn->[MySQL-asteriskcdrdb]
[2022-04-15 11:28:38] VERBOSE[111791] loader.c: res_odbc.so => (ODBC resource)
[2022-04-15 11:28:38] VERBOSE[111791] loader.c: Loading extconfig.
[2022-04-15 11:28:38] VERBOSE[111791] config.c: [ Initializing Custom Configuration Options ]
[2022-04-15 11:28:38] VERBOSE[111791] loader.c: extconfig => (Configuration)
[2022-04-15 11:28:38] VERBOSE[111791] loader.c: Loading res_config_odbc.so.
[2022-04-15 11:28:38] VERBOSE[111791] loader.c: res_config_odbc.so => (Realtime ODBC configuration)
[2022-04-15 11:28:38] VERBOSE[111791] loader.c: Loading cdr.
[2022-04-15 11:28:38] NOTICE[111791] cdr.c: CDR simple logging enabled.
[2022-04-15 11:28:38] VERBOSE[111791] loader.c: cdr => (CDR Engine)
[2022-04-15 11:28:38] VERBOSE[111791] loader.c: Loading cdr_adaptive_odbc.so.
[2022-04-15 11:28:38] VERBOSE[111791] loader.c: cdr_adaptive_odbc.so => (Adaptive ODBC CDR backend)
[2022-04-15 11:28:38] VERBOSE[111791] loader.c: Loading pbx_config.so.
Лог большой, полностью тут проблематично выложить.
Смущает эта ошибка - FRACK!
Re: Помогите разобраться с логом.
Версия 14.0.13.34
Поставить либо 13 либо 16 версию и не заморачиваться.
16-ая версия не спасёт.
Возможная проблема виртуализатора. Согласно
https://community.asterisk.org/t/asteri ... -0x0/83217 (там 16-й Астериск)
причина - попытка обратиться к сегменту памяти, который уже освобождён.
А согласно
https://community.freepbx.org/t/frack-b ... x0/76221/3
причина - обращение к объекту, который уже чем-то занят. Человек нашёл решение для себя, он обновлял версию Астериск, но не обновил сборку chan_sccp-b который там используеит.
