iax не работает
music-sf
iax не работает
Сообщение music-sf »
Всем здравствуйте.
Сразу скажу, что с астериском вообще первый раз столкнулся.. доки почитал, но пока очень немного. И тут случилась засада - перестал работать астериск в одном из удалённых магазинов
[Oct 22 16:51:56] WARNING[2097] res_phoneprov.c: Unable to load users.conf
[Oct 22 16:51:56] WARNING[2097] app_festival.c: No such configuration file festival.conf
[Oct 22 16:51:56] WARNING[2097] res_snmp.c: Could not load res_snmp.conf
[Oct 22 17:23:18] WARNING[2971] app_dial.c: Unable to create channel of type 'IAX2' (cause 20 - Unknown)
[Oct 22 17:25:01] WARNING[3092] app_dial.c: Unable to create channel of type 'IAX2' (cause 20 - Unknown)
[Oct 22 17:28:03] WARNING[3156] app_dial.c: Unable to create channel of type 'IAX2' (cause 20 - Unknown)
[Oct 22 18:00:54] WARNING[3332] app_dial.c: Unable to create channel of type 'IAX2' (cause 20 - Unknown)
[Oct 22 21:01:56] WARNING[3698] app_dial.c: Unable to create channel of type 'IAX2' (cause 20 - Unknown)
[Oct 22 21:02:05] WARNING[3709] app_dial.c: Unable to create channel of type 'IAX2' (cause 20 - Unknown)
[Oct 23 11:34:46] WARNING[2110] indications.c: Can't find indications config file indications.conf.
[Oct 23 11:34:46] WARNING[2110] res_odbc.c: Unable to load config file res_odbc.conf
[Oct 23 11:34:46] WARNING[2110] res_jabber.c: No such configuration file jabber.conf
[Oct 23 11:34:46] WARNING[2110] res_config_pgsql.c: Unable to load config res_pgsql.conf
[Oct 23 11:34:47] WARNING[2110] cdr_sqlite3_custom.c: Failed to load configuration file. Module not activated.
[Oct 23 11:34:47] WARNING[2110] cel_tds.c: cel_tds module had config problems; declining load
[Oct 23 11:34:47] WARNING[2110] cdr_manager.c: Failed to load configuration file. Module not activated.
[Oct 23 11:34:47] WARNING[2110] cdr_adaptive_odbc.c: Unable to load cdr_adaptive_odbc.conf.  No adaptive ODBC CDRs.
[Oct 23 11:34:47] WARNING[2110] cdr_pgsql.c: Unable to load config for PostgreSQL CDR's: cdr_pgsql.conf
[Oct 23 11:34:47] WARNING[2110] cel_pgsql.c: CEL pgsql config file missing global section.
[Oct 23 11:34:47] WARNING[2110] cdr_odbc.c: cdr_odbc: Unable to load config for ODBC CDR's: cdr_odbc.conf
[Oct 23 11:34:47] WARNING[2110] app_followme.c: No follow me config file (followme.conf), so no follow me
[Oct 23 11:34:47] WARNING[2110] app_minivm.c: Failed to load configuration file. Module activated with default settings.
[Oct 23 11:34:47] WARNING[2110] res_phoneprov.c: Unable to load users.conf
[Oct 23 11:34:47] WARNING[2110] app_festival.c: No such configuration file festival.conf
[Oct 23 11:34:47] WARNING[2110] res_snmp.c: Could not load res_snmp.conf
TGGW*CLI> iax2 show peers
Name/Username    Host                 Mask             Port          Status
office/gostinni  192.168.253.90  (S)  255.255.255.255  4569 (T)      OK (19 ms)
1 iax2 peers [1 online, 0 offline, 0 unmonitored]
TGGW*CLI>
Соответственно звонки не проходят. Во время попытки позвонить выскакивает
Со стороны другого сервера
magaz/offic  192.168.7.254   (S)  255.255.255.255  4569 (T)      UNREACHABLE
В магазине
cat syslog | grep WARNING
Oct 23 11:34:46 TGGW asterisk[2110]: WARNING[2110]: indications.c:1057 in load_indications: Can't find indications config file indications.conf.
Oct 23 11:34:46 TGGW asterisk[2110]: WARNING[2110]: res_odbc.c:782 in load_odbc_config: Unable to load config file res_odbc.conf
Oct 23 11:34:46 TGGW asterisk[2110]: WARNING[2110]: res_jabber.c:4553 in aji_load_config: No such configuration file jabber.conf
Oct 23 11:34:46 TGGW asterisk[2110]: WARNING[2110]: res_config_pgsql.c:1425 in parse_config: Unable to load config res_pgsql.conf
Oct 23 11:34:47 TGGW asterisk[2110]: WARNING[2110]: cdr_sqlite3_custom.c:163 in load_config: Failed to load configuration file. Module not activated.
