настройка iad2430-24fxs
phone2user
Сообщение phone2user »
Добрый вечер, столкнулся с недопониманием при настройке голосового шлюза cisco iad2430-24fxs. Все настройки были сброшены на заводские, затем настроено соединение с астериском.
Приведу конфиг (ip и пароли взяты с потолка):
version 12.4
service timestamps debug datetime msec
service timestamps log datetime msec
service password-encryption
hostname iad2430-24fxs
boot-start-marker
boot-end-marker
aaa new-model
aaa session-id common
clock timezone Moscow 4
ip domain name some-domain.ru
voice-card 0
voice service voip
allow-connections h323 to h323
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
sip
registrar server expires max 3600 min 3600
no call service stop
interface FastEthernet0/0
ip address 31.104.34.100 255.255.0.0
duplex auto
speed auto
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
no ip http server
no ip http secure-server
ip forward-protocol nd
access-list 23 permit any log
dialer-list 1 protocol ip permit
control-plane
voice-port 2/0
caller-id enable
voice-port 2/1
voice-port 2/2
voice-port 2/3
voice-port 2/4
voice-port 2/5
voice-port 2/6
voice-port 2/7
voice-port 2/8
voice-port 2/9
voice-port 2/10
voice-port 2/11
voice-port 2/12
voice-port 2/13
voice-port 2/14
voice-port 2/15
voice-port 2/16
voice-port 2/17
voice-port 2/18
voice-port 2/19
voice-port 2/20
voice-port 2/21
voice-port 2/22
voice-port 2/23
dial-peer voice 1 pots
destination-pattern 9988
port 2/0
authentication username 9988 password xzxzxzxzxzxzxzx32666347343532054
dial-peer voice 1001 voip
destination-pattern .T
progress_ind progress enable 8
session protocol sipv2
session target ipv4:104.163.66.148:5060
codec g711alaw
sip-ua
retry invite 3
retry response 3
retry bye 3
retry cancel 3
timers trying 1000
registrar ipv4:104.163.66.148 expires 60
sip-server ipv4:104.163.66.148:5060
notify telephone-event max-duration 500
line con 0
line aux 0
line vty 0 4
access-class 23 in
exec-timeout 60 0
privilege level 15
password 7 zxxzxzxzxzxzxxzzx
logging synchronous
transport input ssh
ntp clock-period 17180023
ntp server 229.136.240.232 prefer
ntp server 229.136.240.231
end
А теперь, что нам говорит про это астериск:
asterisk*CLI> core show version
Asterisk 1.8.11.1 built by root @ asterisk on a x86_64 running Linux
asterisk*CLI> sip show peers
Name/username Host Dyn Forcerport ACL Port Status
200/200 31.104.34.2 D N 5060 Unmonitored
201/201 31.104.34.2 D N 5060 Unmonitored
202/202 31.104.34.2 D N 5060 Unmonitored
203/203 31.104.34.2 D N 5060 Unmonitored
210/210 31.104.34.1 D N 5060 Unmonitored
211/211 31.104.34.1 D N 5060 Unmonitored
212/212 31.104.34.3 D N 5060 Unmonitored
213/213 31.104.34.3 D N 5060 Unmonitored
216/216 31.104.34.4 D N 5060 Unmonitored
217/217 31.104.34.4 D N 5060 Unmonitored
218/218 31.104.34.5 D N 5060 Unmonitored
219/219 31.104.34.5 D N 5060 Unmonitored
9988/9988 31.104.34.100 D N 57496 Unmonitored
13 sip peers [Monitored: 0 online, 0 offline Unmonitored: 13 online, 0 offline]
Пиры типа 200-219 это цифровые аддпаки, меня же интересует, почему пир от циски (9988) законнектился по такому странному порту (57496)?
Re: настройка iad2430-24fxs
Цыска считает, что конечные девайсы (ИП телефоны, шлюзы, и терминалы), которые магнитятся динамически, могут использовать любой порт, а совсем не обязательно 5060. Вот например если устройство выпрыгнет из-за НАТа, оно же прибежит с како-го то произвольного верхнего порта, а не с 5060, Так и тут такая же логика. Ну и у Вас там и стоит N - то есть nat=yes.
Вы или используйте sip-ua, которую прописали, и тогда
session target sip-server
или статичный sip пир, как сейчас указано в dial-peer voice 1001 voip, но тогда секция sip-ua не нужна.
phone2user
благодарю за разъяснение.
phone2user
Перехват звонков работает. О переводе звонков: подозреваю, что настройка перевода осуществляется на данном шлюзе. К вышеуказанным настройкам добавил:
asterisk ~ asterisk -rx "features show"
Builtin Feature Default Current
Pickup *8 *8
Blind Transfer # #
Attended Transfer
One Touch Monitor
Disconnect Call * *
Park Call
One Touch MixMonitor
iad2430-24fxs# sh run
telephony-service
max-conferences 4 gain -6
transfer-system full-consult
transfer-pattern .T
однако при нажатии на решетку и наборе другого номера, ничего не происходит. Есть ли у кого положительный опыт решения данной проблемы?
