Realtime PostgreSQL pjsip
Krymmy
Сообщение Krymmy »
На просторах инета сложно найти готовую sql команду для realtime pjsip работающий на postgesql потому оставлю настройки пользователей для realtime тут, может кому то понадобится)
CREATE TYPE yorn AS ENUM ('yes', 'no');
CREATE TYPE inreup AS ENUM ('invite','reinvite','update');
CREATE TYPE allow_prohib_un AS ENUM ('allowed_not_screened','allowed_passed_screened','allowed_failed_screened','allowed','prohib_not_screened','prohib_passed_screened','prohib_failed_screened','prohib','unavailable');
CREATE TYPE auth_tp AS ENUM ('md5','userpass');
CREATE TYPE noouin AS ENUM ('none','outgoing','incoming');
CREATE TYPE dtmf_md AS ENUM ('rfc4733','inband','info','auto');
CREATE TYPE ind_by AS ENUM ('username','auth_username');
CREATE TYPE timers_mode AS ENUM ('forced','no','required','yes');
CREATE TYPE rel_mode AS ENUM ('no','required','yes');
CREATE TYPE media_encryption_mode AS ENUM ('no','sdes','dtls');
CREATE TYPE t38_udptl_ec_mode AS ENUM ('none','fec','redundancy');
CREATE TYPE dtls_setup_mode AS ENUM ('active','passive','actpass');
CREATE TYPE redirect_method_mode AS ENUM ('user','uri_core','uri_pjsip');
CREATE TYPE transport_method_mode AS ENUM ('default','unspecified','tlsv1','sslv2','sslv3','sslv23');
CREATE TYPE protocol_mode AS ENUM ('udp','tcp','tls','ws','wss');
-- SQLINES LICENSE FOR EVALUATION USE ONLY
CREATE TABLE ps_aors (
  id varchar(40) NOT NULL,
  contact varchar(255) DEFAULT NULL,
  default_expiration int DEFAULT NULL,
  mailboxes varchar(80) DEFAULT NULL,
  max_contacts int DEFAULT NULL,
  minimum_expiration int DEFAULT NULL,
  remove_existing yorn DEFAULT NULL,
  qualify_frequency int DEFAULT NULL,
  authenticate_qualify yorn DEFAULT NULL,
  maximum_expiration int DEFAULT NULL,
  outbound_proxy varchar(40) DEFAULT NULL,
  support_path yorn DEFAULT NULL,
  qualify_timeout double precision DEFAULT NULL,
  voicemail_extension varchar(40) DEFAULT NULL,
  CONSTRAINT id UNIQUE  (id)
CREATE INDEX ps_aors_id ON ps_aors (id);
CREATE INDEX ps_aors_qualifyfreq_contact ON ps_aors (qualify_frequency,contact);
CREATE TABLE ps_auths (
  auth_type auth_tp DEFAULT NULL,
  nonce_lifetime int DEFAULT NULL,
  md5_cred varchar(40) DEFAULT NULL,
  password varchar(80) DEFAULT NULL,
  realm varchar(40) DEFAULT NULL,
  username varchar(40) DEFAULT NULL
CREATE INDEX ps_auths_id ON ps_auths (id);
CREATE TABLE ps_contacts (
  id varchar(255) DEFAULT NULL,
  uri varchar(255) DEFAULT NULL,
  expiration_time bigint DEFAULT NULL,
  path text,
  user_agent varchar(255) DEFAULT NULL,
  reg_server varchar(20) DEFAULT NULL,
  via_addr varchar(40) DEFAULT NULL,
  via_port int DEFAULT NULL,
  call_id varchar(255) DEFAULT NULL,
  endpoint varchar(40) DEFAULT NULL,
  prune_on_boot yorn DEFAULT NULL
  CONSTRAINT ps_contacts_uq UNIQUE  (id,reg_server)
CREATE INDEX ps_contacts_id ON ps_contacts (id);
CREATE INDEX ps_contacts_qualifyfreq_exp ON ps_contacts (qualify_frequency,expiration_time);
CREATE TABLE ps_domain_aliases (
  domain varchar(80) DEFAULT NULL
CREATE INDEX ps_domain_aliases_id ON ps_domain_aliases (id);
CREATE TABLE ps_endpoint_id_ips (
  match varchar(80) DEFAULT NULL
CREATE INDEX ps_endpoint_id_ips_id ON ps_endpoint_id_ips (id);
CREATE TABLE ps_endpoints (
  transport varchar(40) DEFAULT NULL,
  aors varchar(200) DEFAULT NULL,
  auth varchar(40) DEFAULT NULL,
  context varchar(40) DEFAULT NULL,