Oct 23 11:34:47 TGGW asterisk[2110]: WARNING[2110]: cel_tds.c:557 in load_module: cel_tds module had config problems; declining load
Oct 23 11:34:47 TGGW asterisk[2110]: WARNING[2110]: cdr_manager.c:79 in load_config: Failed to load configuration file. Module not activated.
Oct 23 11:34:47 TGGW asterisk[2110]: WARNING[2110]: cdr_adaptive_odbc.c:100 in load_config: Unable to load cdr_adaptive_odbc.conf.  No adaptive ODBC CDRs.
Oct 23 11:34:47 TGGW asterisk[2110]: WARNING[2110]: cdr_pgsql.c:379 in config_module: Unable to load config for PostgreSQL CDR's: cdr_pgsql.conf
Oct 23 11:34:47 TGGW asterisk[2110]: WARNING[2110]: cel_pgsql.c:390 in process_my_load_module: CEL pgsql config file missing global section.
Oct 23 11:34:47 TGGW asterisk[2110]: WARNING[2110]: cdr_odbc.c:178 in odbc_load_module: cdr_odbc: Unable to load config for ODBC CDR's: cdr_odbc.conf
Oct 23 11:34:47 TGGW asterisk[2110]: WARNING[2110]: app_followme.c:340 in reload_followme: No follow me config file (followme.conf), so no follow me
Oct 23 11:34:47 TGGW asterisk[2110]: WARNING[2110]: app_minivm.c:2876 in load_config: Failed to load configuration file. Module activated with default settings.
Oct 23 11:34:47 TGGW asterisk[2110]: WARNING[2110]: res_phoneprov.c:922 in set_config: Unable to load users.conf
Oct 23 11:34:47 TGGW asterisk[2110]: WARNING[2110]: app_festival.c:544 in load_module: No such configuration file festival.conf
Oct 23 11:34:47 TGGW asterisk[2110]: WARNING[2110]: res_snmp.c:57 in load_config: Could not load res_snmp.conf
Oct 23 13:40:13 TGGW asterisk[3641]: WARNING[3641]: indications.c:1057 in load_indications: Can't find indications config file indications.conf.
Oct 23 13:40:13 TGGW asterisk[3641]: WARNING[3641]: res_odbc.c:782 in load_odbc_config: Unable to load config file res_odbc.conf
Oct 23 13:40:13 TGGW asterisk[3641]: WARNING[3641]: res_jabber.c:4553 in aji_load_config: No such configuration file jabber.conf
Oct 23 13:40:13 TGGW asterisk[3641]: WARNING[3641]: res_config_pgsql.c:1425 in parse_config: Unable to load config res_pgsql.conf
Oct 23 13:40:13 TGGW asterisk[3641]: WARNING[3641]: cdr_sqlite3_custom.c:163 in load_config: Failed to load configuration file. Module not activated.
Oct 23 13:40:13 TGGW asterisk[3641]: WARNING[3641]: cel_tds.c:557 in load_module: cel_tds module had config problems; declining load
Oct 23 13:40:13 TGGW asterisk[3641]: WARNING[3641]: cdr_manager.c:79 in load_config: Failed to load configuration file. Module not activated.
Oct 23 13:40:13 TGGW asterisk[3641]: WARNING[3641]: cdr_adaptive_odbc.c:100 in load_config: Unable to load cdr_adaptive_odbc.conf.  No adaptive ODBC CDRs.
Oct 23 13:40:13 TGGW asterisk[3641]: WARNING[3641]: cdr_pgsql.c:379 in config_module: Unable to load config for PostgreSQL CDR's: cdr_pgsql.conf
Oct 23 13:40:13 TGGW asterisk[3641]: WARNING[3641]: cel_pgsql.c:390 in process_my_load_module: CEL pgsql config file missing global section.
Oct 23 13:40:13 TGGW asterisk[3641]: WARNING[3641]: cdr_odbc.c:178 in odbc_load_module: cdr_odbc: Unable to load config for ODBC CDR's: cdr_odbc.conf
Oct 23 13:40:13 TGGW asterisk[3641]: WARNING[3641]: app_followme.c:340 in reload_followme: No follow me config file (followme.conf), so no follow me
Oct 23 13:40:13 TGGW asterisk[3641]: WARNING[3641]: app_minivm.c:2876 in load_config: Failed to load configuration file. Module activated with default settings.
Oct 23 13:40:13 TGGW asterisk[3641]: WARNING[3641]: res_phoneprov.c:922 in set_config: Unable to load users.conf
Oct 23 13:40:13 TGGW asterisk[3641]: WARNING[3641]: app_festival.c:544 in load_module: No such configuration file festival.conf
Oct 23 13:40:13 TGGW asterisk[3641]: WARNING[3641]: res_snmp.c:57 in load_config: Could not load res_snmp.conf
music-sf
Re: iax не работает
Если у вас один пир office/gostinni, то другой должен быть gostinni/office, а никак не magaz/offic .