Последний раз редактировалось phone2user 01 ноя 2012, 08:40, всего редактировалось 1 раз.
conf t
dtmf-relay rtp-nte
phone2user
благодарю, но пока не работает. Теперь при нажатии на телефоне #, в логах появляется следующее:
[Nov 1 08:48:47] DTMF[30937] channel.c: DTMF begin '#' received on SIP/0205-00000f6f
[Nov 1 08:48:47] DTMF[30937] channel.c: DTMF begin passthrough '#' on SIP/0205-00000f6f
[Nov 1 08:48:47] DTMF[30937] channel.c: DTMF end '#' received on SIP/0205-00000f6f, duration 100 ms
[Nov 1 08:48:47] DTMF[30937] channel.c: DTMF end accepted with begin '#' on SIP/0205-00000f6f
[Nov 1 08:48:47] DTMF[30937] channel.c: DTMF end passthrough '#' on SIP/0205-00000f6f
[Nov 1 08:48:48] DTMF[30937] channel.c: DTMF begin '0' received on SIP/0205-00000f6f
[Nov 1 08:48:48] DTMF[30937] channel.c: DTMF begin passthrough '0' on SIP/0205-00000f6f
[Nov 1 08:48:49] DTMF[30937] channel.c: DTMF end '0' received on SIP/0205-00000f6f, duration 100 ms
[Nov 1 08:48:49] DTMF[30937] channel.c: DTMF end accepted with begin '0' on SIP/0205-00000f6f
[Nov 1 08:48:49] DTMF[30937] channel.c: DTMF end passthrough '0' on SIP/0205-00000f6f
[Nov 1 08:48:49] DTMF[30937] channel.c: DTMF begin '2' received on SIP/0205-00000f6f
[Nov 1 08:48:49] DTMF[30937] channel.c: DTMF begin passthrough '2' on SIP/0205-00000f6f
[Nov 1 08:48:49] DTMF[30937] channel.c: DTMF end '2' received on SIP/0205-00000f6f, duration 100 ms
[Nov 1 08:48:49] DTMF[30937] channel.c: DTMF end accepted with begin '2' on SIP/0205-00000f6f
[Nov 1 08:48:49] DTMF[30937] channel.c: DTMF end passthrough '2' on SIP/0205-00000f6f
[Nov 1 08:48:49] DTMF[30937] channel.c: DTMF begin '0' received on SIP/0205-00000f6f
[Nov 1 08:48:49] DTMF[30937] channel.c: DTMF begin passthrough '0' on SIP/0205-00000f6f
[Nov 1 08:48:49] DTMF[30937] channel.c: DTMF end '0' received on SIP/0205-00000f6f, duration 200 ms
[Nov 1 08:48:50] DTMF[30937] channel.c: DTMF begin '4' received on SIP/0205-00000f6f
[Nov 1 08:48:50] DTMF[30937] channel.c: DTMF begin passthrough '4' on SIP/0205-00000f6f
[Nov 1 08:48:50] DTMF[30937] channel.c: DTMF end '4' received on SIP/0205-00000f6f, duration 100 ms
[Nov 1 08:48:50] DTMF[30937] channel.c: DTMF end accepted with begin '4' on SIP/0205-00000f6f
[Nov 1 08:48:50] DTMF[30937] channel.c: DTMF end passthrough '4' on SIP/0205-00000f6f
нужно ли изменить что либо в диалплане астера? (в настоящий момент в диалплане событие перевода никак не обрабатывается)
phone2user
почитал справку и сам себе ответил, благодарю, все работает.
exten => 365123,1,Dial(SIP/0123,,tT)
phone2user
также имеется неприятный нюанс, при звонке с Циски на любого абонента в трубке секунд 8-9 ничего не слышно, и только затем идет дозвон. Грубо говоря, вызываемый телефон начинает звонить секунд через 10. Можете ли указать на ошибку в конфиге циски?
interdigit
ещё как вариант ставить более жесткие маски
destination-pattern ^1..$
codec g711alaw
dial-peer voice 1011 voip
destination-pattern ^[2-79]......$
dial-peer voice 1021 voip
destination-pattern ^8..........$
phone2user
премного благодарен,
voice-port 2/0
 timeouts interdigit 2
спасло :)
