Не поднимается ISDN E1 поток к провайдеру
fire_anton
Сообщение fire_anton »
system.conf
span=1,1,0,ccs,hdb3
# termtype: te
bchan=1-15,17-31
dchan=16
echocanceller=mg2,1-15,17-31
# Global data
loadzone        = ru
defaultzone     = ru
chan_dahdi.conf
[channels]
group=0,11
context=from-pstn
switchtype = euroisdn
signalling = pri_cpe
channel => 1-15,17-31
dahdi_scan
dahdi_scan
[1]
active=yes
alarms=LMFA/OK
description=D115 (E1|T1) Card 0 Span 1
name=D115/0/1
manufacturer=Openvox
devicetype=OpenVox D115P/E  (VPMOCT032)
location=PCI Bus 02 Slot 01
basechan=1
totchans=31
irq=0
type=digital-E1
syncsrc=0
lbo=0 db (CSU)/0-133 feet (DSX-1)
coding_opts=AMI,HDB3
framing_opts=CCS,CRC4
coding=HDB3
framing=CCS
LMFA/OK - Что это за LMFA?
elastix*CLI> pri show spans
PRI span 1/0: Down, Active
elastix*CLI> dahdi show status
Description                              Alarms  IRQ    bpviol CRC    Fra Codi Options  LBO
D115 (E1|T1) Card 0 Span 1               OK      0      0      0      CCS HDB3          0 db (CSU)/0-133 feet (DSX-1)
elastix*CLI> pri show span 1
Primary D-channel: 16
Status: Down, Active
Switchtype: EuroISDN
Type: CPE
Remote type: Unknown node type
Overlap Dial: 0
Logical Channel Mapping: 0
Timer and counter settings:
  N200: 3
  N202: 3
  K: 7
  T200: 1000
  T201: 1000
  T202: 10000
  T203: 10000
  T303: 4000
  T305: 30000
  T308: 4000
  T309: 6000
  T312: 6000
  T313: 4000
  T-HOLD: 4000
  T-RETRIEVE: 4000
  T-RESPONSE: 4000
  T-STATUS: 4000
  T-ACTIVATE: 10000
  T-DEACTIVATE: 4000
  T-INTERROGATE: 4000
  T-RETENTION: 30000
  T-CCBS1: 4000
  T-CCBS2: 2700000
  T-CCBS3: 20000
  T-CCBS4: 5000
  T-CCBS5: 3600000
  T-CCBS6: 3600000
  T-CCNR2: 10800000
  T-CCNR5: 11700000
  T-CCNR6: 11700000
Q931 RX: 0
Q931 TX: 0
Q921 RX: 0
Q921 TX: 117
Q921 Outstanding: 0 (TEI=0)
Total active-calls:0 global:0
CC records:
Overlap Recv: No
Насколько знаю Status: Down, Active должен быть Up
elastix*CLI> dahdi show channels
   Chan Extension  Context         Language   MOH Interpret        Blocked    State
 pseudo            default                    default                         In Service
      1            from-pstn                  default                         In Service
      2            from-pstn                  default                         In Service
      3            from-pstn                  default                         In Service
      4            from-pstn                  default                         In Service
      5            from-pstn                  default                         In Service
      6            from-pstn                  default                         In Service
      7            from-pstn                  default                         In Service
      8            from-pstn                  default                         In Service
      9            from-pstn                  default                         In Service
     10            from-pstn                  default                         In Service
     11            from-pstn                  default                         In Service
     12            from-pstn                  default                         In Service
     13            from-pstn                  default                         In Service
     14            from-pstn                  default                         In Service
     15            from-pstn                  default                         In Service
     17            from-pstn                  default                         In Service
     18            from-pstn                  default                         In Service
     19            from-pstn                  default                         In Service
     20            from-pstn                  default                         In Service
     21            from-pstn                  default                         In Service
     22            from-pstn                  default                         In Service
     23            from-pstn                  default                         In Service
     24            from-pstn                  default                         In Service
     25            from-pstn                  default                         In Service
     26            from-pstn                  default                         In Service
     27            from-pstn                  default                         In Service
     28            from-pstn                  default                         In Service
     29            from-pstn                  default                         In Service
     30            from-pstn                  default                         In Service
     31            from-pstn                  default                         In Service
dahdi_tool
              ┌───────────────┤ D115 (E1|T1) Card 0 Span 1 ├───────────────┐
│     │    Current Alarms:     No alarms.                          │     │
│     │    Sync Source:        Internally clocked                  │  ↑  │
│     │    IRQ Misses:               0                             │  ▒  │
│     │    Bipolar Viol:             0                             │  ▒  │
│     │    Tx/Rx Levels:         0/  0                             │  ▒  │
│     │    Total/Conf/Act:      31/ 31/  0                         │  ▒  │
│     │                 1111111111222222222233         ┌──────┐    │  ▒  │
│     │        1234567890123456789012345678901         │ Back │    │  ▒  │
│     │    TxA -------------------------------         └──────┘    │  ▒  │
│     │    TxB -------------------------------                     │  ▮  │
│     │    TxC -------------------------------                     │  ↓  │
│     │    TxD -------------------------------                     │     │
│     │    RxA -------------------------------                     │     │
│     │    RxB -------------------------------                     │     │
│     │    RxC -------------------------------                     │     │
│     │    RxD -------------------------------                     │     │
[/cade]
Asterisk занимаюсь недавно.
Подскажите, где ошибка, или как диагностировать причину неработоспособности.
Re: Не поднимается ISDN E1 поток к провайдеру
Всё у вас ОК.
Пытайтесь оригинировать и терминировать звонки. Например -
exten => _X.,1,Dial(DAHDI/g0/${EXTEN})
fire_anton
Cybermind
Сообщение Cybermind »
Loss of Multi-Frame Alignment
fire_anton
а если не секрет как это понимать?
куда копать.
Пришел провайдер, проверил прибором, сказал, что все зашибись.
Карту протестировали, сказали, что карта тоже зашибись.
Как говорится, по отдельности все зашибись, а как в кучу собрали не работает.
Samael28
Сообщение Samael28 »
Так а Вы просто звонить пытались?
LMFA - это 2й уровень, если я еще помню, что такое SuperFrame и MultiFrame. Короче, это уже нестыковка по оборудованию. Сделайте на карте loop и посмотрите, что оно выдаст.
Мой профайл на Upwork
fire_anton
Пробовал, сбрасывает.
Расскажите подробно как loop сделать пожалуйста.
fire_anton писал(а):Пробовал, сбрасывает.
Кошмар...
А с каким диагнозом в логе сбрасывает?
А правильный ли вы обратный номер подставляете при вызове?
А в правильном ли формате вы отправляете номер вызываемого абонента оператору?
Попробуйте ответить (для себя) на эти вопросы...
fire_anton
Да, что тут за диагноз?
Я набираю входящий номер, а Asterisk не реагирует. В логах ничего.
Провайдер кричит, что беда у нас. Но коннект есть, а входящие не работают.
чего там пробывать , если