Невнимательность. Хотел везде magaz написать. Вы правы, это ошибка в посте и к поломке отношения не имеет.
С другой стороны
toatc*CLI> iax2 show peers
makarenko/offic 192.168.8.254 (S) 255.255.255.255 4569 (T) UNREACHABLE
sh/sh 192.168.253.3 (S) 255.255.255.255 4569 UNREACHABLE
[b]gostinniy/offic  192.168.7.254   (S)  255.255.255.255  4569 (T)      UNREACHABLE[/b]
sunlink/tutanho  87.244.0.21     (S)  255.255.255.255  4569 (T)      OK (3 ms)
sovetskaya/offi  192.168.6.254   (S)  255.255.255.255  4569 (T)      OK (2 ms)
intersity/offic  192.168.4.254   (S)  255.255.255.255  4569 (T)      OK (1 ms)
oktyabrskaya/of  192.168.2.254   (S)  255.255.255.255  4569 (T)      OK (2 ms)
lenina/office    192.168.5.254   (S)  255.255.255.255  4569 (T)      OK (13 ms)
8 iax2 peers [5 online, 3 offline, 0 unmonitored]
Пинги проходят БЕЗ проблемм в обе стороны.
music-sf
Re: iax не работает
С центральной
Tx-Frame Retry[000] -- OSeqno: 000 ISeqno: 000 Type: IAX     Subclass: POKE
   Timestamp: 00005ms  SCall: 05302  DCall: 00000 [192.168.7.254:4569]
Tx-Frame Retry[001] -- OSeqno: 000 ISeqno: 000 Type: IAX     Subclass: POKE
С магазина
[spoiler]
Rx-Frame Retry[ No] -- OSeqno: 000 ISeqno: 000 Type: IAX     Subclass: POKE
   Timestamp: 00003ms  SCall: 12031  DCall: 00000 [192.168.253.90:1976]
Tx-Frame Retry[ No] -- OSeqno: 000 ISeqno: 001 Type: IAX     Subclass: PONG
   Timestamp: 00003ms  SCall: 00001  DCall: 12031 [192.168.253.90:1976]
Rx-Frame Retry[Yes] -- OSeqno: 000 ISeqno: 000 Type: IAX     Subclass: POKE
   Timestamp: 00002ms  SCall: 06078  DCall: 00000 [192.168.253.90:1976]
   Timestamp: 00002ms  SCall: 00001  DCall: 06078 [192.168.253.90:1976]
   Timestamp: 00002ms  SCall: 06761  DCall: 00000 [192.168.253.90:1976]
   Timestamp: 00002ms  SCall: 00001  DCall: 06761 [192.168.253.90:1976]
   Timestamp: 00011ms  SCall: 00315  DCall: 00000 [192.168.253.90:4569]
Rx-Frame Retry[Yes] -- OSeqno: 000 ISeqno: 001 Type: IAX     Subclass: PONG
   Timestamp: 00011ms  SCall: 00001  DCall: 00315 [192.168.253.90:4569]
Tx-Frame Retry[-01] -- OSeqno: 001 ISeqno: 001 Type: IAX     Subclass: ACK
   Timestamp: 00011ms  SCall: 00315  DCall: 00001 [192.168.253.90:4569]
   Timestamp: 00001ms  SCall: 10772  DCall: 00000 [192.168.253.90:1976]
   Timestamp: 00001ms  SCall: 00001  DCall: 10772 [192.168.253.90:1976]
   Timestamp: 00002ms  SCall: 08057  DCall: 00000 [192.168.253.90:1976]
   Timestamp: 00002ms  SCall: 00001  DCall: 08057 [192.168.253.90:1976]
   Timestamp: 00001ms  SCall: 03688  DCall: 00000 [192.168.253.90:1976]
   Timestamp: 00001ms  SCall: 00001  DCall: 03688 [192.168.253.90:1976]
   Timestamp: 00010ms  SCall: 00857  DCall: 00000 [192.168.253.90:4569]
   Timestamp: 00010ms  SCall: 00001  DCall: 00857 [192.168.253.90:4569]
   Timestamp: 00010ms  SCall: 00857  DCall: 00001 [192.168.253.90:4569]
[/spoiler]
Re: iax не работает
1) На 192.168.7.254 файервол не отвечает на qualify пакеты
2) На 192.168.7.254 маршрутизация VPN ответы шлёт не туда и/или не через тот интерфейс.
На 192.168.7.254 включите tcpdump и всё увидите. А на центральной уберите qualify для этого пира и вообще для всех пиров. Он вам не нужен
music-sf
Re: iax не работает
Проблема решена, дело было в маршрутизации.