  disallow varchar(200) DEFAULT NULL,
  direct_media yorn DEFAULT NULL,
  connected_line_method inreup DEFAULT NULL,
  direct_media_method inreup DEFAULT NULL,
  direct_media_glare_mitigation noouin DEFAULT NULL,
  disable_direct_media_on_nat yorn DEFAULT NULL,
  dtmf_mode dtmf_md DEFAULT NULL,
  external_media_address varchar(40) DEFAULT NULL,
  force_rport yorn DEFAULT NULL,
  ice_support yorn DEFAULT NULL,
  identify_by ind_by DEFAULT NULL,
  mailboxes varchar(40) DEFAULT NULL,
  moh_suggest varchar(40) DEFAULT NULL,
  outbound_auth varchar(40) DEFAULT NULL,
  rewrite_contact yorn DEFAULT NULL,
  rtp_ipv6 yorn DEFAULT NULL,
  rtp_symmetric yorn DEFAULT NULL,
  send_diversion yorn DEFAULT NULL,
  send_pai yorn DEFAULT NULL,
  send_rpid yorn DEFAULT NULL,
  timers_min_se int DEFAULT NULL,
  timers timers_mode DEFAULT NULL,
  timers_sess_expires int DEFAULT NULL,
  callerid varchar(40) DEFAULT NULL,
  callerid_privacy allow_prohib_un DEFAULT NULL,
  callerid_tag varchar(40) DEFAULT NULL,
  "100rel" rel_mode DEFAULT NULL,
  aggregate_mwi yorn DEFAULT NULL,
  trust_id_inbound yorn DEFAULT NULL,
  trust_id_outbound yorn DEFAULT NULL,
  use_ptime yorn DEFAULT NULL,
  use_avpf yorn DEFAULT NULL,
  media_encryption media_encryption_mode DEFAULT NULL,
  inband_progress yorn DEFAULT NULL,
  call_group varchar(40) DEFAULT NULL,
  pickup_group varchar(40) DEFAULT NULL,
  named_call_group varchar(40) DEFAULT NULL,
  named_pickup_group varchar(40) DEFAULT NULL,
  device_state_busy_at int DEFAULT NULL,
  fax_detect yorn DEFAULT NULL,
  t38_udptl yorn DEFAULT NULL,
  t38_udptl_ec t38_udptl_ec_mode DEFAULT NULL,
  t38_udptl_maxdatagram int DEFAULT NULL,
  t38_udptl_nat yorn DEFAULT NULL,
  t38_udptl_ipv6 yorn DEFAULT NULL,
  tone_zone varchar(40) DEFAULT NULL,
  language varchar(40) DEFAULT NULL,
  one_touch_recording yorn DEFAULT NULL,
  record_on_feature varchar(40) DEFAULT NULL,
  record_off_feature varchar(40) DEFAULT NULL,
  rtp_engine varchar(40) DEFAULT NULL,
  allow_transfer yorn DEFAULT NULL,
  allow_subscribe yorn DEFAULT NULL,
  sdp_owner varchar(40) DEFAULT NULL,
  sdp_session varchar(40) DEFAULT NULL,
  tos_audio varchar(10) DEFAULT NULL,
  tos_video varchar(10) DEFAULT NULL,
  sub_min_expiry int DEFAULT NULL,
  from_domain varchar(40) DEFAULT NULL,
  from_user varchar(40) DEFAULT NULL,
  mwi_from_user varchar(40) DEFAULT NULL,
  dtls_verify varchar(40) DEFAULT NULL,
  dtls_rekey varchar(40) DEFAULT NULL,
  dtls_cert_file varchar(200) DEFAULT NULL,
  dtls_private_key varchar(200) DEFAULT NULL,
  dtls_cipher varchar(200) DEFAULT NULL,
  dtls_ca_file varchar(200) DEFAULT NULL,
  dtls_ca_path varchar(200) DEFAULT NULL,
  dtls_setup dtls_setup_mode DEFAULT NULL,
  srtp_tag_32 yorn DEFAULT NULL,
  redirect_method redirect_method_mode DEFAULT NULL,
  set_var text,
  cos_audio int DEFAULT NULL,
  cos_video int DEFAULT NULL,
  message_context varchar(40) DEFAULT NULL,
  force_avp yorn DEFAULT NULL,
  media_use_received_transport yorn DEFAULT NULL,
  accountcode varchar(80) DEFAULT NULL,
  user_eq_phone yorn DEFAULT NULL,
  moh_passthrough yorn DEFAULT NULL,
  media_encryption_optimistic yorn DEFAULT NULL,
  rpid_immediate yorn DEFAULT NULL,
  g726_non_standard yorn DEFAULT NULL,
  rtp_keepalive int DEFAULT NULL,
  rtp_timeout int DEFAULT NULL,
  rtp_timeout_hold int DEFAULT NULL,
  bind_rtp_to_media_address yorn DEFAULT NULL,
  mwi_subscribe_replaces_unsolicited int DEFAULT NULL,
  deny varchar(95) DEFAULT NULL,
  permit varchar(95) DEFAULT NULL,
  acl varchar(40) DEFAULT NULL,
  contact_deny varchar(95) DEFAULT NULL,
  contact_permit varchar(95) DEFAULT NULL,
  contact_acl varchar(40) DEFAULT NULL,
  subscribe_context varchar(40) DEFAULT NULL,
  fax_detect_timeout int DEFAULT NULL,
  contact_user varchar(80) DEFAULT NULL,
  asymmetric_rtp_codec yorn DEFAULT NULL
CREATE INDEX ps_endpoint_id ON ps_endpoints (id);
CREATE TABLE ps_globals (
  max_forwards int DEFAULT NULL,
  default_outbound_endpoint varchar(40) DEFAULT NULL,
  debug varchar(40) DEFAULT NULL,
  endpoint_identifier_order varchar(40) DEFAULT NULL,
  max_initial_qualify_time int DEFAULT NULL,
  default_from_user varchar(80) DEFAULT NULL,
  keep_alive_interval int DEFAULT NULL,
  regcontext varchar(80) DEFAULT NULL,
  contact_expiration_check_interval int DEFAULT NULL,
  default_voicemail_extension varchar(40) DEFAULT NULL,
  disable_multi_domain yorn DEFAULT NULL,
  unidentified_request_count int DEFAULT NULL,
  unidentified_request_period int DEFAULT NULL,
  unidentified_request_prune_interval int DEFAULT NULL,
  default_realm varchar(40) DEFAULT NULL,
  mwi_tps_queue_high int DEFAULT NULL,
  mwi_tps_queue_low int DEFAULT NULL,
  mwi_disable_initial_unsolicited yorn DEFAULT NULL,
  ignore_uri_user_options yorn DEFAULT NULL
CREATE INDEX ps_globals_id ON ps_globals (id);
CREATE TABLE ps_registrations (
  auth_rejection_permanent yorn DEFAULT NULL,
  client_uri varchar(255) DEFAULT NULL,
  contact_user varchar(40) DEFAULT NULL,
  max_retries int DEFAULT NULL,
  retry_interval int DEFAULT NULL,
  forbidden_retry_interval int DEFAULT NULL,
  server_uri varchar(255) DEFAULT NULL,
  fatal_retry_interval int DEFAULT NULL,
  line yorn DEFAULT NULL,
CREATE INDEX ps_registrations_id ON ps_registrations (id);
CREATE TABLE ps_subscription_persistence (
  packet varchar(2048) DEFAULT NULL,
  src_name varchar(128) DEFAULT NULL,
  src_port int DEFAULT NULL,
  transport_key varchar(64) DEFAULT NULL,
  local_name varchar(128) DEFAULT NULL,
  local_port int DEFAULT NULL,
  cseq int DEFAULT NULL,
  tag varchar(128) DEFAULT NULL,
CREATE INDEX ps_subscription_persistence_id ON ps_subscription_persistence (id);
CREATE TABLE ps_systems (
  timer_t1 int DEFAULT NULL,
  timer_b int DEFAULT NULL,
  compact_headers yorn DEFAULT NULL,
  threadpool_initial_size int DEFAULT NULL,
  threadpool_auto_increment int DEFAULT NULL,
  threadpool_idle_timeout int DEFAULT NULL,
  threadpool_max_size int DEFAULT NULL,
  disable_tcp_switch yorn DEFAULT NULL
CREATE INDEX ps_systems_id ON ps_systems (id);
CREATE TABLE ps_transports (
  async_operations int DEFAULT NULL,
  bind varchar(40) DEFAULT NULL,
  ca_list_file varchar(200) DEFAULT NULL,
  external_signaling_address varchar(40) DEFAULT NULL,
  external_signaling_port int DEFAULT NULL,
  method transport_method_mode DEFAULT NULL,
  local_net varchar(40) DEFAULT NULL,
  password varchar(40) DEFAULT NULL,
  priv_key_file varchar(200) DEFAULT NULL,
  protocol protocol_mode DEFAULT NULL,
  require_client_cert yorn DEFAULT NULL,
  verify_client yorn DEFAULT NULL,
  verify_server yorn DEFAULT NULL,
  tos varchar(10) DEFAULT NULL,
  cos int DEFAULT NULL,
  allow_reload yorn DEFAULT NULL
CREATE INDEX ps_transports_id ON ps_transports (id);
Возможны неточности в реализации, в SQL я не силен
